- Catera conversion ideas...
- High Beam doesn't work
- 97 catera - problems shifting/accelerating
- 98 Catera starting problem
- brake lights
- Oil Filter Adapter
- dodge ram wheels for cadillac catera...
- valve cover leaking, what a surprise on a 98!
- Valve Cover Gaskets
- Just got '99 Catera
- Hp/torque Boosts?
- morbid curiosity
- Selling the Catera (this post is NOT a classified ad or whatever)
- Cadillac Catera emission figure
- Greetings: joined the Catera Brotherhood!
- catera 2001
- 99 Catera Sport
- Catera - Pre 1999 vs Post 1999
- A/C Disconnect tools
- 97 catera problems!!!!!
- Greetings
- new wheels
- Oil Problem on 2000 Catera...help?
- Cat custom grilles...
- 98' cat grille?
- new headlights / foglights for 98 cat.
- springs?
- Brake lights aren't coming on.
- Any hints on how to beat a grand-am
- new owner 2001 catera
- 97 head gasget repair price
- 2 Questions
- need a L side headlight 97 catera
- Painting interior-jus an idea
- side markers
- please help on 1984 cimarron
- need the rubber pads in the front arm rests for a 97 catera...
- RSM Supercharger
- drilled and slotted rotors
- A/C not working
- Misfiring problem
- intakes
- 97 catera - how can I make it lighter
- 2000 Catera Won't Start After Warmed Up
- Really Ticked
- Purchase a 99 Catera?
- Starting problems
- 98 Catera heater help
- did i make a mistake?
- 1998 wont start>will start>wont start>......
- Bra recommendations?
- Help Asap
- need front rotors for a catera?
- Jack stand points - where?
- headlight cleaner?
- Anyone have any experience with Steinmetz?
- Help
- my 98' catera
- catera winter tires
- Carjunky25 ...
- catera.org?
- Head light Problems
- looking for a quiet exhaust
- Rear Window Cable Broken
- A Little Help Please
- thanx rollin catera
- 18" kaizers goin up for sale
- Help with a P0730 transmission code
- 2000 catera sport mode flashes and cel comes on and off
- programming FOB 97 Catera
- My Caddy on ebay
- '99 - Door Panel Removal (help)
- thinking about purchase of 2000 catera
- Transmission mount bushing?
- Firing Order - !!!!!!!!!!!!!!!
- Cadillac Catera 1998 shuts down
- Catera 2000 fuses,relays and switches
- Seatbelt refuses to cooperate with me! LOL
- cross drilled rotors for sale.
- Broken Power Seat
- Check engine light!!!!!!!!
- Speaker Sizes For 2000 Catera
- auction for my cross drilled rotors
- performance pads
- Speedometer cutting out...
- billet grill for catera on ebay!!!
- Tornado.....anyone using them??
- timing belt
- Tune up time
- Check Engine Light and Idle
- Speedometer Cutting out Part II
- Oil Pressure Light
- Tape Deck to CD Deck Conversion
- Interior and Exterior Fit and Finish
- customization?
- Heater Control Valve Replacement.Thanks Sjashbrook!!!!!!
- Projector Lenses for a 99
- New plugs....now missing
- Gauge Cluster Bulb Replacement
- Instrument lamp bulb replacement in a Catera
- programming new remotes?
- 2000 Catera Oil Changing - Is there an easier way?
- Spare key
- Headlight replacement for 98 catera
- H.i.d.
- electrical gremlin?
- sparkplugs
- Bose CD
- days late and dollars short (O2 sensors)
- Phantom Sunroof - cheap fix
- '99 Catera, won't do anything.
- heater control valve
- Catera ABS/Traction Control System
- 97 catera Starter HELP!
- Done for the year----FED UP
- Crate Motor
- Floorboard full of water on '97 Catera HELP
- 18's boxed up and ready to sell
- Vent by the windshield Removal '97 Catera
- Catera body kit
- Parts Source?
- wheel is stuck to car
- Wiper Blades
- Power Seats...
- Pulling Codes
- 1st Time Oil Change on my 2000 Catera - Help
- leather seats
- Looking for a Key
- My Catera
- bbob,anyone? 4.x engine in cimarron?
- Catera Productions Numbers - where to find
- Twin Turbo Catera
- High oil pressure
- clearing codes
- !!!***help***!!!
- AM radio static
- Few Questions...
- http://tlentz.oldsgmail.com/howto.html
- A/C & Heat
- gettin my brakes done!!!!!!!!!!!
- Transmission Pump?
- Damn! Anyone help?
- If U Live In Michigan...
- Brake lights...
- body kit for cat
- sunroof
- Oil drain plug
- to rustproof, or not to rust proof
- Projection lights
- Help - Battery Is Dead Again
- Driver's side heated seat
- keyless entry remote!
- Bit of a Rough Idle
- weather stripping
- Platinum 2 plugs
- Driving with the heater on?
- Doin' the brakes!!
- Heat/AC console 'Lights out'
- Octane Boosting? "Should I?"
- Gas Cap Problem
- mods for my catera!
- Just a bulb or two, from mint!
- Grill-who sells it?
- New Owner
- transmission-97 catera
- Oil in the spark plugs?
- Differential Problems
- Cold Natured Catera
- just had brakes done, light still on
- HELP!!! back driver side window doesnt work!!!
- 2nd owner 98 Catera, new member????
- 1998 catera shuts down many times!
- Anyone Know 2000 Cat Interior Bulbs?
- winter tires
- Catera Up keep
- Top Speed
- Sry noobie here
- speaker size?
- What happened to the Catera?
- Am I gonna see elec. probs?
- Engine cooler?
- Catera alarm problems
- Synthetic oil
- programing garage door opener
- oil in coolant problem
- 98 catera oil cooler
- Ignition 98 Catera
- Bose Amp Wire Harness 1997 Catera
- No Cadi Mech Can seem to solve my problem
- Looking for help w/ P0171 code
- Should I buy an extended warranty ?
- Air Intake
- Biggest size rims to fit?
- transmission not shifting when cold
- steering column for cat w/ ignition and key
- alternator for 97 cat
- Rims
- oil cooler gasket?
- Filling Problems?
- engine dying out after high speeds
- Balance
- What do I need to read codes with my PC
- anybody know about the TSC on a 2000 catera?
- dash kit?
- Ignition Wires
- Sticky Ign Lock ???
- Want to put an aftermarket Cd player in your car....look inside!!!
- lugnut covers
- please help no heat
- leaking gas cap???
- 97: Sticking door locks
- aftermarket door mirrors
- Oversteer or Understeer ?
- Funny Problem
- baby seat installation
- cigarette lighters
- heated seat fire
- EBTCM Location/Schematic/Pics
- Frozen doors!
- lug pattern
- Fuel filling problem
- opinions re code reader
- Need Immediate Help with Accessory Tensioner!!
- A/C Blower Fan
- Removing door panels and woodgrain
- button on transmission stick
- (Car Review) - They liked the Catera..
- bad gas mileage
- cylinder numbers on 98 catera
- Where to Buy Oil Cooler
- Heated seat...er not?
- Blown Fuses
- interior
- rear powered sunshade
- Heater control valves?
- Catera Grille - where can I get one?
- Yellow goop on oil cap??
- problem with instument lights (98 Catera)
- What's the trick to removing the wiper arms?
- On Coolant Mixture
- Need some help!!! 97 Caddy!!!
- Fortunate
- Front Door Panels
- Looking to buy a catera
- brake pad sensors
- replacing a pulley
- hardwiriing deck
- How to change oil pump?
- Timing belt tensioner recall tip
