- Ignition Wires
- dash kit?
- anybody know about the TSC on a 2000 catera?
- What do I need to read codes with my PC
- Balance
- engine dying out after high speeds
- Filling Problems?
- oil cooler gasket?
- Rims
- alternator for 97 cat
- steering column for cat w/ ignition and key
- transmission not shifting when cold
- Biggest size rims to fit?
- Air Intake
- Should I buy an extended warranty ?
- Looking for help w/ P0171 code
- No Cadi Mech Can seem to solve my problem
- Bose Amp Wire Harness 1997 Catera
- Ignition 98 Catera
- 98 catera oil cooler
- oil in coolant problem
- programing garage door opener
- Synthetic oil
- Catera alarm problems
- Engine cooler?
- Am I gonna see elec. probs?
- What happened to the Catera?
- speaker size?
- Sry noobie here
- Top Speed
- Catera Up keep
- winter tires
- Anyone Know 2000 Cat Interior Bulbs?
- 1998 catera shuts down many times!
- 2nd owner 98 Catera, new member????
- HELP!!! back driver side window doesnt work!!!
- just had brakes done, light still on
- Cold Natured Catera
- Differential Problems
- Oil in the spark plugs?
- transmission-97 catera
- New Owner
- Grill-who sells it?
- Just a bulb or two, from mint!
- mods for my catera!
- Gas Cap Problem
- Octane Boosting? "Should I?"
- Heat/AC console 'Lights out'
- Doin' the brakes!!
- Driving with the heater on?
- Platinum 2 plugs
- weather stripping
- Bit of a Rough Idle
- keyless entry remote!
- Driver's side heated seat
- Help - Battery Is Dead Again
- Projection lights
- to rustproof, or not to rust proof
- Oil drain plug
- sunroof
- body kit for cat
- Brake lights...
- If U Live In Michigan...
- Damn! Anyone help?
- Transmission Pump?
- gettin my brakes done!!!!!!!!!!!
- A/C & Heat
- http://tlentz.oldsgmail.com/howto.html
- Few Questions...
- AM radio static
- !!!***help***!!!
- clearing codes
- High oil pressure
- Twin Turbo Catera
- Catera Productions Numbers - where to find
- bbob,anyone? 4.x engine in cimarron?
- My Catera
- Looking for a Key
- leather seats
- 1st Time Oil Change on my 2000 Catera - Help
- Pulling Codes
- Power Seats...
- Wiper Blades
- wheel is stuck to car
- Parts Source?
- Catera body kit
- Vent by the windshield Removal '97 Catera
- 18's boxed up and ready to sell
- Floorboard full of water on '97 Catera HELP
- Crate Motor
- Done for the year----FED UP
- 97 catera Starter HELP!
- Catera ABS/Traction Control System
- heater control valve
- '99 Catera, won't do anything.
- Phantom Sunroof - cheap fix
- days late and dollars short (O2 sensors)
- Bose CD
- sparkplugs
- electrical gremlin?
- H.i.d.
- Headlight replacement for 98 catera
- Spare key
- 2000 Catera Oil Changing - Is there an easier way?
- programming new remotes?
- Instrument lamp bulb replacement in a Catera
- Gauge Cluster Bulb Replacement
- New plugs....now missing
- Projector Lenses for a 99
- Heater Control Valve Replacement.Thanks Sjashbrook!!!!!!
- customization?
- Interior and Exterior Fit and Finish
- Tape Deck to CD Deck Conversion
- Oil Pressure Light
- Speedometer Cutting out Part II
- Check Engine Light and Idle
- Tune up time
- timing belt
- Tornado.....anyone using them??
- billet grill for catera on ebay!!!
- Speedometer cutting out...
- performance pads
- auction for my cross drilled rotors
- Speaker Sizes For 2000 Catera
- Check engine light!!!!!!!!
- Broken Power Seat
- cross drilled rotors for sale.
- Seatbelt refuses to cooperate with me! LOL
- Catera 2000 fuses,relays and switches
- Cadillac Catera 1998 shuts down
- Firing Order - !!!!!!!!!!!!!!!
- Transmission mount bushing?
- thinking about purchase of 2000 catera
- '99 - Door Panel Removal (help)
- My Caddy on ebay
- programming FOB 97 Catera
- 2000 catera sport mode flashes and cel comes on and off
- Help with a P0730 transmission code
- 18" kaizers goin up for sale
- thanx rollin catera
- A Little Help Please
- Rear Window Cable Broken
- looking for a quiet exhaust
- Head light Problems
- catera.org?
- Carjunky25 ...
- catera winter tires
- my 98' catera
- Help
- Anyone have any experience with Steinmetz?
- headlight cleaner?
- Jack stand points - where?
- need front rotors for a catera?
- Help Asap
- Bra recommendations?
- 1998 wont start>will start>wont start>......
- did i make a mistake?
- 98 Catera heater help
- Starting problems
- Purchase a 99 Catera?
- Really Ticked
- 2000 Catera Won't Start After Warmed Up
- 97 catera - how can I make it lighter
- intakes
- Misfiring problem
- A/C not working
- drilled and slotted rotors
- RSM Supercharger
- need the rubber pads in the front arm rests for a 97 catera...
- please help on 1984 cimarron
- side markers
- Painting interior-jus an idea
- need a L side headlight 97 catera
- 2 Questions
- 97 head gasget repair price
- new owner 2001 catera
- Any hints on how to beat a grand-am
- Brake lights aren't coming on.
- springs?
- new headlights / foglights for 98 cat.
- 98' cat grille?
- Cat custom grilles...
- Oil Problem on 2000 Catera...help?
- new wheels
- Greetings
- 97 catera problems!!!!!
- A/C Disconnect tools
- Catera - Pre 1999 vs Post 1999
- 99 Catera Sport
- catera 2001
- Greetings: joined the Catera Brotherhood!
- Cadillac Catera emission figure
- Selling the Catera (this post is NOT a classified ad or whatever)
- morbid curiosity
- Hp/torque Boosts?
- Just got '99 Catera
- Valve Cover Gaskets
- valve cover leaking, what a surprise on a 98!
- dodge ram wheels for cadillac catera...
- Oil Filter Adapter
- brake lights
- 98 Catera starting problem
- 97 catera - problems shifting/accelerating
- High Beam doesn't work
- Catera conversion ideas...
- 2000 Catera Production Figures
- Oil filter Canister
- transmission question
- Ouch... this hurts
- Added a CD player.
- Harsh front feel?
- a couple quick questions
- ???TCS-takes off in 2nd gear???
- e-brake problems
- Quality cover for a 2000 Catera Sport
- Opel/Vauxhall Omega Conversion
- Serp. belt
- Code P0455
- Gotta Sell It
- sunroof
- Vacuum Diagram - 98 Catera
- 2000 Catera Air Conditioner
- to buy or not to buy
- Oil filter tool...
- Shaking problem on 97 cat
- service manual
- Wanted: Catera w/bad engine...
- Swap-able parts...
- Updated tuner site
- 99 caterra computer
- Manuals for 1999 Catera
- Catera Head Gasket Blew
- bougt a cimarron for 100 dollars
- Custom grille info
- First Catera W/ Lambo Doors!
- Shift Lock Solenoid + Idle issues
- 1998 Cat Tappin
- Any interest?
- Just got a Catera
- Brake Squeal, HELP!!!
- extended warranty
- Caterra Help!!
- white guages
- Violent Shake
- Upping my Wheel & Tire size..
- ram air idea
- Where to get valve cover gaskets?
- Catera v
- Gear lights light up!
