- After Market Keys & Keyless Remotes
- This may be Off topic
- wanting a new stereo
- Headlights
- Please confirm
- remote Problems?
- Engine/RPM's quit
- Extended Warranty?
- Coolant Leak....
- Drilled and slotted rotors?
- Considered a '97, and bought it anyway.
- Idle speed adjustment...
- Right rear window power motor?
- ETCBM Needed!
- Transmission shift a little rough...
- radio prob
- oil ???
- 97 Catera TC + ABS indicators simulteneous
- car stereo
- Catera suddenly stalls !
- No instrument panel Lights
- Head lights moveing
- Catera 1998 User's Manual
- Air Intake?
- Cupholder
- A little help please...
- relplaceing the crest
- replace head lights?
- Fuel Filter Question...
- Headlamp replacement?
- Oil gasket leak and oil change
- Fuse box?
- Planning on buying a "CATERA"......
- wheels
- Diognostic trany light & Engine light
- Left Headlight
- Just bought my '00 Catera today!
- transmission vacum hose, but where?
- Repair Shop Decision ?
- Help White stuff under oil cap!
- just bought 1998 catera...
- needing a 1998 Bose factory amp...
- Help! Why Does My Catera Quit Running?
- 1997 Catera Starter
- Post your Catera Pic
- Shopping for spark plug wires...
- help me fix my caddi
- 1999 Cadillac Catera Stalls
- grill and crest
- Remote control
- Hood latch help & more
- Just brought home my cadillac catera
- 97 Catera
- Timing Belt - 98 Catera
- Climate Controls Sensor?
- where to buy O2 senors cheap?
- wiring diagram for the fog light
- Changing leaky radiator
- 1998 Catera
- Post up pics of your car!
- Spark Plugs and Suspension
- Chrome Trim
- Xenon Lights for 2001 Catera
- Keyless Entry - People at dealerships liars?
- Spun bearing
- Bose Radio and autolock problems
- I need a owners manual where can I get a online version?
- slipping transmission
- questions about 99 catera buttons
- source for coils
- Radio is on, but no sound. HELP
- Need radio help
- Jeff help please
- buying used 99 catera..questions and help
- gm part #90540746
- Still stumbling at idle
- Misfire hell PLS help!
- New to the ranks!!!
- Spark plug wires
- Radiator Leak
- Cylinder #5 misfire
- Replacing neutral switch
- GM A4S 270R transmission on cateras
- Catera Grille
- Rear axle fluid
- anyone in NY looking for 97-99 catera parts
- camber on front tires
- dumb question lol
- 97 catera sun roof
- idle lumpy at stoplight
- catera will not start??
- Cross Drilled and Slotted
- 97 Catera Transmission For Sale
- White substance in oil filler valley
- trunk lights
- Need a few things
- timing belt
- Radio is crapping out
- Catera is running.
- o2 censor problem
- Can't get car out of park
- Computer confused on slope
- Suspension
- 2001 Catera Transmission Slippage
- Oil light on
- Seals leaking...
- Who is interested in a Group Buy
- Brake light switch removal?
- Subwoofer install...lol
- Jeffery G need your opinion
- 97 - Oil Pressure dropping at idle - please help!
- Catera Aftermarket/Performance Options
- Irmscher Omega / Catera front spoiler.
- Catera Coupe... err I mean GTO
- 2000 Catera Speaker Problem
- Receiver removal- installin subs lol
- Need Catera info
- Aftermarket Car Alarm / Remote Starter
- Carpet removal-installing subs
- Strut bar
- Need 97 shift solenoid
- major problem...go figure!!!!
- Ground Effects Kit
- Recall?
- 98 keyless entry
- Broken Spoiler
- Performance.....
- Cold Air Intake from Europe
- BIG problem, please help...
- Won't Stay Running...
- Pcv Seperator, What Is It ?help
- Taking my car in the shop.......
- heated seats
- Can I do this?
- Outdoor Temp.. Help
- Cold Air Intake
- my right fron tire blew!!
- 19" Chrome Wheels For Sale
- looking for Catera upgrads
- Catera in the snow storm
- Need help.Transmission and cooling problems
- Question for All Please Reply
- Dad's Catera stalls...
- Idling
- 2001 motor in a 1997 catera
- Are they really that bad???
- Ceramic Brake Pads
- Control Arm Bushings
- where are the shift solenoids located
- 97 catera won't shift
- wierd light flashing
- Did someone mentioned Cindy in Cat??
- Catera is getting...........
- Front Suspensions
- Caddy that zips, Now I know
- Vibration
- Please Help
- I looking a Catera Grill! I Have a Omega Grill!
- if this is true!!!
- Free at last
- 2001 Catera Oil filter housing removal
- Engine block heater
- 2000 catera pcv valve need help
- UPDATE to : this is freakin me out
- 99 caterra help
- timing belt replacement
- Tie Rod Ends $$$$
- need help!!!
- Birthday boy JefferyG
- back driver side regulator?
- catera headlights?
- A/c Panel Lights, Not Even Coming On!
- 2002 catera???
- Remote car starter for 1998 Catera
- 98 catera- billet grilles ? ?
- Change Automatic Transmission Fluid?
- Led Center Brake Light
- 1997 Catera Questions
- Catera 2000 CD upgrade
- Can the engine and tranny be installed together?
- 2000 Cadillac Catera
- New Headlights
- Best Catera Ever Made pics
- Tire Wear
- Help! I'm locked out of my Caddy! - Please Respond
- I want to put 18" or 19" rims..............
- crazy about cateras, but boston winters?
- this is freakin me out.
- bolt pattern
- 2001 Catera with Burning Smell
- engine flush
- Coolant light comes on
- What's the trick to removing the throttle cable?
- Just Got A '00 Catera
- 99: how to tell if it is a sedan or a sport sedan.
- Lund Cadillac of Phx, AZ
- After market cd-player for 2000 catera?
- Instrument Panel
- Rear Main leak
- new Owner of 2000 catera sports sedan
- synthetic gear lube
- 98 Catera Fan Not Working?
- Dirty
- headlights staying on
- Most Annoying Feature
- Xenon Lights
- happened way too soon --- catera being parted
- Anyone need a 2000 Sport?
- Back to forum
- want to change oil myself + recall questions
- Looking to buy a 2000 catera!
- Timing belt tensioner recall tip
- How to change oil pump?
- hardwiriing deck
- replacing a pulley
- brake pad sensors
- Looking to buy a catera
- Front Door Panels
- Fortunate
- Need some help!!! 97 Caddy!!!
- problem with instument lights (98 Catera)
- On Coolant Mixture
- What's the trick to removing the wiper arms?
- Yellow goop on oil cap??
- Catera Grille - where can I get one?
- Heater control valves?
- rear powered sunshade
- interior
- Blown Fuses
- Heated seat...er not?
- Where to Buy Oil Cooler
- cylinder numbers on 98 catera
- bad gas mileage
- (Car Review) - They liked the Catera..
- button on transmission stick
- Removing door panels and woodgrain
- A/C Blower Fan
- Need Immediate Help with Accessory Tensioner!!
- opinions re code reader
- Fuel filling problem
- lug pattern
- Frozen doors!
- EBTCM Location/Schematic/Pics
- heated seat fire
- cigarette lighters
- baby seat installation
- Funny Problem
- Oversteer or Understeer ?
- aftermarket door mirrors
