- Resistor Modification Chip/ Cold Air Intake Duct
- Sometimes the Best Solutions are the Obvious Solutions
- 'fuel cap' and 'sport mode' light flashing
- Muffler problem
- Right Side of Instrument Panel
- Low Oil Pressure
- Broken Cup Holder
- A/C Panel inop.
- Is this fine at all?
- Low idle when stopping
- Headlight Brows/Spoilers
- Radiator Light is on
- tape adaptor question
- disappearing dexcool
- Levelling Light
- Exhaust
- Headliner
- Another Alignment Question
- Keyless Remote Problem
- 97-99 Intrax lowering springs $80
- Selling Cd Changer
- Turn Signal
- Oil leaks not valve cover gaskets
- 2000 catera bose radio problems
- Temp gage sending unit??
- transmission shifts like 1st - N - 2nd
- cd player face kit needed
- Instrument panel identification
- Relocating Amp/amprack
- Need help : sudden accelerating at low speed
- Newbie
- remote needed
- Catera is UK car!
- check engine light!
- Automatic Transmission fluid/filter change
- Lower Control Arm Bushings...
- Valve Cover Gasket Replacement... How Much?
- First Cat, What to look out for
- Jeffrey, electrical problems I think!
- Removing the Resonator from my 98
- XM radio
- door catch broke (or should I say...-the door catch broke the door!)
- Catera 2001 Engine Rattle on Idle
- Is this safe?
- K&N Filter, any good?
- Tie Rod Ends 98 Catera....HELP
- 98 Catera Transmission ?
- 500hp and 500torque in a catera?
- strut mounts???
- Leveling Light Blinking
- Which oil filter do I have?
- Can this be possible?
- 97 vs 98 catera
- 97 catera front of car is shaking
- 87MpH quater mile time's.
- stereo code
- Struts
- Erratic Speed of Directional Signals
- Hi, I'm Aaron & this is my (stienmetz?)catera
- Hewlp Please :( (97 catera)
- who says our vehicle is a big problem!!!
- 2001 Catera cold start smoke
- How to sell extra parts?
- Keyless Entry Remote
- Oil Filter - How tight?
- confort contol panel dead
- Need help on scanned codes
- Just plain weird. 1998 Catera steering wheel
- quick question
- 97 Catera Starter Help. Answers?
- "CHECK ENGINE" Light On...
- Front end shaking
- Tire Thread
- 16" stock wheels - what offset?
- Do we really like our cars overall???
- would this work??
- need some help
- Catera Parts Links
- Strange Transmission Experience
- cATERAAA :@
- Fan Sensors
- 2000 Catera with "burning" smell and oil light on
- Transmission Pan
- catera questions i need help
- turn signal always on
- Glovebox Latch???
- rear suspension problem
- Key Problem
- Seville Brake Light goes out when turn signal is on
- Catera air filtratation system leak
- cd changers
- Need some opinion
- 2000 catera
- Here's a new one for you Jeffrey!
- radiator light and washer light stays on.
- 97 catera heater/ac problem
- 2001 Catera Speakers
- Grunting Sound
- Key stuck in ignition!!
- Help!! Catera 1998 Power Window
- Problem shifting into gear
- High Oil Pressure reading
- low voltage
- What brand of fuel do you use?
- Headlights won't shut off
- Headlights gone cross-eyed
- Aftermarket Radio or a/m CD changer
- my bad
- i dont know what's goin' on
- cold air intake for 97 Catera
- aftermarket air intake
- starter spins but not cranking over
- Rim Emblems & Lug Covers
- difference in 99 and 00
- 00 Cat Code: PO100
- Catera Fuel
- Considering Catera purchase, but need help (Cimarron info also inside)
- Coolant Flush
- coolant/water leak
- "Catera CTS??"
- Idle problems, all out of ideas!
- Wobble Wobble
- Should I!
- Grinding Noise from rear
- Has anyone tried this?
- Stock Alternator Amperage
- 2001 Cadillac Catera
- Check Engine Light and Rough Running Engine
- Brake lights
- 97 Catera News Update!
- Engine Coolant Temp Sensor/Sender and Gauge
- Sealers.., Plese Advice!!!!!!!!
- Can we use 180degF Thermostat in the Catera!!
- Front struts/ Oil filter--97 Catera
- A wierd dustcap??
- My Oil Light Is ON---97 Catera
- Gas milage
- Clearing my Headlights...
- Hey I'm New!
- $99 Battery!?!?!?
- Overheating? Or Close to it?
- 2000 Catera: Sport Light Flashes
- 97 Catera Timing Belt Replacement
- Oil around Spark plugs
- Headlight Housing Replacement help!
- Change Things Up A Bit...
- Learned from MAF and Cranckshaft Position Sensor (CKP) Replacements
- Headlight adjustment 1997 Catera
- Is 15w40 right for Cat
- Oil pressure gauge
- Oil filter wrench
- Coolant Leak
- What to Do ?
- I love my CAT
- such a beautifull auto
- Head lights
- Trans MIL on
- Communication with the MOTRONIC ECM
- Cheap O2 Sensors
- Totally Confused-pleeze Help
- 96 Catera WONT UNLOCK!!
- thewheelguy
- Remove Scratches
- Warning dash Light Question (O) ?
- Is there a benefit of using Sport Mode?
- Location Of Fuses
- Trans Light.
- Bought a 97 Catera.... After one month....
- General questions
- 00 Catera Coolant Light & Car Shuts Off
- Major Tune-up?????
- Transmission and Bosch P2 plugs
- Shift Position Switch & Rear axle speed sensor, "O" rings??
- 98' Catera Malfunction code
- Radio Problem
- regarding oil
- Catera has a PCV?
- 2 questions for the guru's....!!
- New Catera Owner With Questions
- Ignition coil broke down
- Crankshaft Possition Sensor Connector...
- LIGHTS ON DASH OFF/HEAT & AC NOT BLOWING
- Spark Plugs and Wires
- Check Engine light not lighting up
- LAST CHANCE - Don't Pass it!
- Heat sink collar on oil filter..
- O2 sensor vs. "check engine" light
- Sport suspension tuning on a 98 Catera?
- Problem With Crankposition Sensor A
- Differences between 97 and 99 engines?
- Speaker Sizes in a 99
- Service Engine Soon........Again.
- repair cost?
- No AC
- Air filter Housing
- Catera won't start
- Catera Sport????
- whats this on my AC panel?
- 98 Catera exhaust problems
- Gasket
- Volt guage fluctuation
- 2000 Cadillac Catera Issues Please Advise
- HID aftermarket retrofit
- Alternator problem??
- re-programming door-lock unlock feature
- Headlight Adjusters
- Changing brakes.
- Spark Plugs
- This is hilarious
- DEX-COOl
- Tranny Fluid & fuel filter
- Daytime Running Lights
- I need some opinion
- Air filter
- 99 Catera crank-no fire, intermittent
- 98 Catera CPU
- Manual Tranny?
- This is freaky, Anyone?
- Cabin air filter replacement
- Intermittent engine light problem
- 98 catera -- won't kick, then does
- How many pounds of boost?
- 1998 Catera Brake Light Problem
- Viper arms
- Electrical problems
- help please no oil pressure ??
- I need new ball joints
- What are the odds???
- Swaping 99-01 models' canister type oil filter with spin on type is possible..!
- Additive
- Group buy with CourtenaySport?
- '00 break help
- I just got a 95 Catera
- Rear Shock Absorber
- Hvac???
- 01 Catera Transmission
- recalls on 98 catera..
- Gas Spill?
- Calling All The Guru's
- 20x 8.5 wheels
- To Omermurat...
- Need Some Help
- System..
- Low beam headlight part number
- Heater Actuators
- Considering selling my 99
- Stereo Problems
- After Market Keys & Keyless Remotes
- This may be Off topic
- wanting a new stereo
