- Catera wheel barring issues?
- Help I need an engine
- Low Oil Pressure when hot
- I love this car!
- Ac delco oil supplement
- # of wires on Oxygen Sensor??
- 98 catera, need major help fast!
- Need an AC clutch diagram.
- HELP!!! ABS light and traction control light come on when shifting from park.
- Ordering from Drivewire.com
- biggest wheels to fit on catera
- What should I know before buying a Catera?
- Braided lines housing kit: received and installing this week
- Got the N20 now need ass. with & 5SPD help
- 97 Catera center console & thanks Allen Pacla
- Exhaust leak, ac compressor clutch
- shaking/vibrating steering wheel
- A little problem when cornering hard.
- How do I take off the headlights?
- Putting in some 12" subs, question on wiring harness
- Sensor Location
- Trunk switch and fuel door switch not working?
- Fuel Filter
- ignition coil resistance values
- 98 catera wont start.. ECM fried?
- The traction control light is fixed...
- Cateras Suck!!!!!
- What the freak.
- 99 Catera "Fuel Cap" warning light comes on
- Rear Door Ashtray
- Leaking Power Steering Pump
- Cat shop manuals: interest
- Bumper 'horns' on Cadillacs
- Catera wrecks database or availability?
- Trans problem + electrical problem, help please
- Melting pot o' problems
- Front suspension top plates: helps
- Screws??
- Catera front license plate frame & hardware
- Parking Lights
- Ls1 Catera - Anyone Finish the Project?
- CATERA water pump pulley recall
- A/c Bulb Replacment Part Number
- 99 catera
- Radio only -- goes out after 15 minutes play
- Hazard + Traction Control switch removal
- Need some advice!
- Leaking Engine Coolant
- Must Brake To Shift
- The Noble Experment
- Ultra.White.Series.Fogg'z.
- Rear Sunshade stuck in the up Position
- timing belt algment kit
- 1998 Catera Factory Alarm ~ HAYWIRE!
- Ignition Cranking problem
- I want to Shorten my Exhaust and change the Exit of it
- 97 Gasket set for sale
- turbo on a catera?
- Engine coolant light :(
- Transmission Control Module
- CD Error
- strong electrical noise
- Heater/AC Lights..
- Snap!!
- Oil indicator: on with a beep then goes out
- 98 wheel lug nut covers
- Polyurithane Bushings Kit?
- Electrical irregularities (dome lights etc)
- Power Lock Button
- Headlight alignment position
- Another Oxygen Sensor Question
- Dashboard light replacement
- Windshield wiper motor troubleshooting
- 97 cimarron-ignition cut out
- take off faster with a 1998 cadillac catera
- AC Delco Ceramic DuraStop Pads - JefferyG
- The Catera is alive in Africa!
- Heater Cooler Control Panel Blank, please help.
- Is there an 'air dam' available?
- Cig Lighter Fuse? What's up With That?
- Driving Light Wiring, 2000 Cat Sport
- A/C System Stuck on Recirculate - No Fresh Air
- Need a mystery solved
- Omermurat, I need your help again.
- 2001 Catera.... What do you guys think?
- 97 Cat w/ Check Engine Light On :(
- turn signal problem...
- Satisfaction
- '98 Catera Dies for no reason
- Bouncing Oil Pressure Gage
- On Star
- 2001 Catera Troubles
- Meaning of Codes 2000 Catera
- High Speed Rear End Vibration
- Control Arm bushing replacement help
- Window!!!
- My radio, fuel door, trunk shuts off whenever.. please help!
- Cimarron Power Window Problem
- Radio lights
- Aftermarket o2 Sensor
- Instrument panel bulb
- Code PO171 and 172
- Any Switched +12 volt in the trunk!
- that trasmission light.....
- Airbag Light On After Changing Dashboard Bulb
- Replace rotors
- 98 Catera what's the deal with the radio/stereo????
- Opel Omega??
- A/C Question....Temperature sensor WAY off
- 0-60 mph time
- Radio shuts off ??
- Brake pad sensor light
- Supercharger Kit For $3,700
- How To Check Coil Pack?
- please help me
- Transmission Identification
- Cat 4 Sale...Low price CDN Funds- MUST SELL A.S.A.P.
- 25-35mph vibration when cold?
- annoying rattling
- Afternoon drive. ?.>>> .vaaroom
- electrical bug
- aftermarket rotors
- Please Help Now !!!!!!!!!!!
- spice up my ride
- Trouble with 00 Cat
- BOSE Wiring Schematic
- Help Me With 97 Catera
- daytime running lights
- Changing Wires On 98- Any Ideas To Make Job Easier?
- Ck engine lite ? Tune-up maybe ?
- Where can I find the Cabin Filter on my 01 Cat?
- IDLING HIGH NOW!- Trying to cure miss-fire by starting with plugs and cleaning IAC
- Newbie questions, looking for some help
- 1997 catera
- 1991 Catera
- My dashboard lights all light up like a Christmas tree!!! yay!!
- where is VSS vehicle speed sensor on 99 cat?
- Car is Hesitating- CODE says,#5 isnt Firing? JEFF HELP
- Mounting fog lights. How?
- Got new Xenon head lights and fog lights!!!
- need EBTCM
- Crank Position Sensor AGAIN!!?!?
- Catera Newbie
- extended warranty
- Which Pads Are The Best FOR 97 Cadillac Catera And Accomodate Sensors
- Suddenly Soaked Valve Covers!
- Bose speakers: can you swap out with aftermarket speakers?
- 97-99 Projector Style Headlights!
- Need help with regular maintenance on '00 Cat
- HELP 1998 CATERA IS ACting crazy
- 2000 HID Headlight Upgrade
- change plugs to BOUSH p4,IDLE LOW&SE LIGHT
- Can I Use 98 Brake Sensor Wires for a 97 Catera??
- 97 Catera Brake Pad sensor wire questions
- On Star Modding and on board computer.
- 97 catera AC/Heat system fuse prob?
- 98 Cat- How to COOL this ENGINE down?
- Vacuum diagram needed for 97 or 98
- Bad odor after A/C turned off
- Updated Pix of the Catera..(Photo Shoot)
- Yellowing HeadLight Lenses- How to Clean?
- Rearview mirror diagram???
- Electrical Problem
- catera cooling problem
- 97 Catera no A/c and sort of review
- 1997 Catera For Sale!
- Bye bye stock radio/cassette
- Opel Mv6 On Ebay !!!
- 2000 Catera AC issue...puzzled???
- Rear Sun Shade Problem
- Sell, Trade in, or Keep?
- N2O and a Maunal tranny question
- does any one know about the cimmaron
- New member to Forum
- Catera => OmegaMV6
- help me i wanna know more
- HID low beam problem
- Something odd....
- Power seat
- Just bought 97 Catera
- o2 sensor
- Curious Questions
- Which HID bulbs too buy for a 98 Cat?
- Radiator Puller Fan
- Doggone 'misfire' frustrated
- What surrounds the glove box/compartment??
- Catera Wagon?
- High RPM's on highway
- 2000 catera coolant probs
- Catera Bose Upgrade, and tranny question.
- CE light on and car shakes while idle
- Code P0501
- Ignition switch feels tight while turning
- Instrument panel gauge lights
- which sied is bank 1
- Front end rattle? 97 Catera
- howto: ignition coil remove and install
- Code PO171
- To Port and Polish my Intake or Not?
- Fan on 2000 Catera Won't shut off!!!
- Catera Group
- 2000 catera for sale
- Gas Problem
- head light problem
- Climate Control has a mind of its own
- Easily accessible hole in firewall?
- coolant in transmission
- Manual tranny an option?
- Sub upgrade question
- Insight on Headlights for a 2001 Catera
- Crankshaft position Sensor
- Bad Valve Gaskets
- cold air intake
- Changing Out the Gas Pedal
- Help Me!
- Winshield Molding
- heater/cooler HELP
- Why won't my key work?
- Roughness, so frustrating!
- New engine
- '98 transmission--good for life?
- what is this?
- catera headlights
- Should I buy it? 97 Catera leaking oil
- 99 Catera EBTCM removal & installation
- Cooling questions
- Climate Control
- Catera shuts off while idle in traffic!?!?!
- if you have advice, please help!
- climate control panel?
- rear suspension
- Catalytic converter support brackets...
- Catera oil leak, rear main seal?
- heater core
- cold air at lights, hot air while driving
- spraying onto pedals!? wtf
- Phatbox Audio
- Key won't turn
- Just buy a Cavalier
- 1999 Catera problems NEED HELP!
- Platinum spark plugs
- Good ole Craptera/OmegaPOS
- Missing cd cartridge
- Should I fix this problem quick?
- Check Engine,ABS,TC - time for brakes?
- cadillac catera codes
- Transmission Fluid Levels
- Oil Filter/Service Manuals?
- 2000 Cadillac Catera "Fuel Cap"
- Resistor Modification Chip/ Cold Air Intake Duct
