- Discounted Caddy parts:
- '00 Coolant Mixing w/ Oil - white sludge in oil filler
- HCV Installation Question
- converible cimarron
- MAF Sensor
- Instrument Cluster Installation?
- "Harsh" Front-End Sound At Low Speeds
- Engine shuts off
- New owner of 2000 Catera
- my '01 sport gets darty and wanders >>>
- Suggestions on remote start?
- Heat, idle, and recalls
- Centrifugal Superchargers
- 99 termostat replacement
- 98 Catera fusebox
- Cheapest Source For Heater Control Valve?
- no more lady cat
- Valve Cover Gasket Advice
- 1998 Catera Heating problem. please help
- no heat?
- 2001 Xenon Replacement
- Brightness Levels of Illuminated Controls
- P0171/p0174
- Code 0411 Secondary Air Injection
- Cadillac Cavalier?
- P0171/p0174
- programming a new remote
- Transmission: slippage to nothing
- 99-01 oxygen sensor for sale
- Limited-Slip Differential
- Campaign 00042???
- Where is the CT Sensor located on my 2001 Catera?
- 98 catera cruse controll failure
- Question regarding paints
- 2000 Catera Xenon Conversion
- Catera Lowering Springs
- NGK spark plugs
- 2001 Non-Bose Speaker Sizes + Installation Help?
- Wobble/Vibration/Shimmy - definitive answer??
- EBTCM symptoms
- catera performance parts ????
- Not the emission system
- Help! Power to stereo head unit question/issue
- Unknown Dash board light
- !temperature display problem!
- Catera Heater problem
- Check Engine Light Removal
- Catera 2000
- Wheel Corrosion
- Unstable Engine?
- catera in the snow?
- snow flake next to shifter?
- 1998 Catera Bose Conversion
- 97 Catera misfire
- Installing a Pioneer Deck
- Purchased 97 Catera auto auction
- test disregard
- Where can I find lamps
- 2000 Catera misfire problem
- cold-air induction: real or hype?
- California Smog Problems?
- changed engine in catera went great
- Help with Intake temp sensor
- before you buy any catera
- Timing belt
- ignition coil made out of paper?
- any good cateras out there
- I am looking for Shift Solenoid for Catera 98
- No radio, lost door lock programming - HELP
- decisions decisions
- Another sensor problem
- electrical problems??!
- Bypassing the Oil Cooler
- 1995 Cadillac Catera parking or fog lamp assembly.
- Nichole
- pep up your catera
- New owner
- Bosch Platinum +4 Spark Plugs
- Brake light switch
- Bose CD / Cassette
- 00 Sport Rebadged to Vauxhall Omega for sale
- catera owners HELP !!!!!
- Help with catera exhaust
- Aftermarket Stereo
- Speakers
- How To Change Catera Engine?
- Need driver side fender
- Catera Needs New Engine
- A National Meet Location Vote!!
- Idea for Brake Pads
- Just gotten into the catria have a question?
- Cheap Oxygen Sensors
- service nightmare
- Replace 97 Catera THERMOSTAT???
- fyi...i now own the 2-volume service manual and the parts# ref-booklet the '01 catera
- sway bar
- minimally invasive front/rear skirts for '01 catera?
- help me please..check engine!
- Heater control valves
- INJECTORS checking? cleaning?
- 1999 Catera, RKE Problem
- Aftermarket Stock CD Changer
- Window plastic buttons(switches)
- which wheels should i get? (photoshop fun)
- VERY RARE catera pic :-D
- seat warmers don't work
- FOG LIGHT housing
- Exhaust Systems and Performance Parts
- Rear end?
- Digital Speedometer Issues
- Coolant stop leak
- jalowiec, i have a ? for you about your guage cluster
- electric going crazy
- Power steering going out?
- fuse panel access details
- best place to get front rotors and pads?
- anemic rear defroster and side mirrors? >>>
- 6 year Corrosion warrantee question
- Transmission Problems
- Low Idle When Stopping - Pls help Miahcornell & JefferyG
- Saturn 3.0 vs. Catera 3.0
- Rear end oil
- Battery Dying
- Whats With The Cooling System
- Replacing the Rear Main Seal
- 2001 Catera CE codes
- 99 Catera timing belt recalls?
- 1998 Catera MUST SELL!!! Toronto Area
- No Dome Lights
- new guy-old problems
- What Have I Done???
- Who Wants my catera?
- Not the oil cooler
- Climate Control Problem Cont.
- what could it be? PLEASE HELP!
- Tach and Speedo quit at same time
- Coolant level
- Ethanols
- Manual Transmission
- What is the Amp draw
- A/C computer module location? RADIO Problems
- Problems after battery was disconnected
- interpreting the voltmeter scale? >>> (image)
- ECC problems
- "lumpy" idle...normal? >>>
- head gasket
- Rear muffler ???
- strut replacement question
- mildly OT: changing tire diameter & effect on acceleration?
- car dies at stop 98 catera
- wont start
- Projector Lamp problem, please help
- In need of O2 Sensors
- mildly OT: effect of rims w/ less offset on fit?
- Did the 2001 Catera have rack & pinion steering or the recirculating ball system?
- The Phantom Oil Light....
- CD Changer
- Multiple DTC's, need help ASAP!!!
- coil pack
- What could cause this noise????? transmission?
- what's the appropriate gas-pedal feel for an '01 catera? >>>
- what's the appropriate brake "feel" for an '01 catera sport? >>>
- 1999 Cadillac Catera: low beam issue
- Tranny Fluid fill plug??? HELP
- 2001 Catera
- Fuel gauge way off!
- Problems Programming Sunroof
- Was the Opel version ever available with the LS1?
- I own a very large paper weight, please help
- Hey - whats that thingy do?
- help me find disconected wire
- Sunroof Switch
- Window problem
- Air Bags
- oil plug
- climate control display
- Fog Lights
- Oil on Plug boots
- Type of Gas?
- O2 Sensor Question
- Cleaning Headlamps
- Tranmission Phenomenon
- help choosing wheels
- Cheapest place to buy Catera Service Manuals
- I'M BAAACK! out with the old, in with the "new >>> (jpegs attached)
- expensive repair!
- Oil Cooler
- Misfire on Number 5
- 2001 Cadillac
- Tires
- Help! Somethin With The Transmission
- 1997 Cadillac Catera Radio shuts off
- Water inside Catera
- Performance Torque Converter
- engine knock
- Replacing Dex Cool
- what is the offset & width of the 17" sport rims??? nt
- Headlights out of alignment.
- 97 Catera Bose Radio Lousy AM
- 2000 Catera A/C Airflow
- Radio Reception
- $95 to program a remote ??
- steering problems
- acceleration problems
- help really need some
- no heat from climate control
- Can anyone show/tell me how to use the stock jack on a CATERA
- Replacing steering wheel but not the air bag.
- Heater control valve?
- Suggest an aftermarket subwoofer with Bose System
- Suspension Knock
- Has anyone had their Catera on a Dyno?
- Engine dies after loud noise. Jeff Help!
- Catera Exhaust
- Incorrect air flow (P4011)
- 98' Catera missing...PLEASE HELP!
- Sudden engine shake
- No Brake Lights
- A/C filter
- 2001 Catera - Soft Brakes?
- Catera engine rattle, possibly timing chain tensioner?
- Ignition switch will not rotate to "ON"
- car sputters at start
- 2001 cat
- new keys, and remote
- Nation wide parts search engine ((Link))
- Does the factory radio have provisions for Auxillary inputs?
- What type of OBD-II protocol does the Catera use
- 5spd into Catera? CPU problem?
- Sticky texture on interior surfaces
- Coolant Light
- Factory 12 disc player, part number?
- Where to find service manual
- Valvetrain Noise, Loud Injectors, Pullys, Exhaust Leak
- cylinder 2,4,6 missfire help
- Radiator fan is LOUD! On startup!
- Control Arm Bushings Where to buy?
- E-brake light??
- P 0411 , secondary air inj flow
- 3rd brake LED light complete fix!!!
- Koni Sport
- determining regular/sport models by VIN alone?
- Do all Cats come with a remote ?
- '97 Catera For Sale Upstate NY
- running rich & wipers
- changing fuel filter in 97 catera
- 2000 Catera Sport Interior features
- Repairs this summer!!
