View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19
  1. Difference Between The 98' and 99' Catera
  2. Question about Wheel Fitment?? Please Help
  3. Can't find in shop manual/valve gasket replament
  4. Alternator
  5. is a sway bar link and stabalizer bar link the same?
  6. sway bar link part #
  7. sway bar or stabalizer bar?
  8. Anyone ever put Nitrous on your
  9. Lug Bolts
  10. 2000 catera service manual
  11. Inside Door Panel Loose - How is it Attached?
  12. Koni Shocks
  13. CD Changer Available for a 2000 Sport?
  14. InterionTrunk release/Fuel door not working?
  15. 98 Catera Crankshaft Position Sensor Replacement - Cranks Won't Start
  16. image post test
  17. Accessing the door speakers on a 2000 Catera
  18. CATERA 97,98,99...internal OEM PARKING BRAKE SHOES
  19. Custom Floor Mats for sale
  20. High stop Mount
  21. Cd Player Help.
  22. tramlining/darty steering solved!
  23. Cat-a-Tonic - Assistance Needed with CD Changer
  24. Bose Wiring Harness
  25. Door hinge
  26. Fuel Door and Trunk will only open from remote
  27. Wreath & Crest 1999 & 2000 interchangeable???
  28. Any Florida owners
  29. ignition wires: Bosch or Prestolite?
  30. P0135
  31. White sludge
  32. Interior Door/Assist Handle
  33. No Heat/Defrost
  34. Dts P0155
  35. stereo upgrade tips: want a new unit, but maintain the Bose speakers
  36. Dash Light Replacement
  37. tcm for 99 catera on sale
  38. Dash light/ coolant tank
  39. Oil Cooler for Sale
  40. Need a "coolent pipe"
  41. Timeing belt Question
  42. Car threw a Check engine light and
  43. Need Xenon help fast!
  44. Need Rotors and Struts up front
  45. German Opel Omega parts same as Catera?
  46. Totaled Car:( Sideskirts 4 sale!!!
  47. Crank, no start - Crank Shaft Position Sensor question
  48. Rattle in back window area??
  49. MAF Sensor
  50. Interior Clean???
  51. Interesting Discovery on the Auxiliary Water Pump
  52. Heat Exchanger Elimination
  53. MP3 - CD Changer 97 Catera with Bose, Suggestions?
  54. Service Manuals
  55. lexani firestar for sale
  56. Need suspension help
  57. Cadillac Dealership can't figure this out!
  58. Ghost in the machine
  59. Timing Belt Replacement
  60. crankshaft sensor location
  61. door freezing problem - need help!
  62. Ignition Coils???
  63. Throttle Body Cable: Need some help.
  64. Fix For Highspeed Vibration
  65. SRS/SDM mudule
  66. Synthetic Motor Oil: Take a look.
  67. engine just stops at red lights
  68. WRAF Sensors - 1999 and Newer Cateras
  69. What replacement headlight for HID?
  70. Youngest 2001 Catera
  71. Torx bolts oil leak (Valve Covers)
  72. 99 Catera spark plug wires
  73. 97 Catera in PERFECT health needs new home
  74. cylinder head damage
  75. Shop manuals
  76. For those who have changed the BOSE
  77. 97 oil leak from a newbie
  78. Oil Pressure Gauge Momentarily Drops to Zero???
  79. Interior light bulbs
  80. Looking for Catera parts
  81. O2 Sensor still ????
  82. Car drains battery in 30 minutes.
  83. front driver side tire feathering
  84. Front hood supports bad... Replacement needed.
  85. battery wont stay charged
  86. Headgasket?
  87. Air Bag Light?????
  88. Actuators again...Sorry!
  89. Catera Catalytic Converter
  90. Hubcentric Rings???
  91. Bad rotors/Shaky Ride
  92. Catera newbie question
  93. Catera shift knob removal
  94. SJMN Article
  95. Correct Alignment Specs for 2001???
  96. Attn: 2001 Catera Owners
  97. Electrical Problems? Anyone have this problem?
  98. Possible purchase 2000 Catera
  99. customize 1997 Catera drive train
  100. EBTCM Removal.... any tips.
  101. How much should I sell the Catera for?
  102. Vent on recent oil cooler work!!!!!
  103. 200,000 <-- has anyone hit this mark on a '97 catera?
  104. Please Help!
  105. Problems can some1 help?
  106. Problems can some1 help?
  107. Counsel Sought - 2001 Catera Sport
  108. New Key And Fob
  109. H1 vs. H7 Bulbs
  110. Headlight Aiming
  111. Catera Rotors question.
  112. center link and bearings arggg
  113. Power Suroof
  114. Car Leveling
  115. Please Help: Looks Like Gm Pp Won't Honor Warranty
  116. PO171 and PO174 to lean
  117. Catera transmission or timing belt? or what????? HELP PLEASE!!
  118. Thinking of buying, what do I look for?
  119. Brittle camshaft cover bolts
  120. Resetting warning lights
  121. Does Omega parts fit to Catera?
  122. Does anyone know
  123. Goodbye to a good car
  124. Driver's side headlamp
  125. dextron coolant
  126. check engine light
  127. Radio Problems
  128. Catera/Omega/Elite
  129. Remember Ziggy?
  130. Catera and Omega used new and performance parts
  131. 99 Catera problem(s)
  132. hiting my head on a wall here 2 problems catera
  133. Best Remote Starter?
  134. Right-Front Headlight out, need info!
  135. New Guage Pod,wheels,grille!!!!pix!!!!!!
  136. Brake and Shock recommendation
  137. No. 5 misfire
  138. "Sport" button is Stuck
  139. Body Control Module
  140. 99 Catera Factory Service Manuals
  141. 00 catera eletrical problems
  142. Brake Lights Work/Don't Work--'97 Catera
  143. Brake Lights Work/Don't Work--'97 Catera
  144. P0171,0174,0300 99 Cat
  145. brake light switch part number?
  146. Transmission Problem?
  147. AC/Heater gone!!!!!
  148. What is this guy thinking
  149. Just Ordered 20's but need adapter kit for spinner's
  150. Yes. another one of those transmission problems...
  151. Need Quality Car Cover - 2000 Catera Sport
  152. Touch-up paint for Catera Sport Rims
  153. New Catera Website
  154. Just got the GM Service Manuals
  155. will the CTS motor fit.
  156. Burnt smell coming from engine
  157. Running Lights/Dome Lights
  158. Headlight problem
  159. Crankshaft posistion sensor: 97' cater, where is it located
  160. P0140 Code
  161. Catera/Omega Dash Kits
  162. New battery.....oil/water lites are still on
  163. light bulb change
  164. Check Engine Light On
  165. what is this symbol
  166. Burning DexCool
  167. New member and new Catera owner...
  168. Limited Slip differential- Who's interested.
  169. Rear brake rotors
  170. Anyone Selling Catera Rims?
  171. Power steering and other ?'s
  172. You asked,they're here, burnout vids!!
  173. Torque for valve cover & oil pan bolts?
  174. 00 cruise control question
  175. Heater Question - Actuator ???
  176. problems with ignition coil after replacement ..
  177. aux waterpump for sale
  178. Help with identifying a loose connector in wheel well?
  179. brake lights
  180. Catera problems fixed!!
  181. Catera coolant leak
  182. Airbag light resetting
  183. Heater Question
  184. guess what now?
  185. Extended Warranty
  186. Half of trunk light went out
  187. What are the steps in removing a radiator?
  188. New Owner of 97 Cat - All advice Welcome!
  189. cd player Not working.
  190. New Head Lights?
  191. New Head Lights?
  192. 2000 Catera Power Steering
  193. P225/55/R16 or P225/60/R16 for 97 catera
  194. the new catera
  195. lady-cat rides again
  196. Oil/water lights stays on after battery charge
  197. power window broke
  198. Engine swap a V8 or a turbo v6
  199. climate control/radio bulbs
  200. tune up/ radiator
  201. Rotors for the rear.
  202. New here. Want info.
  203. Ignition Coil Solution
  204. Complex Air Intake
  205. so santa didnt give me my 1 wish
  206. Ignition Coil
  207. P0442 code
  208. Speedometer stopped working on highway!!
  209. what year is my car??
  210. oops! Replaced mass air flow - not oxygen sensor in 97 cat
  211. PO153 code - check engine light on '97 cat
  212. Watch that ice in wheelwells
  213. Cimarron / J-car Custom Jobs
  214. Light replacement on dash / O2 sensor question
  215. Factory Radio
  216. Finally got the code for y'all
  217. road trips in my 2001 catera sport: missing that 5th gear!
  218. 97-99 Headlight recommendations
  219. no heat eeek
  220. 99 Catera Missing on 2,4,6
  221. heater problems - linkage on right side Activator
  222. charging systems
  223. Headlight Switch Removal
  224. Check Oil Light
  225. Need Info Quick. Seats
  226. Helms Service Manuals on sale!
  227. Trying to determine coolant loss source
  228. P0171 Bank 1 Lean
  229. What's up with my HVAC control ???
  230. Labor Hours for Oil Cooler Replacement?
  231. Original Foglight
  232. Performance Transmission
  233. HID Upgrade on 2001 Catera
  234. Does The Oil Cooler Effect
  235. I Need Major Help Please
  236. Help With Oil Cooler Problem ! ! !
  237. cat on 20's?? need help and info
  238. Aftermarket Heated Seats
  239. Headlight Switch Problem
  240. 2001 Timing Belt TSB/Recall?
  241. Oil Cooler Replacement Questions/Summary
  242. CD changer problems
  243. WTB! 97-99 HVAC control/display
  244. Air in the cooling system
  245. Innova 3100
  246. coolent leak on engine
  247. Block heaters
  248. Discounted Caddy parts:
  249. '00 Coolant Mixing w/ Oil - white sludge in oil filler
  250. HCV Installation Question
