- 2000 Catera Sport Rims Fading!
- 2001 Won't Start - CPS?
- Setting up BCM
- 97 cat a/c compressor noise
- The best fuel system cleaner?
- Rain Leakage on Passenger Side - 98 Catera
- No skills + service manuals = i can fix my valve covers?
- Radiator Hose
- 98 chassis, 2001 motor swap?
- loose fuel door on '99 Catera
- source for aftermarket catera grills?
- Intake manifold gasket
- Air Condition Recharging
- 98 catera parts for sale: inner tie rod end and idler arm
- Coolant flushing
- Filling the Gas Tank (Time to read War and Peace)
- Intermittent starting problem
- wire Diagram for the gear shift position
- After market alarm please help
- XM radio woes
- Bought Catera before reading "Considering an older Catera? READ THIS>>!!
- Caliper Kit
- anyone interested in renting a timing belt kit?
- p0300, p0301, p0302 -> replaced MAF sensor
- '01 Cat - Check Engine Woes
- Lug Caps
- Catera EBTCM (Electronic Brake Traction Control Module) Part number please
- So tired of fog light irritation
- Timing Belt Kit TCK285
- CHK-ENGINE light came on, but no ODB2 codes?!
- Replacing a Transmission - 97 Catera
- Need help new to Catera
- Please HELP!!! Can't get Started!
- coolant color? & check engine light
- Wiring aftermarket alarm to open fuel door, can it be done
- Tire Balancing
- what style/spec of fuses are used in cateras?
- Where is the oil drain?
- PHOTO-ESSAY: removal of all on-star equipment from my catera!
- Audio's gone
- Brake Light Switch
- Oil Pan Removal
- Air inprovements
- Catera Dyno
- Leveling sensor-compressor
- Projector Headlights/Inspection
- 98 Cat Cooling - Radiator Cover Question
- Slick Car
- Drive in movies (what not to do)
- Problems with drivers side door lock
- Cadillac catera help
- Me again
- 1999 Cateras, and Maybe Newer Cats, Too
- HELP..............if you can!
- Smoke-out my head/tail lights
- Will not start after driving and parking for a while
- New Lights and Daytime Running
- 97 control arm bushings?
- Key in ingition, crank, no start?
- Anyone? Loose front brake pads
- New to the Catera and leveling
- what sort of summertime mileage improvements do you see?
- Can Anyone Tell Me What This Light Means?
- Radio trunk release and fuel door only work in gear. PLEASE HELP
- Want better gas mileage???
- Catera 4 sale
- Universal O2 Sensor vs OEM ($71 vs $250)
- dtc's (trouble code) diagnostics or sensor replacement details
- clock problem
- Fog Lights
- Horrible Vibration at 68-70mph
- air bag light
- Repair Manuals
- Entry?
- Sunroof
- gas?
- catera leaks ie oil & coolant
- Engine won't turn over?
- Behind the dash light bulb holder....
- "lumpy start-up" syndrome, various codes...
- 50k odo milestone
- Idle RPM fluctuation
- Do You Have Used Oem Brake Rotors?
- Power door locks
- Poor girl stranded! Need some help
- shifting points for 98 catera?
- Engine Swap or turbo
- Fuse Keeps Blowing
- fog light issue
- Belt Exploded and ripped out a wire.
- Info and opinions on 98 Catera (or any year for that matter)
- catera 97 - how to check transmission fulid level
- Possible to change the color of the dash lights?
- Couple questions for the pro's....
- Fuel pump replacement?
- oil leak
- Can I use laptop on Catera 97 Lighter outlet
- P0171 and P0172 ???
- Oil Pressure
- Weird Noise
- just got my CarChip/EX OBD2 data logger!
- Oil Levels
- had a problem today can anyone help!!
- a lil problem
- '85 Cimarron Concept Indy/Cart
- Cruise Control
- headlight questions
- Vacuum hose, P0171 & P0174
- Performance parts
- Aftermarket Alarm?
- Newbie Needs Help -speedo Inop?
- Different angle on low oil pressure
- how easy are lower control arms, idler arm and tie rod to replace?
- Could anything else go wrong with my Catera?
- Lights and gears
- Belt and Suspenders
- 98 catera with misfires?
- am I being overcharged???
- MAF sensor...$115 @ rockauto.com
- Misfiring everywhere!
- Car stays in High Beams
- anyone considered/tried removing the onstar system completely?
- low-profile replacment for OEM on-star antennae?
- OEM.. Wing spoiler install**Help**
- Brake pads, shoes, rotors, and sensor
- Speedometer and Tach goes out
- Head gasket or oil cooler
- Clunking over bumps & holes?
- 98 Cat intermittent stalling
- Extra Vacuum Line??
- P0171 and P0174 Lean Bank 1 and 2
- Satellite Radio
- Got some anoyine problems with my catera.
- I think the cat needed to take a crap today.
- Cheep! Cheep!
- Catera NEWBIE Questions - Interested in buying a Catera.
- Emergency brake assembly anyone?
- Engine is in , and now Low oil pressure?
- need help on 97 catera battery idle low
- Help for a new old catera shade tree mechanic
- Do you guys think Continental Warranty is a good idea?
- No More bose- New Headunit Qs
- Are all these cars posessed, or just mine?
- Catera Selector Cable (Shifter hard to move)
- Coolant leak
- Oil Pump Replacement Info requested
- 97 catera need help please
- Cigarette Lighter
- Well it looks like......
- goooodbye to yooou
- Anyone have this problem?
- Spark Plugs
- Shorting Throtle cable
- Need help finding a part...
- It's a good thing I enjoy working on it...
- anyone aftermarket their exhaust?
- Stoplight Switch PN 90563455 and now what?
- Catera Engine Change
- Catera Station Wagon?
- I am just full of questions
- What type of air intake?
- Question on type of gas for 98 catera
- 98 Cat Fog lights: moisture issue
- Headlight question
- Overheating issue
- My CTS 3.2 Engine is on the way!
- vacuum hose?
- how to shut off brake like sensor
- Could This Mean a bad EBTCM ?
- Paint Code: cranberry catera?
- Clicking noise from the rear
- Usual 97 problems ;) AC
- Need Help Troubleshooting A/C
- EBTCM replaced -still having problems
- 17inch RIMS: rubber size?
- Drilled and slotted disks (rotors)
- AC Problem...is there a fuse or relay for the AC?
- Ignition Cylinder replacement /Starting problem
- Changed EBTCM and now the brakes don't work
- Revised alignment specs
- will these fit?
- New Headunit
- Anyone have rims and tires for sale?
- Performance Module? Opinions
- Black lug nut cover for sale
- Xenon Lights for 2000 Non-Sport
- Anyone know what: ZJ1 package was?
- Painted calipers... anyone done this?
- Catera 98 stuff
- Comparing the Cats
- 1985 custom Cimarron
- Low oil pressure
- 2001 catera shuts off
- 125 - - - - - > 140
- A few thoughts
- 99 Cartera ECU problem (maybe)
- Bolt size for frt pass lower door hinge?
- Emission leak
- 1999 vs 2001 wheels
- Removing radio...instructions???
- Catera Rear Breaks
- Exhaust
- Have you guys ever considered using a european ECU?
- what does this light mean?
- Timing Belt Tensioner
- Whos Catera Video is this
- Hi there, i'm new, from germany, and have infos
- Catera w/lambo door kit
- Tires for '99 Cat?
- Courtesy Light Problems - 2001
- Courtesy Light Problem - 2001 Non-Sport
- Catera owners like CTS?
- Make Your Cat Really Purrrrr!
- Question about a non working RKE on a 97 Catera
- Haveing problems with the Rear window shade
- Cat 98 Radio woes... (Redux)
- Only decent Catera?
- Oil Level Indicator
- are these cateras?
- blower fan runs on high even with engine off!!
- Brake Lights Not Working
- CD Changer?
- How do you check a relay?
- A/C Computer Module
- Wheel Offset for 18' 19' or 20'
- Lowering Springs or Factory Replacement???
- Replacing Brakes and Rotors
- ghosts in the machine!!!!
- In-Dash DVD Install
- Heeeeelllllllllllllllpppppppppppppp
- Timing Belt Service Interval
- Hello, just picked up a catera...
- Timing Belt Question
- Spark Plugs and Coils, windshield wipers
- 98 Catera - Front End Suspension Tires
- Coolent in Oil, Kinda
- Ac Issues Any Help Appreciated
- Front Struts
- blower fan runs on high always,help!!
- Well,, the dreaded time has come......
- Trick(ed) Cat
- Laundry help with 1997 and 1998 Cats
- Can a Dead Cat Bounce?
- Changing Brakes '99
- Need A Front Bumper
- Head Gasket???????????? PLZ help!!
- Which Rotors from Ebay?
- Door sounds wierd and sticks
- ***wife backed up into the cadi**pic enclosed
- Catera trunk badges
