View Full Version : Cadillac Catera and Cimarron Forum
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19
  1. 97 cadillac catera
  2. Radio Goes Off When Running
  3. what's ironical about the catera and it's propensity to wander/tramline
  4. 97' Catera Sunroof drain holes**leaky sunroof**
  5. Ebay Euro Headlights
  6. Dusty engine...
  7. 97 Catera At Mechanic This Is Odd!
  8. Window Part Question?
  9. Ride Height
  10. 97 catera door panel problem
  11. door lock button light
  12. How many valve cover gaskets needed for 2000 Cat?
  13. Oil in the coolant. Oil in spark plug wells.
  14. Key blank for 2000 Catera -- Cheap source?
  15. leveling problem 97 catera
  16. help have codes what to do now
  17. Don't know what to do next??
  18. No Heat Driver Side -- any ideas?
  19. Cup Holder Alternatives (lots of pics)
  20. Tramlining, aka The (Un)Happy Wanderer
  21. How do you change fog light bulbs?
  22. P0155 O2 Sensor, P0300 Random/Multiple Cylinder Misfire
  23. timing tool would this work
  24. 99 Catera is leaking Coolant
  25. wireless ipod support for the catera? this might do the trick! >>>
  26. Drivers side Fog Light and Cornering light inop
  27. Catera Center Caps
  28. Jiffy Lube disaster
  29. Fog lights, tail lights, high beam, corner blinker all out at same time
  30. timing belt tools, where to get them
  31. catera oil capacity?
  32. Timing Belt Replacement
  33. 97 Catera Data Cable/Wire Harness
  34. Interesting find: front, rear and sideskirts.
  35. Click and Clack . . . .
  36. Brake Pad Sensors
  37. normal oil pressure fluctuation in driving? >>>
  38. occasional white cloud from exhaust upon starting
  39. part out or keep 1998 catera
  40. Best All-Season Tire for Catera?!?!?!
  41. Need Help Please!!
  42. trunk only pops while trunk is open
  43. My Caddie
  44. oil filter
  45. proper engine removal on a 97 cat
  46. Timing Belt Tensioner
  47. code P0455 and hose problem
  48. Air Filter
  49. how to program keyless remote
  50. oil cooler leaking coolant how hard to fix
  51. Engine code for catera
  52. weak alternator
  53. Cadillac Customer Service
  54. tranny light comes on, i need opinions!
  55. What's your opinion, tensioner
  56. Recall Items - Question for Group
  57. Cluster light problem on 2000 catera PLEASE HELP!!!
  58. Coolant Issues
  59. more aggressive sound
  60. flush coolant
  61. Another day wasted on this car!!!
  62. Driver-Side Window Regulator
  63. vehicle history? im a new owner
  64. thanks for the help
  65. HELP!!! - 1998 Catera Recall for Tensioner Pulley
  66. Timing Tool
  67. 97 Catera Security System
  68. 00 catera dr side turn signal stays on when lights are on inside dash......
  69. Outside Temp Display not working
  70. Another P0171 Thread
  71. couple of burnout videos
  72. Catera 97' Spoiler
  73. Anyone own / see non-leather Catera?
  74. Keep or Sell 2000 Catera? Need Advice.
  75. Coolant lite comes on
  76. Truck part replacement for HCV
  77. 1999 Catera Sport
  78. 98 80k miles routine maintenance advice
  79. HCV /need diagrams please help!
  80. easy mods
  81. catera parts??
  82. Alarm Chirp
  83. Valve Cover Gaskets
  84. engine will turn over and not start?
  85. what speaker size for Catera??
  86. What is the HID bulb type on the catera?
  87. Codes P0411 & P0171
  88. New Catera Owner
  89. I need a part!
  90. WTB: Cimarron passenger side seat trim or complete good working track with trim.
  91. First Detailing Experience. Traffic! A Lot of Pics!
  92. Rough Start in the morning
  93. catera performance chip
  94. 2000 Cadillac Cateria Bose Radio wont play all of a sudden
  95. Highway speed and RPM?
  96. GM Shop Manual Thread
  97. couple q's on a 98 cat
  98. Oldest Catera Buying Opportunity?
  99. 12 Volt Outlet Not Working?!?!?!?!?
  100. MP3 Player / Compatible Catera
  101. Headlight clips (replacement)
  102. headlight/taillight tint
  103. Chicago area meet this WEEKEND
  104. Catera A/C
  105. Dying battery - no indication
  106. Losing Oil Pressure- Info Needed
  107. anyone have A/C temp sensor calibration issues?
  108. Reusable Oil Filter Housing
  109. 12v source
  110. Radiator coolant gage
  111. Overfilled with oil....might have a problem
  112. iPod Integration Solution
  113. OBD II reader recommendations
  114. Vibration is scaring me!
  115. Headlight Problem!
  116. fitting aftermarket (read: bigger) brake rotors...do-able?
  117. low oil pressure problem
  118. any known issues on 2000 catera?
  119. Pulling apart dashboard?
  120. Recommended Service
  121. Broken Door Handle
  122. source for drilled (not slotted) brake discs for 2001 sport?
  123. Catera timing belt
  124. 00 trunk on a 98 ?
  125. Speaker wire re-run
  126. Transmission thud
  127. HI first Cadillac Catera
  128. got my 18" wheels fitted >>> (pics, modem warning)
  129. Headlights from ebay Need Help
  130. Problems!!
  131. Trunk Problems
  132. 98 Catera CD Player in a 97?
  133. Rear diff missing bolt?
  134. window tint
  135. factory bose vs. aftermarket: anyone made the change?
  136. Shop Manual DVD Giveaway
  137. Check Engine Light On
  138. more help w/ lug-bolt specs...12mm x 1.50 x conical...but what length?
  139. I Need Omermurat's PDF File on Error Code P0411
  140. Update on INTRAX Lowering Springs, Front and Rear Camber Kit, Rotors... IT WORKS! :o)
  141. Selling Our 2000 Sport - Anyone have a Carfax Available?
  142. Check out this bad boy Omega MV6 on eBay
  143. lug bolt specs for catera?
  144. 2 Din is possible!
  145. PO455 Gas Cap Code
  146. My Catera Problems (currently O2 Heater Sensors)
  147. Another tie rod replacement
  148. Sunroof and A/C Problem
  149. Remove and replace p/s pump
  150. Does'nt sound right
  151. Blowing cold air
  152. Leveling Light Flashing
  153. what is this thing?
  154. Not the fuel pump
  155. 12 Disk CD Changer in '99 Catera
  156. Chicago Area Meet
  157. Light problem
  158. std vs. sport wheel size diff - important?
  159. just ordered me some wheels! 18x8 and will run 245/40 rubber >>>
  160. 1999 Catera will not start
  161. Retiring for now
  162. used BCM
  163. '98 catera rear window defogger
  164. Surprised by Year
  165. what's the word on welded alum rim repairs?
  166. Need part number for A/C line
  167. Catera Radio Software Compatibility
  168. catera rearview mirror
  169. Window Problem!!!!! HELP!!!!!
  170. What do you suggest, water pump? thermostat?
  171. Coolant Gauge Sensor Location??
  172. Problems With My Catera
  173. Cadillac Catera 1997 Question
  174. Dealing with complaint
  175. anyone run staggered wheels on your catera/omega-b?
  176. correct ID measurement for hub-centering rings to fit a catera?
  177. 98 Catera keeps cutting off once it gets warm Need Help
  178. Front bumper cover???
  179. what's a good aftermarket brake-pad that doesnt produce tons of dust? nt
  180. Code P100 or P0100
  181. Fog Light question?
  182. new grill...updated project & pics!
  183. 1999 Catera Stereo/Sound System
  184. What is a coil pack remover?
  185. ECM - Electronic Control Module
  186. Oil in the Coolant Resevoir
  187. Interior Lights and etc.
  188. Cadillac 2.8 Vvt V6 Engine 4x2 Trans Cts Gm Oem 2.8l
  189. Driver's door panel removal.
  190. How hard is it to replace an Alt. in a 98'?
  191. Check Engine Error Code PO411
  192. Spark Plug Change?
  193. oil pressure problem
  194. Battery Cable Replacement procedures - Help
  195. Catera Tires
  196. Alternator Removal Help Needed!
  197. transmission removal procedure 98 catera
  198. Steering-Loosing control over bumps?
  199. Bose Problem
  200. new grill fresh from german-land!
  201. transmission only goes into reverse 98 catera
  202. In Need of LH Side Mirror (glass only)
  203. Catera Clear Coat
  204. Possibly a bad EBTCM, What to do?
  205. Aftermarket timing gear or chain?
  206. External oil cooler
  207. 16 inch Wheels
  208. How to launch?
  209. gas mileage ?
  210. Replacing MAF - Instructions for an '01 Catera?
  211. Transmission: Range Switch
  212. Ipod to 98 bose
  213. speed sensor
  214. INTRAX Springs, Rear Rotors and Calipers. Few questions.
  215. radio shut down with loud volume
  216. BCM replacement
  217. Wheels
  218. Transmission Problems and the alternator?
  219. Park Gear shift Lock won't release
  220. Where's the audio section of this forum?
  221. Definitive answer on fuel door/trunk release inoperative
  222. Aftermarket Lights
  223. Car Bra??
  224. 3.2 Ebay MOtor Swap
  225. fender bender causing multiple problems?
  226. check engine light
  227. What's the Bottom Line on 98 Catera Timing Belt
  228. Best price on timing kit?
  229. Idle RPM - whats yours
  230. Lowering springs
  231. HID Light Help
  232. Performance muffler
  233. A little advice please A/C
  234. location of blower motor resistor?
  235. Ethanol issues?
  236. 1987 Cimarron
  237. '99 Catera starting problems
  238. Weird Noise Coming from front end
  239. A few performance questions
  240. 97 cat crapped out @ 72k miles
  241. Cat 98 Timing belt: news
  242. Opinions and any experience with RockAuto service?
  243. 3.0 VS 3.2 Catera/CTS
  244. rear sunshade problems
  245. Drilled/Slotted Brake Rotors For Sale
  246. Door Panel Removal
  247. Fuel Economy
  248. 20' Rims for my 2000
  249. Radio Problems
  250. 2000 Catera Sport Rims Fading!
