- Does 2004 SRX Have Backup Camera Or Bluetooth?
- Front Turn Signal Socket---Standard or CK wired?
- P0204 and P0304 codes
- Need Quick Advise on buying a 04 SRX...Should I buy it???
- Help Please! 2005 SRX V8 Northstar runs rough cold . no check engine lights on?
- 2004 Cadillac SRX V8 Overheating
- Seeking no cost download of 2005 SRX service manual - need to repair my 05 srx
- Custom cadillac logo car covers - free s&h coupon code
- switching 6 disc to a navigation/dvd unit
- new 04 srx v8 awd owner
- It's On! Total War! HenshinX vs. SRX...The Third Row Power Seat Wars
- SRX 05, leak in hose from PS reservoir to cooler
- Vibration at arond 40 MPH
- Another EBCM problem
- 2006 #2 Seat Pref Button causes A/C to shut off when pushed while in "D"rive moving!
- help meeeee!!!
- Strange front suspension noises. Any help appreciated
- cat replacement/pillar mount?
- catalytic converter delete?
- Oil Consumption Conundrum
- Newbie Needs Advise on a 2004-05 SRX Purchase
- Anyone hook up a remote start
- where is located the oxygen sensor of 2004 SRX v6?
- Free shipping for forum members ends midnight 05/08/2012 no minimum purchase required
- Big brake kit, any interest?
- 2009 Turn signal change observations vs 2004
- Cadillac-SRX-Superchargers
- Cts steering to srx?
- Cadillac Merchandise - Free S&H Offer For Forum Members
- OEM Nav, plug and play with Bose?
- Nerf bars for 07
- In the market
- 2004 AWD SRX V8. A good deal?
- Is "FE1 soft-ride suspension system" the standard SRX suspension?
- Custom exhaust sound video
- update sticky
- tire size all around?
- Lubegard for transmission in my 05´SRX AWD V8
- Floor/Cargo mats
- Weak batteries?
- Steering Collum Noise
- Forum Member Coupon Code - Free S&H No Minimum Purchase Amount
- catch can ?
- 3rd row folding button part number(s)?
- diy oil change question
- Good bye
- 07 SRX manuals?
- Aftermarket brakes
- Cadillac Dealership Coolant Change Cost ?
- 2004 srx 4wd makes grinding noise when making left turns
- New '04 SRX owners
- A pillar leaking
- Can I add TV to my 07 SRX NAV system?
- aftermarket dvd install problem
- iPod and bluetooth SRX 07 Possible?
- compnine is back!!!!
- Can I remap a PCM or TCM SRX?
- Nav disc version? Wider wheells?
- Is my stock radio XM ready?
- TIP: Saving your headlights
- Fuel gauge innop
- Refilling coolant
- Fowl gas smell inside vehicle
- Rumble from speed
- Under body pics of the SRX - Going in for service tomorrow.
- 05 SRX-XM radio.
- A/C blower sometimes works, sometimes not
- tires
- Rear Hatch window seal on 05 SRX V8
- Dipstick - - V6 vs V8
- 2004 V6 SRX Cold air intake?
- Power steering pump replacement
- DVD system remote
- LS engine
- 05 Cadillac SRX (3.6L / 4.6L) turn off check engine light and program
- 2005 SRX questions
- Drivers side front turn signal replacement
- kenwood 9280
- A/c running 400 pounds on the high side
- Fuel
- Fobs and Keys...
- Installed my 265/50-20 NT420S and they rub in the back
- 08 srx4 vetti.g stuck in fourth gear
- How to turn off fault indicating lamp?
- Lowering springs for SRX, interest?
- Real world results for Cold Air Intake and Exhaust mods needed.
- Is it just my car or does everyones car's....
- radiator fans always on (cadillac srx 08)
- Both radiator fans always on high speed ?
- 2004 SRX Code P2119
- oil draining on 06 SRX
- Trans oil change (2004 V6) comments
- 275/45/20 on factory wheels, Pics inside.
- part # for dearler trailer wiring harness 07 srx
- 2007 AWD V8 clunking noise in Reverse
- '04 SRX V6 no start issue...
- Free S&H Offer - Cadillac Merchandise, Apparel, Custom Floor Mats & Car Covers
- Eibach 3810.540 springs installed
- 2006 V8 AWD rpm fluctuation and CEL on with P1101 + P0068 codes
- wheel lock lost
- Odd ? of the day, anyone considering using/used Shell Rotella Synthetic 5W-40 Oil
- Transfer case fluid change interval & recommendation
- 2006 Cadillac SRX
- RIP the greatest SUV Ive ever driven. 2004 SRX V8
- Digipro3!Does anyone have used it before?
- 2006 SRX Bluetooth addition...
- 20 inch wheels
- 2006 SRX Turn-by-Turn Nav
- Newbie with SRX problems, or not?
- 2005 SRX V8 CEL Check Engine Light - How to read codes?
- Those pesky door panel pop-out covers
- Rear of vehicle making noise
- SRX 2005 Spare Tire Carrier & CD Mech Error Message
- Anyone need a factory N* intake?
- Anyone try to trade in your SRX at a Non-Cadillac Dealer??
- Costar or Galaxy1000??
- Slotted rotor advice
- 05' SRX V8 - Firmware Version ?
- Where is the airbag module located?
- where do i put the floor jack to change tire?? 2008 awd v8 sport package
- How to: Rear Wheel Bearing/Hub Install (also covers brake pad & rotor replacement)
- Need some help with the name of a part.
- 04 srx v8 awd
- Stability System and Tires
- Timing chain = noise [video] ? Can I DIY?
- New to me 08 SRX V6 Pre-Certified Used from Lindsay
- Free Shipping Offer - Cadillac Merchandise
- Cadillac Srx 4.6 drive belt install?
- New 2006 SRX Owner: rumble noise
- Chrome Luggage Rack
- Wreath & Skull Apparel
- GM Timing Chain Letter
- I feel much better
- Blue smoke on starting
- Free S&H Offer -Cadillac Merchandise -Official M Licensed Products
- How to get out Ignition Coil Rail on bank one (Cyl 1 to 4)?
- Moisture in top rear LED light bar
- 3 inch antenna on rear of car missing
- transponder keys i got copied worked right away?
- Location of the Eye Tow hook that hooks into front or rear bumpers to tow?
- checking cols (LH2 N*)
- Great Deal for all you V6 Oil Burners
- License plate light bulb, type?
- sooooooo upset!
- Factory warranty question
- Looking for OEM Air Box and MAF Housing..
- Possible new SRX owner, with a question
- New Owner Introduction - Excitement with a dash of panic.
- 05 SRX V8 AWD - keyless engine start ?
- front struts
- Just bought an '08 V8 Sport
- Srx sunroof visor
- 2008 SRX thinking about buying
- 2007 Cadillac SRX problems when veering to left
- Adding a 3rd row seat to a 5 seat SRX....Anything majorly tricky to it?
- Special Coverage Warranty ?
- I'm moving along, thanks for all the help.
- 04´ SRX V8 AWD - converter problems ?
- Anyone looking for one of those rare V8 SRX's
- Condensation (water) in oil fill cap and fill tube
- crossover seals
- Evap Emissions Canister Purge Selonoid Valve ticking
- 2005 SRX V8 AWD - deep noise like a rough street ???
- SRX Power Steering Dipstick
- Cadillac logo merchandise links
- TV on Navigationscreen ???
- SRX Foglamp Access
- 85% of SRX YouTube vids
- New laws regarding accessing your GPS, Radio and more...
- found the exhaust sound i would like for my v8 srx..video
- The problem with the engine
- 2006 SRX rack pinion help
- Head lamp unit removal - how?
- 05 SRS 4.6 V8 - AWD or 4WD - http://www.compnine.com/ is down !?!
- 05 N* 2WD surges, after let off gas. Any ideas?
- Can i get a definitive answer for max tire size for a factory 20" rim?
- Custom cadillac floor mats & cadillac logo car covers
- CD stuck?
- Front Wheel Bearing story .
- Loud exhaust, popcorn or dragging muffler sounds
- 08' awd v8 any one have this same event?
- Srx 05 engine problem
- Ash tray retainer
- Looking at 2nd vehicles... need RPO lookup.
- What's wrong with my SRX?
- rear door panel
- About to take delivery of my 07 and i had a couple questions
- Stupid problem so stupid question [RE: ash tray]
- Little bulb in headlight unit
- Front end rattle/chatter when coming to stop [VIDEO INSIDE]
- Shift Interlock
- My staggered tire quest, part two.
- Transmission question
- Free shipping offer - cadillac merchandise & cadillac floor mats
- Climate Control Problem Srx 2006
- What issues should I look out for? 1st Gen V8 AWD
- How to remove snow from the SRX roof
- At my wits end...
- my 06 srx pre-owned ownership
- New Kid on the block
- 2007 SRX Dealer Order Guide
- Replacing Front brake pads
- checking transmision fluid
- 06 N* White Smoke
- Oxygen sensor-- help please
- Cadillac SRX 4.6 2004 comes with Denso-Navigation where connect mute-wire(yellow)???
- Anyone has information how to install audio in a SRX 2008?
- creaking while aplying brakes
- Wind noise
- 2005 SRX - CD player issues/broken
- 2005 SRX DVD player dim?
- Fuse for Adjustable Pedals
- DIC Problem??
- Free Shipping Offer Cadillac Merchandise - Floor mats & Custom Cadillac Car Covers
- Sold my 07 SRX, picking up 12 CTS Sport Wagon
- Srx navigation/xm
- is my car still under basic 4 year/50k warrenty?
- 2006 SRX with 95000
- front diff oil change
- Anyone have a 12 pin HID ballast they want to sell?
- More power out of my 2008 SRX V6
- Rear window regulator replacement help.
- Cadillac Floor Mats - You Design Them Online
- replacement tires
- replacement tire pressure
- 2008 stering wheel heater not working
- p0204 p0304 codes
- Programming key
- Spark Plug Replacement 2004 V-8
- 2008 srx v8 oil filter
- Luggage rack
- 2006 SRX - Removal of factory navigation
- Possible Brake Assist Problem?
- 04 navigation
- Ongoing CEL problem, need suggestions
- gmpp
- Converting 05 SRX to HID
- HID problem, question
- Hood Open displayed on DIC ?
- i want 20" rims. what tire size do i want??
- Remove and Re-install 2007 SRX Driver's Door Panel
- It served its purpose but I sold the 2005 SRX
- Flooding 2006 3.6l
- Cv shaft difference????
- hello i need help!!!! CV SHAFT
- Will my rims fit?
- New Company Car
- Navigation Icon Blinking... make it stop?
- RPO codes
- '04 SRX brakes pulsing
