View Full Version : Cadillac SRX First Generation Forum - 2004 - 2009
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15
  1. Very Sad to see GM file for Bankruptcy protection
  2. 07 V6 seems very thirsty
  3. navigation system configuration
  4. Towing w/ 2005 srx v8
  5. 2004 SRX with Clicking noise when I accelerate
  6. GM Lockpick 5 install-Help!!!
  7. My 06 SRX is worth muchos dineros!
  8. Ipod for 05 SRX without NAV and XM
  9. XM System Question
  10. Can bearly turn steering wheel! Help!
  11. It's time for new tires. Suggestions?
  12. Cooper CS4 Touring T Tire
  13. Ladies cadillac logo apparel & gifts
  14. Passenger turn signal bulb out
  15. SRX crossover sedan
  16. Blue Screen instead of OFF problem.
  17. Congress wants automakers to cough up diagnostic codes!
  18. Replacing a DRL Bulb
  19. Will turning off traction control help fuel milage?
  20. '06 SRX front engine noise help
  21. Headlight squiter problem on my wifes 06 srx...I think?
  22. Glare from chrome vent trim
  23. P2128 code.. damn srx..
  24. Ladies Cadillac Logo Apparel & Gifts
  25. To Fla SRX owners ...
  26. 25000 tranny fluid service???
  27. Potential SRX owner, need your thoughts please
  28. Engine cradle bolt failure, you should check
  29. A/C not cooling
  30. Looking for 18' rim and tires for my SRX
  31. Different Viscosity
  32. Certified Pre-Owned (CPO) Documentation
  33. AHHHH (she broke it!)
  34. New owner (maybe)
  35. express up pass. window
  36. Obd p0345 & p0346
  37. license Plates
  38. Front Wheel Bearing...defective??
  39. Need bolt torque for engine cradle bolt
  40. Wrong tires installed by selling dealer - Any issues?
  41. Favorite fuel injector cleaner or fuel treatment ?
  42. UltraView Roof Safety Issue/Maintenance!
  43. Performance Brakes?
  44. "service brake assist/traction control/stabilitrak"
  45. Ladies cadillac logo merchandise added to autoprideconcepts.com
  46. Need a drawing of front left subframe. 04 AWD V8
  47. Ignition freezes, SRX
  48. Best place to buy Extra Key Fob and how to program??
  49. Massachussetts SRX owners, chime in.
  50. Massachussetts SRX owners, chime in.
  51. Trailer Towing Switch
  52. SRX Rear AirShocks
  53. recharge ac, what coupler?
  54. Getting ready to store - which car cover?
  55. Blown head gasket @ 40k
  56. Has anyone purchased brakes (rotor & pads) from GMpartsDirect....I need advice!
  57. 04 SRX: After trailer hitch install, how do you know which wiring harness ...
  58. Installed Pioneer AVIC F500BT
  59. Theft alarm goes off..
  60. Cabin filter
  61. RS-As are gone!
  62. Washed my srx, and this happened
  63. (another) Fuel Gauge Problem...
  64. Rare SRX? Strange options or just BS?
  65. Fuel economy worsened and a shimmy
  66. 2004 SRX 3.6L V6 running rough at idle, getting P0300 and P0306 error codes
  67. Buying a used 2007 SRX! Need your expert advice
  68. 2005 SRX air conditioning-help!
  69. Whine
  70. sport rear bumper help
  71. Help! Keyless entry reprogramming for '04 srx
  72. Service pressure monitor
  73. Wipers on after car is off -- UPDATED Question... HELP!
  74. kelleke1
  75. srx
  76. Free shipping on cadillac logo merchandise
  77. On the issue of timing chains
  78. how to adjust parking brake?
  79. Removing Rear Bumper and Tail light
  80. Wipers stay on after ignition?
  81. 05: Want to add sat radio. no Bose/NAV/RSE with 6 cd changer
  82. Info Plz
  83. New SRX member !
  84. Awd?
  85. personalization off
  86. Brake Disc and Pad Change - service manual info?
  87. Wiring Connection to Throttle Body
  88. 2005 V6 SRX Oil Consumption
  89. Cadillac logo apparel, merchandise, accessories & gear
  90. NEW MEMBER with TIMING CHAIN QUESTIONS
  91. FAV Pre-Set design is ODD
  92. GAUGING INTEREST: BLUETOOTH Parrot MKI9100 conversion
  93. Snow flake idiot light
  94. Bumper plugs??
  95. Just finished the SRX Sport swap PICS!
  96. Anyone interested in cold air kits for your SRX?
  97. Worn out front shock
  98. Front end rattle and check engine light
  99. Link On-Star Phone to Verizon Wireless Account
  100. Newbie here...tail light and CD issue
  101. Where's the Sub???
  102. Help!!!
  103. engine code p0303- anyone had this before ?
  104. SRX buy back question need help
  105. V6/V8 Production Numbers
  106. Mobil 1 0w-30 Oil... Any thoughts?
  107. Speaker sizes....please.....
  108. Navigation Disk Noise
  109. Part number for factory floor mats and 'pin'...
  110. Rear View Camera installion
  111. Srx custom floor mats - gm licensed products
  112. Tire Replacement - General Altimax HP????
  113. Worst post ever: Where's my oil drain plug?!
  114. Has any one installed a LOCKPICK to add Bluetooth to the SRX
  115. Manual to power passenger seat?
  116. 2005 SRX w/ BOSE upgrade to aftermarket Nav system questions?
  117. Bluetooth module and ONstar module
  118. New SRX owner checking in
  119. Service and Owner Manual Discrepancies...
  120. How low on oil life before changing?
  121. DIY: SRX Sport front swap.
  122. MY weekend trip in the caddy
  123. 2006 Both Catalytic converter's replaced at 40k
  124. Lf: 2004-2005 srx
  125. Ravelco and Cadillac Warranty
  126. Would not move in Drive
  127. ND-G500 AMP Install
  128. Part Number for HomeLink Visor, 08 SRX
  129. Eyebolt for towing
  130. Clicking Noise from Front of Engine Compartment
  131. Starting Problem
  132. Serpentine Belt Replacement
  133. Engine Power Reduced =(
  134. Gas Tank Noise
  135. will infant car seat fit?
  136. oil consumption
  137. Stock V6 intake moan?
  138. Rear Tail Light LED Out
  139. 05 srx problems/questions
  140. Turn Signal vs Hammer
  141. 04 SRX Leaking Above Spare
  142. Upgrading from 18" to 20" What size tires?
  143. Just closed a deal on a 2008 V6 AWD...
  144. Clunk/noise in steering
  145. Where is the VSS Wire on the 07 SRX
  146. 2004 srx oil change
  147. How do I remove the rear bumper cover?
  148. Code P2231
  149. Suspension Parts
  150. How to remove overhead bezel?
  151. Front Differential Fill/Drain Bolt Hex Size?
  152. 05 SRX chuggle at high way spend under light load
  153. 2004 Nav
  154. Cadillac merchandise site - free shipping offer
  155. sounds like an old ten speed
  156. 04 srx moaning rubbing sound in rear
  157. Metallic Noise in rear
  158. Dvd headrest monitor ?
  159. Looking at an '04 srx v-6
  160. Interior/Perimeter Lighting Problem
  161. Is this an ultraview?
  162. 2 HUGE Problems!!!!
  163. Federal Tire SS595 - anyone running those ?
  164. Zaino or other products
  165. Climate Control Problem- '04 SRX
  166. 2006 SRX Onstar Module Location
  167. SRX Sport front end conversion: build thread
  168. DVD with ultraview
  169. Cadillac logo drinkware
  170. 20" rim ?
  171. Will OEM CTS-V wheels fit the SRX?
  172. Will CTS seats fit in an SRX?
  173. Air suspension failure.
  174. Can 3rd seat be added to SRX easily?
  175. Tire Pressure Sensor / Rim question
  176. New SRX Owner
  177. General Brake Question
  178. Cargo Liner and second row runner?
  179. Rod knocking on cold start up
  180. 2004 SRX Navigation DVD
  181. initializing cd problem help pleaseeeeeeee
  182. Is factory warranty valid if GM files bankruptcy
  183. SRX Ordering Guide
  184. Website with diagrams of SRX, or shop manual.
  185. Headlight Washers.
  186. Rear heat???
  187. Profile of SRX Owners - age, location, etc
  188. Great sale on Goodyear RSA 20"
  189. Turbo
  190. Excessive oil consumption
  191. Bucking, Hesitation in 08 SRX
  192. clear vehicle bra
  193. SRX Custom Floor & Cargo Mats
  194. SRX headlamp
  195. Is this SRX a hoax it V badged
  196. CADILLAC SRX Starting problem, liftgate problem
  197. Potential buyer questions..
  198. Did I miss something?
  199. Anyone have any issues with SRX Factory Alarm?
  200. Passenger headlight getting water in it and I need another
  201. Is this a good deal?
  202. Anyone had any problems getting their struts replaced under GMPP
  203. Sunroof rattle
  204. My 04 SRX Headrest has gone Wonky!!
  205. Check coolant error, ice possible
  206. Milage Distance Indicator
  207. Just Signed up!
  208. Rear Brake Rotors - Uneven Wear
  209. 2005 SRX Fron Brake pads
  210. New SRX and CTS Wagon at Dallas show
  211. Forum Discount - Free Shipping Offer
  212. City Lights - when are they supposed to turn on?
  213. 2008 SRX 3rd row seating purchase
  214. Brake pad squeal@ exactly 39000 miles
  215. Escalade 18" Wheels Fit?
  216. Disable DRL? Oddly, the DRL relay is not present.
  217. Will 2005 cluster work in a 2004?
  218. 2004 --> 2006 Navigation Unit?
  219. Install Corsa on 04 Srx
  220. Steering Wheel Buttons Not Operating Correctly
  221. Cadillac SRX Lockpick for 2004-2006's?
  222. SRX 4 Headlights for the SRX?
  223. How to turn on onstar/XM and clicking noise?
  224. Turn Signal-LED Upgrade?
  225. 08 or 09 SRX
  226. Timing Chain, Liftgate Seal and Carpet Replaced
  227. Lift Gate Gas Cylinder replacement 05 SRX
  228. Brake repair 06 SRX
  229. Rear bumper Rusted
  230. ECM...or Possessed by the Devil?
  231. Power Steering Leak
  232. Weird electric problem?
  233. Remote Start suggestions?
  234. Considering buying a used 2005 SRX...
  235. Ski Rack Recommendations
  236. Front License Plate Bracket
  237. Intermittent Rough Idle.
  238. low or high
  239. engine light
  240. Oil leaking from capped tube near spare tire
  241. Stock Air Filter Housings Wanted for Modification
  242. 08 NorthStar badge?
  243. Traded in the 05 for an 08!
  244. Clunk in Right Rear with Full Tank of Gas
  245. My SRX is SHOT?! HELP!
  246. AWD Tire Chains?
  247. Might buy an SRX...info please
  248. Anyone have info on the 2004 SRX recall? Catalytic converter?
  249. Good News for SRX Owners?
  250. noise
