: Cadillac SRX First Generation Forum - 2004 - 2009
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. 07 SRX Any recalls?
  2. I love my friggin SRX4....
  3. Year to year changes
  4. 04 srx greeting
  5. service steering system
  6. SRX Brake Job and othe stuff...
  7. timing chain replaced at 1500 mi
  8. Spark Plugs?
  9. Lot of Service at 81k
  10. P0638 after cleaning TB
  11. HELP - Drained wrong oil! ????
  12. carbon fiber cover
  13. Intake full of thick oily gunk
  14. Code P0300 and rough idle
  15. Intake manifold replacement...
  16. What is the best online store to buy front turn signal bulb for SRX 2005?
  17. Dealership is telling me - 50K
  18. 50k service
  19. Did anyone here lower their SRX?
  20. N*8 cylinder numbering
  21. traction control
  22. 2004 SRX won't start; key stuck in ignition
  23. Which TSB???
  24. Better brakes?
  25. level control
  26. 2006 srx navigation question?
  27. Camshaft Sensor Replaced, lots of noise??
  28. What are the lines on the side windows in the cargo area?
  29. need parts
  30. battery dies when rear windshield wiper is left on!?
  31. 04 Ultraview top rattles
  32. excessive brake dust
  33. SRX Excessive Oil Consumption- Any ideas?
  34. Under body squeaks and groans
  35. iPod hook up for 2004 w/o Nav or XM
  36. Sold!
  37. SRX Custom Floor Mats & Cadillac Logo Gear
  38. Impressed with the AWD
  39. Help regarding system panel software clear
  40. Clicking Driving Straight
  41. gutting maf sensor
  42. Weird Problem, Need Help...
  43. Cargo/Convienience Net
  44. strange noise from my V8
  45. 2004 courtesy lamp problems
  46. Auto climate control Q
  47. HID Ballast
  48. 3rd row seat
  49. 06 SRX Headlight Washer stopped working
  50. Headlight washer cover missing
  51. lumbar problems?
  52. Xm radio subscription $77.00
  53. Joining soon + questions
  54. LED interior lights
  55. Radio Removal - How to remove Dash panel?
  56. DVD in motion
  57. hazard light steady on
  58. Rear Bumper Install Diagrams
  59. No travel on front suspension
  60. 06 Navigation update issue...
  61. Will non-Sport license plate frame fit a Sport bumper?
  62. question regarding how far back your ultraview sunrood opens
  63. serpentine belt replacement difficult ??
  64. 2004-2006 17" OEM wheels on a 2008-2009
  65. Front Wiper Problems 2004 SRX 2WD
  66. 3.6L Timing Chain Replacement?
  67. 07 SRX4 seeking 20 inch SNOWtire options
  68. Rear Wheel bearing and Hub Assembly replacement
  69. Gas Cap Check Engine Light
  70. Timing Chain replacement
  71. Adjustable brake and throttle pedals
  72. Brake lights won't go off when it's cold
  73. Need Custom Roof Rack
  74. 04 SRX V6 intermittent no start
  75. Magnetic Ride Struts and Shocks ... Help !
  76. Pads and Rotors
  77. dvd to unlock during movement
  78. V6 engine noise
  79. Just picked up winter tires...GENERAL ALTIMAX ARCTIC
  80. help
  81. Steering, Stability and Braking Service
  82. SRX Custom Floor Mats & Cadillac Logo Gear
  83. NAV unit replace
  84. Did Anyone Here Buy my Old SRX?
  85. Snow Tires on SRX4 * Dealer Says No
  86. Coldair intake
  87. CoStar BlueStar Bluetooth install in 2004 SRX
  88. 3rd row seat will not operate
  89. LockPick
  90. 05, Transmission Hot Idle Engine
  91. Corsa Cat-Back for '04 SRX
  92. srx
  93. Thoughts on the original SRX in preparation for testing the 2010
  94. 05 SRX Bose Stereo EQ
  95. Anyone have an extended warranty for a SRX with Chrysler?
  96. Srx floor mats - you design them online
  97. Want louder horn
  98. Cadillac SRX 2003 touchscreen replace ?
  99. 2004 V8 oil change
  100. Park Assist
  101. Oil consumption
  102. Curb Weight
  103. Tweets tab
  104. what are these...
  105. Is this an accurante quote per my mechanic?
  106. Staggered Tire Replacement
  107. Tire Pressure Monitoring
  108. Key
  109. Grill change
  110. Programming New FOBs for 2004 SRX
  111. replace Transfercase
  112. Transmission Failure- No warning lights- 04 SRX
  113. 04 SRX Battery Saver Active
  114. 04 srx headlight trouble in cold weather
  115. Timing chain recall?
  116. How much would you pay? SRX Question
  117. Front Turn Signal Lamp -easy to replace ?
  118. Lock not working
  119. Right rear caliper attach bolt
  120. Aux input/ipod connection
  121. Tire review, BFG All terrain TA
  122. Need help finding a transmission band
  123. aftermarket wheel help
  124. Front end clunk - update
  125. 3.6 V-6 power loss - chain or sensor? Need Help
  126. Introduction and Door Panel Cleaning / Wear Question
  127. really dumb newb question
  128. Looking to buy a cts-v
  129. Cadillac watches
  130. windnoise from sunroof, NON OEM
  131. The cars our SRXs have smoked
  132. HID Headlights - Installation & Pics
  133. LED License Plate Lights - Installation & Pics
  134. new 2010 srx and cts sport wagon
  135. Body flex causing "groan" - help!
  136. Extending srx warranty?
  137. Need GMVIS on 2007 SRX looking to buy
  138. key will not come out of ignition
  139. Full Size Spare
  140. 2004 SRX: DIC and aftermarket NAV
  141. Growling front end
  142. 2004 SRX Courtesy Light Problem
  143. Hood for '04 SRX - silver
  144. White SRX's
  145. Where to find clear fogs and side markers?
  146. Follow up to a Recall Repair
  147. Computer losing memory?
  148. Help with cd changer/player
  149. Possible to remove oil through dipstick tube on V6?
  150. 2004 SRX with NorthStar stalls
  151. thunk between 2nd 3rd
  152. engine-transmission vibration at 38mph/1900rpm
  153. Radio changeout FYI
  154. Rear End Rubbing Noise
  155. Garage opener conversion module required?
  156. Tire pressure sensor replacement advice
  157. Hauling Pinball games in a SRX
  158. '05 SRX AWD, Engine shaking, vibrating when accelaration
  159. Backup Light/License Plate Panel-Color
  160. SRX...Out of Commission?
  161. Starting Problems- P0496
  162. Replace transfercase on 2004 N* SRX with transfercase from 2006 V6 SRX?
  163. New Member With Questions
  164. srx started itself!
  165. 05 srx dvd unlock while driving, help!
  166. Bump when accelerating..
  167. SRX part name
  168. Oil Life % is gone
  169. Condensation leak?? please help diagnose.
  170. SRX Traction control engagement
  171. 9.7 MPG - Help Northstar
  172. 2008 SRX V6 AWD Wheel upgrade questions
  173. SRX parts for sale!!!
  174. Need New Tires Ideas Please
  175. How to enable front DVD in 09 SRX?
  176. 2005 SRX Key Fob Part Nos?
  177. Rear Seat Fuse Block
  178. Differential Bushing
  179. Mirror
  180. Wheel/Hub Sensor On 2008 SRX
  181. One SRX gone!
  182. Rear Entertainment (Head rest DVD players)
  183. 2006 V6 AWD engine trans questions
  184. Need 2008 SRX Nav Manual in .pdf
  185. Just ordered 22's
  186. SRX 18" Wheels
  187. Steering play when turning to one side only
  188. Steering play hen turning to one side only
  189. SRX Wheels
  190. Rear end thumping sound when aggressive acceleration
  191. srx shifting problem
  192. 2005 V8 AWD with intermittent cranking/starting problem
  193. SRX or Mazda CX-9
  194. Yes, I am Stupid
  195. 2005 SRX stolen/recovered a year later.
  196. 05 SRX V8 Stalling
  197. HELP!!! With starting problem
  198. TPMS units- 2 different types
  199. Buy Decision: 2004 SRX
  200. Repair manual for 06 v6
  201. Cargo Net
  202. 2008 SRX 20" Rims Corroding
  203. SRX Accessories Available
  204. Odd Starting Problem
  205. Refill Refrigerant
  206. wtb: Magnetic Ride shocks
  207. Wheels
  208. 2004 SRX won't start, headlights going off and on alternately
  209. Replace RSE DVD Player?
  210. MRC conversion
  211. '05 V6 AWD body vibrates when A/C on high
  212. Torque Converter/ Tranny Oil Smell
  213. Coolant Leak. Where's it coming from?
  214. catalytic converter help
  215. Srx rear hatch
  216. SRX STS Front Seats Interchangable?
  217. Rolled over a tire..
  218. Cadillac srx floor mats - you design them online
  219. SRX Part
  220. 07 timing chain replacement procedure?
  221. Leaving Cadillac
  222. Silver the same 04-08?
  223. Superchips
  224. New Member here
  225. 07' Dead Battery, CPO covered?
  226. Remove roof rack?
  227. Add a third row?
  228. SRX RWD or AWD
  229. Picking up "new" 2008 SRX tomorrow
  230. Fix Squeaking Drivers Inner Door Panel
  231. 2006 Excessive Oil Consumtion - Noted oil in the throttle body area.
  232. Emissions Warranty Question
  233. 05 SRX V6 RWD misfiring
  234. Cadillac logo automotive mats produced by lloyd mats
  235. Linking Video of Aftermarket rear DVD to front NAV screen
  236. Ashtray door spring...where/how does it fit
  237. Engine or Transmission Noise!?!
  238. What are the dimensions of the SRX
  239. Wrong Dipstick ?
  240. 04 SRX - No A/C while in idle????
  241. Premium vs. Regular
  242. Ladies cadillac logo apparel and merchandise
  243. Uneven wearing tires
  244. XM / Ipod adapter question
  245. XM/Ipod Question
  246. 08 SRX Cam Timing Problem - BIG PROBLEM
  247. Lubrication 2009 SRX Greasing Ball Joints
  248. 2009 SRX Digital Clock not working
  249. 18" Hi-Polish GM Accessory Wheels on My '07!
  250. How much to sell my 2006
