: Cadillac SRX First Generation Forum - 2004 - 2009
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Magnaflow Mufflers
  2. Express open and close: Windows and ultraview
  3. Fog lights LED retrofit ?
  4. Help! Ran out of gas, now gas isn't showing once filled
  5. mixing New and old tires
  6. Do your 2nd row headrests shake when driving??
  7. Check your spare tire!!
  8. Front and Rear Sway Bar Bushings and Links
  9. Sticking Ignition Key
  10. Confused: Will 2006+ wheels fit on a 2004? Looking to buy 17"
  11. 2007 SRX - scratches on coated aluminum wheels
  12. SRX just started shifting very hard
  13. DIM Modle Location 04 SRX Nav
  14. Automatic Battery Run Down Protection
  15. VSS location on a 2006 SRX Navi unit?
  16. Ultraview rattle- looking for part no.
  17. school bus versus srx ---srx lost
  18. SRX HID Headlight Diagnosis
  19. Bluetooth Addition for the SRX
  20. First Battery replaced in 09 SRX
  21. driver seat heater and power won't work, and all windows.
  22. OEM Rims
  23. 100K mile service
  24. New to me with error codes :(
  25. Unofficial 04 V8 oil usage post
  26. Experience with my SRX, buildt 10/04 3,6l AWD
  27. Would you still buy SRX all over again??
  28. pass switch - window will go up but not down; lock but not unlock
  29. 2004 owner's manual in PDF?
  30. driver seat (bottom rear) will not move up??
  31. Rear Wheel Bearing
  32. Disconcerting article
  33. Heated seat not working!
  34. Rumble in the rear when taking off from stop
  35. 2004 SRX Battery
  36. Euro vs Us specs
  37. Thinking to buy a SRX (used) and question about car seat
  38. New SRX Owner - 2007 V8 AWD
  39. Cadillac floor mats - gm licensed - custom made
  40. To (OEM) Nav or not to Nav
  41. Need Better Tires for the SRX
  42. Brakes on a 2005 at 30,000 miles?
  43. 2004 SRX Northstar cd/nav/radio issue
  44. It is time to check your motor oil
  45. Washer Fluid Low message would not reset
  46. Time to sell??
  47. Help Accessing Onstar Unit
  48. 04 SRX Fuel Pump
  49. Passenger side mirror changes position
  50. Viper 5591 remote start won't turn my lights off
  51. Sold My '09 SRX. My 3rd. Leased a '11 CTS
  52. Magnetic Ride Control (MRC) Suspension Issues
  53. Kumho KL21 report
  54. Oil light
  55. 2007 SRX Power Liftgate Won't Close
  56. Gargage Door Opener ?
  57. Just changed Right Front Turn Signal Bulb
  58. Heated seats included?
  59. Coffee and Cadillac's in Historic Petersburg, Va
  60. Coolant Flush.. Need Tabs?
  61. 2007 SRX 3.6 - How fast?
  62. 2008 Cadillac SRX Problems
  63. suspension problem with my 2004 srx
  64. Nav/Dvd does only play CD's anymore...
  65. 2 small problems
  66. '06 SRX cranks, but won't start. Help me diagnose?
  67. Front & rear Washers wont work
  68. Heated steering wheel is not heating - fuse?.. Where is it?
  69. 04 cadillac srx throttle problems
  70. Rear Wiper/ Electrical Issue
  71. Repair manuals
  72. Coolant Overflow Tank
  73. Converting speedometer from KM/H to MPH
  74. Rubber Floor mats?
  75. need main radio board part- SRX/ CTS
  76. How do I calibrate a new tire pressure sensor on a 2004 srx?
  77. Headlight adjustment
  78. 2004-SRX Is anyone else experiencing hard downshifts between second and first gears?
  79. ran out of gas, now vehicle surges BADLY and no power brakes
  80. Acceleration difference between an '04 and a '09 Why?
  81. 2007 SRX Heated Seats issues. Getting too hot.
  82. Lockpick for a 2006 SRX or any dvd/navigation unlocks ?
  83. In dash aftermarket GPS installed.....
  84. Emblem/Crest Dimensions
  85. 2008 SRX: Cigarette lighter time out?
  86. 04 srx v8 aftermarket exhaust
  87. Need help with shift indicator light on a 06.....
  88. Wheel offset and fitment help ...
  89. GM Parts issue..
  90. Changing Spark Plugs
  91. Yellow gunk under oil cap?
  92. Retaining DIC with DVD player install
  93. Front Ultrasonic Parking Assist for SRX V8 2005
  94. Need advice heated seat not working!
  95. '04 SRX V6 Cam Timing
  96. Looking for a Cadillac V style billet grill for an 07 SRX can you buy one?
  97. Removing center console
  98. My theory on rough downshifts (when slowing down)
  99. Need Help Buying Used SRX
  100. 04 timing chain problems?????
  101. Need to remove rear passenger seat in '04 SRX
  102. Need a measurment from a 3rd row SRX
  103. Replaced the center dash speaker, what a difference!
  104. Real world experience with current gen X5
  105. 2007 SRX Battery issues
  106. What About Towing?????
  107. Front Parking Lamp Bulb Replacement???
  108. 2004 Timing chain replacement cost?
  109. Extreme Tire Wear
  110. Rear Shock Replacement
  111. How to pull codes
  112. Programmed Key now power seat dead
  113. A/C Compressor
  114. 08 wheel and fob on an 07?
  115. 3rd row seat, need help please
  116. Timing chains - FYI
  117. Nav Update 6.0c PN: 20940248
  118. 2005 Auto Transmission Issues
  119. Help! How to change navigation language in dutch (Europe map version)
  120. Ultraview bolt part number?
  121. will the sport grille fit the non sport front end?
  122. Auto Folding Mirror Question
  123. Need advice, buying used SRX
  124. Xenon Replacement Bulbs?
  125. Turn signal problems!
  126. Installed my new vizualogic headrest monitors
  127. Front Fascia EX-change
  128. noise
  129. Cadillac: Hats - official gm licensed products
  130. Please Help
  131. What Does SRX Stand For
  132. intake gasket
  133. Engine Misfire 2004 SRX
  134. ipod adapter for 2004 srx
  135. AWD - how is it split
  136. Door hinge worn out - 3 years old
  137. Where is cyclinder #1 located?
  138. Power moon roof vibrating, not auto closing
  139. Aftermarket stereo head unit- have you done it?
  140. Lockpick (Coastal Electronic Technologies) in the Consumer Electronics News...
  141. Lower Control Arm bushings can they be replaced?
  142. pissed off srx owner
  143. How do you remove the stock Grille?
  144. 2005 srx passenger seat lombar problem
  145. New SRX owner...
  146. Got a letter in the mail today from Cadillac about SRX catalitic converter
  147. 04 SRX Staring issue
  148. V6 Excessive Oil Consumption - Try This
  149. Upgrade to a power passenger seat?
  150. Suspension / Brake Noise
  151. SRX Cabin Air Filter Replacement
  152. How to change transmission fluid for 2004 SRX
  153. Has anyone tried the latest GPS Nav Update (20940248)?
  154. Code 08 and 18
  155. Reprogram Remote for 2006 SRX with Nav
  156. 2006 srx 3.6 L oil drain plug location?
  157. Heater Problems
  158. Drivers Seat Problem
  159. 05 SRX V8 Valve Job
  160. Unusual tire wear or no?
  161. 07 V6 SRX 69 MPH tranny/engine issue
  162. No sound from 2007 SRX audio/Whine from rear?
  163. 2004 srx backup sensor
  164. DIY transfercase chain replacement
  165. Ultraview Issue--Thanks
  166. OnStar - VCIM for 2006 SRX
  167. Leak from driver Pilar
  168. No oil
  169. VSS Signal in 2008 SRX
  170. Sir-GM1 module installation
  171. Question about the cargo area in a 2007
  172. How do you remove therear passenger side interior
  173. Need SRX taillight diagram
  174. Drivers side front seat moves
  175. 3rd row head rests and Winter wheels. Pontiac Montana SV6/Chevy Uplander 6x115
  176. transmission clunks at low speed
  177. Floor Mat Retainer Clip
  178. Cheap valve cap leads to broken tire pressure sensor...
  179. Aftermarket Speakers
  180. 06' SRX theft system needs reset...
  181. whistle/ticking noise at idle '04 srx
  182. 3rd row seat
  183. Proud new owner!
  184. Bulb replacement list ?
  185. Tire diameter range for Snows?
  186. Is this a good deal?
  187. How much did you pay for your SRX?
  188. Rear window not working
  189. buying an srx
  190. Front End Accessories....
  191. 900 amp jumpstarter enough?
  192. My CaddyWagon got rear-ended!
  193. Left and Right Heated Seat Elements Interchangeable?
  194. xm radio ???
  195. 05 "Euro" bulb replacement
  196. Need some help picking out a SRX....
  197. Power Folding Mirrors
  198. Clear film front bra
  199. SRX loses encounter with gravel truck
  200. DVD Remote 2004 srx needed
  201. DVD remote control help
  202. Any 1st Gen SRX owners use an Invisicord?
  203. Splash Guards for my 2006 SRX
  204. 04 SRX shuts-off/stalls while driving/moving
  205. Tires
  206. SRX Headlights - what the heck
  207. New throttle body connector pin out
  208. 2004 SRX - how to remove left rear door panel?
  209. Leak at Thermostat Housing - any tricks to replacement?
  210. SRX 2006 Nav/GPS Euro disk: where I could find it? help needed.
  211. Ultraview plus question
  212. 2007 AWD - 17" tire headache - please help
  213. 2004 srx rear back up camera need info
  214. more about tires and rims
  215. Help! 2005 SRX running hot!
  216. Tail light bulbs.
  217. nav
  218. Helpful Hint
  219. no more mrc suspension! need help!
  220. emisions not ready
  221. 4x4 Service
  222. Free shipping offer - cadillac merchandise & custom cadillac floor mats
  223. Unknown Fluid Drip
  224. Exhaust for 2004
  225. Bugs and tar removal
  226. iPod integration/AUX input for the Cadillac SRX (PA15-VETTE)
  227. Tire pressure readings maxed out
  228. Considering buying an 04-06 SRX
  229. Tire - why's and what's the advantage
  230. 2006 V8 awd spare tire?
  231. Dash Kit
  232. Key fob stops working after one minute...
  233. Cat code and Mass Air flow code
  234. anyone running yokohama yk520 tires?
  235. '04 SRX low power will not rev past 4k rpm PLEASE HELP
  236. silicone spray and door seals
  237. Oil Change, 1st
  238. Purchased our 2nd SRX
  239. Cross Bars
  240. Rear Bumper Fascia Protector
  241. Need Trim part number 08 SRX
  242. 2007 SRX gas mileage: 10 MPG?
  243. Ultraview Issue
  244. Not an ad - Just an atta boy
  245. Onstar
  246. Onstar
  247. staggered tire load rateing
  248. steering wheel position sensor replace
  249. Power Adjustable Pedlas 2004 SRX Please Help
  250. Service Suspension System?
