- 2001 Eldorado headlights won't come on
- Swaping Stock for BOSE
- B440 Diagnosed...
- Burning Hot Heating Vent - Heat Turned Off
- Strut Replacement suggestions 96 eldo
- 97 Seville Coolant leak on drivers side
- I Need A ELC Height Sensor. Anyone got one?
- My STS is a BMW
- 93 eldorado transmision
- Just bought a Seville, troubleshooting advice?
- wont start
- 92 Eldo, broken door trim panel clips
- 93 seville 4.6l--how do you disable service ride control?!!!
- Change Brake Pads message 2002 SLS
- Broken '94 Eldorado: What's It Worth? How Much to Repair?
- 96 Eldorado came in last night!
- no fourth gear
- Check Engine Soon
- welding exhaust
- front end OVERHAUL - this better fix my baby!
- 02 SLS Fuse Box Location
- codes
- Seville 91 Code 33
- Squeak coming from LR of car
- 2000 sts Tranny
- Heated windshield
- 99sts water pump R&R/ABS&TRACTION ON??
- replacing bose system
- struts
- Vintage review
- 99 Seville troubles
- Thoughts on this idea please...
- 02 SLS options
- code T033 current
- 97 Eldorado Wiring
- E&G Grill Installation on an Eldo
- Wait Three Minutes
- 98 Seville STS, help please
- Broken hood release cable
- 2002 STS w/Magnaride review and Question
- 02 SLS twilight sentinal problem
- 97 STS heater core removal Help!!
- will this PCM work in my Eldo?
- 99 Seville STS rear air ride low ?
- Auto Express UP windows 1999 Seville STS
- Navigation in a 1999 Seville STS ?
- Outer Tie Rods
- Front Strut Bearings 98 sts
- miles per gallon
- anyone here working for a dealer?
- Door stuck in lock?
- OK, I need some help please! 97 Eldorado (O2, vacuum, fuel?)
- what should be the rmps
- 2001 Caddy STS Trans or Electrical Problem? ...HELP!
- Rear struts active vs passive
- Just got my bumper pulled back into alignment . . . 98 ETC
- Rust colored & thick coolant in overflow tank?
- P1574 and c1295 wont go away
- Change shifter nob
- throttle cable routing
- 97 Seville STS hard shifting
- Driver’s side window switches - Need Help
- 2000 STS Seat Cushion needs replacement
- Exterior with Matching Interior Colors code's
- Need help, 99 SLS with heater problems
- Replace Brakes on 99 SLS
- no eng start,dash lights inop
- 95 sts
- Big problem on my Hydramatic (Eldorado 73)
- Coolant overflow causes "other" than HG failure?
- Classic cadillac logo merchandise & custom floor mats
- dead battery reset oil life monitor?
- 02 SLS Igniton Switch Cost
- Surging idle...
- Low Coolant and High Idle RPM's
- Transmission Filter Question
- 97 SLS - CD Magazine Stuck
- 98 Eldorado car cover
- air mix valve adjustment
- Help with Codes
- Intermediate shaft/steering removal?
- 02 sts seat upgrade?
- Where can I get a new badge for my 1976 Eldorado?
- 99 sls drive door lock/keyless entry
- sticky front brakes???
- Winter Driving
- Problems with my Eldorado ETC...
- Gtech in the sts!
- Project: Cell phone mount, MP3 audio to stereo, USB power
- '98 Eldorado - Is this a good deal?
- 02 SLS Elec. Problem?
- HG Preventive Maintenance?
- Still Newbie... Michelin X-ice Xi2
- aftermarket sunroof leaking
- lots of ?'s
- Free Shipping on Cadillac Logo Merchandise & Floor Mats
- 1996 Eldo service manual help
- 2000 Seville northstar cyl 4 misfire
- Rear Defog / heated mirrors?
- 1999 cadillac seville sls
- 93 eldorado front suspension
- antenna part number
- HID headlight ballast 2001 same as 2003?
- Reluctant shifting / transmission issues and tons of codes
- Door locks, interior lights, cig lighters, etc not working
- Any super built northstars out there the same as my 95 eldorado?
- 92 eldo trans leak.
- Replace Water Pump - How Much?
- Has anyone put roofracks on a seville?
- Electric Supercharger
- Aluminum Radiators for 86-91 Eldos/Sevilles?
- Timesert Kit for sale
- keyless
- 01 STS steering column rattle
- 1979-1985 Eldorado Electronic Level Control
- My 99 STS codes from hell
- 00 Seville SLS Speed Limited to 90
- STS sunroof problems
- Phantom Sunroof
- Any experience with Airtex fuel pumps?
- Biarritz vs. Base
- New Cadillac Eldorado owner with problems.
- Service suspension system dash alert
- 02 Seville Code P0410
- I think my starter went. Please help me!
- EVAP fixed. No codes, still gutless!
- seville shuts off when turning
- Anyone else's gas gauge ever do this?
- 94 & 95 Eldo N*- same engine
- Pls help, 2000 sts has no power and no rpms, boogs
- 1995 Cadillac Seville SLS remote keyless entry
- hvac fan problems 2001 STS
- 98 SLS hard to shift out of Park
- 98-04 Seville Owners...who accidently bought a bra??
- headlights turn off in parking lots
- check fuel gauge
- 2002 Seville Idling problem
- 03 SLS Hard starting
- Ugh, please help----HVAC meltdown
- ime to fix that ABS pump.
- Strutmasters: Canadian alternative?
- Help!!!!!
- 84 Eldo - Need Programer for climate control
- Interested in a 79 Seville -- Need Advice
- Looking at buying a 1992 Eldorado Touring
- 2000 Eldorado no power to Onstar/rear view mirror
- 82 Seville - Where's my fuse block - Trunk release not working
- Remove Stock Radio 99 sls
- Too much trans fluid? 4T80E
- 98STS Air Ride Compressor ??
- 98 STS Heat Blows Cold
- 1991 Seville - Diagnostic help please
- Did my water pump just give up?
- Slow acceleration 96 Eldo ETC
- Optima battery replacement
- Low Oil Pressure - Stop Engine
- Help with a Code
- Service Stability System - Traction control Problem
- Pcm po442 msmb1845 current
- 1995 ETC, will Concours digital cluster work?
- Starting issue
- 96 STS bumper and lower panel trim
- RKE Key Fobs
- ......antifreeze......
- NEWBIE...anyone in Illinois help???
- PCM reflashed after 2nd gear limp mode???
- '94 Seville SLS High HydroCarbon output
- Seat Rail Adjust for Tall Guy
- harsh cruise engagement
- service stability sys
- Ride level
- Defrost not blowing very hard?
- Need radiator help 99 STS
- Guages?
- Need help parts 88 Eldorado
- B440 current
- '97 STS Blinker Works Right, But Not Left
- overheating problem, may be hg
- Need some help guys, I hope it's ok to put all of this in one thread. 96 STS
- Help with trouble codes
- Throttle Position Switch vs Throttle Signal Switch
- 00 Seville no heat
- 98-03 STS headlights in 96 STS?
- Brake lights are always on!
- 2004 SLS Ext. Warranty about to Expire
- In need of help!!
- 71 convertible eldo ticking in the trunk
- 71 convertible eldo dimmer switch
- 98 STS no antifreeze
- Service Theft System warning
- WHY Would Anybody Do This!!!
- I need more power
- 2002 Seville SLS question: PCM P0106 Code
- I am pi$$ed!!!!!!!!!!!!
- Seek Instructions/tips for Alternator Change
- codes help
- '99 Seville Driver's Door Mirror Motor
- 02 SLS-Seat Heater Problems
- Winter storage: Indoor or outdoor?
- Front Strut Replacement active susp.
- Which service manual is good for Seville 99?
- My HEART FELT thanks to everyone here!!
- keyless2
- Interior Lighting Gremlins
- Defroster little air, Heater lots of air (84Eldo))
- Old unused Preston Anti-Freeze
- How to manually open or close the bend doors of AC?
- 97 seville sls cd player Model ###
- suspension compressor question?
- Bose Speakers 92 to 97 Cadillacs
- '98 Eldo won't start
- Question on 17" STS 7-spoke wheels
- Rattle on 02 Seville SLS
- Manual Downshift Question
- 99 STS - Slipping transmission might be low fluid?
- Anti-Seize & Spark Plugs
- Automatic healights question
- headlights question ???
- pump and clunk
- windshield wipers froze!
- Tight steering HELP(Strut Mount)?
- 92 Eldo Bose Gold Stereo antenna jack?
- Master Door Switch, Horn, Windows Not Working
- Battery or Alternator?
- ElDawg Saves Family's lives
- 99 SLS died while driving won't restart
- And Still no Over Drive
- 2002 SLS Imitates 1978 Elegante Seville
- 2000 Eldorado heater malfunction
- any sources for lower door trim?
- 98 STS Engine Swap Trouble
- Homelink Compatible?
- 2003 STS speedometer noise - need help to diagnose!
- What is acceptable coolant temperature
- 98 Eldorado ETC "check coolant"
- Rough idle, SES light and 2 codes
- 85 Eldo convertible top problem..
- Holy God....
- When to replace a 1999 Seville sls
- 94 seville sls "service ride control" code s030
- 99 Deville Concours Vin 9 - 99 sts vin 9
- E027 Code, A/C Problem and Service Ride Control
- 1985 Eldorado -- How Underpowered Were They????
- Monroe MA822 for rear shock replacements?
- Getting ready for my new exhuast....
- Unique Smell
- Engine Might Be Blown in My '94 STS
- 2000 Seville STS no pedal
- '03 STS Heat
- Thinking of buying...
