View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Transmission slow shifting
  2. No Heat on Passenger Side
  3. how do i remove shifter nob
  4. 1999 STS and stock NAV?
  5. Headlight restoration
  6. 01 SLS front left turning lamp. help!!!
  7. Funny Noise, coming from dront driver wheel
  8. Oxygen sensor #2
  9. Looking at a 96 Eldorado
  10. F55 Question
  11. Advice for '02 Eldorado ETC 38K Collector's Ed.
  12. 2001 SLS front turn signal
  13. 2003 SLS RPO Code Meaning?
  14. Help with codes
  15. 99 Seville STS Lower Control arm ?
  16. limp in mode
  17. planning on storing my lac in the garage
  18. Trim on a 95 sls
  19. Need Help- Confused
  20. P0449 Need fuse, anyone with Shop manual
  21. 2001 Seville Aftermarket Radio and amps Installed
  22. Tc0061
  23. Look whos ridin in a Caddy!
  24. door piece fell off where can i get one or fix it?
  25. 93 Seville Heated Windshield & radar detector
  26. dimming out all the lights
  27. door lock help
  28. trunk lid not closed all the way down
  29. 96 sts headlight upgrade
  30. Seven and four, Respectively
  31. please tell me no...
  32. do i need to change my transmission fluid?
  33. Shop can't figure out what is wrong with my air bags!
  34. Driver side mirror wiring 91 eldo
  35. windshield washer issue....
  36. Radiator Bushing Fitting
  37. Tune-Up Time
  38. saga
  39. alt. problems
  40. Finally cleared my 073 code
  41. are the coil springs
  42. 1994 sts northstar motor
  43. 98-04 Seville is remarkably reliable
  44. Looking for Kent Moore J-45211 PCM adaptor
  45. power steering expertise needed?
  46. new to forum and my 99 STS a few questions
  47. Replacing Leveling Compressor head/dryer
  48. Interested in a 91 Seville (maybe Eldorado)
  49. Transfer a OEM Sunroof
  50. 95 Eldorado 'running rough' suddenly
  51. ac coming out of shifter
  52. hello from FRANCE:98 STS before buying?
  53. 91 Cadillac Deville 68,000 miles
  54. wrenching/maint on Seville
  55. Problem with set timing mode, please help!!!!
  56. 96 eldorado water pump tool
  57. Sold my caddy SLS
  58. Plenum Difficulty?
  59. Test Drove a 91 Seville
  60. caddy 97 sls
  61. 99 sts, couple questions
  62. Passenger side speaker cover
  63. Interior lights won't shut off
  64. hazard bing bong
  65. first ride after long winter
  66. Corsa Exhaust System
  67. 1991 Seville -- Need Your Advice Before Purchase
  68. 2000 SLS Voltage Problem
  69. Please HELP! 20 PULL CODES 96 SLS
  70. Pricing help please
  71. 96 SLS Throttle Body
  72. front struts non oem parts
  73. 1994 cadillac sts low oil pressure stop engine light
  74. Whats noraml engine temp ?
  75. Aynone else think this is a beaut'?
  76. 97 sls front end noise issue
  77. Couple of Questions.
  78. Special brake pads for STS with sensors?
  79. Ratting, groaning noise under moderate acceleration
  80. 96 SLS Elect. Level Cont.
  81. tapping upper engine 91
  82. pulled these codes today
  83. Radiator Identification
  84. Where can I get a Front Position Sensor?
  85. Headlight won"t adjust
  86. Cadillac Merchandise & Custom Floor Mats - Free shipping Offer Ends 03/31/2009
  87. Good deal on a seville?
  88. Found cadillac seville & eldorado real & actual designed make/model performance chip
  89. Air Shocks Driving me crazy
  90. AC Blues Code: B 1315 Help!!
  91. 1988 Eldorado Biarritz
  92. New Denso Platinum TT spark plugs?
  93. Seville STS
  94. Newbie, prospective buyer, few quick questions
  95. Eldorado Headlight Mod Angel Eyes
  96. Cooling Sysytem Problem
  97. Proud new 99 STS owner. High milage and have questions
  98. Xenon module?
  99. Help Wanted in DFW
  100. new and need some help with 97 sts
  101. dash lighting/electrical problem
  102. Eldorado defroster grille
  103. Effects of a Sway Bar??
  104. has any one tried SureGrip SG series Stud Kit
  105. engine swaps for an 85 seville??
  106. Interior Lights
  107. 1979 Seville Computer needed
  108. Corsa Exhaust on my '01 SLS
  109. Question about ram air intake
  110. Short ram air intake
  111. 99 Seville STS Lower Control Arm Bushings?
  112. T-top Eldorado...
  113. Need part number help
  114. recall question....
  115. HID question
  116. just made the deal i pick up my 2000 Seville on Tuesday next week
  117. Need help now - alarm stuck
  118. 96 STS: Steering, Delayed Start, Improper Downshift (a few issues)
  119. 03 Seville Keyless Remote
  120. Another Heated Seat Problem
  121. affordable replacement speakers?
  122. Interesting '03 STS
  123. 97 eldorado hard starting again!
  124. Quick Question About Locks
  125. Body Subframe Bushings
  126. need opinons on strut conversion kits
  127. Eldorado owners in the Syracuse area
  128. 85 Seville and the HT4100
  129. Heated Seat issues PLEASE HELP!!!!
  130. Bad ground causing dim brake light?
  131. codes p132
  132. Eldorado suddenly died.
  133. 94 sts will goes in limp mode
  134. Low speed shimmy, from rear?
  135. Gas needle/gage not working right
  136. Very Tight Steering!! Please Help!!
  137. 1990 Eldorado Biarittz
  138. Cruise every once in awhile doesn't hold steady
  139. 69 Eldorado
  140. 97 sts buy it?
  141. 01 SLS air ride problems
  142. Replace AC compressor on 2000 ElDorado
  143. Help Identify Cadillac?
  144. please help lac attack!!!!!
  145. Seville / eldorado custom floor mats - free shipping offer
  146. cabin air filter
  147. tried to replace blower motor, what happend to my wipers
  148. What should I expect to pay for 80-85 Seville?
  149. Question Regarding Synthetic in an older N*
  150. Rough idle
  151. Aggressive Spring Fun [VIDEO] in the '96 Seville STS
  152. 02 Seville Trunk Mounted Lights
  153. 1993 Seville SLS
  154. Security problem
  155. Looking for an Eldorado for Weekend Driver
  156. How to remove rear bumper cover on a 1999 STS
  157. 2004 sls block heater advice
  158. Eldorado leather gear shift/wood bezel
  159. simple question for small leak
  160. Vibration in Car
  161. Rattling Noise
  162. 1980 Eldorado warm start stumble
  163. Just Got 96 Seville STS
  164. NO speedo or Tach after dead battery
  165. a few codes i need help with
  166. smoking burning stinking
  167. Considering a 1997 or 1998 Eldorado: Advice Welcome
  168. need to R&R sunroof glass 95 ETC, HELP!
  169. '88 Eldorado park light bulb change
  170. 2000 seville reverse light
  171. please help identify a relay 94 sts
  172. 99 STS replacing blower motor and headunit. Any advice?
  173. Rear knuckle bushings/repair kit
  174. 88 Eldorado Fuel Problem
  175. 1985 Cadillac Eldorado brake problems
  176. Help: Rusted heater pipes 94 Seville
  177. No AC no codes
  178. oil sensor?
  179. K and N air filter
  180. Parts wanted....2000 eldorado
  181. 97 sts cutting out at idle
  182. bumper got pushed in
  183. Eldo wont start....occasionaly
  184. My first ever Cadillac
  185. 98 STS Parking Brake Auto Release Not Working, Tried the Manual Release....NOTHING!!!
  186. need help!!!!!
  187. 99 STS - Sudden Power Loss After Red Light... Car Idles Rough...
  188. Ignition cable, where are?
  189. 97 etc 0300/mil o139/flashn mil new 41-950s@.050
  190. Bondurant Teen Driving $595!!
  191. No traction control or Cruise control
  192. 97 SEVILLE worth buying??
  193. '94 Seville STS, what else can brake?
  194. 94 eldo engine removale
  195. how to drain coolant in eldroado
  196. Overheating at Idle
  197. replaced ac compressor still no cold air
  198. Help with 2002 Seville stereo
  199. Does anyone have a walk through for evaporator replacement?? 1994 El Dorado
  200. 97 seville problems
  201. What can possible go wrong next?
  202. Hard shift & fast idle
  203. Help pcv tube broken!!!
  204. STS Transmission shudder?
  205. High Speed Vibration - 1999 Cadillac STS
  206. Fuel Line Repair
  207. Dealer Can't program RKE
  208. Steering Play after oil gasket replacement
  209. 97 sts has misfire after radiator replaced
  210. more fun with trunks
  211. 96 eldo alternator bearings making a screaming /grinding sound
  212. Engine R&R Question in a 95 SLS.
  213. which is it ?
  214. PZM Code
  215. 1995 Cadillac Seville 4.6 AC Pully Bypass problem
  216. Another headlight lense cleaning post
  217. Fast Blinking Lights
  218. Cooler lines ? I dunno ?
  219. Rough Idle/Engine Stutter - No Codes that make sense
  220. What is the name of this
  221. interior lights in 03 seville blow fuses
  222. Chrome '06 DTS wheels no good. Time to upgrade
  223. Don't shoot me!
  224. transmission temp thermister
  225. New here.2000 SLS Hvac prob. NO HEAT. BEEN VERY COLD. PLEASE HELP.
  226. eldorado lowbeam headlights
  227. Power mirrors go any direction but right
  228. Cadillac Seville STS Headlights, OMG!!!
  229. Did my blower motor kick the bucket?
  230. 96 sts lights question
  231. Power Window Problems
  232. Free Shipping Offer - Cadillac merchandise
  233. P0741 code.....
  234. What is this called and where can i get another one!?
  235. Wreath & Skull Apparel
  236. Trunk Measures
  237. 2002 eldo collector series exhaust
  238. horn hunking constant while driving
  239. Theftlock Activated
  240. RKE programing
  241. Eldorado's Dead
  242. What to do?
  243. ac not working in idle
  244. yeah my dad broke something
  245. water pump pulley removal?
  246. A lot of crazy symptoms
  247. $8.88 - Wreath & Skull Decals
  248. Anybody heard of a camshaft breaking on a NS.
  249. Power Steering Rack
  250. Engine Swap?
