View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 91 Eldo headlight bulbs?
  2. No Start Problem - Can Anyone Help!!!
  3. How Hot Is Too Hot??
  4. 1999 Sts 16,000!
  5. Split In Door Armrest
  6. New dynomax mufflers and stainless tips!
  7. 96 sts heating up leaking oil
  8. 98 ETC Interior repair question...
  9. Programming Key Fob Remote from the Trunk, 93 STS
  10. Question about STS
  11. Performance Modifications??
  12. Smells like coolant...
  13. front sway bar size, 98+ sts
  14. fuel leak! 95 sts
  15. I need new bumper fillers for a 75 Eldorado
  16. where is the starter
  17. how to....
  18. 1996 STS Ride Control Computer for sale on ebay
  19. 1999 Eldo
  20. Headlights Suggested?
  21. Ultrasonic park assistant
  22. HELP!!! Big trouble before the trip!!!
  23. IS a STS good for me? HELP!
  24. cadillac on rails
  25. 1991 Seville Front Seat Removal
  26. Fundamental STS Spark Plug Question!
  27. Got a screaming deal on a 2000 STS, want some opinions...
  28. 1997 STS with door switch problems - Help!
  29. 94 STS Tranny Capacity
  30. Folding mirrors
  31. 98 STS - DIC language
  32. I got it yesterday!
  33. Cadillac generosity
  34. Looking at a 94 ETC with problems
  35. How Do I Properly Clean My Throttle Body?
  36. 93 ETC- the fun continues! more stupid problems...Mirror & parking break plz help...
  37. 93 ELDORADO Northstar
  38. vibrates when breaking
  39. `93 STS Seville, NEED SOME PERFORMANCE
  40. SLS and STS parts compatable?
  41. Trac. light stays on...
  42. Had my 98 STS reringed under warranty!
  43. '96 Eldo leaking coolant
  44. Air Strut question+ Rant
  45. Swap NorthStar into 87 eldo?
  46. How can I get the most HP out of my 03 STS?
  47. 96 STS tranny blew....
  48. P094 History and P117 Current Codes
  49. STS Hot-Rod - Updated Web Site.
  50. Automatic Headlights
  51. Sts
  52. STS vs Lincoln MK VIII
  53. Semper Fi!!!
  54. So60-61
  55. Praise for the STS
  56. How to buy an 70s Eldorado convertible
  57. Dented Fender Strip
  58. How much for Flywheel labor? (PLEASE RESPOND)
  59. steering problem
  60. Slight Hesitation - What Gives???
  61. please help 88 eldo question
  62. Dtc P0503 P1520 Transmission Slip
  63. Weird Steering Noise
  64. 96 STS, worth $10000CND to put a new engine???
  65. Help with replacing headliner!
  66. 95 aurora, bad popping noises comming out of turns!! :(
  67. STS Air susp Compressor, what is normal?
  68. SLS parting out soon....
  69. miles per gallon
  70. Why STS?
  71. Can any1 do VIN check for me?
  72. HELP! On the Road and Need Assistance!
  73. gold emblems
  74. a/c problem...
  75. Ac All The Time!
  76. Dynomax SuperTurbos with Z28 Tips on an Eldo
  77. kcjustsk8's carfax
  78. Bumper repair
  79. Lets be honest here about reliability
  80. SLS vs STS brake questions--Calling BBobynski
  81. New member and STS owner/question
  82. Top speed - Help set the record straight
  83. right front damper solenoid valve
  84. HEY BBOB How do I replace an accelorometer
  85. 1992 Cadillac Seville
  86. Pcm Po27 Code
  87. STS belt knocking
  88. sts door panel
  89. where do i put my ac charge?
  90. 1997 STS Gas question
  91. 1999 STS Code 1760 LF Position Sensor fault FYI
  92. Service Vehicle Soon Light. Factory Reset?
  93. Need to tow Seville -- any gotchas?
  94. Black box behind rearview mirror????
  95. Trunk LED Brake light strip is out on 1999 STS
  96. Starting Problem
  97. looking for sts, which way to go?
  98. 88 Eldo Specs
  99. 1996 seville center caps
  100. phone in 1998 STS
  101. 2 Airbag codes on a '96 Eldorado
  102. PLEASE HELP speedo custer went bad
  103. new pulley required?
  104. 86 Eldorado engine swap..
  105. Pz2255
  106. '99 STS, Front wheel drive shaft nut
  107. Is it possible.....?
  108. 94 Seville STS Starter / Engine issue
  109. 88 El Dorado questions
  110. Where can i find 84 eldo pedal pads?
  111. 71 eldorado 410hp
  112. Eldo/Gone in 60 seconds
  113. How smooth should the STS ride?
  114. Emblem size
  115. Fuel Condenser problem. HELP!
  116. Making a switch, just some basic questions
  117. Wheels
  118. Need help with tranny failure/ solenoid issue ASAP in 93ETC...
  119. CaddyShack's Carfax
  120. Seville intermitent cruise problem
  121. 97 STS...little rough
  122. A/C recharge attempt?? I tried hard, anyway.
  123. Stolen and totalled!!!
  124. P039
  125. a/c directs itself to keep my window cold
  126. Help ..need Door Panel
  127. HELP!! Buying a CADDY advice + VIN Check
  128. 98 STS Brake Light Out
  129. Brake Pedal Switch Adjustment?!?
  130. Pondering.....2000 STS
  131. 1990 etc
  132. Need wheel info...1992 Seville
  133. Contemplating getting a 1997 Seville STS...
  134. Yearly ETC HP Improvements?
  135. My "new" '97 Eldo
  136. Mod the STS??
  137. intresting problem
  138. looking for center cap - Vogue wheel
  139. 94 STS Seville, engine speed erratic
  140. FLYWHEEL spinning freely...help!
  141. '97 STS - I want to do some stuff to it, but what?
  142. Please help/read/respond...
  143. Sunroof help
  144. Trans. Input Speed Sensor
  145. STS 2000 or 2001
  146. fuel pump how to
  147. 79-85 Biaritz things to look for?
  148. oil life meter reset?
  149. 4.9 to a 4.0??????
  150. Electrical Shut Off '94 Sts
  151. FINALLY!!!! I passed SMOG here is how
  152. Rim suggestions for STS
  153. Anyone Change Their Shifter Knob?
  154. Grille Badge
  155. Air filter question
  156. 96 Seville STS noise problem
  157. What does Service Ride Control mean????
  158. transmission oil cooler installed
  159. Tire Pressure & Fuel Economy
  160. What to check on 99 STS?
  161. 1996 Eldorado OBD
  162. She's dead
  163. Help!!! Noise from back seat area
  164. 94 sts running rough
  165. Replaced '94 Eldo Northstar-Now big headaches!!
  166. '01 STS Exhaust System
  167. 94 sts timing belts
  168. Driver window off track
  169. Question on 99 Eldo trim
  170. Where to find a center console armrest?
  171. 94 caddie eldorado 1/4 mile times
  172. 99 sts tranny problem?
  173. Gas Mileage Question
  174. Eldorado running rough
  175. How to enter 1999 STS diagnostics?
  176. '94 Eldo maintenance suggestions?
  177. difference in brakes from 93-02
  178. I Need Convincing! SLS-2001-Reliabillity?
  179. I backed into something!!!
  180. Seat Belt is broken
  181. Which grill looks better
  182. my summer project
  183. Wnated: Service Manual for 96 SLS
  184. moldings for passenger side 97 sts
  185. '94 Eldorado: Touring Coupe or base model?
  186. check engine light
  187. Illuminated Door Window/Mirror Control Panels? on 95 ETC?
  188. Setting Hood Height
  189. Safety Issue: Broken Steering Rack
  190. Post your horsepower. Or, how high can you go?
  191. '94 STS - Possible Transmission Problems?
  192. 96 sls a/c compresser shuts down on long trips
  193. '85 Eldorado Leather Seat Repair
  194. LED Stop Lights on '92 Seville
  195. Clock on the radio
  196. 96 STS New Official 1/4 Mile Time Smoked A Few Good Ones
  197. Wiper Blades Right Hand Drive 98 STS
  198. Transmission Problems - 92 Eldorado
  199. Discharging A/C system
  200. 1994 Cadillac
  201. 1994 Seville SLS Info
  202. STS Transmission "Whine"
  203. 96 Eldorado ETC Temperature Gauge
  204. what to look 4
  205. Post your mileage
  206. Spindle nut size 96 seville?
  207. ac condenser and rocks
  208. clicking noise from the throttle body
  209. Moldings For STS 97
  210. Center Console light bulbs needed - 96 STS
  211. STS/SLS Info Needed
  212. Molded Splash Guards
  213. '97 Seville Service Manual Question
  214. Traction control complete shutoff
  215. Do I have to...
  216. Interior Fuse Box Location- Please Help 98 seville
  217. Tach bounces at startup - '96 SLS
  218. UPDATE on driver's window not going up
  219. Driver's window won't go up
  220. Hurrah! Finally an easy job - fuel pump
  221. Error Codes: Any Easy Fix?
  222. Stubborn PO83 trouble code, Help
  223. 1 1/2 quarts low at 2500 miles
  224. 92 STS w/ 145K worth buying?
  225. 1992 Cadillac Seville Special edition
  226. Engine Quits without warning while driving
  227. 1999 STS Trouble Code DTC C1227
  228. 94 STS Blown head gasket worth fixing???
  229. Rear Tail Light Monitor
  230. Will It Ever Run Right?
  231. 95 sts brake fluid swith problem?
  232. Vacuum Diaphram/Hose Problem Heating&A/C System
  233. Cruise quit 97 STS
  234. rear stab links
  235. Looking for owner of Black ETC that was at NE Dragway on 4/30/04
  236. Installing / setting throttle position sensor
  237. 91 Eldo Turn Signal Chime
  238. Groan when turning left!
  239. I got smoked!
  240. Trans makes noise when starting
  241. Mustangs Respect the 96 STS NOW!!
  242. 1993 Seville head gasket problem?
  243. Seville 1993 Head gasket replacement????
  244. STS Power Seats inop.. HELP!!!
  245. Grille Emblems
  246. STS Stalls/Hard to Start
  247. 97 STS intermittent stalling, rough running
  248. Looking for a '96-'98 Eldo
  249. 1983 eldo
  250. Just had a 55' ElDorado donated to me
