- Towing with my STS?
- Looking for input on build quality
- 93 STS Chugs/Misses under load, idles fine
- 99 STS Trunk Swimming Pool!
- 76 Eldorado vinyl top problem
- '92 Seville, lost lighting on speedo and tach while all the ...
- instruments don't work
- someone mixed antifreeze on me
- 93 Seville Heater Core
- Service Theft System....PCM Codes
- 95 seville oil change
- Strange vibrations
- '95 SLS Runs hot, then not, now hot again
- Stuttering
- It's embarassing when your STS won't start
- Gap setting on spark plugs
- MINT 1979 Cadillac Eldorado Britz Parts For Sale
- No start - clack clack clack clack clack . . .
- shift solenoid 1994 seville
- I Need Help!!!!
- Replacing Fuel Filter
- Stuttering in 3rd gear
- 99 STS door speaker
- Selling my baby.
- Radio Wood Trim
- How important is rim size?
- thanks everybody for the help
- underhood rad/grill cover?
- Please Help
- Need some opinions about buying a 92 seville sts
- A/c And Heater Blower Will Not Work
- need some know how on my cadi PLEASE
- Goin to Carolina in the Morning....Jas Taylor Song
- Storing My STS
- "CHECK BRAKE FLUID" message in DIC.
- Looking for 1998+ rear belts/shale/all
- Need Clifford Hyper 9!!! HELP!!!
- needed: Rear bumper insert...
- 99 sts extended warranty
- Driver Side A Pillar Removel
- 1996 Cadillac STS
- Selling Chilton Guide for 90-98 Caddy
- Cadillac Seville - Vote Now - Appearance Only
- Increasingly low MPG.
- 93 Eldorado surging lights...
- transmission servicing
- codes for 2000 eldorado?
- Door Lock Problem
- transmission and other problems
- Analog Speedometer error. Can it be fixed ?
- 92 4.9 no start, help!
- Why doesn't anybody take pride in their work?
- STS 1996 Steering Wheel Alignment
- tranny problems
- how to enter diagnostic mode
- experiences with car covers
- Cornering lights missing in the European version
- removing door panel of 1988 seville?
- Alpha and Omega for the Seville
- 1992 Seville/Deville Owners....HELP
- oil message?
- 98 ETC Transmission/Drivetrain Problem, PLZ help...
- Eldorado Wheels
- '78 Eldorado Biarritz Advice Needed!!!!
- 1998 Seville Air Bag/ unreported collision
- 94 Eldorado - Need Center Wheel Cap + Locks
- 97 Seville - Driver window wont roll back up.
- Erratic Inst MPG
- seville sts phone
- Humming Noise From Front End While Moving
- Post in classifieds?
- 97 STS - time to mod
- Parking Brake Problem
- anyone have a 95& up front bumper cover for sale??
- Hello everyone!!
- Black Leather Shifter for 93 STS Needed
- Noise when AC Running
- EBTCM - where it is?
- idle throttle angle ?
- 2000 Eldorado...30k mile maintenance & brake ?
- M5board.com pissing in their pants about the CTS-V
- ELDO fan LOOK!!!
- Where to buy emblems?
- '94 eldorado...worth it?
- what are selonoid blocks
- ABS light and Traction Disabled
- pcm tc0073
- Retreive service codes on a 98 seville
- 98 eldo antennae
- CarFax Report
- How to change PCM?
- STS Ride Control Problem
- Anyone Interested In Buying a 94 eldorado etc,Pearl White,$3500 obo
- 92 Seville IPC
- Tranny Problems Or Traction Control
- Blown Head Gasket - Where to Fix? (GA/ALA area)
- Airbag codes - what to do?
- Pulling Codes on a 92 Eldorado
- Paid $280 for Shift Solenoid at Dealership...Too Much??
- 2-3 Accumulator
- Gas Gauge
- TRACTION CONTROL!!!!!!!!!!!problem???
- 92 Seville
- Please Help Can't Set IPC Overrides
- Wondering part name...
- Fixed AC Problem
- Codes on Dash Board Reader
- Disable air bag system for radiator r/r
- Fuel Rail Recall Update
- Trouble Code P0717
- A/C low msg PLZ HELP
- need help with trouble codes
- 1985 Eldorado Enging Swap
- confusing diagnostics patterns
- 1979 Seville Diesel
- 1992 Eldorado Body
- Leather Seats 1995/1996 - Difference?
- I am getting my Car back..LOL
- Speed Sensor Fault
- 95 Seville-mice in blower motor
- how much should it cost to rebuild
- 96 eldorado
- Heavy steering at slow speed
- HELP PLEASE! Need antennas(s). '90 and '95
- Service Stability SYS
- I need Lower ball joint tips
- Need headliner help
- 2nd week of ownership, sts will not start. Help
- STS Soaked.
- New caddy ower
- Front end noise
- Regarding paint codes/fixing paint nicks.
- RainSense ??? -- Bbobynski ???
- new caddy owner
- Question on Y/9 Transmission or Transaxle Swap in '00 Eldorado ESC
- '00 Eldo ESC Needs Help with IPC Overides
- New Slotted Rotors Installed!!
- shifter handle
- Speed Sensor Fault ? Code pc0503 & pc0603
- Trans shift problem 94 sts PO24 code
- Stability Reduced
- Window motor
- 94 ETC - "traction control enabled" - ALOT!
- Tranny Infor
- The Tool
- 96 eldorado problems with transmission
- 2001 STS - Service Stability System
- P094 and P137 together
- ECM or PCM?
- 94 STS Ignition switch won't turn to off
- STS Foglights Useless?
- Reprogramming a new cluster with my old key
- Need caddy original mats!!!!
- DOT-3 or DOT-4??? Seville 90
- Part(s) NEEDED. Power Antenna Eldo '90&'95
- CARFAX - 92 Eldorado
- I'm an ass
- Need Coolant Surge Tank For 97 Cadillac
- Another cluster question
- Carfax Needed Please
- Programming a new ignition key
- Coolant Surge Tank
- 96 eldorado codes
- *caution* when lowering sts....
- pulling codes
- Help, need seville 90 owners manul!!!!!
- Help! Brake light problem... seville 90
- Need IPC for 93 sts seville 4.6 North star
- About to purchase a 95 eldorado,what should I look for???
- New Member Post
- cloth roof on etc
- 96 Eldorado ETC
- Lowered STS rear bushing gone..
- major tune up for 99 STS
- A really serious failure - help please
- Problem with wipers
- 92 Eldorado power steering pump removal
- '98 SLS steering wheel buttons
- Carfax
- Small door in rear seats
- 98 Seville 02 Sensor
- 92 ETC Overheating problem???
- 93 Seville No headlights, fuse box question
- can't wait!!
- Break lamp indicated on panel !!!!!!
- 25 mpg on 900 mile trip
- New Member - 96 Eldorado ETC
- Looking for distributor for 86
- painting my wheels?
- This car climbed Mt. Washington.
- Transmission Fluid Changed
- '94 Eldorado Oil Pan
- Cleaning sunroof rear drains/96
- 99 STS climate control display
- Rear window defogger
- Need Some Help Selecting New Car
- A/C problem code A012
- Paint Job?
- Speakerphone in car.
- Bizzare radio countown & battery drain
- Bank 1 sensor
- Engine block heater
- Air shocks
- transmission question
- New pics are in!!!
- 1990 Seville
- Classy Car Clubs?
- Bad gas mileage?
- I need some opinions!
- Seville Cup Holder
- 1993 Seville STS
- 2000 Seville Shift Knob Replacement
- Eldorado transmission codes
- Cadillac 1995 SLS transmission problems
- What can I do to my car?
- I AM BUYING A 94 SLS & I NEED SOME HELPFUL INFO
- 1993 seville blower not working
- Help With Cluster!!!!!!!!!!
- Transmission oil life still at 100%
- Universal Catalytic Convertors
- Newer Style Seville Rear Mirror w/ OnStar In
- Why do you love your STS?
- battery and radio probs
- 97 Eldo Power Driver Seat Problem
- Quick Help Please!!!!
- Ac
- First time drag racer!
- Strange starting problem
- Dip Stick
- is it worth buying 99 STS with high miles?
- Eibach Suspension Upgrade
- 92 seville keyless remote question
- Fading Of Power
- STS Radio/Nav System
- Service Transmission
- I want a Northstar in a 1991 Seville
- Problem Starting after Tuneup
- Spy Shots of the "New" Eldo & Seville - In 1990 that is!!!
- Newbie needs help
- 93 Seville in need of some advice
- 92 seville a/c condensor
- stop by cop for looking at cadillac
- instrument cluster light replacement
- Better Gas Mileage?????
- 1977 Eldorado Biarritz Convertible ?
- 1968 Fleetwood Eldorado(I want pictures of them)
- Starting Problem
- How should climate control work?
