View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. IO, IO34, IO37 codes
  2. Potential 97/98 Eldorado Buyer PLEASE HELP
  3. Transaxle Oil Life
  4. 94 Eldo ETC Northstar Will Not Start!
  5. '98 - '03 Seville: Difficult to read dash in bright sunlight?
  6. AC blows hot air to driver & rear seat - cold air to passenger
  7. Intake Setup Opinions Needed
  8. '94 STS aftermarket exhaust
  9. is premium fuel really neccassary
  10. Dash trim disassembaly
  11. traction control probs
  12. No cup holders in STS?
  13. my A/C Air gets diverted under hard accelleration
  14. new here, with a question :)
  15. Strange sound when I turn
  16. no interior lights
  17. STS keyless problems
  18. My SLS pics
  19. I need help on codes for a 1999 sable black Seville STS
  20. Eldorado Start Problem...Anti Theft??
  21. Noise at Startup on Northstar
  22. Problems with a 96sts only had it 2 months
  23. blower motor 1997 seville
  24. Need A Transmission Recommendation On '81 Diesel Eldorado
  25. low oil pressure/"stop engine"fighting with dealer
  26. winter driving in a etc/dts/sts;advice sought
  27. Eldo Grille change
  28. New Pics
  29. A/C Question?
  30. NOT happy with the wrecking yard...
  31. 94 Eldorado dash lights flickering
  32. How much would it cost?
  33. Need Radio Cover for Eldorado 94
  34. Recall 96 Seville SLS
  35. Z rated tires... really necessary?
  36. A/C R134 Leaking Off
  37. Fuel Injection System
  38. Coolant temp readout
  39. Can't find my trouble codes in list
  40. starter
  41. what year sts?
  42. Error codes?
  43. Crank sensor "B" 2000 ETC location?
  44. '98 Seville stalled again-Wife PO'd
  45. Where is the lower radiator hose?(99)
  46. If all cars have a reputation/personality, what is my 96 STS?
  47. Aftermarket Suspension
  48. Front End Squeak
  49. '98 Seville stalls
  50. Lube points on a 1999?
  51. Transmission Solenoid problem won't shift out of 1st gear
  52. Tranmission help!!!
  53. Replacing Strut Info. ,from Monroe
  54. Tachometer speed vs. real speed
  55. Alternator Replacement??
  56. Alternator Replacement??
  57. 90 Eldo, won't start, where to begin?
  58. does dealer know ???
  59. Offset on 2000 STS rims same as 93?
  60. Can't find a muffler for my 92 Eldo...
  61. WTB: 97 STS WHat should I check
  62. STS jacking
  63. Help with purchase
  64. 2000 ETC crankshaft prob
  65. 96 ETC Trunk Won't Go Down... :-(
  66. dvd player in dash for sale or trade
  67. billet grill for sale eldorado
  68. sad,sad day
  69. fuel gauge read full - tank empty!
  70. no heat
  71. Knocking/Pinging in 91 Eldo
  72. What did I do wrong??
  73. Lowering On AIR
  74. Sorry--Newbie question on Traction Control
  75. I hate to ask the n00b question but about the Seville...
  76. Need some help with my Eldo
  77. New Member, Old Family Caddy
  78. Considering a 1994 STS
  79. 1997 sts heater not working !! help please
  80. I Have questions
  81. 13s 1/4 Mile Project
  82. 1984 Eldorado trim
  83. Return of the Eldorado?
  84. Option codes etc.
  85. 98 Seville air filter replacement
  86. A/C low pressure switch bypass procedure
  87. 1992 STS won't start
  88. 93 STS Transmission code P056 help?
  89. '95 STS problem (trans. codes)
  90. Slightly Interested.......
  91. To timesert or not to timesert!?
  92. alternator problem, i think
  93. Torque specs.
  94. 2002 STS with BOSE radio
  95. a/c charge check
  96. small black box on windsheild behind mirror
  97. Driver's Side Window Ain't Working
  98. Please Give Direction Coolant Goes Temp Up & Down Fast
  99. Info Needed ASAP
  100. How do I remove the gearshift handle On a '95 STS?
  101. Motors coming out today
  102. replacement door panels
  103. Your opinion: Dextron 2 or Dextron 3???
  104. car thump
  105. Alternator Problems? 94 Eldorado
  106. stalling
  107. Tune Up Schedule
  108. 96 elorado
  109. Turn Signals & A/C
  110. 1992 STS won't start
  111. Driver side mirror
  112. "Front Door Ajar" warning keeps popping-up
  113. Another new guy...
  114. what is used to determine the error codes
  115. RIP...Diesel Caddy
  116. Trouble Codes
  117. 93 STS / Thin chrome strip on door molding
  118. 1992 STS won't start
  119. Just how reliable are Seville's?
  120. It's Over
  121. Switched 12V in 01 SLS
  122. Fuel rail recall
  123. 1985 Cadillac Seville Power Module
  124. Power Mast
  125. 1997 STS Build sheet
  126. First race night with the STS
  127. Apperance ?'s
  128. Freaky brake lights 95STS???
  129. 99 STS "Exit" memory not working
  130. 99 STS lumbar and adaptive control
  131. Need your advice!
  132. How to Fix these.........
  133. Used motor...timesert or not?
  134. 94 Eldo - Will the Analog and Digital Cluster Interchange?
  135. Replacing Ignition Coils
  136. Offset and bolt pattern
  137. New guy 2002 STS questions
  138. WTB a 99STS What do I need to be on the lookout for?
  139. Help With Interior Lamps
  140. motor mounts
  141. Drain cock on radiator will not seal
  142. Changing coolant...Easy question
  143. '97 STS troublespots
  144. '98 Eldorado ELC Performace Options ???
  145. Is this the right Bar's tablets?
  146. Steering Problems
  147. 92 eldorado starting problem
  148. difficulty on changing INNER TIE RODS
  149. 1987 Seville Instrument cluster
  150. Road noise 1998 SLS
  151. '94 Eldorado ETC Is Sputtering
  152. 93 Eldorado ETC alternator?
  153. $11k for a 2000 Eldo. convertable!!!
  154. AC Control Problem?
  155. BBOYinski it wasn't the Waterpump, it was the Compressor ($902)
  156. HID Convertion kit
  157. You have GOT TO check this out!
  158. Painted tail light panel- WOW!
  159. Alarm activated on manual key entry (RKE stopped working)
  160. Diagnostic Codes
  161. 96 eldorado
  162. 1997 STS Speedometer Calibration
  163. case halves oil leak???
  164. Need help with figuring out car. 1998 STS
  165. 1998 SlS Help!
  166. What Is This
  167. Engine & tranny rebuild kits
  168. Vehicle Code Names
  169. Eldo Eating BAtteries
  170. Need help diagnosing b1324 code
  171. WTK: Value of Cadillac Opera Coupe Fake Spare Tire Hubcaps?
  172. FREAK Seville !
  173. installing a system in my 93 SLS
  174. service ride control
  175. Change Engine Oil message
  176. who and how do I test road control
  177. Reprogram computer? Should I do it and can it be done?
  178. would you recomend an sts
  179. Wipers not functioning
  180. Too bad I didn't change the coolant in time
  181. pics pics pics
  182. leak
  183. Brake light problem
  184. 85 Seville
  185. Service Emission System
  186. 01 sts driver 1 name change
  187. Sad Day for Chuck C :( Need Hugs
  188. Inspection again or "these guys don't know how to disable traction control"
  189. 77 eldo into a convertible
  190. tail light
  191. Magazine Articles
  192. 1992 seville side marker lamp?
  193. Wont shift...
  194. STS Wallpaper
  195. HELP! 1991 El Dorado Brake Bleed Problem
  196. Power Mast
  197. Ride control module dead
  198. Cadillac - the brand that is truly built like a rock.
  199. sound distortion
  200. front end noise
  201. 1976 Cadillac Eldorado For Sale
  202. Lowered Eldorado
  203. seville tranny
  204. Cooling fan fault
  205. dash noise
  206. Crankshaft Sensor
  207. 95 STS has haunted gas pedal!!!
  208. 3 Questions-Dash lights, dieing, cruise control
  209. Did a tune up...engine light came on
  210. Pearl White 96 Eldo 66K miles $7700
  211. 1997 Seville STS Air Conditioning Problem
  212. Oil Consumption
  213. p076 and tranny wiring question...
  214. frnt engine mount troubles
  215. What's the best brand of engine oil and fuel to use in a Premium Fuel Only N* engine?
  216. Wait 3 minutes before starting car
  217. Warranty
  218. speed limited to 90????
  219. Ebay Air Intake
  220. New Guys 1st caddy
  221. MY 93 ETC,Display says battery no charge,whats that mean???
  222. i want to see some eldo's with 20 pics
  223. '98-up STS exhaust size?
  224. Dash pad out of location
  225. Coolant Flush - How Many Suppliment Tabs Do I Use?
  226. 89 Eldorado-High idle
  227. how to calibrate a/c?
  228. Check engine light on 95 sts
  229. A/C Blower Fan Quit, bad smell
  230. Carfax for me?
  231. 96 Eldorado Airbag and Transmision Problems
  232. 94 SLS Location of Parking Brake Release Handle
  233. How long would an 87 Seville last me?
  234. 1996 Eldorado Breaks
  235. 96 and 98 Eldorados
  236. Hey Guys
  237. Security Light,rough running and power loss
  238. Towing with my STS?
  239. Looking for input on build quality
  240. 93 STS Chugs/Misses under load, idles fine
  241. 99 STS Trunk Swimming Pool!
  242. 76 Eldorado vinyl top problem
  243. '92 Seville, lost lighting on speedo and tach while all the ...
  244. instruments don't work
  245. someone mixed antifreeze on me
  246. 93 Seville Heater Core
  247. Service Theft System....PCM Codes
  248. 95 seville oil change
  249. Strange vibrations
  250. '95 SLS Runs hot, then not, now hot again
