View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Watts?
  2. '95 STS Traction Control/ABS Data Loss???
  3. 93STS intake manifold exploded
  4. Sts 1994 Fuel Injector Size ??
  5. I've never seen this before
  6. 91 Seville 4.9 dead in the driveway...
  7. Cupholder Assembly
  8. 1980 Caddy Eldorado / $800 / 100K
  9. Rims for a 92 STS
  10. ANY performance mods avalible on 95 SLS???
  11. Service Engine Soon Light Codes???
  12. Exhaust Sounds
  13. 1999 STS decision time
  14. Service Stability System?
  15. Does this sound like a fuel pump?
  16. oil leak
  17. Timesert/nutsert
  18. No heat need help
  19. Exhaust tips
  20. Shift knob will "NOT" come off
  21. Front Grill
  22. P036 error help
  23. Air Mix Doors
  24. Changing Plugs/Wire on SLS Watch Out!
  25. tranny fluid
  26. Door Alignment
  27. Ignition Switch Replacement Help
  28. car wont start help please!
  29. Seville ride height
  30. Any one riding 20's ????
  31. Long Trip/coolant leak
  32. Torx Size 98 Seville Striker
  33. bulbs in dash?
  34. 93 STS backfire, is this major?
  35. 98 STS Error Code P1350?
  36. Auto dimming rearview mirror won't stop
  37. Ultrasonic Rear Parking Assist/New rear bumper
  38. 1996 Seville SLS won't start. Need HELP Please.
  39. help !! ODBII code answer...
  40. Resetting Stored Codes
  41. How many miles does your Northstar have ?
  42. Optima Yellowtop
  43. Exhibition of Speed.
  44. 2002 Seville shifter removal
  45. Problem With Headlights At Night
  46. climate control questions
  47. 94 eldo casette to cd change?
  48. Wanted !!!!!!!!!!
  49. Serious transmission problems - 97 Seville STS
  50. Hard brakes
  51. 94 ELdo tranny problems
  52. STS Gold package: does anyone have this option?
  53. Need help, '96 Eldo
  54. Removing Eldorado Headrest
  55. Power Steering Filter - '96 Seville SLS
  56. Car surges upon acceleration
  57. Spray On Chrome?
  58. CD players in 81-85 Eldorados
  59. Blown head gasket!!!!!!!!!!!!!!!!
  60. Extremely Rare 1957 Eldorado
  61. Eldo Grills
  62. vacum on top of throttle body.HELP!
  63. 72 Edlo wheel specs?
  64. Plugs, Plug Wires, Prices at the Dealers
  65. Adjustment for automatic lights on
  66. Noise under the dash
  67. 97 Seville sls electrical problem
  68. STS Fog lamp bulbs..
  69. need help please
  70. 96 ETC Front End Problems...
  71. Light Question
  72. Input on Brake Rotor please
  73. 91 Eldo trans help
  74. Rattleing front left side.
  75. More than 50% coolant bad?
  76. Help, choke adjustment Eldo 1978
  77. I know what my DTC codes are, now what do I do with them?
  78. 91 Seville, Driver's side window sticks
  79. Chrome coating?
  80. 91 eldorado trunk close problems...
  81. Transmission Engages Driveline in Park on Startup?
  82. 2001 STS Vs. 2005 300C Hemi
  83. V8-6-4
  84. STS 1994 Code P076 still alive! Help PLZ
  85. Keyless entry
  86. firewall hole
  87. ABS/Traction light after installing strutmaster
  88. For Sale
  89. Miss, Sputter, Hesitate
  90. 95 ETC Color code
  91. Why is old badging so expensive? (where else to get it?)
  92. 1994 Sevile heated seat -passenger side not working
  93. need some help >>94 Eldorado
  94. 1992 Cadillac Seville problem
  95. 1989 4.5 Eldorado-oil light index
  96. Thunk from trunk?
  97. Should I facelift the 96 STS Despite wife's objections?
  98. Please help with engine swap
  99. good deal for Cadillac owners
  100. Oxygen Sensor
  101. Stolen STS
  102. Quick reply needed
  103. Where to buy OEM parts?
  104. Performance?
  105. Fogged up tail light
  106. Finding codes on a 97 SLS
  107. '93 Seville...What Does This Mean???
  108. Can't get rear strut out
  109. Fs: Hood - 1995 Cadillac-sts
  110. turn signals..
  111. Another 85 Eldo Question
  112. Just bought a 94 STS. Won't shift / check engine light comes on
  113. 85 Eldo Baritz Question Helpp
  114. 84 Biarritz
  115. T033 RR Wheel Sensor Continuity 95 Eldorado what to replace/repair?
  116. Visual Keyless Response
  117. Green headlights?
  118. 92 Sedan DeVille Cooling/Stalling problem
  119. Used fuel info is lying?
  120. XM Radio for 2000 Eldo ESC?
  121. Stupid question of the day
  122. Loud Grinding noise
  123. Need an Odd Part
  124. I got P040 code and 'service engine soon' light on, need advice
  125. WTB: '95 STS CD ROM manuals
  126. ISC motor acting up...clicks and buzzes...
  127. Torque conver 442 Deg. Celcius??
  128. '93 STS: problem spots?
  129. PCM test
  130. STS in the woods..
  131. New Car, Some questions
  132. Looking for advice
  133. Dic
  134. Fuel leak, need help
  135. Help with codes?
  136. Hesitation and Jerking
  137. code pcm p1520 1998 seville sts
  138. New Cadillac Owner...
  139. Sts Recall On Fuel Rail?
  140. Power Steering Problem
  141. Tire Size Is Critical to ABS/Traction Control Fault codes!!!!!!!
  142. Caddy STS VS, Acura Legend...reliability wise...
  143. Code check questions
  144. '85 Deville Door Stuck Closed
  145. flashing check engine light - bad news?!
  146. Cup Holders
  147. Info button illuminated?
  148. Clicking noise in right turns in 94 STS
  149. '94 Eldo poss part out , redone Northstar
  150. '78 Eldo oil change question
  151. Heated Seats
  152. Cooling Fan Problems 98 Seville
  153. 1981 eldorado door panel
  154. 1993 sts shop manual
  155. 1992 Seville STS Questions.....PLS Help
  156. Is it worth fixing?
  157. Videos...
  158. 92 Eldorado front bumper cover?
  159. Heated seat not working?
  160. CARFAX If anyone needs
  161. Caddy 440T4 Tranny for sale...
  162. long starting time
  163. Drivers Window
  164. Cadillac Seville 1979 5.7 Diesel~~HELP
  165. RCA Inputs In Glove Box`
  166. Am I missing something? How do I remove the shift knob? '92 sts
  167. 1978 78 Eldorado Wiring Diagram and parts needed
  168. Light oil smell when idling 94 STS
  169. EGR valve location..01 seville
  170. 92 Eldorado wont start when cold
  171. 1980/1 Caddy Seville Throttle Position Sensor
  172. Had the STS 6 days, little probs creepin' in!
  173. Peeled paint on the engine...
  174. 93 seville 4.9 blower
  175. Headrest motor does not work
  176. Looking for chrome!
  177. 93 seville STS 130K..$500 bux
  178. Fluctuaiting RPM's
  179. Digital Dash
  180. 2000 Eldo Stereo Question
  181. '85 eldorado: problem spots?
  182. Looking For Clean Cadillacs In Great Shape With Low Miles And Loaded
  183. Unbearable resonance in sound system
  184. Doral vinyl top
  185. Water pump, and fuel octane
  186. Hesitation Accelerating
  187. Battery No Charge Message
  188. New Fueltank
  189. Getting factory certified?
  190. Where to find new Northstar Engine
  191. Braking w/ tranny
  192. 01 STS heated seat not working....
  193. 93 STS transmission
  194. 98 SLS speaker replacement, dash removal???
  195. 1994 STS courtesy lamps
  196. 84 Eldo fan won't shut off! HELP!!!
  197. Sweet! My '94 Eldo just exploded!
  198. Trailer wiring, '92 Seville
  199. Front End Hum ??? Help!
  200. U1128 - Loss of Communications with IRC
  201. Proud new owner of a 94STS! Any more hints??
  202. looking for new to me sts; 97 or 98?
  203. What is a fair asking price for '89 parts?
  204. Probelm with sunroof
  205. Rainsence issue & Plug Wires arcing
  206. 93 STS Manual good for a 97 STS?
  207. Heater runs constantly on 93 STS
  208. 94 Eldo trans code PO56
  209. How can i pull codes on a 95 Eldorado on the cluster?
  210. power steering wheel tilt inop
  211. Weird Wheel
  212. 1994 STS Cruise Control Problem! HELP!
  213. "95 Seville Codes
  214. Unknown Code
  215. Heated windshield
  216. Good Exhaust Systems
  217. Question about testing ISC motor
  218. cps or bcm??
  219. Transmission Knock/ Bang
  220. Please help, new sts owner....
  221. change oil soon light wont go off!!! HELP
  222. 2000 STS fogged headlight
  223. "Rattle" Sound On 1994 STS
  224. Eldorado -96 Starting problem
  225. looking at 94 STS-thump at high speed-would like some advice
  226. $700+ Eldorado Solenoid Repair in Seattle
  227. Back Door locks
  228. Where are VIN located on 2000 STS?
  229. 1999 STS - Potential Suspension Problem
  230. 1985 Eldorado Biarritz - need help!!
  231. 98 sts starting problems
  232. fuel rail recall/water pump
  233. Squeek?
  234. 92 STS SERVICE ENGINE SOON code 3?
  235. Instrument panel message 83 - Service Airbag system
  236. Hub/Bearing replacement leads to CV damage?
  237. ETC vs Eldorado????
  238. Where to get Car replacement part
  239. Eldo heated windshield
  240. Late Model SLS or STS
  241. the new kids kaddy
  242. how do i put BMW Headlights in my 92 sts?
  243. Were can i find after market stuff?
  244. The new kid needs help
  245. 4 sale 1996 eldorado etc ,new jersey
  246. Need help with replacing my eldorado's shift knob
  247. 2002 STS transmission shifter clicking in center counsel...
  248. Hit 190,000 miles
  249. Remove dash on 88 eldo
  250. 2001 SLS tranny slip
