View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. cold driver hot passenger 93 seville
  2. What's the difference between 94 and 95 intakes?
  3. 98 Seville STS with a rough idle and slow acceleration
  4. 4T80E trans gear ratios?
  5. after market struts
  6. Heater Problems 93 Seville
  7. IPC fault??????
  8. 96 eldo traction control light
  9. ´95 Eldo drive restless !
  10. Code Question
  11. looking at 93 sevill codes po45 and po46
  12. Dumb Question Probably
  13. Difference between an STS and SLS?
  14. Free: 92 Seville Owners Manual
  15. Dam ashtray wont work right / 93sts
  16. Front struts from Strutsmaster - 97 Seville
  17. clearing out the headlights on seville/eldo?
  18. headlight alignment 97 SLS
  19. Heater Core
  20. 2000 sts cluster into 1993
  21. List of Codes
  22. Rough Idle at Cold Start - 98 ETC
  23. Tune up
  24. Air Filter behind Evaporator 97 Seville
  25. Extended Warranty
  26. Seville cd/changer
  27. Air Filter behind Evaporator 97 Seville
  28. 98 SLS turn signal lense fell off!
  29. 1984 Eldorado/windshield wipers
  30. Daylight running lights
  31. NO First gear
  32. carbon clearing
  33. Last Friday, Thought my 99 STS tranny went out. It was really a broke axle.
  34. Outside temp
  35. instant mpg
  36. Hard starting seville
  37. 1992 STS 4.9 Where is my gas going???
  38. Looking at a 96 STS
  39. Trunk Leak 2000 Seville
  40. 96 Eldo codes
  41. Coolant Leak / Head Gasket
  42. Finally removed that stupid resonator
  43. Tranny codes in 94 SLS
  44. 2002 Seville heated seats
  45. Windshield Washer ? 1994 STS
  46. Mufflers for Seville???
  47. Sandy, 2002 STS 57,000 KM for $29,000CDN
  48. 02 Seville Trunk Space
  49. 1981 Seville Elegante factory window sticker
  50. Trunk Latch 95 SLS
  51. How should I condition my new ride?
  52. Heater control lights
  53. Baby Blue Eyes
  54. Exhaust for 1996 STS???
  55. Annoying Underbody Knock
  56. Spark plugs or common
  57. Leaking Head Gasket!!!!cover me, i'm goin in!!!!!!!!!
  58. 1957 Cadillac Eldorado Brougham = drool
  59. Removing Housing Around Shifter / HOW???
  60. Interior Lights Stay on
  61. OBD ll?
  62. Drove my 99 STS to the store, tranny blew out and had to walk home.
  63. New car for a 23 year old bought from a 63 year old
  64. 93 seville sts for sale
  65. Play In Shifting Linkage 84 Eldo
  66. 1976 Seville Fuel Injection Problem
  67. Exhaust for 94 Eldo
  68. 99 Sts Front Wheel Bearing..
  69. 2001 STS Extended Warranty
  70. traction control
  71. U.K. Forum Members
  72. (Help) EGR problem
  73. Blower Motor for 95 Eldorado. Cadillillac or Chev?
  74. 120$ for an oil change?!? Damn Stealer!!!
  75. Tighten Rearview Mirror / 93 STS
  76. Found reason for rough idle and stall issue
  77. MRC anyone?
  78. 76 to 79 Cadillac Seville information
  79. Shifting Problem 1984 Eldorado
  80. Another headlight question
  81. 2002 STS Navigation
  82. still hve coolant issues
  83. mileage readout
  84. Shifting "bump"? (currently test driving '98 SLS)
  85. WTH, alternator removal, maybe, 94 eldo
  86. Upholstry peeling off the walls...
  87. nuthin but probs from the eldo
  88. shit, didnt know there was std eldo out there
  89. 95sls no start condition
  90. 95 Eldo, heater
  91. (I need help)Replacing a starter in a 96 eldo
  92. Finally Fixed but some minor problems
  93. 2000 STS Dash Removal
  94. Coolant inlet & outlet on trottle body
  95. 1994 STS Reborn !!!
  96. 97 Seville STS
  97. Need 2 accessories -Cadillac Seville 1990!!!
  98. headlight plastic clip, retainer?? 94 eldorado
  99. Check Fuel Gauge warning?
  100. 94 STS and a few questions /problems
  101. Inner metal part of cigarette lighter got unscrewed and came out
  102. Fast Chip for my ETC????
  103. 96 SLS Smoke behind the steering wheel?
  104. PC1660? any clues sorry for being a pest
  105. how do you reset the service engine soon light?
  106. Are wiper arms splined?
  107. 96 SLS code?
  108. Rear Coil Spring
  109. air intake trouble
  110. 2000 STS Instrument Cluster Problem
  111. ETC in the Blizzard
  112. Goodbye 2000 STS!
  113. Service Manual 2000 STS
  114. Snow & Traction Control
  115. 1997 Cadillac STS Check Engine Problem
  116. Strange coolant leak 92' STS
  117. 95 STS Dies When you are driving?
  118. smoking eldorado
  119. 97 Eldorado Headlight problem
  120. 97 Eldorado headlights
  121. which a/c compressor is better?
  122. Power Steering? SMOKE!
  123. ok 91 seville gone, 93 sts 77k for $4990
  124. Front bumper filler panel
  125. First snow job
  126. Anyone else have any probs with shifting down into 1st but indicator light says 2nd ?
  127. Info on 1949 360 cid engine
  128. Does anyone on this Forum own a
  129. 96 STS trunk popper doesnt work/valet off
  130. production numbers....Sandy....
  131. President Bush's 2005 STS
  132. CARFAX Again
  133. not sure.. rear main seal or crankcase 1/2 reseal?
  134. "Headlights Suggested" during the day??
  135. Should I buy this Eldorado?
  136. the eldo
  137. The ultimate Eldorado? Mosler Twinstar
  138. dub's
  139. Has This Ever Happened To Your Seville?
  140. help!
  141. Replacing Battery question and brand
  142. Help!! Coolant Leaking Under Engine Cover!??!
  143. New owner, finally!
  144. LEDs in Eldorado
  145. Disable DRLs on '98 Seville?
  146. Seville trunk will not close after being slammed!
  147. 1996 STS Back from the Dead (Transmission/Fixed Oil Leak)
  148. 95 Seville E-code headlights ?
  149. Color Change = Value decrease?
  150. rontide
  151. 99 STS SEVILLE Weird Noise
  152. Dash Rattle / 93STS
  153. 96 Seville electrical problem
  154. 99 ETC Wind noise around driver door
  155. 2004 Steering wheel on 1992-1996 car?
  156. Problems with 98STS, from power steering leak to suspension...
  157. Couldn't do it! Decided to keep my STS!!!!!!!!!!!!
  158. Buzzing Noise Drivers Side
  159. Strange idle problem?
  160. 1991 Seville Hood Ornament
  161. 2001 STS Questions
  162. Oil Service
  163. '02+ HID upgrade?
  164. Water pump problems
  165. AlumAseal
  166. Climate Control Flicker When Cool Outside
  167. Dca In Water
  168. help w 94 sls
  169. Please Help - Cracked Oil Housing Unit
  170. 95 SLS Power window switch illumination
  171. 95 Seville STS 100,000 mile tune-up
  172. Rare Eldo's?
  173. recomend wheel tire size?
  174. 98 Seville dash removal?
  175. Part # for headlight lens--good karma to you
  176. Windshield Washer Blues
  177. Cluster Removal
  178. changing rims on 02+ SLS?
  179. My STS Nightmare
  180. extra DIC functions
  181. Brake Pedal Hiss?
  182. 98 and up Seville SLS vs STS 1/4 mile??
  183. I'm stumped-feedback circuit low voltage
  184. 1990 Seville
  185. There's a New Caddy in My Family
  186. Moaning '95
  187. Transmission launching on start
  188. heat yes/no well maybe
  189. frosty windows
  190. instrument cluster, 93 STS
  191. Shake Fixed on my 2000 Eldorado ESC
  192. service engine light
  193. Who has the Fastest / High Horsepower
  194. Almost BBQ'd the Eldorado
  195. Heated Seats....or they were....
  196. AC compressor noise...
  197. New Heated Discontinued Windshields
  198. 98 Seville intake resonator
  199. PICS Of A Local Restored 1959 Eldorado Conv.!
  200. sts air ride leak ????
  201. can,t find horn
  202. Just a thought........
  203. New STS owner quick question
  204. Just bought 99 STS and it's doing some things that are making me nervous..
  205. ABS & TRACTION CONTROL LIGHT
  206. 2001 STS - Car won't start
  207. 2000 sls oil consumption
  208. Magnaride
  209. '01+ STS/SLS mileage
  210. Seville idling high rpms?
  211. Traction control - I'm worried
  212. I''m Frustrated /Window Problems /HELP!
  213. Fast oil leak--- pan top cap?!
  214. Factory service manuals, where to get them?
  215. 32V NORTHSTAR - Rear sticker??
  216. Front defroster vent rattling
  217. Is the STS faster than the ETC?
  218. Opinions on these headlights
  219. Why do you need to pull out the fuse for 30 minutes to get the car to start?
  220. Transmission maintance???
  221. 98 sls trunk full of water
  222. Northstar Engine Swap
  223. Seville STS 1996 - OIL CONSUMPTION!!!!!!
  224. EXP Code Language
  225. Won't Start - Electrical Sys? Battery? HELP! :-(
  226. Anti corrosion additive?
  227. Codes
  228. Factory cd changer wont eject
  229. Is there any interest in Carfax's again
  230. intermittent crank- no start
  231. Best Oil for the 98 STS
  232. Anybody Replace the Plugs in an 97 STS
  233. Engine Cooling Fluid
  234. TCS, ABS, Stability system failure
  235. Headlamp Help
  236. sls trunk leak?wheres the fish?
  237. Tranny Problems 94 ETC
  238. 93 STS worth selling for 94 Deville?
  239. Battery No Charge-94 STS
  240. Code E046
  241. Washer nozzle scratched my windshield!!!
  242. P0741-TCC Not engaging; How to troubleshoot
  243. 91 seville for sale 97k for $1650 Rare??
  244. 91 seville for sale 97k for $1650
  245. More Codes - Help Needed
  246. More Codes Help Needed
  247. I want to "Hook" my cadillac up
  248. '02 Seville windshield washer fluid
  249. Seville RainSense and BOSE RDS radio
  250. Did they damage my engine?
