View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Where does the 4T80E valve body filter go?
  2. NEEDED Eldorado air-dam / front bumper to radiator plastic piece
  3. Urgent: Delco Remy Alternator, or Must I Have ACDelco?
  4. 02 sls whineing noise sounds like a siren at start up
  5. 92 STS Exhaust and Air Compressor Problems
  6. Best Tire Size For 02 STS???
  7. 99 Cadillac Eldorado Rear end problems
  8. Acceptable voltage & Turn Sig. Prob.
  9. Tire Size Change
  10. 1990 Eldorado Radio Replacement Recommendations
  11. 1992 Eldorado rpm problem.
  12. Gauge Cluster Cover Question
  13. 98 sts dash guages and lights out
  14. 2000 STS electrical problem?
  15. Key and Remote
  16. Rough Shift (Jumping/Jolting like a manual)
  17. 2000 eldo alarm issue
  18. battery no charge
  19. rear view mirror acting funny
  20. Service Stability System
  21. 150,000 miles - The 'ol HG story
  22. Love it or hate it? Please comment: side window deflectors.
  23. Introduction
  24. Help Me Change My 91 Eldorado Motor Mount
  25. Cd changer problem 2000 eldorado
  26. Replacing a PCM
  27. Road Bumps Transmit to Steering Wheel
  28. Accessin the fuel pump
  29. ABS/Traction disabled-1993 Seville
  30. Air condition question
  31. I hear a clunk when I turn the steering wheel left
  32. Cadillac Package Deals For Fathers Day
  33. My STS is totalled because of a deer?
  34. Seat adjuster broke, need help finding replacement. Pic.
  35. Door Bose Speakers...
  36. 97 SLS w/ random high idle/rpm's
  37. Proper Fuel Pressure?
  38. 96 seville "service transmission' warning
  39. Anyone chromed there stock grill?
  40. Need help asap please!!!!!!!!!!
  41. "Service Suspension System" - Have code
  42. Getting access to the Cam Position Sensor on Eldo
  43. Breake pedal went down STS 98
  44. Broken ground wire, HELP me place what it goes to.
  45. AC only on front passenger
  46. Mid grade gas in a northstar?
  47. Recommendations for radio replacement
  48. 4T60E...a couple questions...
  49. Caliper in a bind! Please HELP!
  50. Triple Check Your Battery Connections!!!
  51. 1990 Eldorado Rear License Plate Holes
  52. trunk and fuel door open buttons not working
  53. Pics of my 2002 ETC
  54. my new to me 98 seville sts
  55. Is there such thing as a "Jet Wash" with cars?
  56. New ETC Owner!
  57. 2000 Eldo throwing a bunch of codes
  58. Funky Smell from air vents
  59. 1990 Eldorado interior color and/or code
  60. Need help! No HVAC blower operation
  61. Need Advise On A Code
  62. An alternative method to flushing transmission fluid! Is it safe?
  63. Any advice - strange problem for ignition pack
  64. Cadillac teddy bear collection
  65. Got a Problem
  66. Need a couple Eldo parts
  67. NAPA Bearing Quality
  68. Name change in DIC for a 98 Seville
  69. 1997 sls battery not charging.
  70. 100k Service What Do I need To Replace
  71. 92 Seville headlite switch
  72. 4t80e swap
  73. Something is missing and I don't know what it is!
  74. Cadillac STS vs ...
  75. coolant leak
  76. 99 STS Seat Belt Retractor
  77. Any way to make ac cooler?
  78. Eldorado Misfiring Need Help Bad
  79. 97 cadillac SLS air conditioning HELP
  80. Acceptable voltage
  81. Considering Buying a 1999 STS with these codes.
  82. 'Tis The Season...
  83. Emmissions Issues
  84. Keying the remote to the bose system
  85. Question for someone familiar with the '80s Seville
  86. 1999 Seville Bose Stereo Low-Frequency Response Problem
  87. help no headlights on my 92 seville
  88. Ash Tray door wont close
  89. Trying to diagnose "Low refrigerant" message...
  90. I had an excellent transaction with a used Caddy parts place....
  91. Bose Amplifier Replacement (RPO UX9) on 1999 Seville STS
  92. no power to ac compressor
  93. Torque Specs
  94. Almost 200K miles, oil suggestions?
  95. A/C Compressor Oil Amount
  96. Trim Repair?
  97. 94 eldo groaning noise
  98. Need some 95 eldorado knock sensor help
  99. Cadillac watches for father's day
  100. How do i align eldo driver glass
  101. Two More Questions: RF position sensor, short to ground?
  102. Need '97 Eldo ride height sensor pics
  103. Theft System - Odd Wiring Down Under
  104. 95 Eldo. Vacuum Hose Question
  105. Anyone on here ever replaced a trans in a 95 eldo N*?
  106. Help! Considering a 97 Seville STS with 180K on it. Asking $2400 but can do $2,000
  107. Differences in 90 and 91 models: Eldorado
  108. Wood/Dash removal
  109. Car won't start fuel problem
  110. 95 eldorado N* ride control
  111. It's pink....
  112. Service ride control
  113. No Codes for SES Light?
  114. Rust bubbles in paint, rear window molding Eldorado?
  115. Brake fluid switch?
  116. Rough acceleration
  117. can i add an aftermarket water temp gauge? and some other gauges...
  118. Picture Request: E&G billet grille(horizontal version)
  119. extended warrenties
  120. 97 STS PO101 Mass air flow sensor performance
  121. Help P046 Sputter at 80 MPH
  122. L/R Caliper difference?
  123. To much HEAT
  124. 2000 Seville SLS- couple questions from a new owner
  125. 2002 Seville STS Navagation
  126. Idle Speed Control Check
  127. whats going on with my window switch (video inside)
  128. A/C acting weird
  129. my 1973 Eldo Convertible
  130. Still having several probs. w/01 SLS
  131. Can,t get tc and abs lights out!!!
  132. air pump
  133. Dash Vents
  134. Are all eldorado coupes automatically....
  135. 97 Shifter on 95 Eldorado?
  136. NEW no charge question
  137. 2002 SLS no front blower motor
  138. wind deflectors for window frames... tacky or cool? worth $$$?
  139. Coolant Leak
  140. 98 Eldo- Suspension, Steering, or ?
  141. Part number for AC/GM Catalytic Converter
  142. TC and SECURITY lights on - 99 STS
  143. 1994 cadillac sts ac compressor
  144. Do I pay too much for this car?
  145. a series of problems..
  146. Video: what's this noise coming from?
  147. 2001 Seville Lowered and struts/shocks replaced, how bout poly bushings?
  148. 01 STS no cooling fans
  149. 99 parts on a 95 STS
  150. 2001 sts
  151. Rebuilding 1977 Eldo rear calipers
  152. What is the perfect transmission fluid change?
  153. STS / SLS comparable to...
  154. Tie rod ends
  155. just bought 1974 eldorado need help!
  156. I need a part # for window switch??
  157. 69 Eldo Information
  158. Hubcaps/Wheel Covers
  159. just bought 1974 eldorado need help!
  160. 95 eldorado northstar trans?
  161. Horn Sounds at lock
  162. Cadillac Seville & Cadillac Eldorado floor mats - free shipping offer
  163. A/C Compressor removal 1995 STS NSTAR
  164. Just bought a 1997 STS - have several issues, trying to diagnose, please advise!
  165. Is anyone problem free?
  166. Dash light flickering when brakes applied
  167. Removing Seatbelts
  168. 95 Eldorado N* cooling problems...
  169. service engine soon, Clicking sound?
  170. Shift Knob
  171. Is my 1999 Caddy sts double din
  172. 97 ETC Theft System Problem - Exp 33 code
  173. How do i shrink my pics to post here?
  174. 25k mile Seville SLS parting out - may be -
  175. How long have you owned your seville or eldorado?
  176. adding slick 50 to northstar
  177. Class 2 Data wiring short
  178. Need oil suggestions!!
  179. mirror mirror on the drivers door
  180. 95 sts a/c
  181. 1997 Seville SLS Strut Replacement
  182. Acm b1314
  183. An idea for Boost (maybe...) ?
  184. How to remove oil filter adapter???
  185. overheating
  186. Headlight door help on 68 Eldorado
  187. 96 STS swap to '00-'04 N*?
  188. Intermediate shaft p/n for STS 2001
  189. 1992 Eldorado code E053
  190. C0625 current
  191. classic caddy question..
  192. Stability Problems!!!
  193. LED Brake Light 1/3 not lighting up
  194. Octane Booster: Is it Good or Bad?
  195. codes
  196. Banging Noise
  197. No Brake Lights except the Strip
  198. What's the temp...?
  199. Sunny and 71 Degrees - What to do?
  200. another window problem
  201. Plumbers Tape for Tranny Lines?
  202. post pics of your tint please
  203. Ignition Lock Cylinder Removal
  204. AC problem--cleared ACM codes and compressor still won't engage
  205. I did a stupid thing...
  206. MP3 attachment?
  207. Question on El Dorado
  208. Engine knocking with Premium fuel.
  209. 97 STS strut R&R
  210. Fpr
  211. Rotary Engine Noise from Tire
  212. 97 sts??plzz help
  213. Wierd, Loud noises.
  214. Help no power!
  215. 98 STS DIC/Odometer Dead
  216. Service Engine Soon - After Dealer Install of new Struts
  217. '95 Ellie May Pics 42K
  218. adding slick 50 to northstar motor
  219. Strange Overheating Problem
  220. Cd Changer magazine cartridge
  221. Window regulator mod sts
  222. CTS demo in China
  223. Why does my car idle high for 30 seconds then stop
  224. Im looking at a 2001 Seville STS
  225. 97 Seville low fuel pressure ?
  226. N* Plug & Wires Recommendations
  227. how hot should northstar motor run
  228. newbie puzzled over cruise control
  229. 97 seville temp gauge and other
  230. THE most CRITICAL part on your Cadillac is....
  231. Brake Fluid Leak
  232. Question on 95 Eldo Head Unit
  233. CD Changer magazine 2001 Seville STS & Analogue Onstar
  234. Ladies Cadillac Logo Apparel & Gear
  235. 1990 eldorado interior center access??
  236. engine misfiring
  237. little black squar passanger side front seat area underneath glove box near the floor
  238. bose speaker 99 seville
  239. radio swap
  240. Pictures of my ETC and a question.
  241. oil pump 1994 cadillac sts
  242. rain sensing wiper sensor fell off
  243. 00 SLS Vibration and Hesitation...
  244. Bubbles on new tinted windows normal ?
  245. 2000 etc
  246. Bolt rusted to rear strut rod on '91 STS...suggestions?
  247. I notices somting plastic on the inside of the trash area for the drivers door panel
  248. now i know why my window wouldnt work!
  249. SES but no codes
  250. big ****in problem
