View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. how to change water pump on 92 sts w/ 4.9
  2. parts interchangeabilty
  3. Help
  4. Maxi fuse panel?
  5. early 80's Eldorado stock rim question
  6. I need help with 'Service Stability Sys' on my 1999 Seville STS Codes: C1222 & C1233
  7. Wanted Amp for 99 STS Bose
  8. 96 STS will not start but has full power
  9. Wiring Diagrams
  10. 98 Eldorado ETC - OIL LEAK! Advice?
  11. 92 Eldorado power steering pump
  12. how do I remove driver door panel Eldorado 98
  13. 84 Eldo Grille Change
  14. help
  15. Seville Parts Lists Online
  16. Help with Cadillac STS!!!!
  17. Silverstars looking blue?
  18. cooling fan fault
  19. Cadillac security question
  20. Struts...valve adjustment
  21. Air Mix Door One, movement fault--AC help!
  22. Big Wheels on 98-04 Sevilles
  23. fuel injector leak test
  24. Got the Recall Notice, Should I go?
  25. 99 sts removal of speakers
  26. 96 eldo etc hard starting
  27. Stuts & Shocks at 60k Miles?
  28. Non Matching Tires
  29. Details on codes
  30. Big big problem!
  31. NIGHTMARE!!! Should I REALLY need a new engine @ 106k?
  32. My baby is damaged!!!
  33. Need 94-97 Sts Fr Bumper!!!
  34. 1997 Seville Wont Start
  35. Deville,Seville and Eldorado
  36. codes?
  37. 1976&1978 Edorado
  38. Wheels opinion
  39. HELP: '95 Seville AC compressor
  40. HELP: '95 Seville AC compressor
  41. Blower Noise ?
  42. How To Value A 95 Eldo. Convertible
  43. STS p0300 engine trouble
  44. Inner tie rod ends
  45. 1984 Bumper Body filler
  46. New here, Just checkin out how it looks, Cup Holder repair?
  47. All lights, no starting
  48. Anti-Seize, and Dielectric For Spark Plugs
  49. 95 STS Northstar - alternator / AC compressor
  50. HELP: 1995 cadillac seville engine diagrams
  51. Dash Daylight Lighting Problems
  52. CCR - Over Current
  53. They Don't Make 'em Like They Use To.
  54. counsel shift lever
  55. Body Style Differences 92 Vs 99 Eldo?
  56. Ventshades? Tacky?
  57. ok i did it this time
  58. CD Changer Data Noise 97 SLS
  59. Service Ride Control: I039 Current/History Code
  60. new PO'd member - oil comsuption for the unaware
  61. 96 eldo etc hard starting
  62. help for the new guy
  63. Alarm Troubles
  64. How do I know which codes are history and which current?
  65. Finally! Pics of my STS...
  66. replacement lightbulb specs foglights & side?
  67. temp control
  68. Wobbly harmonic balancer
  69. Speaker Wanted
  70. Lambo Doors????
  71. Front STS Lights
  72. 96 eldo temp gauge question
  73. 1970 eldorado...need some info
  74. no crank 95 sls
  75. What does this code mean?
  76. RKE Range
  77. warped rotors?
  78. Bypassing Ride Control 1994 STS
  79. Help with Engine Codes, Pre-purchase inspection
  80. Seville Service Manual anyone?
  81. ETC Rear Suspension - How Complex Is It?
  82. Northstar motor mount question
  83. Code questions for Ride Control problem
  84. 96 sls Blower motor
  85. Power Steering & Idle Problems Sts 98
  86. 95 STS Engine Knock
  87. Accidentally bought a seville part II. doors apart, what next?
  88. new guy needs help!! service ride control?
  89. 1994 Cadillac Eldorado Heater Core Change
  90. Finally Throwing Codes
  91. Parking Brake, who uses it?
  92. 92 eldo codes, please.....
  93. 92 Eldo question
  94. Hesitation-no codes
  95. Fuel & Temp Guages Died * 2001 STS
  96. using the right antifreeze
  97. burned out light behing tach, worth it??
  98. Why should you buy an STS instead of an Eldo
  99. 1990 Eldorado digital speedo/display removal
  100. 1967 Eldo Question - No Rush
  101. AC / Heater problem
  102. Strange buzzing sound - 98 STS
  103. Update on my 96 STS
  104. transmission problem?
  105. 1999 Seville SLS Bad Vibration
  106. heater ?
  107. Need Advice: Trust 87 Eldorado to Safely Transport Son to College?
  108. 1999 Sts
  109. Speedometer is possessed!!
  110. Timing Chain Replacement
  111. Headlamps Suggested in daylight
  112. ´95 Eldo engine oscilation - PART 2 ?
  113. Rain sensor module... How Much???
  114. Another Used Cadillac
  115. 97 SLS ext. trim moulding?
  116. My Eldo Needs Tlc
  117. Hello Caddy Luvers!!
  118. Eldorado, paneling warp... is there a fix?
  119. Just got a 2002 Cadillac SLS. Shifting problems??
  120. !1994 STS For Sale!
  121. How do I get the alternator off my 98 eldorado?
  122. 4 sale
  123. ?clean face,now they dont work
  124. Crank trigger ???????
  125. Exhaust in Overspill/ Rough at Start... Head gasket?
  126. new owner questions.......
  127. Replacing Spark Plug Wires
  128. My Seville kicks, cuts off, and repeats
  129. keyless entry programming
  130. what does it mean when u see exhaust
  131. Dealer said that unleaded regular is okay for STS? My 93 Deville had to have Super.
  132. please help hurry!!!!!
  133. 89 Eldo Barritz removing centre console
  134. Which Vin is the 300 HP Y or 9 ?
  135. 99 STS no Start
  136. What would Will Rogers say ??
  137. Rough Idle
  138. Acessing OBD on 99 STS ?
  139. Engine Oil Change
  140. 99 extra battery
  141. thump while idling
  142. engine code 9 with a trouble code 53.
  143. cabin air filter
  144. where to begin?? 93 sts
  145. navigation system for 1999 sts
  146. STS Handling
  147. Cadillac STS wheel exchange
  148. Eldorado ETC vs. Mark VIII LSC vs. SC400
  149. Proper Running Temperature?
  150. New Exhaust
  151. Need cd/cd changer option..96 Eldo
  152. 1994 STS engine code 9 trouble code 53
  153. 1/4 mile times for '97 STS
  154. a few questions
  155. Gurgling noise audible upon acceleration
  156. Another shimmy question
  157. I hate that...
  158. Coolant flush
  159. Oil Filters
  160. problem on SLS95
  161. weirdness in my 1994 SLS IO52 - PO39 - P110
  162. 94 STS..No dash lights?
  163. Vacuum line on FPR?
  164. Sparkplugs
  165. HELP;Acceleration Problem
  166. "Very low refrigerant and A/C Compressor off"
  167. engine ran hotter than normal for about 10 minutes
  168. part # for 93+ seville...
  169. New Rims 93&97 STS which looks better?
  170. New Rims 93&97 STS which looks better?
  171. How to disable Performance Algorithm Shifting?
  172. Very poor mileage on my 95 ETC
  173. 1985 Seville Commemorative edition
  174. Strange sounds and lack of power?
  175. 79 Eldorado towing capacity
  176. 1994 STS Locking System
  177. Hard Steering on 2000 Seville SLS
  178. eldorado biarritz 1988, 4.5 litre
  179. Rain Sensor
  180. Buy 2000 STS w/ 100k miles?
  181. 97 seville STS 64K good deal
  182. Fault codes
  183. 2000 ESC Fog Lights
  184. Where to find a Full trunk carpet kit??
  185. Service Engine Soon on 2001 STS??
  186. check engine light on a 96 seville
  187. Brake pads and rotors
  188. a slight chug
  189. Another LED Question
  190. Climate Control Cluster
  191. Engine Died, Security code and more.
  192. from brooklyn tony
  193. I'm paranoid after hearing all of these head gasket stories
  194. 97 Eldo ETC I Panal Light
  195. computor codes
  196. Eldorado heater won't work
  197. How many different models of the Eldorado exist for 1998?
  198. New Seville with canvas top
  199. my gold trim?
  200. I accidentally bought a seville!
  201. Outside Temperature Reading 126 Degrees
  202. Friend ALMOST failed emissions test: He got high HC (PPM)
  203. Seville 93:I039 code Current/History, Service Ride Control message
  204. 1992 cadillac seville sts $3,100.00 ??? big Q
  205. 96 eldo a/c won't cut on
  206. 97 Eldo for sale...
  207. smoking engine on Eldorado
  208. Need Advice: purchasing 98 Eldo ETC, independent inspection and Ext warranty terms...
  209. Failed emissions test
  210. seville interior parts
  211. strange problem? haunted? nah...HELP PLEASE
  212. Motor Trend Magazine
  213. Another Question about DTC codes GUYS
  214. 95 Eldo rear deck cover
  215. One more...the traction button
  216. Radio dash kit for 97 SLS
  217. 98 Eldorado Radio question
  218. Power Steering Pressure Hose
  219. Alarm Disable on STS???
  220. 1999 STS Issues post here
  221. where is it
  222. 97 STS Chrome rims...how to make them ALL chrome
  223. HI ALL ... What a great place
  224. Radio Model
  225. Transmission Pressuse Solenoid error
  226. Steering wheel hand control broken off
  227. Power lock problem
  228. cold driver hot passenger 93 seville
  229. What's the difference between 94 and 95 intakes?
  230. 98 Seville STS with a rough idle and slow acceleration
  231. 4T80E trans gear ratios?
  232. after market struts
  233. Heater Problems 93 Seville
  234. IPC fault??????
  235. 96 eldo traction control light
  236. ´95 Eldo drive restless !
  237. Code Question
  238. looking at 93 sevill codes po45 and po46
  239. Dumb Question Probably
  240. Difference between an STS and SLS?
  241. Free: 92 Seville Owners Manual
  242. Dam ashtray wont work right / 93sts
  243. Front struts from Strutsmaster - 97 Seville
  244. clearing out the headlights on seville/eldo?
  245. headlight alignment 97 SLS
  246. Heater Core
  247. 2000 sts cluster into 1993
  248. List of Codes
  249. Rough Idle at Cold Start - 98 ETC
  250. Tune up
