View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 98 Seville Hid Conversion, Do I Need Any Mods?
  2. Help!!..Unusual Tranny Problem
  3. keyless remote
  4. 1996 STS Best 1/4 Mile time ever at Track (14.5) against a GTO
  5. Intermitent door locking failure from remote
  6. Night Lights Not Working
  7. Loud noise in valve cover help!!
  8. '96 SLS Codes.
  9. run down on service ride control
  10. 96 ElDorado gear shift vibration/humming
  11. This Might Be The End
  12. A/C compressor & clutch Assembly-'95 STS
  13. cadillac 93 northstar sts to 92 4.9 sts motorswap possible
  14. A/C clutch Killed my Car-- '95 STS
  15. Aftermarket Parts for 1994 sts
  16. 03 STS suspension?
  17. Egr?
  18. Shifting Question -- '95 Seville STS
  19. 81 eldorado rear speakers
  20. Redlining it
  21. Problem w/PO300 code & rough idle@ cold start..Solved
  22. Clear I033 message from display- '95 STS
  23. Performance Northstar Engines
  24. How to change side mirror?
  25. 2001 STS speed vibration
  26. Can the transmission be pulled without pulling the whole engine?
  27. 67 Eldo ~
  28. Bad Steering Box Manufacturer (look out!)
  29. Gee, my cadi is running great
  30. Hard start/no start 97SLS
  31. There is good Caddy owner here: it's me
  32. Shift Selector wont stay in 1st
  33. Could a bad front motor mount cause a knock?
  34. washer motor Eldorado
  35. First Oil Change under my ownership
  36. Cleaning tubes out of sunroof-'95 STS
  37. What part is this?
  38. STS making a whiny sound under the hood
  39. EGR valve?
  40. driver window intermittant wont go up
  41. Leaky driver window
  42. Wheels for 1985 Eldorado
  43. Bolt pattern/offset on '81 Eldorado
  44. Just Bought a 99STS. Good Deal?
  45. This is getting F'n old.
  46. Center console good for a stash spot?
  47. 1997 Cadillac Eldorado lights flickering prob
  48. Service Stability system
  49. 1996 STS Beating a WRX at 1/4 Mile track VIDEO
  50. serious trunk leak
  51. Rim sizes?
  52. slightly different shifter
  53. Which service manual 98 STS
  54. 95 Eldo Tranny Problems
  55. STS Vs. DTS?
  56. ckp learn after replacing CKP sensor
  57. Coolant System Diagram??
  58. Transmission flush--'95 Seville
  59. 1985 Eldorado
  60. Wierd Noise
  61. Did I create a rust problem by adding splashguards?
  62. Coolant Flush--'95 STS
  63. How-To Reset I033 Code '95 STS
  64. how big can i go?
  65. How-To Disassemble Center Console
  66. Why are you supposed to take the valve body apart to fix the shift solenoids?
  67. 1980 Eldo Styled Wheels...
  68. 95 Seville STS change shifter?
  69. Trunk lid won't latch on '92 Eldorado
  70. 1994 Eldorado No Heat Or Ac
  71. Can somebody please help me out.
  72. Service Air Bag System
  73. STS throttle stuck wide open
  74. 83' Eldorado 4.1L V-8 overheating prob.
  75. 99STS Over temp help needed
  76. Can't find the part in Rockauto.com or elsewhere...
  77. Shifter removal - HELP! HOW?
  78. ALL HAIL:BBOB,SWIMMSTER,R&DGUY, JJBUCKLY
  79. My horn suX!
  80. Tomorrow I am about buying a 1999 STS with 42k miles, Black on Black. Any hints?
  81. Should I clean the mid-dash sensor ball?
  82. Water leak in sun roof
  83. Where are the transmission inupt speed sensors?
  84. <b>Attention: I need an expert!</b>
  85. Help! Eldo AC: "Air mix Door One," drivers or passenger side?
  86. 99 sls starting problems
  87. Day/night mirror w/ compass shakes...
  88. Help!!! A/C Compressor Pulley '95 STS
  89. Codes Po74 and PO56. No 3rd or 4th gear.
  90. Oil Pressure Gauge
  91. How to remove turn signal lever??
  92. access to under the center console '96 SLS
  93. Blueprints
  94. How to replace turn signal lever 97 Seville?
  95. Trailer hitch on an Eldorado??
  96. Stability System
  97. I need a little input.
  98. My First Eldorado
  99. Northstar Intermittent Low RPM misfire-Pulling hair out!!
  100. Strange sound inside when the car is cold
  101. Whats the Value of my 1985 Cadillac Seville?
  102. Seville "Le Ritz" Edition??
  103. I love my Seville!!
  104. 99 STS Running like Trash
  105. 1980-1985 Seville Engines
  106. Windshield wiper nozzles
  107. For you 1991 Seville guys.....
  108. How do you feel about your Seville?
  109. side "ELDORADO" door molding... on some not on others
  110. HELP! - engine is totally locked
  111. Can't get hood open
  112. Leather color
  113. Newb
  114. Won't Start/theft System Wait 3mins.
  115. Sls? Sts?
  116. Where does the shift solenoid ground go?
  117. 81 Cadillac Seville Check Engine and Brake Light
  118. drivers side heated seat not working
  119. Where is the trans. ECU on a 1996 SLS located?
  120. 98 Sts Mpg
  121. Trans goes into neutral-error code P075
  122. Just saying hello
  123. 98 Seville Fuel Pump Interchange???
  124. Splash Guards aka mud flaps
  125. will 97 seville seats fit in a 94 seville?
  126. Light in shifter
  127. Heavy Rain Cause Leaks in 99 Seville STS
  128. aftermarket products
  129. '98-up Seville lug nut thread size
  130. window
  131. 84 seville need relay and printed circuit
  132. My 1990 Eldorado
  133. Check this out
  134. Window Trim?
  135. ****ing snow.
  136. Sewing machine under the hood??
  137. 98 Seville Parking Brake Adjustment
  138. The new guy... gimme tips
  139. Windshield Washer Nozzels - Source?
  140. anyone with a fsm for a 96?
  141. Prom ID?
  142. Spark Plug gap on 98 ETC
  143. Battery Replacement
  144. 94 seville sls operating temp ?
  145. Need urgent easy answer please
  146. 98 sts no pressure in fuel line????
  147. Removing Dash Pad
  148. 97 eldorado durability
  149. 87 Eldo Master Cylinder: New or Rebuilt?
  150. 94 Sts security light
  151. '80 Eldawg In Need Of Help!
  152. cranks and pops/ 97 STS
  153. which one is the wire that runs from alternator to battery?
  154. Anyone help with identifying this component?
  155. No parking lights on right side ?!?
  156. 95 Seville SLS Whining/Drone on the Passenger side.
  157. check oil level
  158. How do find my 2001 Eldorado ESC codes?
  159. how do i my cars codes?????????????
  160. need a new 4.1...
  161. 2001 STS Seville -CLACK noise at cold start
  162. 94 eldo oil leak
  163. Help for german Eldo-driver wanted - DTC
  164. Grinding noise and a leak
  165. 81 Seville
  166. alternator access on a 96
  167. Just bought a 95 Seville SLS. Second Gear only.
  168. Trunk mounted CD changer for '97 Seville SLS?
  169. Fixing up a 79
  170. Putting this here, eldo factory radio, 94
  171. 97 Seville Blown Head Gasket Under Dealer's Care
  172. Check coolant light appearing
  173. Transmission shift solenoids
  174. Replacing injector question on 96STS
  175. what could it be
  176. Eldorados-- which one to buy!
  177. Idle Compensator 1978 Seville
  178. Hello cady maniac
  179. How do I use onboard computer to test injectors
  180. 1997 Seville Le Ritz?!?!?!
  181. Eldorado door window adjustment
  182. SLS with mods
  183. Top speed for 2002 SLS
  184. online service manual
  185. Considering 1997 STS Help Please
  186. Traction Control 93 STS
  187. RKE Range Inprovement-sts 96
  188. new sound system ????????
  189. Dead Eldo - code33 Help!!
  190. Put 91 octanes yesterday and cant believe the difference!!!
  191. My 95 STS (PICS)
  192. quick early 80's eldo hubcap question.
  193. Location of EBTCM '96 Eldorado
  194. 97 SLS coolant leak
  195. Fuel in Exhaust--any Ideas??
  196. Is it OK to change just one O2 sensor?
  197. clear code
  198. 94 STS needs new ignition switch
  199. 2500RPM Limit in park?
  200. foggy windows
  201. '76 Seville Vinyl Top Help?
  202. Oh No! It died on me!
  203. 1997 Eldorado Traction Control
  204. clunk clunk clunk
  205. 95 eldo etc heater
  206. 88 seville twilight sentinal
  207. seville sts 98 code RSS C1769
  208. Crankshaft position sensor removal?
  209. Need Some Help or Should I Say Advice!
  210. 80 seville vacuum lines
  211. Purchasing '94 Eldorado Touring - Help
  212. Young Caddy owner in need of guidance
  213. Wood shift knob for 99 SLS?
  214. Locks and Door handles! help please!
  215. New 1985 Seville Owner-
  216. Another Low A/C thread, 88 Seville
  217. Another plug wire question.
  218. Seville - N* A/C compessor ! ! !
  219. Eldo, code PC1611, Service ride control also appears
  220. 1998 Eldo Radio
  221. Whats the difference between.....?
  222. Most common?
  223. lights flicker on&off
  224. Chrome trim
  225. Want to know what oil is the best for the Northstar ?
  226. 1999 Seville Power Seat Memory Shut Off
  227. 1992 seville Antena wiring
  228. Post pages to buy new wood panel replacements
  229. Help!! EO85 code on a 92 seville sls
  230. Strut Question
  231. AC Compressor removal - HOW ? -
  232. 1990 Seville Engine Noise
  233. replacing fog lights and parking lights.. how?
  234. 1983 El dorado starter relay
  235. the best repair manuals?
  236. 93sts Rear Window Moulding / replacement question
  237. dash lights
  238. My last head light question
  239. My ELDO just turned off!!!!
  240. STS Service Manuals on CD-Rom
  241. HELP: BPTB, AC compressor
  242. 98 STS code 1255
  243. Engine Control System
  244. Questions from a Newbie (Please help!)
  245. 2000 Seville Radio Problem...please help
  246. 71 Eldo: My door is locked and it won't open - Help
  247. My "new" 99 STS (recent GM "conversion")
  248. Service engine soon codes
  249. Considering a 99 ETC....advice?
  250. need help with new tunes..........
