- 1996 STS Beats VW GTI Turbo at Dragstrip Plus pics of Bad N* engine
- seville Engine swap
- Newbie thinking about an '88 Seville
- can you replace just the a/c clutch?
- Newbie seeks information about rear air shocks, seat module, antenna motor.
- Boston suspension or Arnott Industries Please help!!!
- Trunk?
- 98 STS info center programming
- Floor mats, fromthat ad on the left...
- Seville die-cast?
- Advice On Engine / Motor Mount Repair Price!
- Help!!!
- Coolant bypass lines (i think )
- IDLING & STALLING PROBLEMS!!! 93' STS
- Traction control or tranny troubles
- 1996 STS Kills an S2000 from 55 MPH roll
- 99 STS Wheel Hub Size
- Transaxle problem (torque converter clutch) ?
- hi
- anyone know
- 2000 El Dorado convertible on ebay
- Emissions/SMOG help
- Finally got my STS painted! I'm in love...
- replacing the trunk-weatherstrip
- Wot?
- Anyone in need of a 6 disk changer?
- Throtle body cleaner question?
- 1992 New Dash Cluster
- oil change...ran into a problem :-\
- anybody Know the actual way to do this !!!
- Thunk From Trunk
- 2001 STS - Low Beam Headlight
- Pics of my 96 STS
- 78 motor and trans for sale
- Need help closing window on 96' Eldo
- 2000 STS -Ticking sound coming from top pulley
- Need some good advice
- Service stability sys???
- 99 Sts-v!
- 92 STS radio/cd player
- Very Strange Electrical Issues 93 STS
- Need Exhaust Manifolds For 500 C.i. Eldo
- Pics of my 96 SLS
- 1984 Seville Transmission Question
- 98 sts rear shocks
- Window loses power when going up!
- Custom 98 Sts For Sale
- 92 sts problems
- Interior lights stay on after door opened?
- Would 92 STS parts fit 93 STS?
- Accelerometer fault
- Just bought a 1998 STS
- obd not ready
- help
- AC compressor bypass?
- Dash kit 97 SLS, custom?
- P067 code - No cruise
- service stabiliy system - need help
- Center Cap Cover
- Sunroof will not retract
- Foglight Replacement 98 STS
- a\c assembly
- 96 Eldorado missing
- wiper arm tension
- 1997 Eldo production numbers? Z-rated?
- Slightly rough idle, 98 STS
- power window switch
- Signs of a bad ISC motor
- Does anyone make a exhaust system for a 96 Cadillac Seville SLS Northstar
- center console / floor shifter
- Speed Limited to 90
- What do u think of my sevilles new bodykit
- Will a 99 Eldorado Transmission Work in a 95 Seville SLS?
- Corsa Exhaust for 98 eldorado??
- '97 Eldo - door panels - best way to fasten?
- Defogger Indicator
- Will the CORSA Power-Pulse RSC Exhaust System for 99up Fit My 1996 Cadillac Seville
- 98 STS - Reading ODBII Codes on DIC
- Will 98 STS seats fit a 93 STS?
- Vibration during low speed turns
- how do i change fender lights????
- Please Help!!
- Having problems with tranny
- Some codes im getting
- Front License Filler Plate
- TSB's for Seville (copy and paste)
- Straanngge noise
- Chrome Grill For 1999 STS
- CD Player in Dash 1997 STS
- Anyone else notice bumper color differences?
- From start a bump
- Bras
- Hey, look what I found for sale....
- Oil level Question
- Motor / Tranny Mount Causes Noise?
- Purchased a 1996 Eldorado
- Tranny hesitates ...
- Spare part #
- 93 STS wheel fitment
- 95 ETC Climate control question.
- Suggestion on my 1994 STS
- Needs suggestions on my 1994 STS
- Putting a 95-96 Eldorado Hood on A 94 Eldorado
- ignition switch replacement
- 97 STS bad rear wheel bearings?
- No Start/ Factory Security Light comes On
- weatherstrips
- Disable DRL?
- 81 eldo v6
- high idle???
- Which car is better ?
- How To Clean Throttle Body
- Really need to sell this Eldorado
- Source for traction control information.
- 1993 Seville STS Questions
- msrp for old caddies
- Burning carbon deposits...
- 99 STS Radio Muting Problem
- How do I change the Key Fob remote from...
- Fog Lamp Replacement 2000 STS
- Check gas cap
- just outta curiosity...
- '76 Eldo Barritz with Fuel Injected 500 CI for Sale
- Checked out a 1984 Seville, Pics
- Steering Wheels
- Front end vibration at high speeds
- 97 Eldorado Underbody covers, but covering what ??
- fire
- leaking into trunk 01 STS
- Timing chain?
- How doI reset all the memorized functions?
- BMW headlights + Foglights
- 93 Eldorado TC Roadster 63,000 Miles
- Need Help--> A/C Compressor not kicking on!
- This is what your Northstar looks like if you don't WOT weekly
- Should I buy an extended warranty on a '97 SLS?
- Adding freon: How to kick Compressor On???
- Squeak/Creak 2001 STS strut tower
- 2000 STS Transmission Fluid Low question
- I have an air bag question
- Curiosity question about 92 Seville radio
- 1998 STS - HID Headlight Kit's Available?
- 98-04 Sts Lowering Kit?????
- Illuminated Entry System
- Just have to have 20s
- a lot of codes on 1994 eldorado
- Gas octane
- my Caddillac is total crap
- Just picked up a '98 STS, White Diamond!
- I hit the jackpot
- CADILLAC Seville 96 ( windshield wiper motor )
- Seville "dual" exhaust / Corsa question
- K2K I Have a question for you....
- 99 STS Service Manuals - DVD/CD/Book
- Stretched my legs on a Nevada freeway...
- Suggestions on tinting my windows
- Fog light adjustment
- HID's in my SLS
- '79-85 Eldo Windshield RUST...
- Eldo
- 94 SLS What Should I Do?
- loose side view mirrors
- New here, looks like I'll be on alot
- '97 SLS stalls
- 1999 seville sls
- engine knock @ 60K miles????????????????
- engine code po27 & po75
- Cd Player For My 1996 Seville Sls
- 1975 Eldorado
- Difference between a seville ss and a seville sls
- 1998 STS - are there inherent problems?
- Lumpy Power Steering Feeling
- Please Help!!! - 97 ELDO TRANS SLIPPING
- 100K Mile Service
- New SLS owner...what a great forum...
- 2005 Etc?
- Sunroof windshield not rising
- Having a few problems
- 02 STS question
- STS Codes - What does "History" Mean - Help
- 89 speedo
- Checking out an 80's Seville This Weekend
- Replacing Steering wheel audio & Climate buttons?
- How many MPG are you getting in your N* Seville/Eldo?
- Stock Cad center caps instead of vogues?
- egr bench test / disassembly ?
- 1997 eldorado stalling
- A/C compressor clutch step-by-step?
- 96 Seville chrome Fener trim
- Helpp!!!! 99 Sts Completely Dead!!
- Cost for window motor 94STS
- 1995 STS "Check Coolant Level" / Coolant Already Full
- A/C changeout - success / THANKS ALL
- speaker removal in a 95 sts
- New around here...
- Corsa for STS?
- Bulletproof Window Film?
- 92 seville side molding?
- removal watger pump 86 Seville
- 99 STS Pics
- Vacumn Compressor Motor on 75 Eldorado
- New Seville Owner
- wow this is clean...good deal?
- 1998 Sts For 5k
- Oil Cooler & Lines... where are they/ what name?
- Intermittent MAP signal,Open MAP Sensor signal, MAP sensor signal out of range
- Orifice tube for the A/C
- no heat or air conditioning fan
- Fuel consumption improvement STS 1998
- On-Board diagnostics problem,,pls.comment
- STS - Temperature Gage and Fuel Gage not moving
- Changing igniton switch 1999 STS
- >>>HELP!!A.S.A.P!!<<<
- Traded 98 STS for 99 Aurora 4.0
- Leaking rear glass
- cabin filter location
- Ashtray problems
- Rough Engine RPM
- Abs U1255
- It finally happened, BOSE cd stuck
- Serpentine belt bypass A/C compressor
- 2000 sts cabin filter
- Engine Coolant Low-- message '95 STS
- Whistliing sound when I accelerate- '95 STS
- Coolant overflowing
- trailer hitches
- 2000 STS electrical problem...Maybe?
- Key Help
- '96 Seville trunk brake light fit
- Water in trunk of 99 seville
- Leaky Trunk Gm Service Bulletin
- Windshield
- Checking codes without scanner?
- 98 Seville Hid Conversion, Do I Need Any Mods?
- Help!!..Unusual Tranny Problem
- keyless remote
- 1996 STS Best 1/4 Mile time ever at Track (14.5) against a GTO
- Intermitent door locking failure from remote
- Night Lights Not Working
- Loud noise in valve cover help!!
- '96 SLS Codes.
- run down on service ride control
- 96 ElDorado gear shift vibration/humming
- This Might Be The End
- A/C compressor & clutch Assembly-'95 STS
- cadillac 93 northstar sts to 92 4.9 sts motorswap possible
- A/C clutch Killed my Car-- '95 STS
- Aftermarket Parts for 1994 sts
