View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. A/C conversion didnt work
  2. Heated seats
  3. Eldo Turbocharger?
  4. Need advice on weather my car is safe to drive
  5. Reason for Service Manual Price Difference
  6. Car Totalled- Engine/Trans Swap Suggestions Please
  7. Does a new Northstar engine increase or decrease resale value?
  8. Engine Cuts off
  9. Seville STS 1994 cylinder head gasket
  10. Quick RKE question
  11. 95 SLS - 2600 Mile Road Trip Report
  12. Security Light
  13. Broken SIde view mirror..How easy to fix??
  14. PC0717 right after self changing air filter - I think I did it, help.
  15. Need some advice...Expensive dealer diagnostics...
  16. oil pressure 1992 eldorado
  17. oil pressure 1992 eldorado
  18. Need advice on how to sell a 1979 Seville Opera Coupe
  19. Fuel Pump Relay Fuse
  20. T063--Valve Relay Fault
  21. Cadillac STS Steering fault
  22. 2000 STS vibration
  23. Eldorado Diecast Model
  24. 92 STS Starter Bad - difficult to replace?
  25. RKE module location for 97 Seville
  26. over heating w/ac on
  27. Smoked or Projection headbeams for a 1995?
  28. Newbe
  29. i got a question????
  30. Trip computer won't reset
  31. Adding a 2nd Battery
  32. 94 Northstar overheat
  33. 85 Eldo a/c help
  34. engine is blown...
  35. 98 seville a/c problem
  36. I have a thingy behind my rear-view mirror, what is it?
  37. Yet another Strut question...
  38. AC Compressor off and no fans blowing air
  39. Late model Seville drop top?
  40. ckt
  41. '86 Eldorado Biarritz questions
  42. Whitewall Tires
  43. Keyless entry ID?????
  44. Help..Help... 1976 Seville Upper Grill .....Where do I get one?
  45. HELP!!!94 sts won't startlow, oil pressure
  46. Pcm???????????
  47. Vogue hooked me up!
  48. 95 Eldo Driver's Side Power Window
  49. High Performance Tires
  50. Oil Leaks!
  51. A/C fuse keeps blowing???
  52. Coolant Reservoir Level
  53. Sold the Sprucegoose...
  54. bumped while parked--security/airbag messages?
  55. Traction Control
  56. 95 Seville STS Blower Motor
  57. Need help ASTRO ROOF!!!!
  58. 83 Eldorado Engine Needed
  59. A/C Question for R12 GM compressor on 79 Eldorado
  60. water pump removal socket
  61. 96 Seville No air
  62. P0741 code - ATTN: bbobynski
  63. trunk actuator
  64. 1994 Cadillac Eldorado Grill
  65. 94 Eldo overheating - Help?
  66. Wont Start :(
  67. 1999 Sts
  68. 96 Seville SLS wipers inoperative
  69. Over head cool shades compartment
  70. Oil level reset
  71. Torque/Oversteer ?
  72. Charging the A/C (94 Seville)
  73. flowmasters
  74. Attention:...........91TEXASSEVILLE::::::::::::
  75. 1997 Seville 75,000 check
  76. Fuel Problem
  77. My Seville has got the dealership
  78. Quick Motor oil question
  79. Left Turn Singal Flashes Fast then Slow
  80. Coughing problem
  81. Install Tachometer
  82. What Y'all Think of this rims
  83. Code Overides
  84. Plugs/Oil ??
  85. 97 Eldorado dashpad , fix or buy new from GM?
  86. Noise or looseness in front suspension
  87. door chime!!!!
  88. Price feedback please
  89. What size torx is needed to replace front brake pads on a 94 seville SLS?
  90. code 34 35 37
  91. Found a part in the driveway.. Anyone?
  92. SES Light, Stumble at Idle
  93. quick code translation anyone?
  94. HT4100 swap to non HT engine
  95. 2000 Seville Seat Covers
  96. carbra.com update
  97. How to change control arm bushings?
  98. Any perfomance tricks for gen.1 N*
  99. anyone have carfax account?
  100. rattling? "high end audio only need look"
  101. yawn, "service engine soon"
  102. What is Code AO12?
  103. Cadillac 2000 Eldorado ETC "Service Engine Soon"
  104. Front motor mount -98 STS- how hard?
  105. What are The Differences Between an Eldo ETC and ESC
  106. For those who remember the planning, I finally got my new system put in [56k no way]
  107. This massage is for ROB_M
  108. new eldorado for me
  109. trunk light
  110. ABS problem???
  111. trunk pull down
  112. stolen emblem
  113. check engine light?????
  114. a/c blowing warm air
  115. Exhaust
  116. No longer A "TOTAL PIECE OF CRAP"
  117. ?? Whats the best year for an Eldorado ??
  118. 98sts whats the trick to drop fuel tank???
  119. Even more problems!!!!!!!!!
  120. Troubleshooting Codes
  121. 96 SLS: white wall or no?
  122. Tensioner Pulley Squeaking? (92 STS)
  123. 86 ELDO Parts Needed Badly Help Anyone
  124. Fuel pump problem...
  125. 85 eldo verses 88 tell me
  126. Wacky DIC Messages
  127. A/C compressor ticking
  128. 2000 STS A/C problem
  129. Code help
  130. Battery Question
  131. Daytime Running Lights (DRL) for '82 Eldo
  132. Almost!!!
  133. Rear control arm bushings
  134. just bought a 1992 seville and i need some help
  135. Transmission service at the dealer?
  136. Stereo Kit
  137. 1998 Sts
  138. P0741 code came back.
  139. 1988 Eldorado Wheels Questions
  140. Camaro brakes on the Seville!
  141. What to do now?
  142. How do i? get rid of the fuel cut off!!!
  143. 73 Eldo Conv Car Cover question
  144. sun roof
  145. Check Engine Light???????
  146. need part numbers
  147. 96 Eldorado A/C problems
  148. Turn Signals
  149. 88 eldorado auto headlights..not
  150. 02 STS heated seat
  151. Performance exhaust
  152. installing a mp3 cd player in a caddy with bose system
  153. Cadillac Seville 1997
  154. All brake lights are off including the strip
  155. What is normal temp. on a Northstar motor?
  156. Checking for continuity
  157. My Cadillac Is Total Crap
  158. what color is the remote turn on lead for the power antenna
  159. Both of my brakes lights are off
  160. 93 STS tranny and coolant issues
  161. Please help out with a few questons about my 94 STS
  162. Traction Control Overide
  163. 1998 STS brake light?
  164. 93 sls air ride?
  165. Passive Shocks/Struts 98 STS
  166. Red Eldorado
  167. Please help my 1991 Seville won't start!
  168. Driver side door speaker
  169. Probably a dumb question re: battery cable...
  170. Selling the Eldo...
  171. 94 elderado eatin batteries
  172. '97 STS - Grounding Problems...
  173. Bleeding brakes: fluid capacity??
  174. Dynomax Super Turbo Mufflers
  175. Will 2003 STS HID lamps fit 1998?
  176. sway bar bushings
  177. help with diagnositc codes pd76....
  178. No more front end shake!
  179. 92 STS cooling fans
  180. New Car leather smell
  181. 92 STS Air Cond Compressor Problem
  182. OBD 11 won't self examine- 98 STS
  183. How long is the 74 El
  184. ASC Button
  185. Rear suspension creaking
  186. How do I remove the door panels from my 79 Eldo?
  187. 96 SLS radiator
  188. old cady
  189. Spark Plugs Replacement
  190. Gas problem...
  191. 94 SLS Tranny Problems...Need Tranny Expertise!
  192. Wiring for Eldorado 89 for anti-theft bypass help
  193. starting problem
  194. ELDO trade for STS
  195. I bought a STS
  196. Safe range after Change brake pads message?
  197. How much/ keyless entry module/ junkyard
  198. Help!!need Codes Please A.s.a.p.!!!
  199. Need Tan Armrest 99 STS
  200. Looking for purpleish 95ish STS in CT
  201. 94 Eldo Keyless Problems Continue
  202. 85 Eldorado HT4100
  203. 92 Seville Brake Light goes out when opposite turn signal is on
  204. Tranny fluid change & solenoids
  205. Buying An STS
  206. 95/96 headlights changed to 97+?
  207. 2005 Strange Seville Production Specs.
  208. How do these 18"s look on my ETC???
  209. engine crankshaft pulley is wobbling
  210. Stock 98-03 MiniDisc
  211. Overheating Problem on 1996 STS
  212. 99 STS Rear Fogs...
  213. My 96 El needs a deck
  214. 1991 Cadillac Seville w/ Phaeton Top
  215. smoke and fuel smell?
  216. Buying a 96 or 97 seville sts
  217. clear codes
  218. Short in courtesy lights
  219. Northstar-stuck rings
  220. Please Help 95 STS
  221. 03 airbag
  222. My 78 Biarritz needs rims
  223. 01 STS Overrev during WOT?
  224. What to do? Help Please!
  225. fuse and circuit breaker problems
  226. removeing engine & trans from 98 seville
  227. Somebody help me with my 95' STS
  228. Need some help
  229. alternator amp
  230. Accessing Radio Aux
  231. PCM Repair Question
  232. might buy a 95 seville
  233. Front end noise
  234. Rattling Center Caps
  235. 1987 Eldorado 4.1Litre Coolant Question?
  236. NO Start ......Mystery
  237. Door panel skins
  238. 79-85 front suspension?
  239. need help with codes
  240. 94 sls problems
  241. need help, no automatic shift/manual in 94 sls
  242. trans shift problem 94 sls
  243. power seat problem
  244. 95 Seville Keyless problem
  245. 94 Eldorado Keyless Entry Problems
  246. Is 225*f Hot On N.star Or Is It Normal
  247. My Climate Control is Posessed
  248. Seat Heater Module
  249. 92 seville fogged up tail lights?
  250. FI Cleaner
