View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. CURRENT CODE: RSS C1761 RF Position Sensor Input Fault on 1999 Seville STS
  2. code c1225 Excessive wheel speed.
  3. Code assistance please
  4. codes??
  5. Shift knob on 98+ STS/SLS & 2000+ DTS... no button?
  6. BZM B0533: "FUEL LEVEL LOW" message
  7. ABS and Traction Control lights come on intermittently
  8. Need 97 Eldarado EBTCM module
  9. probably a dumb question but here goes.....
  10. Tires?
  11. Low Coolant Level Sensor---Where in Surge Tank?
  12. dash fan dilema 97-Edorado
  13. 1993 sts slight miss/ idle not steady
  14. My STS noise...
  15. Xms Supercharger
  16. '93 ETC Oil pan gasket replacement...
  17. Hidden rattle in '93 ETC
  18. Eldo/Seville rear center arm rest compartment
  19. Power Steering Help
  20. Stainless Steel Eldo Roof
  21. Brake Switch Problem
  22. Shifter handle problems
  23. Sell Caddy?
  24. Road texture comes through steering and pedals.... normal?
  25. Hold the tire, turn the wheel **'click'**
  26. Just ordered new front engine mount from RSM
  27. Coolant tabs No Need?
  28. Brake Trouble
  29. Sloshing water sound during acceleration.
  30. Vinyl roof needed
  31. ok, now im in trouble, its overheating, but why...?
  32. Level control sensor
  33. Radiator removal on 98' STS
  34. Brake lines leaking
  35. 1992 Eldo Catalytic converter problem
  36. Carfax or problems with 2001 STS?
  37. speed up speed dn
  38. 92 STS - Air Conditioning Code
  39. Anyone Know where to find 79-85 Eldorado Restoration Parts??
  40. Is there a "HOW TO "Forum in Cadillacowners.com
  41. Used OBDII for the first time!! Need Help with codes
  42. Broken Motor Mount
  43. A/C Repair Help
  44. Interior lights
  45. Tire Suggestions
  46. MAP sensor installation and crankshaft location
  47. Shopping for 69-70 caddy drop top
  48. Need a part! 90 Seville
  49. Blower motor replacement on 96 ETC
  50. 96 sls performance specs
  51. PCM Computer Problems
  52. 93 sls clicking when turning the wheel
  53. 1995 Eldorado A/C trouble "ACP Module"?
  54. SLS Questions
  55. Damn TP sensor and it's crappy low voltage...
  56. Cursed.. Transmission craps out after selling car
  57. problems...
  58. '97 Eldorado Center Caps - weird ones
  59. 93 SLS intermittant start
  60. Cooling Fans 50A Fuse Blowing....WHY?
  61. 2000 or 2001 STS?
  62. Transmission Problems - Please help!
  63. 95 SLS, where is the pcm?
  64. Bumper Paint
  65. 2000 SLS Center Console Cup Holder
  66. 93 Seville SLS Value
  67. crappy spark plugs
  68. ckt 800
  69. My '85 Biarritz
  70. Code Question
  71. Cold air intake
  72. Brake pad question
  73. OnStar Retor fit STS
  74. Lowered Suspension- 90mph limited???
  75. Loss of Power Problem
  76. Should I keep the secondary muffler for 99 STS??
  77. My '86 Eldorado
  78. Caddy gets a transplant.
  79. 99 STS Fuel Level Sensor
  80. 1998 Sls Rides Rough
  81. 1994 seville sls transmission problems
  82. Removing inner door panels
  83. The STS is cool, my dealer is NOT...
  84. Need advice
  85. Operating temperature w/new water pump?
  86. 98+ STS Bose Minidisc Head Unit
  87. Plastic Sliding Sunroof Shield for Sale?
  88. New Tires for my STS today!
  89. Aftermarket Sunroof?
  90. BG products coolant flush
  91. front end vibration is gone yippeee
  92. Which ones do you suggest?
  93. How do I remove head unit
  94. 99 Cadillac STS Steering Problems
  95. GXP performance struts vs. CVRSS
  96. Code TCS C1241?
  97. Engine Shakes at idle on 1999 STS Misfire or ?.
  98. 92 STS shifting problem
  99. Tightening Water Pump.....HOW???
  100. Fram Air Hog Filter for Cadillacs
  101. 92 Seville Rear brake pads
  102. 2000 STS brake pad sensors not working !
  103. Speaker needed or advice on new after market
  104. Driver side taillight lens
  105. 97 Seville for UK or other Right Hand Drive on eBay!
  106. Help Please!!! Troubleshooting Error Codes & Wiring
  107. turbine input sensor
  108. Computer Problem
  109. Chip for 95
  110. Which year STS (91-04) is the fastest?
  111. 88 El Dorado A/C & water pump
  112. Transmission Fluid Leak (92 STS)??????
  113. 98 Seville IPC overrides with Tech2
  114. Front grill emblem
  115. 97 STS Top Speed reached
  116. Problems with 1990 Eldorado
  117. squeek when turning left
  118. 2002 vibration resolved
  119. Cracked Brake Hoses (92 STS)?????
  120. 2000 STS engine knock before warm up
  121. 2000 STS, Regular? Mid? Premium?
  122. What kind of oil do you use?
  123. water pump labor cost?
  124. Shifter Trim by Trimbrite
  125. New Water Pump....Coolant Flush Info.
  126. Mice in the Car !
  127. Found out something new about Caddy
  128. '99 Eldorado trunk pulldown problem
  129. WOT exercise past 100,000 miles????
  130. 1984 Eldorado 4.1L Fuel Pump Replacement
  131. Mulifunction Switch(Cruise, Wipers, Blinkers, etc...)
  132. 1989 Seville - Intermittent No-Start
  133. 1990 Seville engine problem(s)
  134. I'm an Idiot, impatience does not pay.
  135. air pockets in coolant system
  136. 92 Sts Question???
  137. Reman Engine Project
  138. 1992 Cadilliac Seville Broken VAT wire HELP
  139. Friend got an Eldorado.
  140. 94 sts boat pull question
  141. Need help with codes please!
  142. Question for everyone to answer...
  143. New guy here with questions!!
  144. 94 Cadillac Seville SLS Parts
  145. 93' Seville STS
  146. manual
  147. 94 Cadillac Seville SLS Parts
  148. rot around base of landau top...what to do?
  149. motor mount replacement- 98 STS
  150. 1985 Eldorado Roadster
  151. hail damage remedy
  152. 94 STS Injectors?
  153. Cadillac Seville 1990 R12 or 134 ?
  154. Trim and Color codes, '93 ElDorado
  155. Restore 95 STS
  156. Premium Fuel Question...
  157. PPPLLEEAASSEE help me with STEREO info on 1997 STS!!
  158. test
  159. Headlight cleaning??
  160. Navigtion System for STS?
  161. problem with a jerking when at a constant speed
  162. service system stability
  163. 95 Eldo engine codes.
  164. 1992 Seville w/compression leak
  165. missing coolant
  166. Cadillac Service Manager told me 96 is the worst year for Cadillacs
  167. I027 --------> PRND321 switch failure
  168. lube body on 99 seville
  169. Wide Open Throttles
  170. cooolant supplement
  171. Traction Disabled; Service Ride Control
  172. HELP! AC Blower Question - 94 Eldo ETC
  173. 95 Seville rearview mirror fell off PLEASE HELP!!
  174. Sunroof & windows Auto close
  175. Need a good body/paint shop
  176. EBC Greenstuff Sensor?
  177. 99 Elderado Radio ?'s
  178. heres a good one....
  179. good guess anyone?
  180. Eldorado & Seville Performance Air Filter on eBay
  181. Instrument Cluster Problem
  182. Brake pad sensor
  183. New member
  184. Mirror Tint?
  185. performance shifting and suspension question
  186. Grille Mask/Front
  187. Custom Interior Work
  188. Just bought '03 STS, trunk Stinks, auto A/C always on full - Help please!
  189. 92 sts
  190. Did I F#*@ up? RKE question
  191. Body 2 10A Fuse ??? (92 STS)
  192. Removing Exhaust catalizers
  193. Wood Trim?
  194. new member - hi !
  195. Werid sounds...
  196. ignition cyclinder problem
  197. 95 Eldo Code P036
  198. Might sell SLS
  199. neutral safety switch
  200. 92' STS, reset oil life thingy
  201. Trouble need help.
  202. '76 Seville Radio Options
  203. Got a 61 convertible
  204. 95 Eldo Belt housing.
  205. Can you Carfax 90 Eldorado
  206. Custom seat covers?
  207. Rear end rattle
  208. AC / Heat not working/other problems
  209. Air Compressor Diode
  210. Trunk light not working!
  211. Mirrors do not work(92 STS)
  212. Reg. Gas In 95 Sts
  213. 94 Eldorado Wheel Q?
  214. 95 eldo flywheel wearing.
  215. No POWER!!! 94 eldo
  216. Gear Shifter Problems
  217. AC Recharge Help needed
  218. temp gauge
  219. Hot days in Ohio
  220. Replacement Hood Question
  221. I've Found one! (relating to "my son wants one")
  222. Information display question
  223. Pedals
  224. Engine Service/Swap Question 97 STS
  225. Noise
  226. 1983 Seville Air Conditioning Problem
  227. Airbag (wheel) cover sold seperatly?
  228. Stumbling Idle
  229. Help with a 93 STS
  230. A/C leak
  231. Brake lights not working properly
  232. 95 Sts
  233. Body Lowering Kit and Electronic speed governor bypass
  234. ATTN.Eldyfig
  235. HD6 and HR6 compressor differences?
  236. Burning oil?
  237. I Got The Codes
  238. Y Does It Keep Cumin On!!
  239. Moisture in anti-glare side-view mirror
  240. Replaced Engine
  241. Passanger Rear Window Broken
  242. 98 STS Problems, Please Help
  243. A/C problem
  244. 95 Seville Missing During Excelleration
  245. 1991 Deville stalling
  246. code 300
  247. 2001/2 STS - power steering
  248. 1996 Eldorado
  249. WTF is a Pitman Arm?
  250. a/c problem
