- 99 STS Sunroof...
- White Smoke?????????
- Brakes making loud noise...
- 98 STS Squawk/squeak noise from rear suspension
- Sloppy Drunk Front End & Tranny-Need Info Pls
- fuel soaked spark plugs no start HELP
- 94 etc mufflers
- Struts and shimmy
- STS/SLS 93-99 Interchangable?
- HELP!!! please? Codes for a 95 Seville SLS
- 'Service Engine Soon' light in 1st gear
- Interior Trim Questions
- Coolant Temperature
- Part search
- Wireing Diagrams, manuals
- New Da 6 A/c Compressor Help
- knocking sound
- Changing Engine Coolant 99 STS
- 78 eldorado parts
- You guys are awesome
- Error Codes
- 87 Seville Trunk Spring And Fuel Filter
- Angry at my Cadillac... Cabin Air filter...
- Newbie with XM question
- Neutral Safety Swtich HELP!
- Eldorado parts
- 1993 Eldo...oil Poured out...none left
- In Need Of An ABS Pressure Switch (90 Seville)
- Finally got rid of Seville !!!
- Kelowna Junkyards, maybe of interest to someone?
- Antenna wire help
- Transmission Fluid Change Sunday...
- IAT sensor 2000 Eldorado
- 2000 STS Bose stereo question?
- Disable Anti Theft in Seville STS 97
- ATTN! Pjs/patrick, PO 91
- Radiator Fans
- steering wheel controls
- Need some help please.. MPG
- Help! How to Remove "Check Oil Level" message?
- Error Codes from 97 Eldo ETC
- Eldorado Brakes
- Overheating
- Oil (?) film under intake manifold cover
- No more oil leak!
- Po741 Tcc Stuck Off
- 1997 cadillac seville sls oxygen sensor
- PO41 code, Service engine soon, Please help!
- Engine Miss Problem... Please Help
- Various ramblings about the STS; Z -rating, etc...
- Leaking Coolant 95 SLS
- 2001 Eldo drivers leather seat
- Code RS0027
- '92 Seville Coolant Temps
- Navigation system??
- 99 STS Cabin air filter
- Warranty issues, and shakey quality
- This should be an easy one!
- Car turned off and reset while driving...
- 88 eldo front end noise
- 94 sts engin blown?
- Engine Rebuliders In Canada
- Front Drivers side wheel-well clicking
- 88 Eldo Water Pump & Starter
- Okay heres another dumb 1, how big is gas tank
- putting carpet back in '94 STS
- blown head gasket - reasonable cost?
- power window dead
- Replacing Window Switch 99 STS
- '02 Seville vibration
- Power Steering Vent
- Hot start problem
- I can't do what?
- Heater core bone connected to the AC bone?
- 97 SLS rear bumper removal?
- '92 Eldo, Stalls At Lights, Right-front Rattle Over Bumps
- 85 eldo codes and help
- 02 N* into 98 STS?
- 1998 SLS Antifreeze problem?
- Drop Eldo
- 1968 Eldorado Question
- 93 sls tranny prob, HELP!
- After Market Sound System
- Transmission problems 79 Eldo
- Ride Control Problem 94 STS
- 92 Fleetwood Brakes
- Cruise Control Servo location?
- Help! How to Remove Headrests 98 Sts
- wood trim help
- Problem on startup?
- Service Suspension Sys / More Codes - Insane
- Will my cadillac carpet shrink?
- Replacing Cup Holder 99 STS
- Set Time on a 1988 El Dorado
- Recommended Tire Pressure - 78 Eldorado
- Finally pics of my Eldo
- Need stock moonroof dimensions
- 27.7 mpg
- 1997 STS Tires/suspension
- 1997 STS Tires/Suspension
- '78 Seville books
- 72 eldo convertable top ?
- 96 STS Service Emissions System Warning
- Can't Open Hood
- 97 Eldo ETC idle and front suspension noise
- 1985 Eldo AC/ Vent problems
- Transmission Fluid...Draining & Refilling?
- WTB: 92-96 L Black Driver Door Panel
- Pep Boys????
- Power!!
- Best Tires For An STS
- generation of sts's
- 85 eldo a/c electrical ??
- What to look for in an Eldo
- New Caddie dude
- 1996 Seville rubber radiator/headlight cover needs replacing - help
- help with codes 93 eldo 4.9 NOT N*
- 96 Eldorado A/C problem
- Delco 12 CD changer
- Cleaned it, Replaced it, and still no change!
- Battery Replaced, Now All Warning lights On
- New to the club, first car and it's a caddy!
- '78 Seville electrical problems
- What Else Is There?
- "CHECK COOLANT LEVEL"
- After brief flirtation with upgrade, LOVING the 98 STS again...
- 91 ETC Eldorado Bubba Wiring
- Moonroof Problems...along with alternator
- MINOR LIGHTS flickering while engine running
- Help removing center console
- Extended Warranty Worth The $$$$
- Fuel loading up
- Wood Dash Kits
- Transmission Fluid Reset
- 96 ElDorado with A/C problems
- Odd Sound
- Alternators
- Leaking rain onto driver's seat
- New to me 02 STS
- Northstar engine parts
- STS and SLS interchangable?
- Head Gaskets? WTF?
- Help w/ getting rid of Check Oil Level msg
- finally got some rims
- Need Help With Code RF2560.
- Scanners
- 97 sts ACM U1027
- AC help 99 STS
- Got in an accident In my 83 Eldo, and im Extremely impressed.
- 98 Seville STS nitrous install
- 95 Seville Shift Handle
- Onstar & XM
- Temperature Reading.
- Covertable Top Care
- Steering Wheel Replacement
- Is your Northstar Seville reliable?
- Catalytic Convertor Advice
- All over the place, like a smacked ASS...
- Need to vent...POS 1999 Sevile
- jerking motion
- P039 problem after solkenoid switch
- Tornado Air..Increases Miles per Gallon?
- whirrrrrrr...grrr...poof...grrrrr
- 1996 cadillac deville service manual
- Seems like a headgasket prob, but isn't??
- code help
- FM not working
- Battery No Charge
- Pulling shifter into First at any speed!!!!
- 91 Eldorado Water Termperature TOO HIGH
- MPG help!
- goin to run the sts in the 1/4 mile
- PO 76 with hard shift
- car bras for Seville's HELP NEEDED!
- Farewell Old Faithful
- 94 eldo, need rubber vagina piece by window
- Helm's Repair Manual Arrived...Assistance Needed:
- Need Help with 2 Problems
- 99STS Power loss/hesitation
- coolant temp waaayyy wrong car burning rich
- Remote fuel door issue
- help, rear wheels locked
- What's your opinion?
- halfshaft
- Idle Play
- Morning Smoke
- Wont start, low battery V, take a read
- odometer tampering
- Throttle Body
- HELP just purchaces 95 seville sls trouble p052, p109, p039 and p094
- 98+ STS Dash Cluster...Blue lights?
- A/C Heater Vent Problem
- Still Having Water Pump Problems
- '96 Eldo column-mounted control lights
- Fair price??
- Rotate This
- Your informed thoughts on 94 Eldorado ETC purchase
- 1993 Cadillac Seville SLS - Strange Overheating Problem....AC Cools it down?
- Quick Question
- I'm keeping my '95 SLS forever!
- my 99 STS annhialated a mustang GT
- Vibration Gone!!!
- What next ?????
- 4th of july horror
- Engine too hot!!!
- 92 Allante
- Traction Disabled
- confession
- Neutral Safety Switch
- Eldorado Sport Package?
- 98 Seville cup holder
- Door Panel Clips '99 Eldo
- I cant believe this Eldorado!
- Need Input: Engine Swap
- How
- tranny problem?
- 97 STS Factory CD Changer What?
- No Ashtrays???
- Seville/Eldo Ride Good?
- Part search
- Cutting hole in Rear deck....safe?
- CTS Rims on a STS?
- 97 STS Front Bumper Cover Fitment Years
- New problems w/ tranny or ISC?
- ODB II codes - how to display on dash
- ElDorado vs. Lexus ES300
- Check Stabilizer ???
- Disconnect SIR for service
- 99 STS Console
- baffeled help please
- Rear Passenger Windows
- no start
- Proper coolant color
- 92 eldo grille
- Cross Country Trip
- ???custom Grille???
- fun and safe 4th
- Need Help Removing Headrest for TV's
- should I pull the trigger?
- Fuse box
- Are headgasket leaks still fairly common on 1999 STSs?
- Rear Struts life
- A/C Problems 94 STS
- 245/45/18
- ABS and Traction Control lights staying on
- Restoring a 1995 Seville SLS
- Vehicle Speed Indicator came on
- Late 90s Seville Reliability
- Leaking Water Pump
