View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 1988 Eldorado CRUISE CONTROL
  2. 98 eldorado wiper problems
  3. Windshield and other issues
  4. slight suspension squeak from up front (99 STS)
  5. Considering purchasing a 2002 Eldo ECS
  6. Caddy Seville's and thwir owners Age!
  7. Seville stalling problem
  8. Just bought STS... some newb ??s
  9. Changing Rear Upper Control Arms
  10. Loose drivers side view mirror...??? (99 STS)
  11. AC Temp, 10 degree diff left side/right side
  12. '92 Seville Some fuel injectors bad???
  13. problems with memory system
  14. please help..Antifreeze from exhaust....
  15. Enter Diagnostic Mode for 2000 Eldo
  16. Hello! newb here
  17. HID Lights
  18. Engine & Underhood stickers
  19. **** Insurance companies!
  20. Ride Height '94 SLS
  21. no 4th gear
  22. If you think you can swap OBDII Modules, Think Again!!
  23. Camshaft Position Sensor - How Many $s
  24. 93 eldorado a/c fan won't stop
  25. Rough runnin' 99 STS- no current codes
  26. tranny woes in 95 SLS
  27. 99 Eldo with 1/2 working AC
  28. Blower Motor cuts out on 97 but only on high or auto? Blower Motor?
  29. Power lock / aftermarket keyless remote
  30. 98 STS Cloudy Headlights
  31. dashboard temp display
  32. 93 STS AC Problems
  33. 2002 Seville STS Steering question
  34. well i ran my 1/4 mile
  35. Transmission - Fail Safe Shift Mode
  36. STS Throttle Stuck Wide Open
  37. 94 STS Tranny Problems
  38. "Service Engine Soon" flashing
  39. HELP! N* Injector Control Circuit Problem
  40. Steering issues.
  41. sts 1/4 mile
  42. Diagonostic Codes Eldorado
  43. Trans issue 1997 STS
  44. what to look for
  45. First gear disabled?....Then check your stoplamps!!!
  46. HELP! oil problem!
  47. Great Balls of Fire
  48. DRL's, Tilting Mirror, Suspension Fixed with Vogues!!
  49. 9X Eldorado: General Newbie Q
  50. P0340 & P1350 Error Codes & Tach Not Working
  51. 1990 Seville dash saying "Diesel Fuel Only"
  52. idle speed control
  53. 79 EL Dorado trany exploded
  54. Finally something good on Ebay...
  55. 99 STS "SERVICE THEFT SYSTEM"
  56. Gas Leak!
  57. Cruise control and overdrive
  58. 94 STS Can Someone Help PLease
  59. 97 Eldo Code P1350
  60. a/c condenser 98 eldorado
  61. OVER 7000RPM on WOT!??
  62. Tech2 Connection Point
  63. Slow Power Windows - 1998 STS
  64. CLick CLick from the drivers wheel well
  65. Just can't win, no cold AC
  66. Initiate Key?
  67. seville a good buy?
  68. Highway Tranny Problems!
  69. Hey check it out!
  70. 85 eldorado tcc switch
  71. '92 ETC stalling at lights intermittently
  72. Battery Temp Sensor
  73. A/C issues!! Anyone else having some? please read and post reply.
  74. Body Parts- Seville
  75. Are STS's Engines loud at start up???
  76. "Service Air Ride Control"
  77. ghettohoopdee-check this out...
  78. Recall issue, New post
  79. Is the owner manual for 1976 Eldorado available online to download?
  80. Broken ignition rod, replacable?
  81. XLR N* to 2000 STS!!!!!!!!!!
  82. Are Delco starters required for reliability in 4.9L
  83. Can a 2000 Northstar be swapped into a 97 Seville by using the 2000 engine harness?
  84. supercharger and bodykit needed!!!!!!
  85. Head Gasket Blown durning WOT, beware!
  86. Reset refrig low
  87. radio ?'s
  88. License Plate Housing- Needed, 94 Eldo
  89. 2000 Seville engine harness in 97 Seville
  90. Very Rough Idle 99 STS
  91. oil leak question in the late model STS (1992)
  92. Door Panel needed
  93. Sunvisor Tension Adjustment
  94. owners manuals in the sticky
  95. 98 seville parts needed HELP
  96. 96 Cadillac STS Error Codes
  97. 92 eldo radiator fix
  98. I need a top gun Cadillac guru...
  99. 1993 eldo steering wheel
  100. STS Interior light change???
  101. Set the timing on the vehicle
  102. Debating a 1993 Cadillac Seville STS
  103. Tire patching question 2 parts
  104. Head Bolts, How to not strip?
  105. Advice on removing dome light-homelink panel? (2000 STS)
  106. stabilitrak
  107. turn signal flasher problem
  108. 20W-50 Oil for a N*???
  109. Car Leaking "something" but from where?
  110. Another coolant question
  111. 95 Seville SLS - Should I refurbi$$$h it?
  112. 1996 SLS - bad AT input shaft speed sensor
  113. STS Rear Door Panel
  114. SES light flashing
  115. Deville Vs. Seville ?
  116. Recall Info
  117. 97 ETC: When to change radiator hoses
  118. Help me find this front molding/trim part for a late model STS
  119. Need Professional Machinic Help, 1992 Seville
  120. Need Help
  121. I Need Help!!! Just Look ..please!
  122. Need direction in looking for parts
  123. 98 STS Service Suspension System
  124. Top speed?
  125. 95 Seville Shift Knob
  126. Initiate key?
  127. Speaking of ebay hogwash performance gizmos....
  128. Woodgrain Steering Wheel
  129. More Power-Better Gas Mileage Cadillac Deville/Seville
  130. 97 STS Fuel Gage Problem
  131. Code Help On 94 SLS
  132. 98 Seville SLS to STS front bumper cover
  133. Help the new guy...
  134. over head console for 98 SLS or STS
  135. It's hot but not this hot!
  136. 92 Seville ...Temps go up when AC?heat is on
  137. Repair or Replace Rear Interior Panel
  138. Wiring diagram for 95 eldo.
  139. New to the board, need a little help
  140. 1985 Eldorado Biarritz wheels & tires
  141. rear lights went out
  142. Coolant Temp
  143. What is DIM B1324 code mean??
  144. 95 sts 159000 miles blown head gasket!!!!!!
  145. The best service manual for my 2001 Seville STS?
  146. 92 sts, Intermittent no start
  147. Front End Vibration
  148. AC compressor questions
  149. Need a pictorial view of the AC Blower Motor for 01 STS
  150. R12 to R134a Conversion - A/C not getting Cold
  151. 2001 STS Codes-Important Histories?
  152. 4T60-E or 4T80-E Transmission
  153. '96-'97 STS Buying Help
  154. Driver Name Setting on Info Panel. . .
  155. 94 sts climate cotrol/ outside temp inop
  156. Air Bag Removal
  157. Car Audio system question
  158. 2001 Seville STS Bose Sub Woofer Power?
  159. Clear history code
  160. Lights flicker when turn signal is on
  161. Heater/AC
  162. Need help with '94 STS codes
  163. Service Ride Control reset
  164. 92 Seville Injector Rails
  165. N* Engine Removal From Above
  166. Need Help Quick!!!
  167. Help! Fan quit working for AC.
  168. Old man with a '74 Eldorado for sale!
  169. Cooling System Service: need to flush?
  170. Service Ride Control
  171. ride control
  172. 1986 Deville Door Panel Removal
  173. dash lights flash on and off
  174. 97 Eldorado CD Changer
  175. How do I run codes on 01 sts
  176. A great photo for Eldo lovers.
  177. Questions about 1970's Eldorado.....
  178. No 1st ar 4th 96 sts
  179. $$ more problems
  180. driver window motor
  181. Pulling out the back seat
  182. Disabling "Service Ride Control" on 1994 SLS?
  183. where to put aftermarket speakers in 85 eldorado?
  184. headlight replacement
  185. Larger wheels on '72 eldo
  186. Replacing Crank Shaft Sensors
  187. 98 Eldo phone Removal
  188. 96 Seville Fan Blower Does Not!
  189. 92 Seville...Please Help!!...
  190. non working headlights 94 eldorado
  191. 88 eldo a/c problem help
  192. Engine Flooding. Need Help.
  193. Reprograming steering wheel controls?
  194. Cruise Control
  195. Greasing Control Arm Bushings
  196. Wtf???????????????
  197. Traction disabled on my 95 Eldo
  198. Oil Life percent guage
  199. 2001 STS Dash Speaker Removal/Replacement
  200. Rear passenger lock
  201. HELP! 92 Seville STS won't start
  202. Battery or something else??? HELP
  203. HELP!!!!!!!! Plastic tube ( vacuum?)
  204. 97 Eldorado fuel rail recall
  205. Delco 12 CD changer
  206. "91-"96 Eldorado & Sevillerear arm rest
  207. 1992 eldorado center caps
  208. Vinyl top
  209. How about another round of applause!
  210. HELP!! Keys fell into center console and cant get them out!
  211. Need help with AMP sub installation in 95' ETC
  212. 94 STS blower motor
  213. Water Pump Leaking
  214. 97 ETC Repair Results...$198 for wire set?
  215. 19's on a 2001 STS?
  216. How to remove 1994 Seville SLS radiator???
  217. 89 Seville wont crank.....Help!
  218. 1962 Cadillac
  219. Tranny cooler install...Link?
  220. Alarm Settings
  221. Gucci
  222. Ac is going off then on
  223. Northstar history
  224. Need Help, Front suspension is creaking
  225. 14.5 Average MPG
  226. Help on wiring
  227. Employee pricing and my feeling on it
  228. 99 Seville STS Shaky ride above 65 MPH
  229. where can i find a 95 STS engine ?
  230. NOT a repost...
  231. STS 94 air conditioning proplem
  232. water in wheel well trunk area-98 SLS
  233. performance headers?
  234. No overdrive in my 98 STS
  235. 92 Seville High Pitch Noise!!!
  236. Sequential Taillights
  237. 97 ETC transmission not shifting into 1st
  238. 1992 Seville Wine
  239. 99 STS rear ride height adjustment..
  240. Discussion on Gas...
  241. 97 Eldo ground wire problem Please Help!
  242. 99 STS Stability Problem
  243. Problems with my 93 Seville
  244. Gas leaking out of Carbon Vent Canister
  245. Need Quick Tire Answer
  246. 99 STS Sunroof...
  247. White Smoke?????????
  248. Brakes making loud noise...
  249. 98 STS Squawk/squeak noise from rear suspension
  250. Sloppy Drunk Front End & Tranny-Need Info Pls
