View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. What kind of Brake Pads are you using ???
  2. Nice car cover for the price...
  3. Smelly air conditioner
  4. "Green stuff"
  5. 02 SLS Self Diagnostic Help!
  6. Heating Question
  7. Oil Pressure Low Stop Engine on a 1999 Seville STS
  8. Underpressure installation
  9. 95 SLS Intermittent MAT signal
  10. 97 ETC - Low Tach and Speedo Reading
  11. Heat Is Not Working????
  12. transmission doesnt shift, code PO29, PO30
  13. Help me id this grille!
  14. 97 sts codes
  15. 1999 STS Front Bumper Removal
  16. Wood grain shifter
  17. How Bad Could It Be ??
  18. 1988 seville trans prob
  19. make eng data and ECM coolant temp same number?
  20. Need the letter A
  21. 92 Eldorado runs like a dream
  22. Squeeky Struts
  23. Battery No charge - 92 Sevile
  24. Two quickies
  25. EGR cleaning easy
  26. digital display goes off on.
  27. insrument panel lights go & on.
  28. insrument panel lights go & on.
  29. Burned out Tranny, now steam from Water Pump
  30. bad sound coming from... steering pump?
  31. '93 ETC leaking oil, is the pan bad or what?
  32. Smoke coming from the steerng wheel
  33. Not Shifting 1-2 at WOT
  34. Hey, Ranger!
  35. More fun with my '92 Seville
  36. WOW 84 Seville G-Ride Question !!!
  37. Worn Brake sensors?
  38. NEED HELP WITH RADIO INSTALL ON A 1992 Seville with AMP
  39. AO47 but pressure is too high??
  40. Help!
  41. I just need a diagram, not a whole manual
  42. starts but motor wont run
  43. Impotant To Me
  44. Pulsing/Rubbing while driving
  45. New 2002 SLS
  46. 97 ETC awful rattle at idle
  47. I'm a virgin STS owner & loving it!
  48. VIN Decoder / HELP
  49. 85 seville heater/ac
  50. Electrical problem in my 2002 Cadillac SLS! HELP!
  51. Service Stability System
  52. Dipstick locations
  53. Fpr
  54. Brake problem
  55. '01 Seville SLS burning oil excessively
  56. Coolant/Heater Core Problem, not sure
  57. Unusual, and somewhat disturbing noise....
  58. Fuel Pressure Regulator
  59. Few quick interior questions...
  60. Tech Tips?
  61. engine and vin ???????
  62. PCM damaged from motor swap?
  63. Lean Mixture
  64. U1064 - Loss of Communications with DIM
  65. How do you turn off automatic locks on '95 STS?
  66. Electrical gremlins are in my Caddy
  67. CODE P1527 - Transmission Range to Pressure Switch Correlation
  68. $1,735!
  69. 97STS codes
  70. What kind of fuel?
  71. 95 seville alarm woes
  72. 1994 cadillac sdv
  73. service soon light po48 code
  74. color code
  75. Lots of Lights On, PCM Going Crazy
  76. 1988 Eldorado 440T4 tranny questions
  77. AutoZone?
  78. HELP 88 eldo HVAC blower problems
  79. Help with car
  80. Looking for wheel parts
  81. 2001 STS Cell Phone
  82. 86 to 90 eldo console removal
  83. T063 Valve relay fault location?
  84. checking and clearing codes
  85. HELP! "SERVICE AIR BAG" ??
  86. Opinions on 80's 4.1 Digital Fuel Inj motor?
  87. Going rate for window tint?
  88. 84 seville - Funky Clunk?
  89. Video clips of my 95 SLS
  90. What's wrong wit this STS picture?
  91. NorthStar Cruising Speed???
  92. Electro/Chemical reaction in cooling system?
  93. Change Break Pads... Help, this is annoying
  94. SLS trim
  95. Widest Wheel/Tire???
  96. 1999 Seville SLS, Driver's seat vibrating massager
  97. Leather seat care..
  98. 97 STS - AC Delco Rear Passive Air Shocks Installed
  99. 1994 Seville heater a/c computer?
  100. new fuel pump with labor for $650?
  101. "cadillac calipers"
  102. Clearing OBD 1 Codes
  103. 4 heater cores in 6 months. Why?
  104. Water pump and Alternator Life 99 STS
  105. Rough Engine Idle - '99 Seville SLS
  106. Clutch Fan
  107. Climate Control
  108. Flushing Cooling system
  109. Drove my first Cadillac. I'm in love.
  110. '94 STS Mufflers
  111. Some pictures of my baby
  112. '85 Eldorado - Error Code 52
  113. parts car
  114. Where do can I get Chrome Rocker Panels and A-pillars for 94' SLS
  115. parts needed
  116. '93 Eldorado Transmission (?) Problem
  117. Auto-start / Keyless Entry
  118. Codes read: P029, P052, P109, I052, A047, NO SIR, NO TCS, S044.
  119. Set of AC/Delco passive shocks & struts for $218.07?
  120. '00 Eldorado Service Engine Soon Light and other issues
  121. 99 sts doesn't start on first attempt, but will after
  122. intermediate shaft to steering gear - pinch bolt?
  123. Arghhhh! Help Please
  124. 95 seville factory alarm
  125. Power Window Question
  126. 5% off at Rock Auto
  127. Inside Door Handle Broke
  128. 1980 Seville buying: what should I look for?
  129. How Much?
  130. Opera lamps
  131. 95 STS- A/C stops when hard acceleration
  132. Cloth top question...
  133. My other ride
  134. New to forum, new Cadillac owner
  135. STS Windschield wiper switch
  136. Trouble Code P0741 (TCC stuck off) Question on a 99 Seville SLS
  137. photos/products
  138. Parts Crossover, body
  139. few more questions about dropping my '94 northstar...
  140. 88 eldorado sending unit?
  141. Shift knobs
  142. where is the o2 sensor
  143. Traction Control Operation Check
  144. 93 sts wont start
  145. Winter In NY HELP!!!!
  146. cracked flexplate! cause?
  147. 1995 Seville rear suspension squeek
  148. My 96 STS
  149. What Is This Noise?
  150. Trying to Learn
  151. No Fuel level low message
  152. Struts or Seals: How to Tell?
  153. '95 ELDO shifting/ A/C / fuel guage
  154. ground connections ? Sts-93
  155. 99 STS head-gasket
  156. here is what I drive every day to work ...
  157. you guys ever see this nice caddy junkyard out by where I live ???
  158. 95 STS-HVAC Blower Motor
  159. 92 Eldo Idle Problem Help
  160. Rear Window Defogger on 99 SLS
  161. eldorado hood needed
  162. $1000.00 Reward !
  163. Took a long trip this weekend..
  164. how to replace gear shifter knob
  165. History of the Eldorado
  166. Polo Edition
  167. "Clunk" on take off
  168. start up problem
  169. Tell me If my Axel looks bent..
  170. 95 Seville Power Locks
  171. disconnecting my exhaust
  172. How much for an oil change
  173. Why'd they discontinue the Eldorado
  174. Fog Light Question...
  175. coolant draining problem
  176. Cabin air filter
  177. dropping my '94 northstar, and.. the wiring?
  178. winter
  179. Wiring diagram for Bose head replacement?
  180. 1990 eldorado code b447
  181. My sweet 99 SLS
  182. keyless remote programinig WEB SITE HELP ME
  183. Eldorados are really nice...
  184. Oil Life Monitor WTF
  185. A couple(few) questions
  186. Amp power line
  187. Mystery module between the rear speakers
  188. 1992 Seville STS-- any advice??
  189. How can I Up my Horse?
  190. Traction Control Light
  191. Hic Up while accelerating in a 2000 Eldo
  192. Won my case against PrimusCare! All repair will be paid for.
  193. 98 cd radio in a 97 sls
  194. Cloolant Problem
  195. Calibrating
  196. Gas prices are going down!!
  197. North* oil pan
  198. radio problem
  199. Water In Trunk 02sts
  200. Squeaky noise when applying brakes
  201. Rear suspension problem, still!
  202. Remove seatbelts - 1998 STS
  203. Need a vinyl topp
  204. Mag Suspension Question on '03 STS
  205. 92 Eldorado Transmission
  206. Have you ever noticed on your eldorado...
  207. AC Refrig replacement 92 eldo
  208. code question
  209. Help me with VATS
  210. Cracked coolant reservior... 97 STS
  211. 97 STS - Rear Coils R&R
  212. '98 STS front strut replacement
  213. light flash
  214. 97sts check engine light
  215. 1992 Abs Light
  216. 92 seville with dead dash
  217. 1997 SLS Blower Motor or Resister?
  218. Saber Wheel Size????
  219. '72 Eldo Covertible, what to expect?
  220. 1999 El Dorado Service Engine Soon light
  221. 1999 El Dorado-Service engine soon
  222. Slipping Tranny in 90 Eldorado
  223. 1996 STS rear vent cover
  224. parts diagram needed
  225. 94 SLS front struts???
  226. wrong anti-freeze?
  227. 1996 Seville STS wiper fluid pump
  228. removing 97 eldorado head rests..
  229. 1977 Eldo Steering Wheel removal?
  230. Radiator replacement, 92 Eldo.?
  231. 99 ETC suddenly hard-shift 2 to 3
  232. 97 STS Traction Control Problem
  233. Lost Ignition Key 1988 Eldorado
  234. 1985 seville wiring
  235. whrr...PANK!
  236. Strange problem on my 01 STS!
  237. RKE doesnt work??
  238. Car Battery Keeps Dieing!!!!
  239. 90 Eldorado tranny slippage
  240. Oil Level Sensor +
  241. 95 sts won't start unless shifter is "jiggled"
  242. 87 Seville "Gear select problem 27", Help
  243. Paradise by the dashboard lights ....
  244. 94 Eldo blown rear speaker
  245. can i?
  246. best place to buy interior parts please help
  247. 2000 STS crankshaft position sensors
  248. Fuel Gauge Not Working Correctly
  249. Courtesy lights
  250. 95 STS Fuel problem
