View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. custom convertible pics
  2. Overseas Stalling Trouble--Help Please
  3. Spin Tech Mufflers verse Corsa
  4. Fuel Rail
  5. AC compressor OFF low refrigarant
  6. Seville / Eldo dash swap?
  7. Squeaks Noise. Sounds like a mouse.
  8. Fastest 1996 STS on the Forum, Who has it? I may!!!
  9. Coolant change problem
  10. Heated Seat coverage
  11. Used Vehicle Review: Eldo/Seville-1992-2004
  12. K&N - Interesting Article in December 2005 Road and Track Magazine
  13. 2002 STS Test Drive...So Close yet So Far
  14. Service Air Bags
  15. 12 Oil filters for North* acDelco PF61
  16. bumper and scuff guard
  17. 98 STS Brakepad Sensor Questions
  18. Carbon Deposit cleaning TEC
  19. camshaft position sensor
  20. 99 STS starts hard when warm
  21. Quick question
  22. Codes
  23. I027 after wreak
  24. air hog??
  25. How do i remove the TRUNK LOCK?
  26. 1994 STS Steering
  27. Oh gosh....
  28. Power Steering Leak - Left Front
  29. 95 in a WREAK!!!DAMNIT
  30. K&N help 97 ETC
  31. See What Rice Burners Can Add To Their Cars
  32. Obtaining Helm's Repair Manual ofr 1999 STS?
  33. 96 Eldo steering column smoke
  34. 98 eldorado reliability
  35. Sellin the Bose Equipment
  36. 98 eldo blower woes
  37. 1994 STS Engine R&R Update
  38. Help with codes please
  39. Can the IPC display MPH on an OBD1 STS?
  40. Gas tank/ mileage
  41. New Wheels - How to RetroFit TPM's
  42. what would you prefer owning, SLS or STS?
  43. I'M BACK and readyto get started this time
  44. What Is Top Speed Of A 99 Sts?
  45. 98 ETC loss of power
  46. Update- I Have Heat!! 01 STS
  47. Golddie
  48. Another MPG Question
  49. N* comp&performance mods
  50. N* comp mods
  51. Buying a 1999 STS on November 17th
  52. Warranty for STS with over 90,000 miles??
  53. Is My Sts Z-rated?
  54. Need a taillight assembly for a 2000 Seville
  55. fule filter ????
  56. big mistake !!!
  57. wax ?????????????????????????/
  58. overheating 95sts
  59. How Change Fender Turn Signal Lights (87 Eldo)?
  60. 1998 Sts
  61. Need help, Code 46 on Monitor
  62. 97 Etc Cpu Mods Or Other N* Performace
  63. '85 Eldo Needs A Good Mechanic.
  64. thermostat change
  65. Troubled times :o(
  66. No TCC lockup
  67. My Baby
  68. New Here
  69. Astroroof
  70. 2000 STS keeps shutting off
  71. biggest rim/tire under an 98+ sls
  72. how to lubricate the power antenna
  73. fog light
  74. 1991 Seville [left oxygen sensor]
  75. Time to buy a new radiator!
  76. Water Pump Question?????
  77. Troubleshooting Code Numbers
  78. 1991 Seville - New to mechanic work
  79. I got the STS going again!!!!! :D
  80. Tranny Slipping, no code
  81. P1660 AC clutch diode... which way does it connect?
  82. rear leveler
  83. door panels
  84. TP's
  85. Cabin Air Filter
  86. NEED HELP ( no heat)
  87. Bose HU Connected into ECM?
  88. Water leaks
  89. Does this look normal to you? (Heater related)
  90. Temp Guage ??
  91. Double Din Kenwood screen in 94 STS
  92. Grills
  93. humming noise under radio/climate control
  94. Fog lamps for my SLS?
  95. Whats your age again?
  96. Rev Limit
  97. replace side view mirror glass
  98. Need Help Please! No Heat!
  99. Serpentine Belt Tensioner
  100. Tranny slipping, but no trouble code?
  101. I want BOSE.. what all do I need?
  102. 98 sts runs rough when cold
  103. Vote for (Inter)National Meet Location!
  104. Headlamps always on (Not DRL)
  105. Does anyone else have this problem???
  106. won't start - loud pop
  107. 2002 Cadillac SLS... faulty Crankshaft Position Sensor.
  108. Dealer informaton in Virginia?
  109. Sayin Goodby To The Ol' 93 SLS
  110. CAUTION! Don't make my mistake.
  111. Loose headlight
  112. no heat till engine is at noraml temp
  113. heat won't come out till temp is at normal
  114. Change computer language
  115. Engine Restore?????
  116. RSS Code needed...
  117. RPO List - a Big one
  118. Timesert issues
  119. 94 STS custom speaker baffles
  120. 92 Seville STS Dash Display Out
  121. Any tips on replacing the a/c blower?
  122. any Auto-RX eldorado users ??
  123. I would like to add a remote starter...
  124. ac lines
  125. Battery Question?
  126. iginition wires???
  127. bars leak seal
  128. 1996 ETC tranny question
  129. You guys in Texas beware.
  130. 95 Seville Won't Start
  131. vacuum canister
  132. ISC went south.
  133. Recalls?
  134. Questions about '97 seville
  135. Code p036 on my 95 Eldo?
  136. No 1st gear or overdrive
  137. Looking for '98 - '04 grille
  138. '76 Eldorado Cruise Control Working Soradically
  139. Slipping, whinning, hardly drivable transmission
  140. remote start problem`
  141. 94 Seville SLS Heater Blower Problems
  142. Someone enlighten me!
  143. Sts Problems
  144. SLS heated seats trouble
  145. Does this sound right?
  146. Looking to buy 96 STS for 3.5K, tranny issue
  147. Uh, strange stuff going on here
  148. '99 STS Won't Start
  149. '94 STS heater problem
  150. oil level
  151. emissions system service???
  152. Eldo Starting Problems
  153. ecm?
  154. How To Set Electric Dashboard Clock On A '76 Eldorado
  155. change engine oil message
  156. Need Some Direction
  157. codes/strut q please..96 seville sls
  158. Aesthetic Modifications? 95 SLS?
  159. Grill upgrade? on 95 SLS
  160. 96 seville - access to starter
  161. 2004 Seville / Satellite Radio
  162. 92 Nstar in a 94 Seville?
  163. Harsh Rattle from front and rear of vehicle.
  164. 2001 STS questions
  165. Ok, where the %&*# are my cheap struts at??
  166. Certified Preowned Warranty
  167. '94 SLS With N* and floor shifter?
  168. newbie looking at a 1996 seville sls
  169. Caddy/GM Paint Codes-HELP!
  170. VIU - Vehicle Interface Unit and VCIM: What are they?
  171. How do you drain the transmission?
  172. unleaded instead of super?
  173. White Back Up lights not Working
  174. Up and down idle in any gear...
  175. Glovebox lamp replacement - 2003 STS
  176. OMRON relay replacement part? (94 Seville)
  177. Dash Electronics pulsing and failing
  178. the seville left tailight and dash short problem
  179. I screwed up bad.. please help!
  180. P071 Code Intermittent Map Sensor returning
  181. HELP!! I can't seem to be able to find a cadillac seville sts aftermarket grill!!
  182. Traction Control Grinding?
  183. found a Wood shifter for Eldo/pre 98 Seville--Opinion?
  184. Radiator cooling fans after engine gets too hot.
  185. STS/SLS Adaptive Seats????
  186. maybe selling
  187. Most current 2002 GPS DVD?
  188. Bought 98 ETC, have some questions
  189. STS Tail lights for sale
  190. How to clear the security problem error message
  191. stupid stereo problem
  192. Door Mirror, replacement glass?
  193. heated seats
  194. Fuel Pressure Regulator.
  195. Parts, I Need More Parts
  196. Performance Exhaust... how loud??... corsa, Magnaflow, Dynomax, Borla, etc.
  197. 90,000 and 100,000 check-up
  198. Check Brake Switch
  199. XM Satellite Retrofit
  200. how to determine paint color on '76 Eldo convertible
  201. Engine too cold?
  202. 1996 ETC Parking Brake Problem
  203. 98 STS shifter problem
  204. A/C compressor oil
  205. 1985 Eldorado Baritz Convertible
  206. How do you stop Hub caps from rattling and clanging
  207. pending to buy 98 eldorado
  208. Heater Core
  209. ok.. here's one. Will this fit?
  210. 84 Eldo issues Please help
  211. 93 STS Electrical Problems?
  212. Tranny case ,crack ???
  213. Seville and Eldorado owners? Love your car but don't post much?
  214. thrid brake light
  215. '95 Eldo - Check Engine - No Codes?
  216. 95 Eldo RKE - Black Wire?
  217. 2002 Seville RKE Part Numbers?
  218. 1976 Seville HELP!....PLEASE
  219. Self Diagnostic
  220. Check Emissions Sytsem Brake Vacum Problem?
  221. A/C Compressor
  222. 96 ETC steering rack
  223. Tire Pressure Quandary
  224. Another speaker question???
  225. trunk pulldown
  226. SLS top speed
  227. Winter storage for 01 STS (looking for tips)
  228. Interior Parts Needed-- '95 STS
  229. "99 STS - To Service XMSN, or Not To Service XMSN,
  230. Anyone done an overhead map light mod ???
  231. Nice Display Mod...
  232. how does the !@%&*(!! thing come off??
  233. 92 eldo
  234. A/C Bypass
  235. 99 SLS Reset "Change Brake Pads" in DIC
  236. Crash Test Ratings
  237. Just bought a RHD Seville STS - a Few Issues - Help!!!
  238. Greasing Intermediate Shaft
  239. Auto Up Function
  240. has anyone replaced bulbs in analog instrument panel 96-97 Seville, 96-02 Eldo
  241. Factory Alarm - Add on Shock Sensor?
  242. Purge Line Question?
  243. Looking at a '96 seville SLS need advice
  244. sts tire size
  245. Eldo: Instrument Panel Cluster "BULB" color replacement
  246. Service Manual(s) for 2003 STS
  247. Tranny2000 Sts
  248. Service Engine Soon
  249. Possible Fuel Regulator Issue
  250. Whats This Wire
