View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Removing the trunk's weather stripping?
  2. Removing shifter trim plate?
  3. Rear compressor 98 sls
  4. 97 eldorado how to remove alternator?
  5. Replacing the PCV Valve 1999 seville sls
  6. Exhaust burble volume opinion: muffler SIZE selection time
  7. Need MAJOR Help with my 95 STS!!!
  8. How much oil after check oil message appears?
  9. High pitched whistling
  10. service engine light
  11. What Brand of Gas do you use in your STS??
  12. Bought another one
  13. Northstar reliability seems hit or miss
  14. Kumho Ecsta ASX - Anyone use them on STS?
  15. car Phones and hands free kits
  16. 92 Seville and I just want to use the heater
  17. Oil Changes?
  18. Eldorado fog lamps
  19. Suspension On '84 Eldorado
  20. Eldorado 1992 Need Help Wood Trim!!
  21. 95 sts acceleration problem
  22. A/C Compressor Leaks
  23. 1999 Seville Radio Removal
  24. 92-97 style headlight lens
  25. Wrong engine oil put in by oil shop...overtightened drain plug
  26. 1968 Eldorado
  27. '97 Eldorado...Drivers side window quit working
  28. Steering wheel neutral position slightly off, and low speed vibration
  29. SLS fog lights?
  30. Great trip
  31. Poor fuel economy
  32. Eldo door panels: reliable, easy fix found
  33. service engine soon code's
  34. code question
  35. Coolant heater for Cold Weather!?!
  36. 92 Seville and a rattle issue
  37. Golfers
  38. Got new front tires, and now....
  39. Head gaskets - 92 Seville 4.9
  40. I have a Huge Problem
  41. Need RADIO WIRING DIAGRAM 95 SEVILLE
  42. Biarritz Mouldings for 1984 Convertible Eldorado
  43. Finally Tha Time Has Come....
  44. Check out a quick clip of my SLS
  45. New struts already?
  46. Steering Rack and Pinion.
  47. tc and abs light only go out in the cold!!
  48. '94-'97 SLS Door Trim
  49. Upper Plenum
  50. Heat Only On 1 Side
  51. dashboard material on '95 sts
  52. cold weather = bad times
  53. not starting cold
  54. Heated Seat Wiring diagram 92 STS
  55. How many quarts??
  56. activate DRL in STS 97
  57. Gas Door No Open - Temp 20f, Snow & Ice
  58. Switching coolants...is it bad?
  59. Snow Tires
  60. 95 SLS Dashboard
  61. LED taillight repair
  62. too many miles?
  63. Hi to everyone
  64. Strutmaster front kit for sale
  65. Highway High-wind Stability
  66. Help, I need a power steering pump.
  67. does anyone know how to take off a steering wheel?
  68. steering wheel squeak while turning
  69. Steering Intermediate Shaft - What is it?
  70. Genius at work
  71. Got my service manuals finally!
  72. Ride Height Position Sensor
  73. Rain Sensor & interior lighting.
  74. Codes need help
  75. Another "is this normal?" Transmisson this time!
  76. Clanging from under the car when stationary
  77. Minimum blinks in DTS
  78. Replacing door seal rubbers ??
  79. 96 STS Drivers seat not working
  80. Power Window Regulator access?
  81. What is this leaking?
  82. 85 Eldo. Service Soon, Trouble Codes
  83. ride control problems
  84. engine mount????
  85. my new 2000 sls
  86. Code P032-open MAP sensor
  87. Is this normal for a 92 Seville?
  88. A040 Code What needs fixing??
  89. Might not be a caddy owner for much longer!!
  90. Custom Plates
  91. Getting an SLS
  92. IAT sensor
  93. 95 Seville Instrument Cluster Removal
  94. Lost my gold wheel emblem..
  95. 2003 SLS Vibration???
  96. Hazaed button
  97. Where did they build the 2000 Seville?
  98. 93 Seville STS overheating fixed
  99. Coolant tabs question
  100. Thanks everyone..!!!!!
  101. 97 Seville Stumbles
  102. Noisy lifter on startup, but v low miles?
  103. C1738 - Exhaust Solenoid Valve Short to GND
  104. 4T80-E ATF color 9 months after exchange
  105. Class II receiver hitch installation on 95 SLS.
  106. heater problems-91 Seville
  107. '98-'04 stereo question
  108. Eldo owners: Found a pathetic review of the Eldorado...
  109. New amp box installed
  110. OBDI Codes: short to ground open/short to B+???
  111. Self levelling every time I start the car?
  112. Service Ride Control
  113. artie
  114. artie
  115. Snow Yesterday - No Heat Today - Brrrrr
  116. Service record please
  117. Code P025 Ingnition Control Module, 24X reference low indicator. What is that?
  118. 92 STS - heat doesnt work - or - maybe I dont know how to use it ! LOL
  119. Traction control problem
  120. Idle problem and PCM code P0101
  121. 03 STS Hood Bra
  122. How to enter Diagnostics on 199 STS
  123. LED brakelight in Spoiler - ETC
  124. Oxygen sensor question
  125. Help please
  126. Need Help Service Engine Light
  127. Ugliest Seville ever
  128. A&C pillar cloth restoration.
  129. Proud new STS owner
  130. Need help finding a part...
  131. 4t80e Tranny oil cooler upgrade
  132. Is there a SLS and STS in '92?
  133. Does anyone know where to get a high performance alternator?
  134. 1994 Eldorado Prone to Surging While Idling
  135. Delay Wipers Not Working
  136. Need help with sway bar!
  137. ETC in Book, and the XMas Caddy Dealer
  138. Overheating problem.
  139. 84 eldo conv't tire size and white walls
  140. A/C Blower replacement
  141. How to find codes on DIC (SLS 94)?
  142. Climate control system
  143. alarms
  144. 2002 Eldorado - factory colors offered??
  145. Help!
  146. Oil Cooler
  147. RPO Codes...
  148. just bought an 01 ESC, have a few ?s
  149. TRAC Light on, & DIC shows "Stability Reduced"
  150. You guys ROCK!
  151. sls 94,*no start, no crank, no power when I try to start...
  152. Wow look at this '80 Seville!
  153. Road Sensing Suspension.
  154. Recall Experience...1999 STS
  155. Want New Interior 4/my Eldorado
  156. Seville OEM 16 inch wheel dimensions
  157. Headlamps Suggested
  158. UK RHD Seville STS - What did they change from yours?
  159. help me decide...sts vs dts
  160. CD changers. Want the smallest
  161. Door Card - Best design I've seen
  162. Oil leak
  163. Any 1991 Seville owners out there?
  164. 1989 eldorado on its last leg!
  165. Seat Heater problem in my 2001 STS
  166. '84 eldorado-alternator problem
  167. Where is over current limiter located?
  168. Tires,Tires,Tires
  169. Folding Seats on Eldorado?
  170. Stalls at stop
  171. ride height sensor 98 STS
  172. Hunter Road Force Balance
  173. New STS owner
  174. Strange Noise And Smell From Underhood
  175. What fog light # do I need for my 1994 STS
  176. Anniversary gift to my SLS
  177. Plastic AC/Heater Cover On Firewall
  178. Strut replacement
  179. 97 sts ebtcm
  180. 98 - 2003 STS / SLS stock muffler length?
  181. 94 SLS will not gain power
  182. 96 Seville Blower Motor
  183. Carbon Deposit HELP FAST
  184. Pic of the caddy I hope
  185. time sert or big sert
  186. 1998 eldo - c1243,c1234,c1255 codes -how can I turn off lights
  187. Ignition Switch
  188. '97 seville trunk cd changer wiring?
  189. Newbie saying hello
  190. water pump rusted in housing
  191. '95 meets '05
  192. fuel rail shorting out passanger side only
  193. 1995 Eldo To 1996?? Questions,,
  194. Camshaft Position Sensor
  195. Cig Lighter Draws power even with ignition off?
  196. Ip1910 Code What To Do???
  197. need a little help
  198. HELP! 1977 Eldo headlights quit working HELP!
  199. 98 sts seville lights
  200. Helm's Factory Service Manual--'99 STS
  201. MPG Tracking on Your DIC
  202. 94 Seville SLS - P039 & P110
  203. Moisture in taillight sections...
  204. 67´eldorado parts
  205. 94 Eldo on auction, Chicagoland area
  206. 93 faster than 97
  207. ok, what is this plug for??
  208. Keep blowing fuse?
  209. code history
  210. After tuneup, no change in fuel efficiency change
  211. No Boom
  212. 94 STS Blower Motor
  213. Pics of my 95 STS
  214. 94 eldo power window failure
  215. Flowmaster exhaust
  216. Something weird is going down!
  217. Cold Minnesota Air Sunroof Question
  218. service engine soon
  219. Need You Guys On This One, Please Help
  220. OEM Interior Parts
  221. Help with floor knock
  222. Fuel Filter/95 Sts
  223. Big Brake Kit - 99STS
  224. 99 SLS Dash Disply Problems
  225. Why does your mileage vary? vs the EPA ratings...
  226. Coolant Temperature Rise After Hard Acceleration/95 Sts
  227. What is this ?
  228. 98 cadillac sts
  229. 1992 Seville - coolant question - non N* engine (4.9)
  230. Head Gasket symptoms--- How Long???
  231. Please help!!!! 94 Seville leaking antifreeze bad!!!
  232. Eldorado and body style, what years did they change ?
  233. Performance exhaust for '95 STS
  234. custom convertible pics
  235. Overseas Stalling Trouble--Help Please
  236. Spin Tech Mufflers verse Corsa
  237. Fuel Rail
  238. AC compressor OFF low refrigarant
  239. Seville / Eldo dash swap?
  240. Squeaks Noise. Sounds like a mouse.
  241. Fastest 1996 STS on the Forum, Who has it? I may!!!
  242. Coolant change problem
  243. Heated Seat coverage
  244. Used Vehicle Review: Eldo/Seville-1992-2004
  245. K&N - Interesting Article in December 2005 Road and Track Magazine
  246. 2002 STS Test Drive...So Close yet So Far
  247. Service Air Bags
  248. 12 Oil filters for North* acDelco PF61
  249. bumper and scuff guard
  250. 98 STS Brakepad Sensor Questions
