View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Do I really need two ker when programing?
  2. Full Boar Exhaust + Z/28 Rectangle Tips
  3. Help radio has no memory!
  4. 1998 STS - B1343 Air Inlet Door Movement Fault
  5. Fuel Rail Campaign & FPR
  6. Looking at a 1998 Seville STS, what warning signs to be aware of?
  7. 97 STS help?
  8. rack and pinion two different ones for a 2000
  9. 98 eldo 60k miles.. some issues
  10. Digital Speed Display
  11. My Eldo and I are fighting...
  12. How do you tell if you have keyless entry?
  13. where to find AC parts online for 97 eldorado
  14. Keys, can you still get them from the dealer?
  15. Pre wired options.
  16. oil change brings knock
  17. 99 STS battery?
  18. Road Trip results
  19. Sitting Low, No Bounce
  20. poor gas mileage when accelerating
  21. '01 STS Noise and Bad Vibration
  22. 1994 Eldo N* with code p080
  23. 98 STS Stalling and Starting
  24. climate control problem help!
  25. Can't find front engine mount on Rock Auto?
  26. Pic: ETC Flight deck--note steering wheel cover, phone holder, and wood shifter
  27. How do I fix the backseat
  28. another paint question.
  29. 94 Service Manual set CHEAP
  30. Fast reply needed. Trans drain plug.
  31. mirror dips, won't come back up
  32. 96' STS shadtree 100k service complete....did i miss anything?
  33. 97 STS Needs Some Help!!!
  34. 74 eldorado paint question
  35. 2003 Sts
  36. Remote Start
  37. Need suggestion for filler for cd changer in 98 sts
  38. electric window diagram 2000 sls
  39. Ahem, I know ill get killed for asking this...
  40. Post Your Ride (56k DIE)
  41. Replace Seville engine with a Deville one?
  42. Homelink removal
  43. h.i.d. conversion on 2000 sts?
  44. Part Needed
  45. '97 Eldorado..Trying to Recharge AC
  46. 02 STS Remote Starter
  47. Northstar Oil Leak onto Exhaust Manifold?
  48. Aussie 1975 Eldo?
  49. new member needs new engine
  50. 2001 Seville Obdii Code Procedure
  51. Fog Light Wattage
  52. 99 STS fog light wattage?
  53. Need a part # please
  54. Is the "ELC compressor" same as "Air Ride Compressor"
  55. Parting out caddy
  56. 95 SLS Monroe strut/shock #'s?
  57. O2 Sensors and Tranny Ping
  58. Annoying high pitch squeel
  59. 97 Eldorado...Where's the Oil Filter Located ?
  60. Help - bent wheel/rims - Chicago area
  61. Strange Noise
  62. A/C Compressor Riddle
  63. Guess What Broke . . . (PIC)
  64. Do i have the L37 in my sls?
  65. Sorry to see it go ....
  66. 95 ETC won't start
  67. Part wanted
  68. codes on dash
  69. Help! - Roadster Top Blew Off !
  70. '96 SLS Gauge cluster cover removal
  71. Wet Carpet in back seat floor
  72. Replace Engine
  73. Possible Stut Noise??
  74. From Me To All Of You
  75. 2000 STS on ebay..No Reserve!
  76. check engine & upped MPG!
  77. 2000 SLS Keyless
  78. I want my 95 STS to run perfect! Need Advice
  79. Sts 1993 Tranny
  80. 93' Seville ...poor heat
  81. Most expensive repairs
  82. Very Poor MPG
  83. Seek Rec. on Exhaust Shop in Cleveland
  84. Passagers door mirror
  85. Part number 98 STS front brakes?
  86. codes
  87. window switch 96 Seville
  88. 98 STS radiator fans
  89. Check oil, but oil is almost full
  90. Anyone ever see a rear lower control arm mounting failure?
  91. 94 STS - Wheels and hub caps
  92. Ran out of gas, now runs horrible. Fuel Pump?
  93. eBay 2002 SLS????
  94. Recommend steering wheel cover?
  95. 96 SLS Plug Wires--YESSS!!!
  96. Is It The Fuel Pump
  97. P0741 code
  98. Beware of Cadillac Dealership Services like Penske in Torrance, CA
  99. Decision Help
  100. service engine soon
  101. heater core ???
  102. newbie saying HI
  103. Tire rim leak Can I use a Tube
  104. Interior handle broken!!
  105. Owners Manuals in PDF (NOT Service Manuals)
  106. To all '02 SLS owners
  107. Factory service manual
  108. Starter question
  109. No dash power only speedometer
  110. Harsh Shifting Transmission
  111. Elec Seat Switch for 79 Eldorado Biarritz
  112. European Eldo versus US-Eldo Rear lights
  113. gas door frozen shut
  114. Tail Light Lens Condensation
  115. dash question what years
  116. Steering wheel controls
  117. Need to know what these parts are
  118. 1997 eldorado etc exhaust
  119. I the Northstar for me?
  120. windnoise/whistle
  121. Stupid question or what?? block heater
  122. 95 sls Code P094
  123. 1995 Eldorado ETC
  124. OK this is interesting
  125. 96 El Dorado FSM Owners... HELP
  126. northstar at high speed
  127. Northstar or 4.9L traditional
  128. Thermostat Problems
  129. Serious Problems with 95 STS. HELP!!!!!!
  130. gas mileage/tach readings?
  131. Service Stability SYS
  132. 85 eldorado front speakers?
  133. HVAC question for an '87 Seville.
  134. paint
  135. Only 1 Wiper
  136. Factory Olo On Ol '76 Eldorado
  137. New to Eldo/Seville Forum
  138. Battery terminal question?
  139. coolant question
  140. 96 El Dorado Seat Heat Switches
  141. Heater 1998 STS
  142. Ok Wtf!?!?!?!?
  143. '97 Eldorado.. Windshield Washer not working..
  144. STS or ETC? / SLS or ESC?
  145. Have P0139 Code, Service Engine and Emission System Lights On
  146. Curious Radiator
  147. Which year is the best?
  148. what clusters interchange
  149. Brake Booster
  150. Block heater
  151. Am I just dumb or what?
  152. 2001 Eldorado heater at 90
  153. B1652 - Loss of Keep Alive Memory HISTORY
  154. Reading OBD codes information.
  155. Failed bulb indicator?
  156. how to check my codes in 00' sts?
  157. Only 1 Wiper
  158. Heater Hose
  159. Some useless information
  160. code p110 2day
  161. Broken door handle
  162. Another code question?
  163. Need parts for Christmas Present
  164. Arnott Suspension kit
  165. Rattling rear view mirror
  166. Motor Mount Count...
  167. colder weather: shifter button stiffens
  168. Burns Oil...help
  169. Glass Replacemant
  170. FSM - any real diff. btween '00 and '01?
  171. Scratch one STS
  172. Driver side electrochromic mirror not dimming
  173. whats under my air filter housing????
  174. Engine computers
  175. When to change trans fluid
  176. P023 trouble code
  177. Rear Shock Absorbers
  178. Reading onboard diagnostics
  179. '75 Eldorado in Snow
  180. Dynomax Super Turbo review, Eldorado Touring
  181. Looking at purchasing a used '97 STS
  182. Really Really Bad Gas Mileage! Why?
  183. STS 1994 turned into a swimming Pool
  184. Strange noise from inside car
  185. Average mileage?
  186. Trans fluid change
  187. Difference between 1997/98 STS
  188. Brake and turn signal light problems
  189. radio/CC lights out
  190. front end noise
  191. 2000 Seville
  192. Warming up the Northstar ??
  193. Production Figures - 2000 Seville STS
  194. 2000 STS - Is a fast launch even possible?
  195. bad #2 crank sensor, but bad PMC?
  196. 1997 eldorado etc with a new blower motor
  197. Engine Overheating indicator
  198. Clean Cassette?
  199. overheating - but with a twist
  200. Vehicle Weight
  201. Help - Service Engne Soon Light came on
  202. Once Again...
  203. crank position sensor
  204. Rubbing-Brakes? Steering? WTF.
  205. Another Question A/C
  206. Help!!
  207. Wheel squeeking
  208. Need Help Please W/95 Sts
  209. RPO #'s please...
  210. Ewill3rd - seat heater question
  211. Heater blowin out cold air
  212. Car dies when i slow down
  213. Please Help Need Input/ 1995 Sts
  214. Codes for a 93 STS?
  215. Radiator Fans, Stays On...
  216. factory rim question
  217. Engine shuts off while driving
  218. Fair price on service manual
  219. 96 STS Blower Moter
  220. 92 Eldorado ECM Problem??
  221. Rear Windshield Cracked today
  222. ELC (Electronic Level Control) part?
  223. Warranty
  224. Steering wheel buttons
  225. key question
  226. ARGHH! I hate this DIESEL Eldo when it's cold!
  227. Change tranny fluid?
  228. 93 STS/ Cup Holder/ Latch
  229. 94 SLS Starter
  230. What is the correct pressure cap limit?
  231. Eldorado Tires
  232. Gremlins molested my car's electronics...
  233. Caddy hates hot starts....
  234. whiny noise from rear of engine compartment
  235. Exchange 2002 Northstar STS engine to 97?
  236. 92 Seville knee bolster
  237. Code PO 71 MAP sensor 95 SLS
  238. Who in the right mind vandalizes someone car???
  239. Opera Coupe
  240. Power Window Regulator?
  241. Good News! Kinda....
  242. Transmission hesitating
  243. ISC Brand
  244. Which Nothstar motor!?
  245. trans backlash
  246. i need an engine
  247. Removing door sill plates?
  248. Advice on pin stripes
  249. Engine
  250. Tightening side mirror screws...?
