- hey my rough idle i think i know ?
- Water pump belt removal
- for sale: 74 Eldorado 55K, $4995
- Check engine soon. Digits missing on info centre
- 98 ETC vs 98 STS
- No A/c, No Codes
- Dashboard Vent...
- I want heated seats, Is this plug and play?
- hey Mr. mtflight....
- Water pump install
- new lifters or engine flush?
- How many brakepad sensors are there?
- Serpentine belt replacement question
- A few questions regarding my 2003 STS
- 90 eldo running rough
- Gas pedal sticks...
- 97 Seville idle problems
- Is my stock cd player fixable or is it broken for good?
- do all sevilles have cup holders?
- Painting Chrome grill, how to if it is possible?
- 97 Eldorado...Looking for new tires...
- Ride Height Adjustment w/F45 (Stabilitrack)
- AC System
- Fixing up my car, please review before i bite the bullet = )
- isc still !!!!!
- what do you sls/sts owners think of this car
- Radiator NIB Feeler
- Exhaust for Eldorado?
- Selling her
- 2000 sts, feals very weak??!!!
- Physical tire size difference...MPG ??
- 1999 Toyota corolla VE V.S 1996 STS is it worth a race?
- just bought a 98 sts
- Anyone have a GM Service Manual for a 97 Caddy
- P0741 (TCC stuck off) at 80mph
- Dirty&Scratched Headlamp Covers
- cracking sound in drive and break on only when turning wheel
- Looking for SLS Grill & Genuine Sheepskin seat covers
- Door lock problems,can the power lock cilonoid go bad?
- Traction Control Switch
- Needed: Stereo wire harness diagram!!!
- ECL(ELC?) Fuse
- radiator flush?
- NOOB QUESTION, How To Change Fuel Filter
- Question about tranny???
- 1994 cadillac eldorado, is dead!! HELP
- RSS 1761 Position Sensor
- Considering Purchasing a STS
- Rear End Humming
- sunroof issues
- Is This A 1997 SLS?
- Newbie, looking for an STS, any advise?
- 1998 Alternator Amps?
- Looking for a new sts caddy
- I Failed Emissions Test???
- mods
- Moist back headlights
- MINT 2003 17" STS Chrome Wheels 4 SALE
- i need help with a motor!!
- Broken wire by fire wall, does anyone now what it goes to?
- If Only I Had the Room....
- How do I get ABS codes if I dont have Traction control?
- Thinking of dumping tire pressure sensors
- Seville Struts
- which years transmission fits in 98 STS
- 99 STS warning messages
- another code problem
- Weird electrical stuff
- Does the radiator on a 99 have a drain plug?
- Wiring Valet Switch to Allow Remote Trunk Access?
- adding STS fog lamps to an SLS model: can it be done?
- Strange sound after i instaled E&G grille
- seat heater fixed- 98 STS
- how much oil uses...
- Codes in car, but not on Diagnostic
- cant turn water pump with the tool
- Window Sticker
- need onther part!!!!
- 97 Eldorado - Steps for Replacing AC Compressor ???
- SES comes on at start in cold
- heater ?
- How To: Replace front Struts: Documented with photos
- CARFAX for Repo, please
- How do you put in your name instead of DRIVER NO. 1
- New STS wheels
- 94 SLS Exterior Accessories
- Wood-Grain Steering Wheel
- Locking Steering Column to Remove Rack?
- Interior Paint?
- right oxygen sensor
- HELP!! What's normal? pmc codes '95 STS
- '03 STS Navigation without XM. Upgradable?
- Hey guys...advice please!
- Serious MPG problem...
- Baseball card in the spokes noise from my STS
- looking for a grille
- 1993 Cadillac seville suspension problem
- Has this happened to you? Problem or fluke?
- What does the code IP1910 mean??
- 99 Seville Crankcase leaks
- what does this wire do?
- Front seats of a 89 Eldorado
- different size tires for my 98 eldo?
- First time checking codes
- Oil Changes, 2000 STS
- finally figured it out..
- Dic Help????
- AC Question
- 97 Eldorado AC Oil PAG Oil Weight...
- Hi i need a part .....
- Turn SLS into STS?
- New Flip-out
- STS in the UK
- Bad Gas in 97 SLS
- 2002 STS, confused over posts here
- 97 Eldorado - AC - Flushing System
- Water Pump
- Some pics of my 1970 Eldo
- Should I buy this Eldo?
- Profile
- help with my isc
- Fuel grade
- Heater Core drain?
- 99 STS Headlight Failure
- C1762 - Left Rear Position Sensor Input Fault
- Interior color code
- clearing all codes
- 0-60 time
- 1995 Seville SLS first car ever having problems
- Error codes, Help
- Adding fog lights to 98 SLS?
- Check This Out!! Barn Fresh Eldo!!!
- Diagrams/Images of N*
- Anti theft Enabled 91 Seville
- What make/size tire do you use?
- Faulty PCM?
- MPG question
- Drl
- 99 STS Governor
- Uhh wth... My inside door release is broken?? 01 Seville
- coolant system question
- New Shift Knob
- 1994 Sts!!!!!!!
- Need Help on power window 97 STS
- 97 Eldorado - AC - Replacing Expansion Tube...
- ABS & TC Warning Light
- Please Help w/Seat Swap
- Power Antenna broken, any unique solutions?
- Understanding Codes??
- Seat Control looses its mind & Turn signal Problem
- slight shake btween gears
- MTV Meet the Barkers-- 67 Eldorado "El Conquistador"
- Well, it USED to be a nice Eldo,,,,,
- wheel size
- 1994 Seville STS - Doors won't unlock with remote
- 2006 STS 18" Wheels
- Aux Audio connection
- I have a idle issue somtimes help!!!
- 99 Eldorado Headlights
- Car Cut off / lights out
- Cold weather idle issues
- Gas door popping open
- Got dynomax
- 96 SLS Dash Problem - by Cad Tech
- Speed limited to 90, HELP
- Howdy
- Factory Navigation 02 Seville
- Success Story
- Success Story
- Codes on a 93 STS
- 1/4 Mile Times
- I need platform shoes.
- Angel eyes question
- 93 Eldo Flashers Rapid
- Oil Pressure Switch
- Radio doesn't work??
- 98 STS (advice...)
- Speed Limited To 90 Mph
- Silverstars for Fog Lights
- Can someone run a carfax or get a Service History?
- What's In A Number
- Extended Warranties over 100K
- 91 Eldorado- Engine turns over but won't start
- Sticky Gas Pedal?
- Considering A Seville, need a little input
- S038 Code
- 92 Seville SLS, talk to me about them. Found 1 for sale cheap
- 1994 Cadillac STS 4,9 Northstar
- Water in spare tire well?
- Ride Height Sensor -- Unusual Question
- How To: Change Rear Brake Pads & Rotors, Documented
- 97 Seville STS
- coolant leak
- Can this dent be popped out?
- water in trunk
- Should I...??
- Eldorado Prototype for Auction -- Real or fake?
- PD07 data
- 98 Sts Headlights Waterspots
- Help Dash trouble!!!
- 94 ETC 4.6 Wont start!!! HELP PLEASE
- Eldorado Emblems / Side Pillar
- Removeing trunk hinges,how?
- Angel Eyes
- martyp
- Engine mounts....who's got them?
- disable drl's
- Code help
- 1995 Eldorado Code Po41 Still?
- New To The Site
- eBay NOS Radiator from Alpha Auto - (PICS)
- Cadillac classified?? Where to sell used parts.
- 99 seville tune up question
- Need Northstar Help PLEASE! DECISION TOMORROW MORNING!
- Oil Pump
- GTNX-120 rear view mirror
- My Eldo Dies
- alternator no charge since radiator install
- Bumper Clearcoat
- 1996 Spark Plug Gap
- 97 Eldorado no driver side heat.
- 98-04 Seville floormat suggestions??
- Question for a 98 Seville STS
- Nob questions on sls and sts?
- Battery problems again
- water pump 94 etc
- retrofitting eldo wheels
- 97 Eldorado..What do they mean when they flush the AC system ?
- R&R Procedure for Thermostat Housing?
- Seville - Head Gasket Problem
- Help Rear End All The Way Up In The Air!! 98 STS
- 98 STS P1599 Engine Stall
- Service Record '02 SLS
- Replacing Air Cond Components.. Do I need oil?
- part # request
- o2
- 93 STS Owners!!
- 1996 STS aftermarket cd player help
- It takes two or three attempts to start 1998 STS
- 1994 ETC Bumper Covers
- Power steering??
- What would you do?
- how to protect chrome sts wheels
- Caddy dealer dmaged my quarter panel...
- CD Changer
- Oh Sh*t Handles?
- Cracked Windsheild with Rain Sense wipers.
- Key Codes Needed, '79 Seville
- Random voltage drops at cruise - 2000 STS
- bose stereo upgrade to 98 seville SLS
