View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Quick Help I need today please...
  2. 2003 Sts Performance Improvement?
  3. Adjusting the doors... How?
  4. Vogue 18" Rims, will they fit?
  5. I Can't Believe My Luck!!!
  6. 94 Eldorado 2000 mi round trip notes
  7. voltage 2000 Seville SLS
  8. 1997 eldorado control arms
  9. 1996 STS parking beake stuck on
  10. value of 78 Seville
  11. 2000 ETC Eldorado For Sale on eBay
  12. Steering Shudder...
  13. recing chip for 2000 seville sts?
  14. Wheels
  15. steering wheel removal on a 98 sts
  16. Radiator petcock and flush?
  17. tires
  18. Does anyone else have electric struts on there seville?
  19. 97 sts trouble codes
  20. Eldorado driving shudder
  21. Eldorado Seats Through the Years
  22. S Rated Vogue Tyres for Cadillac STS
  23. 1999 STS Oil Pump Low Pressure
  24. heater cold on right half ducts warm on left sid
  25. heater/ ac problem
  26. Stupid Struts
  27. 1999 STS Oil Pump Low Pressure
  28. What is a good site f/AC DELCO parts?
  29. In a flat area, is a compression/leakdown test the only way...
  30. Hesitation Problem/ got codes
  31. Driver-side headlight and rear view mirror question
  32. richmitch 97 seville sle
  33. Idler Pulley Belt Tensioner Squeel advice for 96 STS
  34. 94 Seville sls...
  35. fixed the 98 eldo starting prob
  36. My wife has the option to trade her car for a '94 STS
  37. Should I keep my 99 STS?
  38. Cooling System Seal Tabs
  39. Part number for Eldo chrome door moldings/trimmings?
  40. seville sls 96 window glass rollup sticks
  41. Couple questions on the bose gold series stereo.
  42. Purchased 95 STS and Need imput
  43. road force balance
  44. Transmission fluid -- a few small bubbles.
  45. 1989 Eldo: Clunk when shifting from Park to Reverse
  46. grinding noise from dash
  47. Shameless Plug...US Speed
  48. '92 Seville - antenna broke
  49. 1996 Seville SLS Custom Dash
  50. 98 sts grease zerts
  51. 2000 cadillac seville sTs.. custom grille with emblem?
  52. 1994 STS Sputtering
  53. seville SLS 96 window switch or regulator?
  54. Aftermarket Sunroof
  55. XENON Premium Bulbs????
  56. can i put 2000 deville side mirrors on seville?
  57. Color Codes
  58. Radar Detector For Sale
  59. 1998 Stock pan gasket question
  60. plugs and wires...which ones?
  61. 99 STS Exhaust Clip - Dynomax Super Turbos + High Flow Cat...
  62. Need '92 Seville Transmission Dip Stick Length - Transmission slips in second gear!
  63. 2002 NAVIGATION IN a 1998 Seville
  64. 96 STS Won't Shift past 2nd
  65. Cost for replacing '93 STS shifting solenoids - WHAT?
  66. Looking to buy...
  67. Chrome trimmings on 93 and 95 Eldorados interchangable?
  68. Car is occasionally hard to start.
  69. E53 code, car wont start...........PLZ HELP.
  70. ok so my car needs help please!!!!!!!!
  71. 1995 Eldorado
  72. Help Handy Husband not so handy
  73. My 91 Eldo just DIES!
  74. A very bad day
  75. Strange Sound
  76. Car Insurance Comparison Site
  77. 94 STS Headlight Adjustment Screws
  78. Want new mufflers and need some help on which ones.
  79. 1989 Biaritz Interior Trim
  80. Which Seville STS should I buy and why?????
  81. 98 eldo didnt want to start
  82. 00 Eldo trunk seal part #
  83. Few Questions...
  84. Replacement taillight lens
  85. Pulled ABS codes a diffrent way, do they sound right?
  86. Sunroof Wont Stop
  87. 96 STS 1/4 Mile Times and Video
  88. Just out of curiosity.
  89. Rotors
  90. Front light and Fog light clean procedure.
  91. do they make diffrent keys for our cars?
  92. strange interior noise
  93. C1286/C1287 and "SERVICE STABILITY SYS"
  94. 92 STS service engine, on and off and on and off...
  95. Need clarification on BOSE options in 03 STS...
  96. Deville wheels on Seville
  97. How to get the codes from a '93 STS? Tranny problem :(
  98. No Cam Reference Signal from Ignition Control Module
  99. smart chip
  100. Searcing for '93-'97 STS: what to look for?
  101. taking apart my bottom trunk latch
  102. Car wouldn't start
  103. coolant pipes behind engine
  104. Gas Mileage for a '94-'95 Seville
  105. Shutting car off with climate control on AUTO, is it OK?
  106. High quality dash cover?
  107. Charging issue?
  108. Car wont start
  109. Brake question -- replacing hard lines '93 STS
  110. European Grille on 1996 STS ?
  111. cooling fans
  112. Is the Hunter Road Force Balance really worth it ?
  113. Bent 'K-frame'...Help!
  114. For the cadillac experts
  115. Chrome Door Handle Kit for 00 STS
  116. Help! How to get rid of Traction Control on a 95 SLS
  117. 1997 eldorado etc control arms
  118. 1996 eldorado heater blower
  119. License Plate Lamps 1997 sls
  120. 1998 rear break-lite bar
  121. no trunk pulldown
  122. Automatic Trunk Problem
  123. Pcv
  124. Spoiler on an Eldo
  125. Bought a 94 STS!!!!
  126. 1985 Eldorado Barittz Radio help
  127. N* vin 9 for 900! Enjoy guys thought someone here could use it
  128. Cracked transmission case
  129. wow my car freaked me out !!!!
  130. oil
  131. Bakup Assist
  132. N* Preventive Maintenance: suggestions?
  133. '99 STS SES lights but all codes are "history"?
  134. long crank- hot start- 98 STS
  135. no heat to the drivers seat
  136. *Wanted* 1998 STS Chin spoiler
  137. A Few Quick Questions
  138. Wait 3 minutes
  139. Wait 3 minutes
  140. Weird Sound from motor
  141. removing console controls????
  142. 00 ETC Power antenna
  143. STS Replacement Engine Nightmare
  144. somebody help i need new seats!!!
  145. Ok, let me try and explain....
  146. How to change Tranmission fluid
  147. DIC Says I Got 17.5 MPG
  148. Can I have a bad FPR and can it do this?
  149. 1999 STS Questions (susp, speakers)
  150. Service Ride Controll...what do I do about it
  151. 98 STS overheating
  152. Help
  153. License Plate Lamp Rplacement 97 SLS
  154. Changing '92 Seville spark plugs
  155. Door Weatherstripping...
  156. Picking up a cheap 97 sts...
  157. No pass. power window?
  158. Head rest repair
  159. 98 Seville SLS ride quality???
  160. 1976 Cadillac Eldorado Convertible Help
  161. A little help with an '84 Seville
  162. My 95 StS factory CD player not working! Please help
  163. slow responding cruise control- 99STS
  164. "Stabilizing" advice would be appreciated!
  165. Purchased 01 Seville STS
  166. My 98 STS has 3 codes:PO741,P1614,PO420
  167. Knocking/ticking from motor? 93 Eldorado
  168. BMW M3 Lip Spoiler - Pic
  169. Opera Lamps - Where can I buy them?
  170. DVD Upgrade
  171. 96 Sts Won't Always Shift To Reverse
  172. Chrome Mesh Grill for 98-2003 STS???
  173. Help Please!
  174. Cadillac Graveyard
  175. suspenion
  176. Squeaky Break
  177. Horsepower boost
  178. '97 Eldorado.. Got a good deal on tires today...
  179. Water getting in by windows on 93 Eldorado
  180. 93 Eldorado stuttering during acceleration
  181. Need Help Asap Altenator Info
  182. Beginning in 93 to present, which Seville is the fastest?
  183. Just got Eldorado with minor problems. HELP
  184. 99 Seville STS Charging Problem
  185. P1258 code and very low coolant... Mystery to solve...
  186. Smoke at WOT, is this normal?
  187. redyeing leather has anyone done this?
  188. Cruise Control Unlocks Torque Converter?
  189. hey its me with the idle problem help please!!
  190. Saudi Arabia's dream Cadillac!
  191. '92 STS Lower Valance grill ??? Is there one
  192. 01 ETC is it worth it
  193. how much amp ?
  194. Grill for 92 Eldorado?
  195. Question;98 sts heater core change
  196. Reached 100,000 miles today!
  197. Please help car shakes a little......
  198. Door handle assembly?
  199. Best way to change the coolant on a 96 sts
  200. Good Winter Rims
  201. Power Steering Pump side of engine is making an ear-piercing whistling sound on 98STS
  202. 1995 Eldorado Crankshaft Sensor?
  203. Whats the problem????????
  204. Display Coolant Temperature?
  205. Suggestion on 98 projection beams
  206. Service Engine , A/C and Heater Problems
  207. Heater core Flush or replace?
  208. Fog light removal 99 STS
  209. Granatelli Trans Tuner
  210. Lowering Springs
  211. Tech 2 capabilities
  212. '77 Seville - 350 FI - Runs/Dies
  213. Click, Click...
  214. battery volts
  215. Coolant Leak
  216. 98 STS engine cover part number
  217. Seville/STS sunroof removal
  218. Remote#2 Giveaway- Pay Shipping or P/U
  219. love this 98 sts but....
  220. Opions wanted on a 1980 Eldo Brtz
  221. 1981 - 1985 eldorado ?
  222. FOB Relearn procedure not working?
  223. AC Compressor rattle?
  224. 98' Eldo Power steering problem
  225. Buying 2000 STS, what do I look for?
  226. Tranny service at dealer?
  227. 98 Seville Sts Dash lights stopped working
  228. Car overheating
  229. Overheating 97 Northstar SLS Help!!!!
  230. older sevilles with keyless entry, do your lights/horn honk when locking or unlockin?
  231. ugly gray on my SLS
  232. How do I burp my baby?
  233. 96 Northstar sls power steering leak
  234. My current issues
  235. Transmission Plug Question
  236. Several Codes - No ABS Data...
  237. Heater core lines
  238. Service Ride Control coming on and off
  239. Headlights on and of when opening door.Do all sevilles do this?
  240. stereo question
  241. HID headlights are great.
  242. How to get to the Alternator on a 96 ETC
  243. Dealership Invoice.
  244. Wake Up procedure & Drain Tubes
  245. 1998-2003 Hid Lights FS
  246. Shifter Knob
  247. My STS failed the block test
  248. Tried a couple of arty shots today...
  249. 97 Eldorado. Stalled and died. No warning at all.
  250. Another Transmission Problem
