View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Code PO94
  2. 99 STS codes
  3. Window Sticker
  4. Power accessories relay/timer problem HELP!
  5. Need Parts Info
  6. Good tires for '95 sts?
  7. 97 Eldorado.. I wish there was a way to enable the traction..
  8. 94 STS Signal Light Problem
  9. '99 Eldo Video
  10. 1996 STS- Free to good home
  11. How to control climate control fan speed ?
  12. Florida Owners
  13. Turning Light Question.
  14. Keyless Entry Programming...E-bay
  15. Exp Id 113 ?
  16. '03 STS Climate control reads 10-15 hotter than actual
  17. '94 STS Transmission...
  18. Leaking coolant
  19. Service Engine Soon!
  20. Auto-Dimming Rear View Mirror Question...
  21. Driver side mirror glass
  22. Carbon build up on the intake....
  23. 94 seville overheating???
  24. 2001 Eldorado Steering
  25. How to get codes?
  26. 1996 Eldorado Fuel Pump Diagnosis Help!
  27. traction disabled
  28. Traction Control.
  29. SLS + ETC = impossible
  30. Whats your favorite Cadillac Color?
  31. 97 Eldorado.. How to change the rear spark plugs ?
  32. How To Change Trany A Solenoid
  33. Blower Motor Intermittent
  34. steeringwheel botton lights???
  35. code question
  36. STS running beautiful!!!
  37. How to remove rear seat on 93 seville?
  38. Seville Paint colors/codes year-year
  39. 99 STS dead!
  40. 95 Seville Brakes making air hissing noise
  41. 93 Seville Throttle body cleaning
  42. Top Speed 110!?! WTF. Is this right???
  43. 2001 SLS Flasher Location??
  44. Trunk Lid not closing tight!! Motor?
  45. interior door panel, split in "leather"....
  46. False codes and history question
  47. Long Haul
  48. crankshaft position senors on 2000 STS
  49. Can anyone help?
  50. help what could cause ? ? ?
  51. Found Navigation Code New!! 6497
  52. Heated Seats...Clicking Noises in Dash!??
  53. WOT virgin, affraid
  54. 2000 STS Intermittent start issue and stall
  55. Fuel Level Sensor Kit for 97 STS
  56. 1999 STS Electrical Issue
  57. Rear Air Ride
  58. "Theft system problem"
  59. Replacing 97 Eldorado Air components.. Very Satisfying !!
  60. Seville SLS Oil Burning ?????
  61. Bumpers 75-76 Eldorado
  62. high pressure power steering line?
  63. 91 Eldo Intermitent Elec. Problem
  64. Rim opinions
  65. FPR....or not??
  66. 2002 SLS engine stall
  67. Oh wise car guys, please help :)
  68. interior lights dont come on when door opens
  69. STS aftermarket radio replacement
  70. 95 SLS Radio Removal?
  71. Laundry List O' Woes....
  72. Transmission ID tags
  73. Rear Window Restriction
  74. H rated sts vs v rated sts...questions
  75. what is this world coming to
  76. 1985 seville body parts
  77. Ranger Need Help Once More ?? ?? ??
  78. Help With Codes
  79. Service Engine Soon Light On Could It Be Major ??
  80. Need More Help Please ? ? ? ? Gotta Problem
  81. 01 STS Climate Control Problem
  82. 97' SLS Questions!!!???!!!
  83. Eating out at Beavers
  84. 89 Eldo and rust
  85. Dyno'd my car today - puzzled
  86. '93 North* engine removal ??
  87. replacement of front motor mount
  88. where to get STS manual
  89. Update on rear brake pads for my '01 STS
  90. A few ?'s
  91. Should I get rid of my Bose system?
  92. Bike Rack / Canoe Rack / Roof Rack / Hitch
  93. Were my heatercore hoses crossed?
  94. ACM B1315 code will not clear
  95. 92 Seville door handle relay problem
  96. 92 Seville where to buy license plate bracket
  97. 01 Seville STS trip report
  98. Would it...?
  99. 87 Eldorado: Keep or Sell
  100. odd noise when cold
  101. difference in transmissions
  102. 1993 STS Heated Seats
  103. 2000 ETC heating\AC issue
  104. Vogue widetrack II
  105. Performance chip for 95 STS possible?
  106. Tinting question and a couple others
  107. Voltage Inverters ??
  108. Please Help Me Make A Decision
  109. How hard ?
  110. 1999 STS Bad Piston
  111. U1064 - Loss of Communications with DIM; what??
  112. Code C1243 - BPMV Pum0p Motor Stalled; this means WHAT??
  113. South Florida Cadillac Meet-up March 5th
  114. 92 Power seat switch Question
  115. 93 Seville STS Will not start no spark HELP!
  116. 95-02 Cadillac Eldorado Billet Grilles top & bottom Forsale
  117. Service Steering System (got a code what do they mean???)
  118. Weird Problem
  119. Anti Theft Message
  120. Coolant Problems, Leak?
  121. new member, new car. 73 eldorado. Diesal swap?
  122. Major problem with Seville STS Northstar 1994
  123. Flywheel replacement how to
  124. Best Designed Seville
  125. Low transmissio fluid
  126. STS Shift solenoids
  127. transmission diagram/pictures
  128. 3rd brake light works- but not threw OEM dessign?
  129. 95 seeking guidance
  130. 2000 STS traction light, ABS light, Brake light....
  131. 1979 Eldorado Hesitation/Stalling Problem
  132. 90 seville cruise control question
  133. pulling abs codes
  134. backseat
  135. bench test a starter?
  136. Bad Vibrations
  137. The "BIG ONE"!!!
  138. Overheating, but not really..........
  139. P0420 - Catalyst System Low Efficiency / Change cat or o2
  140. 2000 ETC Fog Lamp Replacement
  141. Code 0442 Emission leak detected. Help
  142. '02 SLS deal or not?
  143. 93STS low oil pressure- trans have to be removed?
  144. Can't Access Trunk
  145. transmission/electrical problem
  146. The Answer to all my problems
  147. Eldo Grilles, chrome lip moldings, and more!
  148. 97 STS Cd Changer (Trunk) Keeps Shuffling
  149. Heater on... burnt oil smell?
  150. codes not sure?
  151. Coolant Smell
  152. Top radiator hose hot, bottom cold,= warm heat not good.
  153. Has Anyone tried this mileage booster product
  154. Whoa!! N* in an Alante??
  155. Cheap northstar, parts, tranny
  156. oil problem
  157. 00 ETC Fact 12 disc changer part #?
  158. ASC on sunroof control
  159. 1990 Seville - sputters, stalls and dies. Help!!
  160. 2003 Northstar Engine Cover
  161. Holy Smoke,Heater/Defroster problem-93 Eldo
  162. Heated seat problem...
  163. Easy to do or not??
  164. 2002 STS starting problem
  165. 2002 STS starting problem (sometimes)
  166. Holy Smoke,Heater/Defroster problem-93 Eldo
  167. 85 seville heater/ac
  168. Low Refrigerant Message
  169. Window Problem Heeeelp
  170. Power Antenna Problems
  171. Turning Signal...
  172. 92 4.9l to 95 4.6l northstar swap
  173. Trouble Code Hell!!!
  174. Best exhaust combos for best HP and sound
  175. Caddy molding
  176. 95 Seville SLS- Rough Idling
  177. C clip on FPR - how to remove?
  178. 88 eldo stuck (frozen) in park, need help please.
  179. Garbled BOSE Stereo Display
  180. 99 Eldo suspension question
  181. The right place FOR SALE of 94 eldo, pa?
  182. Bad/ no heat?
  183. 92 Seville digital cluster burned out???
  184. Mineral Oil for AC Flush ???
  185. Power Antenna Care
  186. Passenger-side low beam headlight won't come on in a 1998 Seville STS!
  187. parts from 1994 to 1996 sts
  188. what happened to my post
  189. 99 Northstar Overheating
  190. 97 HG Project $2k on eBay
  191. 95 Seville hood struts worn out?
  192. 1995 sts bought today
  193. How do I turn off the auto lock when I shift in Drive?
  194. 92 Seville Trunk Seal #
  195. Power steering working half the time
  196. need help choosing new tires
  197. 88 Eldorado heat a/c fan problems
  198. My FPR...
  199. day time running lights
  200. Need help removing ad from "cadillac classifieds" on this website.
  201. Brake bleeding sequence
  202. Bought a 99 STS, few Q?
  203. VENT and HEATER question!
  204. Aftermarket sony speakers with bose system? Can I put the amp on it?
  205. 1995 eldo code p071?
  206. Displaying "Low Range"
  207. 89 Seville Shuts Off! HELP!!
  208. Found a 94 STS for $800, needs flywheel.
  209. Should I buy a 94 STS for $800? It needs a flywheel
  210. How do I program keyless entry remotes for 98 STS???
  211. Custom STS grilles sold?
  212. dead eldo
  213. Goofy Gas Gauge
  214. MAF sensor???
  215. STRUT HELP for EMDORADO
  216. oil pump
  217. 92 seville dark cluster, won't start???
  218. Getting Codes Please Help
  219. Rear Brake Pads on my '01 STS
  220. need some help
  221. 1980 Seville, is this the right forum?
  222. I Need Help!!! '97 Sls
  223. Caution: Objects in mirror WILL dissapear
  224. I hate winter! snow storm likely in Mlps,mn
  225. For sale Mlps,mn.
  226. What's Wong?!?!?!?!?
  227. The Eldorado, Returns for 2009????
  228. EGR valve location and water pump belt
  229. NO RFA DATA Message on 97 SLS
  230. 1984 Eldo Valve Covers NEEDED!
  231. 22 inch rims
  232. 1995 sts radio not working
  233. How many hours to remove and replace steering wheel on 98 STS???
  234. Controller Calibration Information
  235. Please help at wits end with my 1994 Seville SLS
  236. 94 Eldo good deal?
  237. Disable Traction Control On Pre-Traction Control Button Cadillac
  238. PC0300 and Blue Smoke?
  239. 85 Eldo HELP
  240. Where do i get new leather for 94 eldo seats??
  241. 1979 Gucci Seville
  242. 2000 sls over heating
  243. Having trouble adjusting ISC motor - tip won't turn - what's the secret?
  244. Where to Find a Spare Tire?
  245. Tires
  246. Pcm/ipc/pzm?
  247. Whats stock exhaust pipe size at mufler.
  248. Tires
  249. Control Arm Bushings (1998 STS )
  250. Im a nerd... I just sat in my car for half an hour with no good reason...
