- Idle relearn
- Door Moulding Rip Off?
- If you have a missing Lug-Nut...
- 99 STS Starting Problems
- How in the heck
- 77 Seville.. just picked up but where to find parts?
- WooHoo! 100k on the OD!
- 01 STS Tie Rod Problem
- Anybody Know??
- 99 STS Loose glass in side view mirror
- 95 Eldorado Engine Surging
- Help selecting a used STS (97-00)
- 90 seville help with codes please
- How Do You Disconnect Chime?
- Things to look for on a used STS
- 90 Seville driver information center/climate control
- Got Eldo Finaly Pics and need Advice on Audio
- 01 STS Dash Problem
- 300 HP is not what it used to be.
- P0385
- 1985 Eldo A/C ???
- Time Sert Kit
- Can someone help with cylinder misfire?
- Height Control Sensor/ Quick Question/ HELP
- False "Check Oil Level" Warning?
- Steering Sensor Codes. Can I fix it myself?
- interior lights, radio, blower, hood engine light
- Are O2 Sensors Really This Expensive?
- Hypertech will hack the N* if we show enough interest!!!
- Leather Repair
- Headlamps...Sylvania Silverstar thoughts???
- Brake Pads-Ceramic, Kevlar, Semi-metallic, etc...
- Eldorado 71 emission system
- 2004 Sts ???
- Shift problems
- Version 6 Navigation Disc
- I feel bad admitting this...
- Headlight bulb remove??
- Any Help Appreciated
- Need help choosing good brakes for 1999 STS
- Ok had my car checked out at dealer they say my starter is bad, you tell me..
- Maybe Im jsut stupid...but starter relay ?
- Brembo Brakes on an Eldorado?
- Oil
- Stereo problems
- Shifting a 97 SLS (performance)
- Turn Signal Which Part Need Replacement
- Do I have a bad fuel pump???
- buying 85K 2000 eldo conv't risky?
- Suspension what type?
- STS purchase.. Owned a 99STS for a month.. my comments..
- Help me NOT lose my fingers! Power Window Motor Replacement
- Turn signal is signaling twice as fast...700 miles and a quart low of oil...
- Tech advice for replacing power window motor.
- Side Mirror Codes
- head removal
- 1996 STS Fuel Tank Drain
- Fuel Sender on the fritz...
- Fog Lights
- T-Tops for 1992 and Up Eldorado
- High Speed Snow Tires
- wanted 1988 eldo parts.
- aftermarket sunroof leaking
- loud wipers, suggestions?
- 87 Eldo, What Power Steering Fluid?
- Are 93-96 Fleetwoods Collectible?
- Could it be the starter? 95 SLS
- Need 1988 Eldorado Interior Door Lock Switch
- how is every one doing
- Bad Tranny Mounts - How can you tell??
- Digital Tach in 99 STS
- Eldo 99 Transmission Question
- Erratic speedo and no cruise control
- T063 code on my 95 Eldo
- No More Front Suspension Noise!!!!
- Suspension Problem
- 1988 Eldorado/New Owner/Suspension Questions
- Is it worth repairing a bad head gasket on a 79 Eldo?
- 1997 ELorado Radiator Fan Speed
- Window motor removal..
- What should I do now?
- Seville passenger side mirror
- How many think their Gas Pedal feels too soft?
- 1994 STS astro roof problem
- How do i fix this code, SRC
- Pulling codes 99 STS
- wanted 1988 eldorado parts/ help.
- RKE Problems
- 99 STS trans fluid
- Where to find parts for a 93' STS???
- '92 STS- What else should I do while I have the "cradle" out of the car?
- How do you know if the 0/2 sensor is working?
- Cleaned TB/EGR, Now car won't start! Help!
- questions questions questions
- 92 sts overheating*please help!*
- Back up lights
- Vats/Ignition/starter which is it?
- 98 Cadillac Seville STS Opinions
- Still hesitating, idling poorly...wishing for rain
- 97 sts stability reduced. Can you disable?
- 1997 Cadillac STS - Fuel Pressure Regulator
- Paint/Exterior Colors...
- Shift Selonoids
- Where to get or download the "maintenance schedule booklet"?
- Coolant cap stuck
- first post!
- I got a steal on a 90 Seville service manual..
- Need under dash pictures of 1990 seville
- HELP THE FRED! Driver information center won't light up..
- Potential STS buyer with questions
- Driver information center won't light up
- Cadillac Woes! Can't Figure it out!
- computer message please help ?
- 129 Mph
- Help With Driver Door Problem
- Hmmm Who Here Knows Cadillacs Better Than The Dealership???
- Ride Level Sensor
- 92 Eldorado won't shift out 1st-speedometer going haywire
- Pics
- Center Cap Theft Deterrent?
- Where to rent a classic convertible Cadillac? (Florida/Arizona/Texas)
- Peter
- 81 El Dorado Tail Light Lenses
- Heater problem 1998 Eldorado
- Trunk pull down unit
- Transmission QUESTION...whos got their smart pants on?
- Dealer is blowing me off!
- front hub&wheel bearing assy.
- Remanufactured N* engines from Advance Auto
- Has anyone had struts/shocks rebuilt?
- Help Removing Buffer Swirls
- Engine knocking upon startup
- The Z Rated Club
- Cabin Filter Cover Replacement
- DIC Help 96 STS
- Which AntiFreeze to use
- Now this is a pleasent surprize!!!
- Dash Trim...sweet
- Oil Mixing
- '92 Seville Halfshaft/CV joint replacement
- Right oxygen location?
- How much $$ should I be looking at?
- Need advice after changing FPR on 1994 Eldo
- '94 STS slight misfire
- Transmission?
- Good Independant Mechanic-Fullerton, CA ?
- 98 STS misfires. Pretty badly. Unless it's raining.
- Driver Window Problem
- ""VERY LOW REFRIGERANT"" AC OFF message
- coolent in oil?
- Brakes 89 Seville
- Eldo CD player question
- 92 Seville - tranny fluid/filter change
- Quick question. Quick answer?
- Thank You Ranger
- SRC message "Success Stories"
- 1991 Eldorado Instrument panel problem
- Need help with 90 Seville power window ?relay?
- Strobing Dash/Instrument Panel Lights
- Starting Problem
- 1980 Cadillac Eldorado
- '92 STS- Massive Trans Leak
- Smoke
- 1995 Eldorado Test Drive
- Code PO29 on 95 eldorado
- Wipers acting crazy!!!!!!!
- OH $HIT, you guys! I did it....
- Z speed rated 97 STS
- 99' STS ANyone know any mods?
- Alternator / Water Pump Belt Tensioner
- Strange Noise
- 1999 STS Tire rotation question
- Cigarette Lighter Question
- Water Pump
- car starts but dies
- HELP WITH P094 CODE AND TRAN STUCK IN 1st
- $3600 for nothing?? Stupid Dealership
- Coolant Leak?? Running or not...
- A & B Selonoids
- 90 seville driver information center/climate control
- can i get 22s o 2000 seville sts?
- Trans will not shift out of 1st gear
- New guy with a couple questions :)
- MP3 for my STS
- Selling Eldorado is it worth it
- DYNO on my ODBII software question
- I have some tail lights for a 90 seville.. Is there a for sale forum on here?
- Cadillac Seville 1977
- 98 Seville stalling when it rains....
- Owners Manual
- I don't know what the buttons are for.
- just out of warrenty and window mech breaks
- 1986 Eldorado America Edition
- 87 Seville with dash problems
- Hit 160k Miles Today!
- 1996 STS Tranny Help?
- 96 SEville sls seats interchangable with 98 sls
- Better Get MAACO??
- Lets please take the time to thank a member.
- Waterpump
- How to remove 2000STS airbag
- 98 sts with 60's shackles
- 91 Eldo problem after new FPR
- 69/70 Eldo Body Parts
- 98 Sts Fuel Rail Recall?
- trunk lid torque rods '99 Seville: how to repair ??
- 94 Z rated STS air box vs 98 STS box
- 98 sts front wheel hubs
- Gone but not forgotten
- My new Seville
- Bought a seville, troubleshooting some things..
- 2000 sts oem front struts tower bar
- 22's on a 1999 sts
- So synthetic oil the way to go?
- Major Help Needed Guys PLEASE HELP!!!
- '93 STS a/c problem
- Vaccum, I need VACCUM!!!
- Idk if I showed ya'll or not...but new stitching
- HID Conversion
- 97 STS Front End on a 97 ETC
- my car has the shakes, 98 sls
- I think I'm being stoked!
- 2002 SLS dies going down the road-help!
- Light throttle hesitation
- I just got broke in to
- Codes for 97 STS
- Can I disable the service ride controll without going passive?
- nearly dead battery after sitting a week
- Oil Filter
- Found Something Broken/ Which Code?
- Revving limited to 3500-4000
- Steering wheel button lights
- Black Listed Parts: What Are They???
- 88 Eldo Question
- Hooked on Caddys, oh yeah!
- Why is my coolant boiling out?
- Looking to buy a 93' STS, any advice? First Cadillac here.
- Will this do the trick?
- New thump from the front end
- Steering wheel
- Fuel grade: Is "super" always needed?
- What are the Aftermarket engine choices for a '79-85 Eldorado
- 99 SLS Tranny ?????
- Dashboard uninstall, how to do it?
- help with
- Air Inlet Door
- Northstar Eldorado, your likes and dislikes!!!
- When Eldorados go bad!
- cornering lamps 98-04 seville
- Parking lamps/back up lamps/license plate lamps inoperative on a 98 Seville STS
