View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Some body Tried to Steal My Rim Caps!
  2. 96 STS-Need to buy bushings but what is the front sway bar size 19, 21, 29, or 31mm?
  3. Please help me RESET my oil life meter.!
  4. Side Mirror's
  5. Hail damage.....
  6. stabalizer bar bushings
  7. 89 seville codes
  8. New member + pics of car
  9. Anyone try that heal a seal stuff
  10. question about 1996 sts
  11. 79 Eldorado engine codes??
  12. Looking For Fuel Injectors For 91 Eldorldo
  13. 95 etc exhaust
  14. traction control override with 1st gear??
  15. car for sale
  16. Amsoil For Your Eldo?? Nano Oil And Air Filter?
  17. Trouble Code Website
  18. Priming the oil pump by overfilling the sump
  19. '01 Etc Question...
  20. How to remove coil pack
  21. Urgent - Spark Plug tightning torque ?
  22. My Wipers never work right, HELP!!
  23. 92 eldorado trunk motor sensor
  24. Waterpump socket
  25. outer tie rod ends
  26. Driver Side Door Panel 1999 Seville
  27. 92 sts engine ticks..should I buy HELP!!!
  28. New girl on the bock needs help.
  29. Heater
  30. 1998 STS keyless entry
  31. 1998 STS Temp contronl only blows hot air!
  32. New Northstars discontinued???
  33. Selling '92-'97 Seville Billet Grill
  34. Remanufactured Engine/turbo
  35. Changing the Starter
  36. Patfarrel
  37. Want floor mats
  38. Seat back upholstery coming loose
  39. What is normal oil pressure specs for '93 N*?
  40. 97 Seville Rattle
  41. Rare STS Color Combo??
  42. starfox??
  43. Seville cutting off intermittently?
  44. New here, just registered, great site
  45. 89 Seville pull down trunk problem
  46. 1994 sts transmission swap question
  47. Rear main on 99 STS
  48. Boston Suspension/Struts
  49. Axle shaft?
  50. Please Help, loud tapping after new heads 97 ETC
  51. 100000 Mile NorthStar Service
  52. Squeeky Headliner
  53. oil pan leaks
  54. Worth a look, 1957 Eldorado Brougham
  55. 1996 Cadillac Seville STS stalling - HELP!
  56. stability SYS system
  57. '85 Eldo headlight holder...
  58. seville SLS 96 - how to change spark plugs
  59. Ipc B2710????????? Whats That
  60. Help! Tie Rods? Steering?
  61. Seconds Delay message
  62. Transmission Help.
  63. ECM,BCM modules is there a way to check them?
  64. Traction controll
  65. A/C....no messages.....no compressor
  66. 1985 Eldo opera lamp help...
  67. where is the cars milage stored?
  68. [92 seville SLS] Possible starter problem??
  69. PROM units
  70. Tourque Specs
  71. Can a EBTCM cause hesitation problems?
  72. 1999 sts 4.6l northstar thermostate
  73. Four note Horn
  74. Heater actuators 1998 Eldorado
  75. I've HAD IT
  76. Carfax Pleaaaaase!!!
  77. Shifter Knob Removal
  78. Tires for 20's
  79. 1997 STS List of options?
  80. How do most people back up-
  81. Shock absorbers
  82. 75 Eldorado... Help me get my door open!!!
  83. A/C Blower Shroud
  84. Antenna Repair question
  85. steering column, small puff of smoke
  86. Search Forum re Wet Trunk
  87. STS 2000 AC blowing hot air
  88. Can someone tell me what this means?
  89. Climate Control 81 Eldorado
  90. 1986 Eldorado America II LTD Edition OBD1 codes
  91. 96 Seville STS DIC Question...
  92. Someone tried to buy my Seville already
  93. AC Delco Plugs and Wires work great
  94. a little advice wanted
  95. 2000 Eldorado ETC
  96. Need Help
  97. Changing 1999 Seville SLS Headlamp bulbs
  98. Same part numbers pre 1998?
  99. Lucas Power Steering Stop Leak???
  100. Added some pictures to my site
  101. Third Brake Light Problems. Where to Buy
  102. Dual Light Relay Setup...
  103. TCS 1228 After replacing hub...
  104. How to change center brake lights?
  105. help,....Overheating Seville
  106. I need,,,,,,,
  107. Help! thought it was egr problem
  108. It wont stay down !!
  109. What is the best intake for the buck??? For my 96' SLS...
  110. different solution to vibration 45-55!! :-)
  111. Fuel Pressure Regulator?
  112. CARFAX Pleaaaaaaaase!!
  113. 90 Seville... 26mpg.. 0/2 sensor?
  114. PCM Question.............
  115. Water Pump Tool
  116. Best repair manual for 96 sts
  117. Changing wheel hubs today
  118. 1997 Eldorado display backward
  119. 73% engine oil life
  120. Rough engine while coasting
  121. 99 STS - Could a bad ABS computer have adverse affects?
  122. Problems installing struts on 96 sts
  123. 99 Sts
  124. antifreeze fill procedure?
  125. Rims?
  126. Mounting Licence Plate onto 98 STS
  127. 98-03 Radiator and Headlights
  128. Mr. Tailfin.. you calm down my nerves.
  129. HELP!!! A/c Compressor OFF!!!
  130. weard sounds from under the car
  131. 97' STS Idle Problems
  132. Steering Problem
  133. Transmission help please.
  134. Gas gauge
  135. "Starting Disabled" Remove Key.........Msg
  136. 99 STS z speed option for sale
  137. trunk buckels/ continental kit
  138. By summer im rolling on these!
  139. Quick Help...Replacing A/C Parts...Moisture concerns?
  140. 92 Seville - water pump replace
  141. Sputter upon start up and accelleration
  142. Micro fiber deal
  143. SWIMMSTER I need help with tranny
  144. 2004 seville STS???
  145. HELP!!!!!!!Dead Dash and Driver info center,
  146. Dash trouble
  147. Eldo purchase questions
  148. Ok, new struts, active??
  149. 1996 sts exhaust suggestions?
  150. disk brakes on front... prone to warping??
  151. Tranny Problems
  152. Lost power to sunroof and windows
  153. SLS Fog Lamps
  154. TPM Question
  155. Fog Horn Noise in Steering
  156. Fuel pump relay location
  157. The KICK ITS ASS method
  158. CARFAX anyone please!!!
  159. 87 89 93 Gas???
  160. Shifting clunk and torque strut mounts
  161. Need Help. Replacing Condensor, Accumulator and Compressor
  162. 2000 ETC Convt, regular gas OK?
  163. STS Wheels
  164. Eldo and/or STS custom creations? Your best most unique ideas...
  165. Change brake pads
  166. help!!! my 95 seville wont turn over
  167. PICS of my SLS with HID's
  168. Rollin, Rollin, Rollin....160K TODAY!
  169. Installing an O2 Sensor in a 4.9
  170. 85 seville 36000 miles windshield wiper pbm
  171. Headed to the track - shift firmness question
  172. hlaf passive / half active
  173. Front motor mound removal
  174. Help with parts list. A/C does not work.
  175. Alternator coolant line
  176. Pls. Help! removal of driver airbag '99 Seville
  177. Cam and Crank Sensor Replacement
  178. Name that belt! (please)
  179. used car buying question
  180. Carpet color 98 Eldorado
  181. Cruise control surging....99 STS
  182. 22 Inch Rims On 99 Sts
  183. My SLS
  184. Sliding Moonroof
  185. Odometer Lights?
  186. 97 sts low beam headlights
  187. This one noise...
  188. Refrigerant
  189. car losing power while driving
  190. 88 caddy
  191. Refregerant Again?!?!?!
  192. What Do These Codes Mean???
  193. Need Help - Dead `69 SLS & in a fix.
  194. HID Lighting??
  195. Would you drive a 90 seville 1100 miles?
  196. Pic request
  197. P440 Code
  198. Color of 00 Eldo 1GET1293YU13?
  199. Air Shocks - ELD -ETC - 1999
  200. 97 STS Traction control problem
  201. My Favorite Cadillac Customization
  202. 2005 Deville On Board Diagnostics Access
  203. 88 vcc temp. sensor???
  204. Need some help with codes.
  205. What in the world does this mean?
  206. Speedo Tach going crazy?
  207. help with code
  208. Big problem..
  209. Tracked down driver information center problem
  210. Help !!
  211. Tech Bullitens/ 93 STS
  212. Cranking but not starting prob
  213. Changed battery now have rough idle
  214. difference 96/97 sts?
  215. 94 STS RSS Controller
  216. Service manual scans (1990 digital console issues)
  217. Fuel Pump Died, replacement help.
  218. New owner/New member
  219. great news!!!!!!!!!
  220. Cargo Net
  221. '94 STS engine
  222. my 94 eldo trunk wont open
  223. If you need scans of service manual.. 1990 Cadillac
  224. 99 STS will not start, even with a new starter! Help please!
  225. Plug wire change...
  226. Bar's Leak
  227. 88 eldorado front seat
  228. Sulphur smell & bad mileage...
  229. 95 Seville makes loud Thud noise!
  230. 2000 Eldo ETC 1St year?
  231. Trunk pull down switch replaced, still won't close.
  232. Cheap multimeter a little squirrley
  233. Winter rust problems...discussion??
  234. 99 Sls Topspeed
  235. Should I get a month of OnStar?
  236. Trailer Towing Help!
  237. What happened to Bbob?
  238. ? need to know what this is
  239. 93 STS Interior
  240. Leaking Water pump.
  241. 2000 STS Seville for sale! 67,000/ MINT* condition
  242. The Arnott Stuts & Shocks Are In!!!
  243. 1988 Eldorado Oil Lines Leaking
  244. Transmission swap 95 to 93?
  245. Super Super Rare STS...
  246. Broken Line Found/ What is it?
  247. Man, ...? VOLTAGE MATTERS...help...
  248. brake sensor!!??
  249. why why why why why
  250. New Security System?
