View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Little quirks about my Seville that drive me nuts...
  2. Quick question on anti-freeze.....
  3. Bleed Brakes? Any suggestions/help please.
  4. Cataylst Will Not Ready for OBDII Test
  5. considering a seville
  6. Is This Caddy Dealer Screwing Me?
  7. Extreme heat coming from vents.
  8. Need help changing taillight bulb.
  9. 94 eldorado Wack problem
  10. Motor Mount Question
  11. For Sale: AC Delco Front Struts 580-2 pair 22189452
  12. Black smoke??? valves rattling???
  13. ALDL location ??
  14. Advice needed on a transmission rebuild.
  15. Searched All 325 Pages And Foud Nothing!!!!
  16. Front end noises fixed .....
  17. clay bar
  18. STS $10 test drive at GM-The Drive Las Vegas
  19. Windows/Sunroof Switch
  20. post pics of your rides
  21. The unveiling of the new Eldorado.
  22. question
  23. What tires are best for my sts?
  24. Weird turn Signal
  25. P0101 - Mass Air Flow (MAF) Sensor Performance
  26. Aftermarket radio
  27. Sss Module
  28. Looking at 2000 SLS good or bad?
  29. A/C servicing
  30. 1994 Eldorado engine heating problem
  31. Code C1711 on 98 STS
  32. codes codes codes
  33. Help Please!
  34. '01 STS 3rd brake light
  35. Boosting combustion efficiency with hydrogen
  36. White STS on 101 near Salinas CA on 4/22/06
  37. Trunk and fuel door opening-2000 Seville/SLS
  38. ETC & SLS Problems & Questions
  39. 94 Eldorado - What do you think?
  40. Overheating - Maybe the transmission?
  41. Aftermarket stereo 1992 STS
  42. help vss cable
  43. 03 Sls Steering Adjustment
  44. tire pressure
  45. Bose Speaker
  46. Please HELP ELEC PROB / FUSE
  47. Temp of car ?
  48. PCM 0154 History and PZM 0533 History
  49. Deposit down and so is brake pedal on 2000 eldo
  50. woodgrain covers
  51. Horrible Ride/Brake problem
  52. Headlight Lens Cleaning
  53. Anyone got a 97 Service Manual PLEASE HELP
  54. Car being stupid starting
  55. The dreaded northstar oil pan leak problem
  56. '96/'97 Seville STS with no Sunroof???
  57. How do i adjust the gear selector switch on a 95sls
  58. Tuning a newly acquired 99 STS
  59. Where can I find the RPO's and interior color codes..
  60. 1992 Seville Flashing Dash / Interior Lights Problem
  61. Just bought a 98 STS
  62. interior
  63. A different trunk latch problem
  64. Google Search Tool on this forum ...
  65. Driver side window won't go down 96 STS
  66. Original options...
  67. Changed the starter
  68. looking for the guy that emailed me
  69. Anybody else troubled by the bright yellow Shift Illumination on in the dash
  70. Passenger door lock
  71. Fixing Backup Sensors, help finding wire
  72. 1995 SLS Trouble Codes - New to GM need help!
  73. TPM relearn procedure
  74. Help--alignment done, new tires... continued Front wheel outer shoulder wear.
  75. Complete reseal of northstar
  76. Fuel Pressure Regulator on a 96 STS
  77. i got some codes, help please!
  78. crankshaft position sensor sts 96
  79. Aftermarket Radio
  80. Transmission problem
  81. needhelp
  82. pcm location 94 sts
  83. Tool Help
  84. looking for Austin, Texas mechanic
  85. Service Airbag? 1999 Sts
  86. Signal Relay Location
  87. Radiator issue
  88. Motor Is Racing at Idle
  89. 99 STS Oscillation Over Bumps
  90. Code pc0153 came on today - is this the left O2 sensor?
  91. '94 door lock actuator repair
  92. Surging only in warm weather
  93. 97 eldo change sparks plugs
  94. fusebox messed up
  95. 1993 Cadillac STS ac problems
  96. Passenger door Won't open from inside!
  97. 97 Eldorado.(not etc)..which ignition wires ??
  98. 97 STS plugs and gap?
  99. 96 Sts Vin 9, 4.6 N*
  100. WTB Front Bumper cover 1996 Eldo
  101. Trunk leaks 2000 Seville
  102. How do you disable DRL on a '97 ETC?
  103. Starting problem VATS or something else
  104. HELP! 96 STS with shifting problems...
  105. Nice 1988 Eldorado on Ebay!
  106. Dont kno how to cut off high beams in a 1992 STS
  107. HELP with a/c cooling fans
  108. Hit and run, worst day ever
  109. 4.9 Performance Exhaust
  110. 99 Seville Fuel Tk Lvl Sensor
  111. 1998 ETC Code Problem C1242
  112. STS help
  113. Eldorado door panels
  114. More Dynomax questions.
  115. Cam Cover Replacement
  116. Are the Any 84 & 85 Eldorado Convertible Owner's Out There
  117. clear "CHANGE TRANS FLUID" code/new PCM
  118. What brand tire should I buy?
  119. That's what happens when parents drive -or- Where can I get this part?
  120. Should I be worried, or just a glitch?
  121. Shift Solenoids 1996 STS
  122. 1990 Cadillac Seville Belt Squeaks?
  123. seville 96 SLS RTK 16259819 - any substitues
  124. T/C light on and ABS light
  125. HELP WITH My 95 STS PRETTY PLEASE!
  126. out of 134a
  127. 96 Seville power steering at low rpm
  128. 96 seville a/c air conditioner problems
  129. Just bought a 2000 Seville SLS, need a little help
  130. Need Information on 98+ STS'
  131. Traction control button does not work?
  132. two part question!!!
  133. Varying Idle 800RPM up to 2500
  134. Oxygen Senor Problem
  135. 1st Gear and Traction Control
  136. Lost power steering fluid very fast. Where is the hose?
  137. Lost power steering fluid How do I get to the hose?
  138. Owners Manuel
  139. Where to buy remote transmitter seville 96
  140. 1997 deville with ac problems
  141. ESC Conversion to ETC???
  142. Caddy is worth the pain.
  143. Bumpers and Trim
  144. what's up with headlight??
  145. Transmission Diagnostic
  146. What to do with some scrapes on the fender?
  147. Respect your Cadillac
  148. Can the cooling fans come on sooner?
  149. Water Wetter In The Northstar
  150. Quick Help on Brakes
  151. lowering these cars
  152. 76 cadalliac eldo feul injection problem on start up
  153. panal cluster trouble
  154. wheres the sss module in the trunk?
  155. Happy Easter Everyone
  156. 96 STS rebuilt tranny problem
  157. WHY? Changed rear pads, still have message "CHANGE BRAKE PADS"
  158. part number
  159. I need some tire info
  160. '98 ETC, SES light on, history codes, need help.
  161. PCM Location
  162. Seville Speaker Sizes
  163. Over-reacting?
  164. Would be cooler w/ AC working...
  165. i got my e and g grill
  166. cup holder won't stay closed
  167. How to remove electrical connector from Oil Level Sensor
  168. Service Bulletin?
  169. 1996 STS Shift solenoids, Julian Date?
  170. Need Help 1996 SLS service ride control issue
  171. Good News Guysssss!!!!
  172. 2001 Seville Steering issue
  173. 98 Cadillac Seville STS OVERHEATING
  174. Just me being me
  175. 4 Vogue Tires, Less Than 8000 Miles, Going On Sale.
  176. Wheelskins Steering wheel cover
  177. At home install of an ignition switch???? Possible??
  178. Exhuast tip question
  179. Hello [Name] on start-up
  180. EBTCM/ABS/TC= Confusion
  181. OBD Error Code: RSS C1760
  182. Left Front Brake Pads Sticking
  183. Doesnt everyone wish for this???
  184. Eldorado "standard" version vs. ETC ride and handling question
  185. Fuel pump not shutting off
  186. Want another Eldawg...
  187. Need step by step procedure on how to...
  188. If you have a sensitive stomach... don't open
  189. 1997 sts refuses to start
  190. Eldo with car bra pics
  191. small vent to left of steering wheel
  192. Ipc B1552?
  193. My Eldo Slides Over Bumps? What's Wrong?
  194. 99 STS-Vents underneath the seats?
  195. Ignition coil on 92 Seville
  196. Rear Passenger floor pan water leak
  197. front seat covers beige needed
  198. EBTCM Replaced/ No Luck/TRACTION DISABLED
  199. 1998 ETC factory spoiler?
  200. Cabin air filter stuck!
  201. Front sway bar 23mm diameter, bushings only for 19,21,29 & 31 - HELP!
  202. Read anti-theft threads but....
  203. Eldo door panel clips
  204. 99 SLS Misses while Cold then smoothes Out? Why?
  205. New member with a few Cadillac Questions
  206. Why Are Tranny Pan Bolts Loose?
  207. AC repair question
  208. 94 eldorado power question
  209. Transmission Impossible
  210. Replaced blower...now no cold air on 95 STS
  211. How do I know if I have the heated winshield?
  212. How to check for spark and fuel
  213. considering buying an 97 eldorado
  214. HeHeHeHeHe....
  215. GOOD NEWS (for me)
  216. Temperatures on Dash Gauge
  217. 98 sls codes
  218. 96 Eldo Rough Idle No power
  219. 92 Seville won't start
  220. price for replacing engine part
  221. Whoops! Broke something. What is it?
  222. Purchasing Advice
  223. 1976 Eldorado Convertible boot help
  224. Oil Pan Leak Repair Using RTV High Temp Sealer
  225. Rough Idle after sitting for 3 days
  226. 1994 STS Engine problem *Urgent*
  227. New coil springs for '90 Seville?
  228. Suspension RSS Code C1761 i know what it is But ?
  229. blueish, blackish smoke
  230. '95 ETC Dash, Tail & Marker Lights failed at once
  231. Tire pressure
  232. Instrument Cluster Problem
  233. Suspension Code is RSS-C1761 ?
  234. Pcm P1599
  235. Front Valve Cover Removal
  236. 94 DeVille - Service Transmission light
  237. 95 STS Shocks
  238. on board computer glitch or ????????
  239. GM PartsDirect vs. GM Dealer/93 STS Fuel Pump
  240. PLZ Carfax report
  241. 99 sls overheating after bar leaks
  242. 1998 Eldorado Need Some Information
  243. need to know how to remove code for suspension sys
  244. Service Suspension sys, how do i clear off the code ?
  245. 99 STS , can some one Help Me ? With Codes
  246. SQUEAKY DRIVERS SIDE DOOR! help!
  247. Change fog lamp 2001 STS
  248. White substance mixed in with oil???
  249. Popping noise when turning??...
  250. Rotor minimum thickness? 1999 STS
