- Trunk pull down switch question, again
- SLS Front Bumper Cover Damage need advice...........
- 2000 eldrado rear suspension
- dont crank
- EGR valve next..????
- ignition control
- WANTED:1968-1970 cadillac
- Cylinder differential compression
- Full sweep gauges?
- Need help / thoughts with 01' STS wipers..
- 95 Eldo Interior Questions
- help me please!
- 98-04 hood ornament
- i need a picture ...
- water for coolant
- Tachometer vs. speedometer
- Help with Seville STS
- plug wire
- Reviews for 92 STS/Eldorado
- Magazine reviews
- New Seville
- '95 STS Should I ?
- Pcm?
- Need help for 98 Eldorado plz !!
- Looking at a 98' STS tomorrow!!
- Thanks iametarq and JimD for saving me $1850!!!!
- ECM Location
- Changing my radiator
- 99 STS rear end a little droopy on drivers side. Any idea why?
- 94 sts air conditioning recharge
- toubleshoot cruise control 86 Eldo
- Car Not Even On Rear After Lowering Car & Moving Sensors...Why?
- need wiring harness for 94 el dorado p/n 12121172
- rear suspension creek
- Removing coolant cap???
- Engine Slips While Turning Corners
- Passive sturts install today, how to suppress SRC? Help please.
- Last night I had a nightmare
- Coolant capacity for a 90 seville 4.5 pfi?
- Does anyone know where the thread for front strut replacement is?
- HID Kits?
- Where to mount front license plate?
- What is a Commemorative Edition '85 Seville?
- Exhaust and H.I.D. lights on new 97 ETC Z Rated
- Any suggestions on bumper fillers?
- Is plastic windshield lining removable? 85 Seville
- Weird Noise When Im On The Gas!
- Finally got pics of my Eldo, what do you think?
- service suspension sys code on dash
- '92 STS- A/C-Heater Vacuum System Problems
- parting '93 eldo
- So I did a cylinder air check for head gasket leak
- Do I need special instruments for codes?
- Do I Need To Move Both Position Sensors?
- Heater Core Help
- Hyper-kool
- 74 Eldorado Question (s)
- 1970 Eldorado brake booster
- 99 STS AC Refill
- New Radiator
- 97 seville 142k overheating
- ROUGH IDLE / CODE P046/ New O2 Sensor?
- Ccr or Passive?
- Please help guys i need a part number
- suspension differences.....
- After Lowering Car, Rear Still Sits High. Why?
- Another eBay Scam
- Newbie needs advice, cooling sys., etc
- 95 STS blower motor problems. UPDATE but Please help anyone.
- Answers about 95 SLS Suspention Issues
- oil change or tow truck
- Starting problem with Northstar
- 95 Eldo vs 00 Eldo.
- New codes
- Code P1376
- 2000 eldorado A/C problem !! anyone have service manuals or ????
- Code 49 HELP ! Please !!!
- 94 Seville 4.9
- had a wierd problem on my 1997 ETC
- 98 Seville STS - What is this belt called
- Ultrasonic Rear Parking Assist
- Ok fellas.. Possible 03' STS Sale
- 97 STS motor noise?
- Service Air bag?
- K-body? G-body?
- 91 seville coolant leak
- Power window help!! *Pictures*
- How will these new rims and tires work!?!?!?
- Coolant leak under AIR?? at intake
- 2001 Eldorado transmission drain and refill???
- tire pressure
- want help pulling codes!
- Can I Replace Radiator Side Tank Only ?
- Code EO49 Air Injection Reaction System Fault
- Need Part Number
- Bad key..
- "Service Engine Soon" light
- why is the dealer asking for less than the trade in value??
- Blower motor slows down upon acceleration
- 1993 ETC going haywire
- 02-03 seville reliability???
- hot or cold but no medium
- Clear message 91 seville
- Traction Control
- EGR Valve P0404 Code
- Help name these parts!
- WTB: Fuel Injectors for 78 Seville
- overheating, shut engine off message
- 1977 Eldorado - Body Mount Bushing
- Poor ride on 99 STS :(
- Anyone ever replaced an A/C evaporator ????
- overheated and now trans wont shift
- Is it worth getting a eldo throttle on my sts
- Sounds like my Starter
- How to: SLS & STS Door Panel Removal
- '98 STS performance exhaust...
- Coolant Problem
- Floor shifter?
- New Cadillac owner looking for advice/info
- Tried to Program RKE
- Have A Question?
- oxygen sensor help
- Tires losing pressure
- 97 ETC: "Service Engine Soon" info
- My rear brakes don't wear
- On Board Service Diagnostics
- Trunk Repaint?
- Blower motor on 95 etc. vibrates
- A.C. not as cold as ice
- Code help
- Oil leak, need adviced
- Question Reguarding Power Locks
- 99 STS - TPS Question
- Front motor mount 2000 STS
- Restart your car in 3 minutes, 2 min, 1 min! What?!?!?
- 1992 Seville Service Engine Codes
- Nice E & G Continental kit on Ebay...
- studs instead of headbolts
- 2000 STS Door Molding
- Need Help!!!
- 2002 STS "performance" MAF Sensor
- Weather beaten bumper fillers '84 Biarritz
- 2002 STS exhaust
- '97 eldorado-drivers side window motor install
- Death to an Old Cadillac
- 97 ETC: Just lost water pump belt: help
- New struts & springs soon to come.
- Dual Headlights for a 93 Eldo?
- No Oil???
- 99 STS help
- AC problem 91 seville..
- Help Me Sort This Out?
- Squeeeking!
- Just ordered a pair of Dynomax S/Turbos..
- Trying to mod a 99 sts
- Blower Motor Problem.... Please help.
- '92 Eldo
- 97 Eldorado - Climate Control Vent Selector Issue
- 1993 Cadillac Seville trouble code
- dealer or stealer
- dealer or stealer?
- What is a good tire to get?
- Wierd interrmittent speaker pop
- Typical dealer cost for coolant replacement?
- A place to get cadillac parts for a 1969 cadillac
- 30k Service "Package"
- Start Problem on 96 STS
- Intro
- Air intake plenum on 96 STS
- 98 Eldo chime
- '01 Seville CD-Changer Removal
- '98 STS Door panel removal?
- 1997 Seville SLS 0-60 & Quarter mile times
- 1993 Cadillac Seville Stereo
- One more cross country trip under our belt
- Rear brakes
- Clicking noise?
- Who here has the best license plate frames....
- '97 eldorado...check trans fluid ...
- '97 eldorado radiator replacement..
- 1998 Seville SLS
- 1996 Cadillac Seville STS airbox blower help needed. What is missing?
- 2000 Eldorado...blown head gaskets....
- 2003 STS Codes
- Keyless Remote System
- 97 SLS a/c problem, I need a wiring diagram
- more problems abs c1232
- coolant change on 92 4.9!
- What brand drive axles to buy?
- 1985 eldo climate control ??? help
- Engine Hot
- 96 sts occasional start problem
- 02 STS New tires, huge problems!
- 76 Eldo convertible
- sad day: an anonymous idiot reversed into my Eldo; I have to file claim
- 2000 SLS Code Help!
- What I call, "All-of-a-sudden air"...
- AC Stopped Working
- Seville 2001 ipod stereo removal
- HVAC Blower Motor out!?
- 4T60-E Trans. won't shift to 3rd/4th
- Considering 2003 STS
- Power Steering
- Pressure Control Solenoid
- Mystery Vent, What is it???
- 1994 Eldorado on eBay
- Body Panel Fit Questions
- freshly cleaned caddy
- steering wheel botton lights??
- Brake and Tail Lights Not Working
- Just bought my first Cadillac
- dome light on 92 seville problems
- Please can someone help?
- Got A Couple Issues!
- Lucky me....
- Neowedge Bulbs for heated seat switches
- Brake pad replacement Q
- bubble flare??
- radio question
- 81 Seville Temp Control Issue
- Temp Gauge
- Head Gaskets
- P089 Transmission Code
- New Plugs/New Wires Help Quick!!!!
- Newbie question 1997 Seville STS...
- My little accident =(
- How Do I Clear History Codes ?
- Steering wheel auto adjust?
- 1995 Seville STS rear control arm bushings
- Fsm!!
- Blower Motor replacement..
- 98 ELDORADO Voltage Issues
- Trying to Correct lock up convert code on 1993 eldo 4.9
- Brake light on dash ?
- Eldorado "tag"
- Turbo on Northstar??
- Climate Control and Fan Problem
- '96 Eldo Tranny issue :-(
- Just turned 100k 93 ELDO N*
- need help with front end
- New water pump, still missing coolant
- ETC Custom Exhaust Movie
- 99 STS Climate Control
- 1999 Sts
- 95 wheel center caps
- New Member
- Speed limited to 90
- Bars Leak Golden Seal...?
- 1998-2003 Seville Radiator
- 95 STS having EGR trouble
