View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Tachometer bounce
  2. No wipers
  3. Oil Pressure
  4. imfamous s022
  5. Using old CV half shaft parts???
  6. Radiator Surge Tank
  7. 1985 eldo evaporator help ???
  8. '85 Seville: where is the temp sensor & where does this connector go?
  9. It's HOT OUT!
  10. Problems with the FM/CD Player PLEASE HELP
  11. Coolant Leak Problem (PIC & VIDEO)
  12. roof liner
  13. 92 Eldo with blown headgasket... worth it?
  14. seville pcm problem
  15. parting out 1969 cadillac eldorado
  16. 94 ETC chrome questions
  17. eldorado exhaust questions...
  18. CV halfshaft RR
  19. 94 STS loud metal to metal clang from under car
  20. Need Help Installing A/C Clutch on '93 Seville (SLS)
  21. Overheated..car cranks but wont start
  22. Problem with lights on 92 STS
  23. Changing brake pads on 92 Seville SLS
  24. tranny slippin
  25. Alternator replaced, now something else!!
  26. I want my first gear back
  27. SoCal D3 Grand Opening 7/15
  28. Alternator Dying?
  29. sputter
  30. NEED HELP ASAP:how to get fenders off 1969 cadillac eldorado
  31. Might Have a Problem With Overheating!
  32. Source for gold emblems
  33. Reset "Check Brake Pads" in DIC?
  34. Accessory 12V Fuse Question
  35. Help with 97 STS
  36. 98 sls, bad motor?
  37. Instrument guage problem on 92 ETC
  38. Important Safety Information for 79-85 Eldorado and 80-85 Sevilles!
  39. 94 SLS Parts Car on eBay
  40. Engine knock in 1985 4100 engine.
  41. Low Oil Pressure
  42. 1979-early 80's Eldo knowledge needed....
  43. Need help with tire size selection
  44. Help Please with water pump and belt!!!!!
  45. How to drop a fuel tank in a 1994 seville???
  46. EGR Cleaning: Fuel Rail Removal
  47. Service AC, AC Compressor Off
  48. 1998 STS ignition switch??
  49. WANTED: 1969-1970 eldorado in colorado
  50. P071 code intake oil leak and engine stalling
  51. I wasn't celebrating on the 4th.
  52. Starting Problem with 94 Seville SLS
  53. First Road Trip----RAN OUT OF GAS
  54. Good and Important question for you experts
  55. Coolant leaking 99 sts
  56. Engine Compartment noise from the air vents
  57. Stability reduced message
  58. Wanted: Red Leather Front Bench Seat For 69 Eldorado
  59. Window motor replacement
  60. Sunroof issue please help!
  61. Any pictures of the turn signal boxes?
  62. 92 ETC computer questions
  63. Who buys a new cadillac without keyless entry?
  64. Installed Corsa on '98 Seville STS
  65. 92 eldorado light sensors
  66. Starting hesitation
  67. Coolent Leak?
  68. Alternator replacement??
  69. Have to replace turn signal switch
  70. Stalling Problem
  71. 2001 cooling problem
  72. Need help on replacing EBTCM
  73. Eldorado tire/car ratings
  74. ETC's been hexed???
  75. Radar Dectector
  76. 1998 Eldo accident damage pics....any opinions or thoughts?
  77. 1993 Eldo Northstar starter and EGR troughs
  78. Outside temperature always reads -36F
  79. N* Engine for sale, any interest. More parts coming...
  80. Need ? answered 94 Eldo
  81. Current A/C code
  82. Help Please Help!!! Compressor going nuts.
  83. Losing my mind? Disp Mode + Info Up/Down buttons
  84. Concerns about buying another Cadillac
  85. High Speed stop shimmy
  86. '88 Eldorado - couple questions
  87. Terrible Dealer Service Experience - What to do...
  88. STS Crisis
  89. Not much wiggle room ?
  90. Head gaskets
  91. Free 1985 Cadillac Eldorado Seats Plus Parts Car
  92. A/C help 97 STS
  93. Turn Signal Problems
  94. low oil pressure
  95. Coolant Leak
  96. 98 ETC...Wierd sound???
  97. My 1998 STS only blows heat!
  98. Just how bad are these plugs???
  99. Oxygen sensor replaced 2 weeks ago - how long for code to go from current to history
  100. Too Much Oil
  101. Need Wire Spokes Rims For My Eldo
  102. squaking sound
  103. noise by firewall and it's not the EGR valve
  104. coolant change
  105. a/c compressor relay
  106. Is there a suspension replacement for air shocks?
  107. 94STS Cruise won't stay set
  108. Engine swap.....
  109. Selling my 95 STS and buying a 2002?!?! Need advice!
  110. Dash Seperation
  111. Low gas mileage & Power loss
  112. 1997 Eldorado - Carbon Cleaning - Where is the PCV valve?
  113. short circuit?
  114. cooling fan fault
  115. Feels Wierd...
  116. My First Caddy
  117. EGR Valve stud stuck
  118. AntiFreeze Leak (Newbie Help)
  119. Leak in from of the passenger front tire
  120. Not ALL Northy's leak oil...
  121. Fog Lights
  122. Blower thermal switch needed
  123. Bedding the Performance Friction Pads - - - Letting the smoke out!
  124. Service air bag system
  125. Traction Control Abs Light On After Going Thru Deep Water
  126. I need advice!
  127. Coils Packs
  128. Attention All Units, WANTED- Eldorado ETC
  129. Mystery Spring
  130. '98 Seville Dies
  131. A/C has MUSTY ODOR
  132. gurgling sound coming from sunroof whenever I open a window
  133. Rear window pulley problem
  134. gauges all messed up
  135. "Service Air Bag" and "Change Engine Oil" on Display
  136. Got car back: am I picky or is this unacceptable to you too?
  137. Suspention upgrade?
  138. Lack Revival
  139. Oil light keeps coming on
  140. HELP-rear seat removal for 93 seville
  141. Broken door handle
  142. AC Noise
  143. Good batteries
  144. Eldo in a coma.....
  145. Well...A Sad Day For My Car.
  146. Repairing a Lumbar Pump
  147. please help me with this
  148. Anybody use anti freeze test strips to test a/f condition?
  149. computer says low a/c refrigerant
  150. Road Trip
  151. frustrated
  152. Belt tensioner pulley gone south...
  153. PC0717 on '96 STS
  154. 92 Eldorado Recharge AC
  155. Battery Light On and Off
  156. SLS can't tell outside temp.
  157. 90 Seville Exhaust
  158. Your choice ... which pads do you like?
  159. collision repair question
  160. Cleaned under the hood
  161. Ranger driving his new DHS from TX back to IL
  162. HELP! My trunk and my fuel door won't release!!!
  163. Steering Wheel and Suspension. 2 Big Problems
  164. 92 SevilleTurn Signal Stalk Illumination?
  165. Common A/C leak locations
  166. Anyone know where I can get these?
  167. cadillac spoke rims
  168. After Rain - ABS/TC lights w/nonstop chime
  169. Changed Transmission Fluid - '96 STS
  170. Dealer is going to FLASH REPROGRAM PCM
  171. EGR valve
  172. Speed Governor Override - OTC 3646
  173. Help with a code...
  174. 97 ETC air intake modification: PART TWO
  175. 2001 Seville SLS Tail Light (bulb) replcmnt
  176. security
  177. 8mm Plug Wires better than Delco 7mms
  178. 93 seville sts bcm
  179. Just a couple parts
  180. noise by the firewall
  181. Thank-you from a Newbie
  182. need parts
  183. How to fix E-Brake release.
  184. Anyone think the 2.5" exhaust pipe is too small?
  185. We may be parting
  186. what kind of power steering fluid do you use?
  187. Rev limiter in park?
  188. Technician !!
  189. 96 STS tail light, moisture
  190. No more FI for the 85 Eldorado!
  191. Carpet question
  192. where to find an exhaust y-pipe
  193. What is Normal Coolant Temperature ?
  194. Aftermarket sunroof problems
  195. A/C Leak
  196. water pump belt
  197. Any '77-'78 Eldorado Biarritz owners here?
  198. All (many in stock) OEM Parts at Great Prices
  199. What will new brakes all 'round cost me?
  200. Part Number: Tail light covers?
  201. need professionel
  202. So..... how does your head gaskets get blown?
  203. Electrical
  204. Looking To Up Grade Steering Wheel
  205. Strut Bar?
  206. Eldorado Headlights VS. STS Headlights
  207. What Movie is This?!?!
  208. Need Info On Fog Light Install On 98 Sls
  209. Anyone use car covers?
  210. Any advice for the desert heat?
  211. Is this the wheel position sensor? PIC
  212. 2 things hopefully light can be shed on
  213. no A.C. hot in Maryland this week!!
  214. My ETC is really an ESC!
  215. 1999 STS Blown Headgasket
  216. AC exploded
  217. Need help clearing a current code.
  218. Need help clearing a current code.
  219. 12-Disc for sale
  220. Forum Newbee seeking info on Biarritz
  221. What is speed governor set at on my car?
  222. A/c Help Please!!!!!
  223. Mtflight - Where are you in Dallas?
  224. How to Recharge my AC?
  225. Selling 2000 Eldorado...asking too much?
  226. Help My Poor Wife...
  227. 94 sts need leather seat covers
  228. Lowest price you've ever seen
  229. Need 99 STS Turn Signal/Brake Light Housing Source
  230. How to tell if the Ignition Coil are still good?
  231. Error in theft deterant system - car may not restart
  232. 97 ETC air intake modification
  233. California Emission
  234. 94 STS Northstar Knocking
  235. sts headlamps, customizing possible?
  236. 97 sts?
  237. 92 Eldo OBD Code help
  238. Replacing '94 STS radio
  239. Plese Help. Noise From Wheel
  240. Blower Motor Noise & Trans
  241. hello hello
  242. Cup holder 92 Eldorado
  243. 95 Seville SLS Exhaust Questions
  244. Removing Molding On A SLS
  245. Cadillac Seville Clear Corners
  246. Tranny fluid change
  247. Trunk pull down switch question, again
  248. SLS Front Bumper Cover Damage need advice...........
  249. 2000 eldrado rear suspension
  250. dont crank
