View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. '01 STS... need help / advice... PLEASE!!!
  2. Help! Need to locate door trim on 95 SLS
  3. no key, need to move STS, help!
  4. Charging system problem....help
  5. Buying a 94 Eldo, need advice
  6. Fender Fillers
  7. G12bp
  8. Shift Knob Replacement - 96 Seville
  9. "W" Rated Tires
  10. Help with TO73 code. Traction Disabled.
  11. turn signal and fog light problem
  12. Returned from coast to coast drive
  13. Where can I get this steering wheel?
  14. newbie wondering if this is a good deal?
  15. Which is faster - 97 or 98 STS?
  16. HID replacement costs a small fortune
  17. How do I add more coolant tabs from home?
  18. How's the ride with 22's??
  19. Eldorado 1988 Seat Belt Front
  20. P080 / Transmission / Idle Problem
  21. Problems w/ 99 sls
  22. Positive Battery Cable Replacement
  23. Mirror and Lumbar switch problem
  24. Best Cadillac to buy for $5k
  25. newbie climate control problem
  26. Does anybody else notice...
  27. Help!...with regard to trunk release mechanism on 95 Seville
  28. coolant change advice please
  29. Need help finding a cool Eldorado
  30. New member, first caddy tech questions
  31. Wheels and tires for sale.. A MUST SEE- IN NJ Essex County
  32. Type of oil?
  33. Check engine light on
  34. Power antenna
  35. Cornering light issue on a 2000 STS
  36. No start after warm ?
  37. Wheel Bearing / Hub Assembly question
  38. Vacuum Leak
  39. What is the effective difference between and STS and an SLS?
  40. STS Center Hub Cap help
  41. 92 Eldo Service Engine Soon & Blower on
  42. Can't go left (SLS)
  43. power stearing pump HELP!
  44. 1997 eldo obd2 scanner question
  45. idle too high
  46. Upgrades...Hmm let's get serious.
  47. Newbie who now has a STS
  48. Help: rough idle and Service Engine Soon light
  49. Yet another believe in Hunter Road Force Balance
  50. Abs
  51. How to remove oil pressure sending unit?
  52. help! is this STS worth buying??
  53. Window Question
  54. Lock relay
  55. 1988 eldo 4.5 liter idler pulley bolt left or rt?
  56. 1994-1996 STS's
  57. 94 ETC Dragging Brake
  58. brake help
  59. Engine Hot - Ac Off
  60. emergency brake light
  61. Compare this FSM a/c fix to a $1000 overhaul
  62. airconditioning problem
  63. Arnott Struts
  64. 98 Seville STS Coolant / Overheating HELP
  65. Questions About Headrest Monitor/audio
  66. 1994 Cadillac STS
  67. tint
  68. 97 Seville Eldo Deville FSM Vol 1
  69. A/C problems
  70. Is the 97 ETC engine a "L36?"
  71. Parking brake help!
  72. 1997 eldorado 1599 code help
  73. Sub Frame Seville STS
  74. How to properly bleed the cooling system ???????
  75. Interior Cost?
  76. 99 eldorado, cd player wont work...
  77. Color match 94 and 97
  78. Is my digital readout right?
  79. 89 First Gen STS - Any interest?
  80. 96 Eldorado Ashtray
  81. maintenance question
  82. Clean them bugs
  83. 95 sls passenger door lock problem
  84. Front End Clunk
  85. 1995 SLS Dead
  86. 1996 SLS Seville, Diagnostic Codes
  87. possible transmission problem?
  88. sunroof
  89. Where are the coolant drain plugs?
  90. Driving me crazy! Please help.
  91. I can't find these dang caps anywhere...
  92. Need Codes Clearified
  93. Some pics of my Seville
  94. Could we use something like this for more power?
  95. `93 STS Seville Codes
  96. New STS Owner - questions
  97. Too much oil cause low oil pressure?
  98. 1979 Eldo...where to find trim parts???
  99. Hunter Road Force tomarrow, what to ask for??
  100. digital temp gauge whats the norm??????
  101. 2000 STS Power Window Question
  102. Can't Find Color Codes
  103. 01' Seville air filter silence???
  104. 97 sts for SALE 5500 - 160kms
  105. Power window help anybody??
  106. 2000 ETC Wheel
  107. wheel center caps
  108. trailer hitch for sale
  109. power window trouble 95 seville
  110. I need some interior parts. 99 STS
  111. New member who wants a 01 to 03 STS
  112. Electrical 1999 Seville STS
  113. 94 Eldorado total loss? Help...
  114. Need A Good Tranny Rebuilt place in San Jose California
  115. Opinions please on overheating......
  116. Cd player?
  117. Erratic turn signal- 96 sls
  118. Reading the guages
  119. 1985 caddy eldorado for sale..Low miles
  120. More noises from the car. Please help me sleep at night
  121. Anyone live near Calgary, Alberta Canada?????
  122. 92 STS 4.9 Coolant Leak
  123. wheels, tires, rear suspension parts f/s
  124. Change serpitine belt
  125. Calling Canada Cadillac Owners (WHO WANTS TO BE THE 1ST WHO HAVE A MODDED PCM FREE!)
  126. Injured Caddy for Sale in Cleveland,OH
  127. Help Please RE:Power Tilt Steering 00 STS
  128. Average Temperature
  129. Found Pcm Programmer For 96-04 4.6 N* Obd-2
  130. Eldo maybe going to Canada, what to check?
  131. Garage opener (homelink) frequency range
  132. My parts 1969 cadillac stolen/missing
  133. Air Cond Trouble
  134. 96 sts charging system acting funny
  135. Anyone tested out their "EuroEldo" yet?
  136. Got my FSM, Now have Theft deterrent
  137. What's wrong with this picture?
  138. Anyone Have Carfax Privileges
  139. "System Problem" Message ??
  140. 99 STS bike rack
  141. Question
  142. Need help with my 97 sts overheating
  143. Will a 96 SLS tranny go into a 95 SLS??
  144. just noticed this
  145. "Service Vehicle Soon"
  146. battery question...Need Quick Answer Please
  147. Self Inflicted Lifter Noises, Low Oil Pressure..STOP ENGINE!
  148. Reverse Lights activate with brake pedal
  149. 1996 Eldo N* wont start
  150. Eldorado or Coupe deVille
  151. PCM Code P086
  152. Engine Swap
  153. do i need new dual electric fans?
  154. Vote on Should Steps to remove the speed limter be shared?
  155. 1979 Eldorado trunk won't stay open...
  156. HUD in 2000 STS
  157. codes from nowhere
  158. K&N and opened up the intake
  159. Low range
  160. Is it possible to clear codes permanently?
  161. coolant mixture gauge (hydrometer?)
  162. Serpentine Belt Diagram
  163. WTF is IO32??? Need help ASAP!
  164. A/C woes
  165. 98 STS lurching during 1-2 shift.
  166. Tail light covers?
  167. Considering 94 seville STS w/138K for $2500, what to look for?
  168. Bottoming issue!
  169. Fast blinker-bulbs all good
  170. Another A/C Question....
  171. Passenger reclining seat button
  172. coolant help
  173. door speakers on sls 95
  174. Lets try a new header - How do you access the PCM on a 97 seville?
  175. thinking of selling
  176. 01 STS - cruise control inop - need some help
  177. Cadillac Diagnostic Codes
  178. STS convertable
  179. Tranny Concerns
  180. STS SLS tail lights the same?
  181. 107,000
  182. 97 SevilleSLS,high idle again,new wrinkle
  183. Electrical Systems Will Restart when going 60
  184. refrigerant overpressure
  185. Anybody heard of this kit?
  186. Polyurethane Front End Bushings? 1980 Eldo.
  187. 1998 STS New HUGE Problem..
  188. 94 STS Broadsided
  189. Rear Bulb Replacement
  190. Solenoid?
  191. Blower won't shut off!?!
  192. STS rear brakes
  193. Power Steering hose
  194. Service ride control? - seville 96
  195. Parting a 90 Seville
  196. '93 STS heater core bypass
  197. Jerky tranny
  198. Summer road trip, here is how it is going
  199. Thinking of an 04 Seville
  200. Sticker inside Driver door missing
  201. 99 STS MagnaSteer problem!
  202. Need To Change O2 Sensor 93STS
  203. 97 Seville Service Manual on EBay
  204. 2000 STS Air Conditioner Acting Weird- Please Help!
  205. 93,675 Mile Maintenance
  206. Thank you everyone for helping me put both of my cadillacs in top running condition.
  207. 1999 STS 90000 mile maintenance
  208. 89 Eldo Air conditoner
  209. Wet STS
  210. wut kinda rims for my sls
  211. selling my caddy
  212. Yikes!
  213. Clacking sound after Engine shut down
  214. Speed Control Unit
  215. 98-04 Sevilles
  216. Where's the leak???
  217. Resetting the computer on a 97 STS
  218. Creaking sound when accelerating??
  219. 1996 Seville Transmission not shifting
  220. Billet Grill 93 Sts
  221. Embroidered Headrests??
  222. pcm replacement 95 seville
  223. 93 Etc Mpg?
  224. Check this out ...
  225. 97 SLS Compass will not calibrate
  226. 1993 eldorado
  227. rear dampner solanoid
  228. cheapest mufflers
  229. 2001 Sts Chrome Wheels
  230. Anyone have a Rock Auto discount code
  231. Looking 92-97 Seville
  232. Retro Navigation Radio Install 2003 STS
  233. Problems with 93 STS...
  234. my second cadillac
  235. Seville Wont Start
  236. 1st Caddy
  237. steering wheel shakes!!!
  238. ac pressure question
  239. Wanting to remove gray trim
  240. blown head gasket?
  241. 1998 Seville STS Service Stability System!! HELP!!!
  242. 2000 STS Cracked Block doesn't overheat.
  243. Eldorado over heating
  244. Tachometer bounce
  245. No wipers
  246. Oil Pressure
  247. imfamous s022
  248. Using old CV half shaft parts???
  249. Radiator Surge Tank
  250. 1985 eldo evaporator help ???
