View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Whirly sound from engine after coolant change
  2. How to Flush Coolant
  3. F/S: 92 Seville/Deville Cluster
  4. Northstar Knock?
  5. Automatic Antena won't go down...Please Help!
  6. 99 STS shifts into 3rd while in "2" ??
  7. Car wont start HELP!
  8. 92 sts LTB
  9. Cool Air On Driver - HOT! HOT! On Passenger -
  10. What is this pulley called?
  11. Where can I find Seville accessories.
  12. 99 Seville SLS
  13. Would this mirror work for my STS?
  14. Need some serious advice !
  15. Window problems
  16. Help Me Understand??
  17. To Buy or Not?
  18. Front Bumper Cover Removal 93 STS
  19. A REAL mistery coolent leak.
  20. ABS Computer
  21. 1975 Eldorado Rear Bumper Bar
  22. 98 sts elec. prob -Short maybe.
  23. Engine misfire and SES light illuminated
  24. What to watch for in 99 Seville SLS.
  25. 94 Eldorado - Hesitating & Stumbling/RPMs Sucked Down
  26. p1637 Bad Alternater?
  27. 95 ETC Diagnostic Codes
  28. Water Pump Removal Tool
  29. Starter won't disengage. Gonna destroy something..
  30. '99 vs. '00 Seville SLS
  31. 02 sensors
  32. Coolant Leak HELP!
  33. Good interior cleaners
  34. A little help guys...please
  35. eldorado opera lights
  36. Help. Iowa is cold.
  37. 2003 sts ashtray door alignment
  38. Clearing OBDI Codes?
  39. Idle problem
  40. crazy question
  41. Brakes Grinding?????
  42. STS gone berzerk
  43. Is this CVRSS?
  44. HELP - Need new tires. TripleTred????
  45. `97 Seville STS using a LOT of oil...
  46. Rear shock leaking??
  47. Water in Gas
  48. It dies
  49. could my computer be going out ?
  50. 2003 Cadillac STS Seville tire problems
  51. Theft system problem
  52. obd 1 code 84?
  53. 98 STS Head Unit upgrade
  54. 1995 Caddy Eldorado MUST Sell
  55. Rear End "Clunk"
  56. Mystery Coolant Leak
  57. Problems with lowering?
  58. computer reset? 1994 seville sls
  59. Engine light comes on
  60. Eldorado Rag Top problem?
  61. 76 el dorado
  62. anyone have a drivers window regulator i can buy?
  63. Need Help on 94 Eldorado Rag Top
  64. did?
  65. Bent wheel assembly!
  66. 3rd Break Light as a rear tail lamp / break lamp?
  67. False Brake Pad Message 1999 STS
  68. Please educate the newest member!
  69. 76 Seville value?
  70. Navigation questions
  71. Is my Alternator Dying? (voltage drops at stops)
  72. What is the official name and/or part number for...
  73. ride height - drivers side
  74. 2003 Seville STS with drivetrain problem
  75. high beam switch
  76. Getting a '76 Eldorado Convertible, Have Q's
  77. Wiring harness troubles
  78. What do these codes mean
  79. Adding switch to manually lock torque converter
  80. How to check my Transmission fluid level??
  81. "trunk open" on display, dead battery,..........
  82. change head gasket or buy a used engine???
  83. Cadillac Eldorado 95 Ping noise
  84. 97 eldo altinator is it hard to install
  85. did my plugs
  86. how bad would it be to drive with a blown head gasket?
  87. broke a lug
  88. My 95 Caddy pics
  89. Air mix actuator question????
  90. Question about '99 STS power steering??
  91. Running Choppy
  92. Exhaust tips anyone??
  93. 98 RKE work on a 97???
  94. '94 Eldo Oil Burning Question
  95. Idler pulley question
  96. Should I buy this 93 Seville?
  97. sub frame
  98. A 97 Seville should be similar to a 96, you would think...
  99. Air Mix Actuator failure in 1999 STS?
  100. Oil Leak
  101. Warped Interior Panels 95 Eldo
  102. climate control fan will not go off 92 eldo
  103. My 98 Eldo with Mask (pics)
  104. 1997 Onstar Cell Phone
  105. Ses
  106. Bad Night
  107. A/C leak location help!
  108. Gas tank vent?
  109. 2000 SLS Rear Defrost
  110. Anybody tried the Aero turbine muffler on their car?
  111. cheep 92 STS w/ a catch, what should I do?
  112. grille
  113. CPU Program Upgrade for 99 STS
  114. STS rear panel
  115. ses flashing
  116. arrrrrrgh...........
  117. Front License Plate Cover
  118. The darn leaky trunk
  119. couple of semi important questions
  120. 2000 el dorado stalling
  121. Rust warranty for hoods
  122. Exhaust for STS's...
  123. 1993 Seville STS - Starting Disabled
  124. 2000 STS HELP!!! Please
  125. US Speed products
  126. door locks
  127. Found a nearly complete 98 STS, Parts interchange?
  128. Motor Noise in Vent
  129. 1995 Seville Sls Northstar Transmission Trouble. Please Help Me
  130. Factory Recalls
  131. Door Open on DIC, '97 STS....HELP!!
  132. 1989 Eldorado codes
  133. idle problem?
  134. Brake trouble big time
  135. Parts for '73 Eldorado
  136. Front End noise that Cracks?
  137. Windshield wiper
  138. Arnold Palmer 1974 Cadillac Eldorado Commercial
  139. Air Compressor - Seizing - Freon
  140. Few Questions
  141. where can i find a 1996 sts front bumper cover
  142. Carfax Please
  143. Chrome bumper trim on ETC's??
  144. Performed general maintainence today
  145. Whining noise from engine
  146. Front Motor Mount How-To Writeup
  147. 90 Seville Electrical issues related?
  148. How high should the rear end of a 2001 SLS be?
  149. Convertible Top Service
  150. nothing important, just an annoyning tick?
  151. Bad fuel pump 96 STS
  152. 93 Seville Body Control Module
  153. I hate this car.
  154. Can I give my 1992 Eldorado a facelift?
  155. Any good mechanics in michigan - kalamazoo area
  156. 97 Eldo shuts down
  157. Anit-theft device preventing vehicle start
  158. CD Navigation swapped with DVD Navigation??
  159. Seville Security problem
  160. 97 Eldo shuts down
  161. Temperatures
  162. Stainless Steel Roof
  163. Heated Seat Not Working in Seville
  164. Bent Rim + Hunter
  165. Blower motor insulation replacement
  166. PLEASE HELP WITH CADDY STS? battery problem!
  167. ... Codes ...
  168. codes where to go from here????????
  169. This Will Never End!!!!
  170. Floor shifter trim plate question
  171. Need some help changing a light bulb..lol
  172. Is this a bad belt chirp?
  173. Cracked Radiater
  174. Considering '88 Eldo-pros?/cons?
  175. Replacement Shocks for 1970 El Dorado?
  176. 95 Eldo need to sell
  177. 97 Eldo - strange heater problem...
  178. 95 sevill sts problems
  179. Difference between 99 and 00 ETC?
  180. Io34 To77 So38 Please Help!!!
  181. Where can I find a Woodgrain steering wheel for a 96-02 Eldorado??
  182. Po 39
  183. my 97 sts
  184. Non HID Headlights
  185. Ewww....
  186. Whip 'Em Out Boys...
  187. cruise control fuse keeps blowing
  188. engine overspeed problem
  189. 98 SLS Loud POP thru radio amp on start up
  190. 95 SLS engine whining
  191. Engine locks up when warm??
  192. 2000 SLS, Changed both CV Shafts
  193. 1979-85 Eldorados... Who's owned one?
  194. T-shaped connector of 3 rubber hoses of antifreeze line is deteriorated
  195. Overheated
  196. New and could use some pricing help on a 2000 ETC.
  197. Some more pics of my Eldo as a work in progress
  198. My 2000 Eldorado ETC pics
  199. Body Kits and Custom hoods for STS!!
  200. used rims
  201. Cadillac Eldorado Body Kits!!!!!!
  202. Rough Start when Cold or Sitting
  203. adaptive cruise retro-fit
  204. My 96 sts, pics
  205. Orange Coolant Okay?
  206. 95 cigarette plug question
  207. sounds like a bad HG but it really....doesnt....
  208. VATS By-Pass kit
  209. engine swap question
  210. The best day of my life
  211. service engine light
  212. 98 SLS Water Pump R&R advice
  213. (98 Driver's SLS Seat Heater INOP
  214. BF Goodrich T/A Tires
  215. PCM Code - P025
  216. exhaust smell driving me crazy
  217. Eibach suspension question - 99 STS
  218. Change tranny fluid message
  219. Parking Brake
  220. Fog in tailight
  221. 00 SLS Remote Help
  222. cost to replaceme vynil top?
  223. STS 2003 FROM GERMANY/ KICKDOWN SHIFTPROBLEM / Need Help / THANX
  224. Head Gasket replacement
  225. changing coolant 94 eldo
  226. 98 Eldorado suspension
  227. Coin/ash tray door
  228. DIC Messages
  229. Another Strut Bar Installation..
  230. E85?!??!?
  231. leaking brake fluid
  232. ignition wires
  233. Computer issue after battery replaced
  234. 03 STS Heated Seat Broke HELP Diagnose
  235. What Mileage Can Be Attained ?
  236. Dic Feature Programming
  237. Old Caddy Help
  238. Just put a spoiler on my 1997 etc
  239. trailer hitch for 00
  240. please help me!!!
  241. Seville SLS Service????
  242. A couple Nasty Problems! HELP!
  243. im joining the club
  244. Help: Want To Bleed Brakes- 1999 STS
  245. retraining ignition key 1999 SLS
  246. '95 Eldorado dies
  247. rear lower control arms
  248. Dic Message "snapshot Taken"
  249. SES Light - 1990 Eldorado
  250. STS Fuel Pump Interchange??
