View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 96 Eldo tranny won't shift to O.D?
  2. Alternator change? 93 Eldorado
  3. Finally riding in style...
  4. Help on tire size...
  5. 1990 Seville
  6. 93 Eldorado tranny stuck in 1-2 gear- other probs too, help?
  7. Storage mode
  8. My 97 STS has Arrived!!!
  9. 88 Eldo - How To Access Turn Signals
  10. Rattling Noise on take off?
  11. 96 STS tail lights/water
  12. Just got engine code E039. TCC/VCC problem. Is it serious?
  13. Alternator Issue after Water Pump Change
  14. "Reduced Stability" TCS C1251
  15. 01 STS D/S Seat heater problem??
  16. Fuse locations on 1997 ETC
  17. C1763 code help!!
  18. Is it rare?
  19. Radio unlock problems
  20. 93 Seville Rear Spindle Bushings
  21. Northstar Coolant Tablets & Clogs
  22. 10amp fuse (cooling fans) keeps blowing
  23. Rear Compressor Problem
  24. Elaines gotta brand new ass
  25. 67 Eidorado Suspension??
  26. I found a cherry '93 STS for sale ( white)
  27. 71-76 gm fullsize conv top pics
  28. Here's an interesting classic Eldorado...
  29. 1967 Eldo Win or Sin Question
  30. Overhead control pannel 96 STS
  31. Problems a plenty
  32. 2003 seville sts service suspension system codes: c0582, c1246
  33. Torque Specs.
  34. O2 Sensor Help
  35. HELP 1986 87 parts interchangable
  36. 4T80E and transaxle ratio
  37. 95 sls car is off loud clicking from throttle?
  38. 1984 Eldorado convertible questions
  39. Water pump removal
  40. Here's an easy one...DCing the battery
  41. Disabling air suspension and installing regular suspension
  42. 95 sls pressure solenoid drop the tranny???
  43. car lost power during burnout?
  44. Cadillac 1994 Electrical Problem
  45. '94 Eldorado Secondary hood latch
  46. Dim Headlight
  47. Nightmare Tranny 95 Sls
  48. Need help figuring out these codes on my 96 Seville
  49. Suspension problems
  50. No Heat on the Passengers Side - STS 1997
  51. Trouble keeping balance weights on inside of rim
  52. Water in Trunk
  53. What Sevilles should be avoided?
  54. inside mirror swap?
  55. Why is it that....
  56. rear strut replacement 1997 cadillac eldorado etc
  57. "Service Ignition System" warning light help
  58. Has anyone removed the fake convertible top from their STS?
  59. !998 STS Non HID headlight on a 1997 STS?
  60. what is the 'window clip' for?
  61. HELP Cadillac Diagnostic
  62. Shifting Downhill
  63. Bad Tranny/New Tranny/Parts Car/Sell As-Is?????
  64. 2000 engine in a 1999
  65. Eldo Suspension Conversion?
  66. Radiator Reservoir
  67. 1996 Cadillac SLS audio question PLEASE HELP!
  68. Wait 3 Minutes?
  69. Air Shocks?
  70. Window goes down slow, but up at normal speed!?
  71. Test drove '93 Seville STS...LOVED IT!
  72. Mirror / Drivers Door
  73. P 0446 - time for the mechanic?
  74. Failed emissions
  75. 2002 Cadillac SeVille SLS - Twilight Sentinel
  76. 94 eldorado power antenna & blower quit
  77. 97 STS Onstar Phone Question
  78. Keyless Entry Range
  79. Tranny Pump Shaft Shear
  80. HELP 97 Seville STS Low compression in cylinder 1 and 2
  81. Service Stability System and Steering at start up
  82. Yay for junkyards!
  83. Codes on 92 STS Seville
  84. PART NAME/NUMBER??and other ??
  85. How to: Align wheels properly?
  86. 94 eldo oil leaking bad.....what to do
  87. 1996 Seville stalling problem
  88. 97 STS - Fuel Tank Evaporator Control
  89. the moneypit
  90. Can you make the suspension feel like new?
  91. Coolant Problems
  92. how do i change fog lights on 00 sts?
  93. Difference 02 ETC from 02 ETC Collectors Series
  94. Eldo door panels
  95. Overheated!!
  96. Refridgerant low... AC off
  97. Diecast 93-02 Eldorado
  98. A/C Compressor removal in 1995 Eldorado
  99. 1999 SLS Anit lock brakes
  100. 02 seville sts service engine soon
  101. SPeaker problem in bose 4.0 99 STS
  102. Where are all the '85 Eldo/Sev wire spoke alloys?
  103. 96 SLS instrument cluster swap
  104. T/C button relocation
  105. A Couple Problems/Codes
  106. Engine Stalls when trying to start car
  107. PO300, Service Engine Soon. Rough Idle
  108. I feel dumb: Trunk access from rear seat
  109. Parts 1998 STS air flow sensor
  110. Rain Sensors
  111. Heated Wheel
  112. Pile of Communication Codes
  113. Heal-A-Seal??
  114. Yay or Nay?
  115. Coolent ans Oil
  116. Pls contribute traction control ABS Warning EBTCM
  117. Cheap 1994 Eldo Vert!!!
  118. Traction Control 2nd Gear Start?
  119. lightbulb question..interior
  120. Things you never knew about your '92-'97 STS
  121. How to Shut off DRLs (and add digital coolant temp and speedo in the dic)
  122. New Caddy Owner to be....
  123. 1999 Seville Engine Stalling Problem Help!
  124. Eldorado Fuel Tank Removal
  125. Changing door panels on Seville...
  126. Remote Starter (aftermarket)
  127. 95 Seville, seized engine
  128. I'm going to ask first...
  129. 1985 Cadillac Eldorado( Everything for sale)
  130. Best Tire Choice
  131. Nasty smell coming from heater vents..
  132. Look at this totally AW.... Ebay Car
  133. Broken seatback locks on 92-02 Eldorado
  134. 91 Eldo STILL misses!
  135. 2000 STS running lamps
  136. Rear battery
  137. Replaced Steering Wheel & Button controls!
  138. Very Nice And Cheap STS On Ebay!
  139. Hello all. I am probably getting a 92 STS tomorrow, what should i look for?
  140. Update on 97 sts
  141. Coolant to the Alternator?
  142. crankcase seal leak
  143. God I love this car so much but every week is another problem...
  144. '91 Eldorado-Ignition Key / Door Adjar Bell
  145. Battary no Charge
  146. 2003 Seville navi
  147. I need 12 VDC switched power
  148. Would these bulbs help?
  149. When should radiator hoses be replaced?
  150. 175K Around the bend...
  151. I Tinted My Tails
  152. Service CCR System
  153. Few updated pics of my Dad's '78 Eldorado Collectors Edition Biarritz
  154. Question About Fender/Hood Sizes (Examples)
  155. sts 2000 passenger heated seat problem
  156. fuel door panel needed
  157. CODE PO46 Runs ROUGH!
  158. Coolant Leak. HELP!
  159. 1999 STS Overhead console - Homelink
  160. change brake pads indicator
  161. 88 Seville need some work done
  162. Slotted and Drilled Rotors for Eldos '97-2002
  163. 92 Seville Brake Light Problem
  164. Speaker upgrade on ETC...
  165. When it rains my dash panel quits
  166. Getting New Tires, balance & alignment
  167. ETC Lower Door Molding
  168. Wanna Z?
  169. Eldorado Chimes 83-85
  170. Down for the count.... With pics!
  171. display prob after new battery
  172. Speaker replacement
  173. Front struts on my ETC
  174. seat height
  175. Clanking when I hit bumps
  176. 92 STS Shifter Rattle?
  177. Water in Headlight...
  178. Never Never Never Ever... Run Out Of Gas!
  179. Windsheild De-Ice Feature Voltage Drops
  180. Convertible top help
  181. STS Car cover - good deal
  182. Seeking Navi System!!!
  183. change brake pads message
  184. no heat
  185. help!! shifter button freezes when it's cold outside and I cant put it in gear!
  186. 2000 STS Brake Replacement
  187. Eldo Trunk Pull-Down No Workee -
  188. Injector diagnose and R&R 96/97 N* engine
  189. Spark plug gap...4.9L
  190. Thinking about a newer Eldorado.
  191. 1997 Eldorado replacing shocks
  192. 4.9 fit
  193. 1990 Seville Head Lights
  194. uh oh, hope it isn't the rings..
  195. Eldorado air intake "thingy" is ???
  196. Power Seat
  197. `97 Blower Motor - no power???
  198. Tire Pressure Sensors
  199. Still feeling like an amatuer...help with my window please
  200. 1985 Eldorado...pics+questions
  201. theft system 96 sts, wait 3 min.
  202. 96 STS IPC swap problem starting high revs
  203. Valve guide seals or what?
  204. Not running right..please help
  205. Sometimes smooth, sometimes rough
  206. CLEAN Eldo with less than 2k on the clock!!!!
  207. 1969 Eldorado for sale in Southern Callifornia
  208. ?'s about an engine swap.
  209. Bubbles in power steering fluid reservoir
  210. What type of oil to use?
  211. '01 eldorado problem
  212. digital display system
  213. Headlight Help!
  214. dealership quote
  215. 1999 Seville SLS Headlights
  216. How do you pull the codes on a 1997 Eldorado?
  217. FS: Framed Dealer poster Eldorado ETC
  218. A/C Problem?
  219. selling eldorado is it a good price
  220. Code P0207 help!
  221. seats needed
  222. Tranny/Code question
  223. Transmission P1810 HELP
  224. 1998-2002 SeVille Aftermarket Tail Lights
  225. SLS Oil Leak....
  226. 92 Seville non STS heater problems
  227. replacing side mirror glass
  228. Follow-up to "need serious advice"
  229. Water in the interior/ & cold/ hot air from vents
  230. 1997 Northstar STS
  231. Eldorado ETC
  232. Looking to buy a 96 eldo...simple questions
  233. Problem with wipers
  234. Severe Coolant leakage issue 95 STS
  235. 1995 Cadillac Eldorado Code P080. Help PLEASe
  236. 1996 Eldorado wheel centers
  237. 1997 Seville STS with Codes P0201 P0204 P0300 Help PLEASE
  238. Rear shocks exhaust valve
  239. 95 sls shocks= can you firm them up?
  240. Kudos to Hunter Road Force balancer.
  241. headlight trim
  242. Eldorado Center Console Removal
  243. 95 SLS with runaway idle
  244. Aftermarket Rims for a 1970 Eldorado?
  245. CCxxxx code ??? pls help ...
  246. cracked bezel
  247. Brake Pad Replacement
  248. Pressure sensor in transmission
  249. 99 Eldo rear end all of sudden jacked up, need advise
  250. Battery No Charge (92 Sts 4.9)
