View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Bent Fender Lip need opinions
  2. Installed Monroe Sensi-tracs
  3. What would you sell this Caddy for?
  4. How do you take a 93 sts dashboard apart
  5. GMPartsdirect.com Anyone have a phone #?
  6. How do I customize dash display? 02 Seville STS
  7. Misfire Codes
  8. where can I find restoration parts
  9. doorlocks,interiorlights,powermirrors,ac failing
  10. 99 Seville overheating
  11. Bye, bye dumb tire.........
  12. Parking brake manual release lever?
  13. "Sticky?" rpm in park with acceleration
  14. Main Dash Vents
  15. Entrance / Accessory Lights
  16. '91 SeVille No Heat
  17. 4.9 v's 4.6
  18. '97 Seville Overheating/Heater Issue
  19. DVD Navigation for '99 ETC
  20. Antenna plug
  21. Seville STS: Rough When in Gear, Dies
  22. Cleaned TB now what?
  23. 95 sts coil test.
  24. 02 seville instrument panel cluster problem.
  25. Service Anti-Theft System...
  26. Mesh Grill
  27. Amusing Picture
  28. Make your STS wheels nice and shiny!
  29. New member, 3rd Seville-Problems!
  30. Sunroof drain holes 01 STS
  31. STS Suspension fix......
  32. Coolant in oil
  33. New Member: 96 STS
  34. Monroe Quick Strut assemblies for 98-04 Sevilles?
  35. 94 sts tranny wont shift
  36. 95 Seville idler pulley gone....
  37. Heater Core R&r
  38. I need help Cadillac experts ..
  39. Overheated 99 STS, new Tick/Knock underhood (rut-roh...)
  40. Neutral safety switch on 95' STS
  41. Sunroof Motor location
  42. OnStar
  43. 94 Eldorado ignition miss
  44. Clean Throttle Body Bore
  45. Front end clunk/rattle.... asking opinions..
  46. How to know what swaybar diameter?
  47. Anyone have an 02 Eldo Collectors in Aztec Red?
  48. How do I fix this
  49. Radio AVC sensor location. 03 STS
  50. Changing Rear Knuckles (Spindles)
  51. Service Fuel System Message
  52. Wipers in PARK position
  53. tapping engine
  54. warped interior panels
  55. 1998 SLS hesitation and occasional popping/backfiring under hood
  56. overheating then knocking sound
  57. 1990 Seville, Beauty gone bad
  58. 97 SLS acceleration
  59. 94 Eldo w/ Arnott & Eibach PROBLEMS!
  60. [92 seville SLS] Problem with my heater
  61. N* Regular vs Premium unleaded..what year?
  62. 1998 STS diagnostic mode
  63. OK Sevillers!
  64. Vertical Tint Striations on Glass
  65. 95 sls P076 code pressure solenoid bad??
  66. 2000 Seville STS Hiccupped and Died.
  67. CadillacETC1997 need to speak with you..
  68. Codes, codes, codes..
  69. MaxiFuses????
  70. Seville parking brake release question?????
  71. changing wires on 97 STS
  72. 1997 Cadillac SLS Remote Garage Door settings
  73. Anyone know how much it would cost. . .
  74. Transmission problem....
  75. Rear View Mirror Plug Pins???
  76. 94 Eldorado Factory Chrome Wheels
  77. Any serious interest in 02 SLS near me?
  78. Help Identify This Suspension
  79. 95 STS heated or non-heated windshield?
  80. HD6/HT6 A/C Compressor Clutch question.
  81. 92' STS electronic professional advice
  82. trouble codes
  83. 1996 STS seville
  84. Slugish SLS
  85. 1996 STS seville front supension noise
  86. 1996 STS seville cruise control problem
  87. 94 Eldorado missfire
  88. 10/40 oil?????
  89. Water pump leak on my new SLS
  90. Rear View Compass Mirror Work On a 95 Eldo
  91. auto headlights work sometimes
  92. Another strut question.
  93. eldo97 - how to check plenum /vacuum leak
  94. How long to keep Seafoam in oil before changing???
  95. emissions failure-NOx-'93 eldo
  96. my new 95'
  97. Why not to drive with blown gasket
  98. 500 in a 78 eldo?
  99. Engine Missfire
  100. 2000 Eldorado no crank
  101. Transmission Fluid Level
  102. How To Control The Ac Fan ?????
  103. Chrome 20's Seville/Eldorado
  104. Pictures of my 2001 SLS!!!
  105. 1972 Eldorado - Soon to Be Daily Driver
  106. So i need new struts. Where should i buy them???
  107. Picked up 98 SLS & STS Dealer brochure
  108. $2,000 - where to spend it?
  109. Error code 1323 help please
  110. Service Engine Light No Codes?bad Alt
  111. One last desperate plea for help
  112. Is someone an expert on battery replacement?
  113. Heater Core Replacement DONE
  114. how do I read engine temp in degrees
  115. 1983 Eldorado instrument panel lights - not working
  116. head unit conversion kit
  117. Looking for input
  118. Firewall heater/air box
  119. 79 Seville Suspension Part
  120. '91 Eldo no start again
  121. Fpr Pics
  122. Disaster or inconvenience?
  123. 74 eldorado -floor boards, etc
  124. Mileage on a North*.
  125. Tranny gone??
  126. 2001 STS Wheel Bearings
  127. 99 Seville STS Overheating!
  128. IMHO Worst Looking STS I've ever seen
  129. Codes codes codes
  130. Pl advise Eldo97 IPC B1910 and stals when cold
  131. 95 Seville STS starting problem
  132. trunk leak or trunk river i should say
  133. Front and Rear Brake Pad Replacement
  134. Bad moonroof leak in 2000 STS - HELP!
  135. Tossing around the idea of a 96 STS w/ 64K miles
  136. Low Beam-Low Range
  137. Head Lamps
  138. Merry Christmas All
  139. Speed limiter
  140. new 99 Eldo....
  141. High Performance Alternator recommendation
  142. Got my second Cadillac!
  143. Starter Solenoid on 90 Seville?
  144. LED brake light
  145. Battery No Charge (92 STS) URGENT!
  146. Coolant temp monitor question
  147. 1999 Caadillac Eldorado Replacement
  148. First Post.
  149. Checking the VIN
  150. Heated Windshield Question
  151. Help! Somebody please tell me how to take the valve cover off!
  152. Bought the 96 seville sls, code PO717
  153. Whats the normal operating temp?
  154. Stabilizer bar link problem?
  155. 5321 mile 2002 Cadillac Eldorado Touring Coupe Collectors Edition in Aztec Red!
  156. 94 STS Head gasket repair
  157. Clearing the codes on a 2000 STS
  158. 96 cadillac sls ??
  159. Fuel Injection Service from Walmart - Eldo 97,
  160. Eldo 97 - How to check EGR
  161. Aftermarket GPS
  162. 1998 ETC Electrical Problems
  163. 99 STS: Adding Satellite Radio
  164. Q about how to remove valve cover
  165. stereo wiring
  166. Eldo 97 Crank position sensor replacement procedue
  167. Code Help
  168. Chirping noise under hood when cold - fixed!!!
  169. Replacement keyless remote for STS?
  170. 01 STS HID problem, fast help needed
  171. coolant fan not coming on
  172. 1998-2004 Nav System
  173. Thinking of letting her go
  174. Fuel Odor
  175. radiator recommendation for 95 SLS
  176. 93 Eldo- Installing head unit. Wiring??
  177. This can't be legit...right?
  178. No power in Eldo
  179. Blower motor out
  180. '95 z-rated STS on Ebay; 81,000 miles!!
  181. what kind of oil
  182. 1998 Eldorado ETC Question! PLEASE HELP
  183. Pic of the Eldo
  184. STS Performance Mods
  185. STILL stuck in 2nd gear.... What gives?
  186. Anyone know where I can find a '92 Seville light assembly?
  187. Ignition control module location
  188. Altezza/Euro Style Tail Lights?
  189. Are '92 STS still good? Found a good deal on one...
  190. 78 Seville Cornering & Turn Signal lens ?
  191. '92 Seville - Very Low Refrigerant
  192. New Lighting [Xenon and LED]
  193. What a bitch.. Changing Radiator..
  194. 98-02 STS...wanna easy way to disable DRL's?
  195. How much is my 99 STS worth?
  196. 1996 STS New Lighting [Xenon and LED]
  197. 95 SLS inner tie bellow clamp removal
  198. Tornado and K&N
  199. How much Bars Leaks to add?
  200. bearing chirp/clicking sound when idleing
  201. 02 Seville Gas Guage Reads too much
  202. CVRSS Module - 98 STS (Please Help!)
  203. 1997 Cadillac Seville Traction Control Problem
  204. built in phone
  205. Speedometer recalibration?
  206. Waterpump tensioner pulley
  207. No codes for idle control valve
  208. Voltage Out Of Range P016 Code
  209. Oil Oil Oil
  210. reboot?
  211. How to remove Radio from Eldo97
  212. Just got back from looking at a 95 sts!
  213. Gearshift slider....black coating?
  214. Overheating - stumped
  215. Help amateur playing mechanic needs help!
  216. DIC Start-up Message
  217. Eldo97 Radio display - is there internal fuse
  218. where is the hidden transmission drain
  219. Advise
  220. 96 SLS got Code P1406
  221. ESI Techline DVD's Factory Manuals
  222. Cadillac Shirts
  223. 99 STS Headlight Question
  224. Tranny solenoid change and Alternator change- 93 Eldo
  225. Will running low on fuel cause check engine?
  226. Airbag Code R026: Scan Tool?
  227. 95 sts? what to look at for problems
  228. Power steering pump replacement 97 deville sls
  229. Eldo electrical problem
  230. Alternator 95 Sls ????? Help
  231. What do you think, am I asking for trouble? - '94 STS, 330k, $2000
  232. Wireing Diagram
  233. Coolant on the Windshield?
  234. 2000 STS - Lots of U1000 Codes
  235. great Eldorado webpage
  236. Crashed up my baby
  237. Parts Seville STS 1994
  238. burning coolant - head gasket?
  239. 97 SLS Wont start in park.
  240. ac compressor question
  241. Brake pad part numbers?
  242. 2000 Seville SLS Fogged headlights
  243. 2001 STS Stalling when coming to stop
  244. sunroof noise
  245. sub-woofer into a '97 Eldo
  246. 96 Eldorado leaking Transmission Fluid
  247. Help...Dimming Headlights...
  248. 2001 Seville power door locks-trunk-gas won't open
  249. Splicing across ABS sensors....will it work??
  250. Water in passenger side footwell (ETC)
