View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 96 Eldo Blower Motor & Housing Replacement
  2. Jolty acceleration in overdrive
  3. Where is Powertrain control module located SLS96
  4. Can Service Emission System due to bad spark plugs
  5. Whatcha KnowAbout the 94 Eldo
  6. Cutouts
  7. Watch Out for Idiots On The Road!!!
  8. 96 Eldo ETC Shifting Problems
  9. Car rear riding too low...
  10. radio question (87 seville)
  11. 97 STS with Courtesy Light problem
  12. 2000 STS......Time to step it up a notch..
  13. New Owner
  14. ACTUALLY disabling traction control
  15. ACTUALLY disabling traction control
  16. Would Chrysler 300 wheels fit?
  17. Heated Seat Problem
  18. Cool Addition to Interior. Check it Out...
  19. Climate Control Quirk
  20. Seville Owners, ATTN!!!
  21. Can a loose oil dipstick cause DTC codes
  22. Need data for 2000 STS heated seat repair
  23. Oil Brand?
  24. Tune up
  25. Excellent Gas Mileage
  26. "STS Turbo Systems" on a N*?
  27. Eldorado Touring Coupe Video
  28. new to cadillacs -- error codes on recently bought '95 SeVille SLS -- major or minor?
  29. Codes PCM 442 and MSM B 1900 - and now?
  30. Is there a starter relay?
  31. Seville Pillar Post Question
  32. overflow when turned off
  33. History Codes. Need I Be Concerned ?
  34. Service Stability
  35. seville/deville have same grill shape/size?
  36. Corsa Owners: Attn!
  37. best place for a spoiler?
  38. Yard Run Part 2
  39. Whats Better 4.9 or Northstar?
  40. Jamed Glove box
  41. Bad gas mileage
  42. P0171 Fuel Trim System Lean Bank 1, meaning?
  43. standard for STS HID's?
  44. I disable the TRACTION!
  45. need removal steps
  46. Stumped
  47. Service Air Bag - B0041
  48. Reseting ebtcm
  49. Warning Noob questions enclosed:
  50. Does SLS96 follow OBD1 or OBD2
  51. Service emission system - SLS96 - need help
  52. Help - Engine Cadillac Seville V8, 6 L, 368 CID
  53. THM 440-T4 information
  54. Astroroof Moonroof Problems - Dead
  55. 97 Eldorado ABS Module?
  56. Can't reset code using the normal methods
  57. 93 seville - heater ???
  58. Help 1997 Seville STS with P0201 Code Again
  59. Reuse Or Trans Pan Gasket
  60. 1993 Eldorado 4.6 won't run
  61. 92 STS transmission ratio F79 or GX3??
  62. Heater Blower Fan Not Working
  63. Quick alignment question.
  64. quick coolant question
  65. josua
  66. Rear Shocks '98 Eldo
  67. 1988 Eldorado Instrument Cluster
  68. Is 92 STS (4.9L) parts interchangeable with 93 STS (4.6N*)?
  69. Alternator Coolant Pipe needs replacing
  70. Just A Thought!
  71. Fuel guage reads empty after battery disconnect
  72. '97 Seville - Should I Buy?
  73. Soft top
  74. Hmm... Driver Side Fog Light Connection?
  75. center cap gold rims
  76. Selling 97' STS
  77. Radiator Leak - Help!
  78. Used car lot
  79. 99 Seville Factory Service Manual!
  80. Wandering 02 SLS
  81. Anyone changed an inner tie rod end?
  82. Canadian Members....Petro Canada ??
  83. Compressor for rear shocks not working
  84. 2001 SLS video screen options
  85. PassKey III and Door Locks
  86. Just bought and ran codes for 2001 SLS,Please help
  87. correct blower motor for rear passengers?
  88. OMG When Cadillacs Go Bad part 2
  89. Parting out '93 STS...
  90. Xenon Conversion
  91. Advice...
  92. Electical problems...
  93. Rain sensor wiper function
  94. The STS I Saved.
  95. Ice+ETC= F U N
  96. Window Defroster
  97. Mass Air screen
  98. Northstar Powered Monte Carlo on Ebay!!!
  99. Steering Column Buzz
  100. Headlights and Dash Lights Dimming
  101. Windshield washer pump
  102. Aftermarket Air Intakes
  103. 95 SLS: What is expected life of original water pump?
  104. Limp home mode when cold
  105. Eibach Pro Spring Kit for 98-99 Seville/STS (for sale)
  106. Transmission or alternator?
  107. 06 STS 18 inch wheels on Eldo or 98-03 STS
  108. 1998 Eldorado need towing harness
  109. Need Help with sunroof shade removal?????
  110. lambo doors
  111. Service Theft System
  112. Alternator replacement... 97 STS
  113. A/C Help 97 Eldo
  114. Horribly dumb headlight alignment question
  115. 2001 vs. 2002 STS Buying advice
  116. 98 SLS Heat Fiasco
  117. Probable Price for Eldo Parts Car
  118. Seville Headlights
  119. Lights OUT! radio,climate controls,gear select....
  120. samm
  121. Performance Chip?
  122. regular gas?
  123. Brake Problems!! Please help
  124. Battery drain amp codes stereo signal no sound
  125. 1990 Cadillac Seville For Sale !
  126. How to restore foggy headlights.
  127. Anybody Live In Missouri?
  128. Couple Questions
  129. aftermarket stereo
  130. I finally did it... =(
  131. St Louis meet, February 10th
  132. driver door modul
  133. '92 Eldorado Display
  134. Front valve cover replacement
  135. Sunroof install?
  136. 1995 seville headlight retainer
  137. 1996 Seville Red: What's The Paint Color Name?
  138. engine coolant fan ?
  139. 2003 STS Just Stalls on Me!
  140. Got codes pc0171 and pc0174
  141. dreaded one click no start problem
  142. Need help with CODES!
  143. 97 eldorado engine leaking water
  144. What happened to the new car smell?
  145. Check This Out...
  146. Brake pad wear sensor
  147. Check Out This Z-Rated STS!
  148. 97 seville sls traction control
  149. Ma Car Overheats!!!!
  150. 2002 seville navi
  151. Eibach Pro Kit 3809.140 93-99 Eldos ~ WANTED
  152. Don't know whether to laugh or cry.
  153. Horrible smells in 2000 SLS
  154. p035
  155. Cleaning Exhaust Tips. Any Advice?
  156. Discontinued Eibach Pro Spring Kits for Eldos/STS... FOUND THEM!
  157. 1983 Eldorado rear shoulder seat belts
  158. 1999 STS... need to know what kind of problems I may run into...
  159. 1995 Sts
  160. 94-97 Seville rear knuckle bushings
  161. BG Services
  162. You built a time machine out of a....Eldorado?!
  163. Rear Bleeder Screw Broke !!Help!!
  164. tension strut rod
  165. strange.. 94 STS not starting.. any ideas?
  166. 97 STS Oil indicator comes on (after highway drive)
  167. Door clips?
  168. Ok, I guess this is what it is...?
  169. Mystery!
  170. 94 4.6 seville part #
  171. To Much About Problems
  172. '97 eldo won't get to fob program state
  173. 2001 Northstar into 95-97 Seville?
  174. Found Seville Performance Chip :: is this Cheap or Real?
  175. Possible for sale as parts, mint condition 93 STS
  176. what is wrong with my 93 sts
  177. Service Contracts/Extended Warranty
  178. Driver window wont go up...which wires to jump?
  179. Driver window wont go up...which wires to jump?
  180. Which Struts ?
  181. Heater Core Gurgling
  182. HELP HeadGasket?????
  183. FSM- pages on rear caliper 85 Eldo - copy anyone ? Please
  184. How to remove door panel?
  185. 97 SLS Fuel Gauge
  186. did road force balance car still vibrates @ 65 +
  187. 95 ETC Brake Fluid Switch Problem...Any Ideas?
  188. Code 0741-Anyone having inspection probs
  189. 97 STS - Fuel Injectors
  190. STS electrical gremlins
  191. Right turn groans
  192. Temperatures
  193. this bad?
  194. Pics of my lowered STS
  195. 86 Eldorado, E012 code, intermittently won't start
  196. Rear Integration Module?
  197. help overheating could i have a dead head???
  198. Help! Removing License plate on trunk lid panel.
  199. Gucci Seville
  200. Knock Knock - at start-up
  201. Lower Ball Joint Replacement - opinions?
  202. Heat On the Fritz - Help Please!
  203. Trans slips out of gear - only during a long rh turn at speed
  204. Relay Removal
  205. some electrical problems
  206. 85 Eldo caliper removal
  207. 01 STS Interior Lighting Probz
  208. Codes
  209. What happened here?
  210. Blower Motor Resistor Location
  211. Any Suggestions For An Indash Navigation System?
  212. Audio: Disable Antenna: Question
  213. stability reduced
  214. R1 Concepts ~ Difference between STS & ETC?
  215. New to Cadillacs...buying 83 Eldorado..good buy?
  216. Rear Calipers
  217. Could it just be too cold?
  218. heater and blower assembly woes
  219. 1996 STS Tail Light Replacement Lenses
  220. THEFTLOCK active, How do I deactivate?
  221. 1995 front end assembly
  222. head unit
  223. chrome door handles
  224. Service Stability System
  225. What did I get my self into...
  226. Service AC Unit .. Compressor off ?
  227. Car ID?
  228. Coolant Fan STS 1992
  229. More Tinted Tails and HID Fogs
  230. 99 eldo w/brake problems
  231. Engine Torque Struts- Dogbones question
  232. Rear struts/valve actuation- technical.
  233. What to do....
  234. steering wheel kick 03 STS
  235. Looking at an 01 SLS
  236. Oil pressure idiot light?
  237. Filler neck
  238. When Cadillacs go bad...
  239. Help With 3 codes PLEASE
  240. Arnott + Eibach experiences?
  241. bad MPG
  242. need help finding part number for shift solenoid
  243. starter protection
  244. Caddy after the crash ...
  245. Anyone Have a Seville w/ Fender Trim/Flares?
  246. Anti Freeze Smell & Leak In Interior Of Car !!
  247. 1996 Cadillac Seville SLS with Werid Transmission Issue HELP
  248. 1997 Cadillac Seville STS with Cade P0201 Phease Help It's Driving me Crazy
  249. How to replace the dashboard computer
  250. Need Help with this code, please...
