View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Mechanics for Cadillacs?
  2. 94 sts body parts
  3. 2003 STS, Aiming Headlights?
  4. 95 Eldorado Shift Problems
  5. Programing Remote 94 Eldorado ETC
  6. Problem with shorting tail lights, or something?
  7. Problems w/ 92 ELDO ETC! :(
  8. Thinking about buying an El Dorado or Seville
  9. 2001 STS "New Purchase" Pictures
  10. 1992 Etc
  11. 90 Eldorado 4.5L - Replacing back 4 plugs
  12. Engine shut off when driving
  13. A/C Not Working
  14. 06 STS seats in a 95 Eldorado
  15. Warning!! - Wheel fell off!!
  16. 2000 ESC Creampuff
  17. 93 STS Problems - Rough idle, LOT of smoke
  18. Drilled and slotted rotors
  19. Spark Plugs
  20. Xenon Headlights For Eldorados and Sevilles
  21. 1995 eldorado touring coupe
  22. My new 1999 STS
  23. Caddy Northstars Vs. Police Cars
  24. 1995 eldorado touring
  25. 00 STS Programming
  26. Eldo Suspension/Sway Bar Problem?
  27. 96 seville brake issues
  28. Starting Problem
  29. 1993 STS stalling with many codes
  30. windsheild defrost trim cracking (pic)
  31. Brake problems
  32. 1996 Seville STS. More issues.(moonroof/ac heater
  33. code 85
  34. Needing to replace a front axle hub 97 Eldo
  35. Fluid Flushing
  36. Serious Electrical Problem. 98 deville
  37. Coolant leak-FOUND?!
  38. 01 SLS Sputtering at stop light
  39. My New 03 STS Sasha!
  40. Radar Detector Hard Wiring
  41. 1970 Eldo - HELP! drive axle seal tearing all the time
  42. 1990 Seville Questions
  43. Cadillac License Plate Frames - Forum Discount Code
  44. Help!
  45. Parking Brake
  46. Seville Radio Solutions
  47. 500+ HP Cadillac Eldorado
  48. '92 Seville Tranny hesitates until warm-up.
  49. 99 STS Dead at 160k
  50. '97 SLS Starter Replacement
  51. Parting out an STS?
  52. Does everybody have this 2-piece oil dipstick?
  53. Warranty Recommendations
  54. End links replacement
  55. Seeking a 1981-1985 Seville
  56. Head Gasket Repair Process
  57. What transmission does my seville have?
  58. My Little List of Problems :: Your Input Requested
  59. I think I need new HG's
  60. Armrest Squeak in 02 Seville
  61. Possible tensioner problem..
  62. Just picked up a 75 eldorado!
  63. 99 STS Stupid Gas Gauge
  64. arm rest
  65. Performance Parts Mega-Post
  66. Getting the '97 ready...
  67. Performance Parts
  68. C1716 - Code, is this from my strut?
  69. Bad Heads or Bull
  70. Heat Won't Blow!! Need Help! Please!
  71. Anyone near Corpus Christi, TX?
  72. Has anyone put 18 in. rim w/114.3 bolt pattern on a Seville?
  73. Where can i get a new DIC
  74. Caught an hour of sunlight today!
  75. Moisture in the headlight
  76. Maxwells silver hammer
  77. 1996 Sls Remote Starter Removal
  78. 98' STS, 4th gear is gone
  79. 95 STS Power Window Stuck.
  80. water pump, can i change or shop change?
  81. Airbag Tool
  82. Big difference between 87 and 91 Seville?
  83. Took some pictures today
  84. 2001 STS Weird Electric Problems?!?
  85. Going back to my first love
  86. Painted rear bezel
  87. New Seville owner with questions
  88. 99 STS Front License Plate Holder needed
  89. Interesting Bumper on 95 Seville STS sold out of japan
  90. Dirty EGR, plugs/wires=white smoke?
  91. Looking for a FACTORY "CD/TAPE" player...
  92. I Need A Color Code
  93. 1992 STS 4T60-E Question
  94. engine hesitation, rattle sound from engine
  95. Actual Prototype Infotainment System for sale on EBAY
  96. Who makes the best gaskets ?
  97. New owner of a 92 Seville STS
  98. need to replace A/C mixer
  99. HELP: Weird Engine Oil Leak Issue
  100. Has anyone replaced the wheel speed sensor
  101. Braking after going 40+, sounds like a plane
  102. Too good to be true?
  103. Starter?? Battery?
  104. Need to know info please!
  105. Can Someone Carfax A Vin#
  106. Canadian Speedometer
  107. Good 'ole TWC efficiency code....
  108. 2001 STS sounds like a diesel (cold start)
  109. Car Selling Advice/ High Miles
  110. Northstar Flush Location
  111. Center console Ashtray removal
  112. Breaks, Struts and Electrical
  113. Strut tower brace question
  114. eldorado engine swap question
  115. Left turn signal wont work
  116. 1984 eldorado sunroof stays on
  117. Power steering fluid for '97 STS
  118. Should I buy an '89 Eldorado?
  119. 2002 STS low oil level message
  120. 1999 Sts Grille
  121. 2004 Cts Vs 1999 Sts
  122. 97 STS alignment issues
  123. TSB's for 03STS
  124. 02 Seville Wheel Bearings
  125. Removing Lower Body Cladding
  126. T84 and T90 lights?
  127. Strutmaster Rear Shocks
  128. New SilverStars (all 3) 01 Eldo
  129. Oil Pressure Switch tool...which one?
  130. How to turn off "check engine light", and "service Computer control suspension"
  131. Clock Question
  132. Jet Chip MAF sensor
  133. 91 Eldo STILL Dying!!!!
  134. B483 ABS/TCS Disabled: How is this possible?
  135. Labor to replace rear shocks
  136. A blinking dash?
  137. Tires - Cooper
  138. Video
  139. where can i get these
  140. Finally got my ETC back from the dealer....(tire problem?)
  141. Aftermarket Wheel Strength
  142. Special Tools
  143. New Northstar Engines
  144. Driving me crazy!
  145. 1960's eldorado custom wheels
  146. Would you purchase a 83-87 ElDorado?
  147. 98+ Rear Bulbs
  148. Horn issue that is very odd. '92 Seville
  149. Little bit of info...
  150. Onboard Computer Reset to Factory Settings
  151. Brake Fluid resevoir float?
  152. Marvel Mystery Oil
  153. Anybody else with a brake line problem?
  154. A couple of things...
  155. another coolant thing
  156. fuel injector
  157. STS Cabin Air Filter Recommendation?
  158. 2000 Eldorado Superchip
  159. Too Cheap to buy Vogues?
  160. PWM Circuit No Frequency
  161. Creaking/clunking noise from front end
  162. 95 STS Seville engine suge when cruising
  163. Need A 2003 Sts Vin Number!!!
  164. Potential Purchase 1999 STS with hard brakes...
  165. Rough idle on start
  166. Rear riding too high
  167. Strange sound
  168. My ETCs being passed on...
  169. Brake pedal to the floor!
  170. My '85 Seville i sold on Ebay last year...
  171. 92 STS How to Clear Codes
  172. WHY do the Cadillac gods hate me so??
  173. Whats The Best Way To Drain And Flush Coolant, Northstar
  174. 83 eldo map sensor
  175. 99 sts
  176. Just bought 92 STS
  177. Part # for drivers seat heating element 03 STS
  178. 1976 Seville
  179. New mods to the car today
  180. vogues
  181. Not so happy with the Eibachs
  182. Punks!!!!
  183. Help with Code P086-Undefined Gear Ratio(Transmission Pressure Control)-95 STS
  184. oil pressure. stop engine
  185. Code-ac1313- can anyone help me?
  186. Exhaust on The 93-03 Sevilles
  187. power antena
  188. Unchangeable radio volume. Wierd
  189. Lost my Keys, got new ones, horn honks now.
  190. Torque Converter Solenoid
  191. Coolant leak 97 Eldorado
  192. Bad Ground
  193. what the duce?
  194. 2001 ETC help with loose/rough ride
  195. How to remove lower grille
  196. 97 eldorado battery connection
  197. Help me - Seville Hood Release
  198. Just a few questions about my 1996 STS
  199. 2000 Eldorado: Advice sought
  200. Seville spoiler
  201. If you figure out the problem with my ETC, youre good
  202. 97 STS Gear Lights
  203. 94 Eldo Chugging Exhaust problem
  204. Expected Coolant Loss?
  205. 1995 SLS cranking but not starting, code p035
  206. What's an 80 Eldorado worth?
  207. Power Steering Pump Replacement
  208. Need Rotors
  209. Brake Pad Question
  210. '03 Seville STS - Dealer wants $1100 for Cali. Catalytic converter - what's the diff?
  211. '98-'04 Seville SLS/STS
  212. Anyone ever do an Intermediate Steering Shaft replacement?
  213. Cadillac Apparel & Cadillac Merchandise
  214. Parts Website
  215. Yellow Mirror
  216. STS Rear Fog Light Conversion?
  217. Seville 80 MM throttle body
  218. Looking at a 93 Eldorado
  219. 95 Seville what to know before buying
  220. Throttle stuck on 72 Eldo? Help!
  221. 1992 4t60e shift solenoid ground
  222. e098 code
  223. Installed a new trunk tail light harness, same problem.
  224. Noisy dash fan, success!!
  225. RR Grilles on Sevilles
  226. Windshield Wiper Problem
  227. P094 code but got selonoids replaced already
  228. 4.6
  229. exhaust work
  230. Speed Limited to 90 MPH -- HELP
  231. 95 Tripple Black STS
  232. 95 Tripple Black STS (FOR SALE)
  233. 4t60e and shifting
  234. Exhaust questions
  235. Broken Seat Cable, '92 El Dorado
  236. Hello and Help!
  237. The "Juicebox" Performace Enhancer or BS
  238. Evaporator Core Replacement
  239. got a code tonight
  240. '99 SLS idle/acceleration problems
  241. 02 Seville Wheel Bearings
  242. Clearing the orange corners? (early STS)
  243. 1997 eldorado 1599 stall code
  244. Interior door panel clips
  245. FINALLY, a way to add XM radio and IPOD to Navigation system in Seville, Possibly Dev
  246. 97ETC interior lights/door switch?
  247. Plastic Chunks In Oil
  248. 1992 STS Suspension Advice
  249. Question on coolant flush
  250. Strange ride-related problem (ghost bumps!)
