View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. Front end Clunk/Knock!!!
  2. 98 ElDorado ETC Drama
  3. 2000 SLS Slight Rough Idle
  4. Water pump removal ??
  5. 1995 Eldorado
  6. Sirius Install with Factory Radio
  7. new here 2002 sts
  8. o2's help
  9. 1990 seville
  10. check oil level
  11. EBTCM - PC1602, PC1644 and PZ2042
  12. How to access evaporator to chage orifice tube - eldo 97
  13. Replaced EBTCM - new codes appear- now what to do?
  14. Temp indicator
  15. 87 Eldo: DIC Going On & Off Intermittently - Engine Control System Light
  16. Rear Suspension Compreesor problem...
  17. voltage on my 92 eldo drops to 12.8
  18. Odd Rough Idle Continues...
  19. Minor Electrical Glitches
  20. Steering "thumping"
  21. Hid's??????
  22. Performance Algorithm
  23. Cadillac STS w. Train Horn (on VIDEO)
  24. AC clutch on, have freon but no cooling - Need Help please
  25. P025 Trouble Code
  26. leaks like a sive
  27. 96 Cadillac Air Condition Box Cracked!
  28. AC Flush
  29. Electrical mystery.
  30. Dash reading all 8s
  31. Two mysteries - dashboard
  32. Code C1738 Air Leveling
  33. Rough idling/starting 82 Seville
  34. 99 seville sts
  35. I Can Dream... *pics*
  36. Windshield defroster vent
  37. Sirius Working with Stock Radio 02 Seville
  38. Some photos of my ETC, 56K hell no
  39. Need Part Number for Seville
  40. Cassette Adapter Question
  41. 2000 STS window regulators going out left and right. Literally!
  42. after new "a" and "b" solenoid - trouble with p029...
  43. rearview mirror compas prob
  44. Neat feature
  45. Audio Guru needs help, those with Nav please
  46. I just bought a 92 Eldorado with 114000 miles on it and the AC blows warm.......
  47. 1995 Eldorado
  48. El Dorado '93
  49. At what point should tires be replaced due to age?
  50. rough idle...
  51. For the Cadillac Gurus! Can't reset oil life
  52. Thinking about purchasing a '97 ETC w/ 120k...
  53. Seville A/C problem
  54. Rough start-up
  55. Crank Shaft position sensor
  56. Weekend Roadtrip
  57. 1992 Seville is sagging
  58. Different Take On a 92 Seville
  59. 97 STS overheating?
  60. 98 SLS overheating...
  61. Another "check coolant level" ?
  62. Re-syncing Remote
  63. Hard ride on "new" 1993 Seville
  64. Dash lights
  65. 92 seville trouble codes
  66. 1999 ElDorado w/ 36k Miles - Good Buy? Any Recommended Info Sources?
  67. Need help with 96 Eldorado Transmission Sensor
  68. How to check for codes on a 2000 Eldorado?
  69. AC1312 - Were is this sensor, and how can I fix it ??
  70. Help a little! Moscow, ETC 1994, silence...
  71. 1993 STS Rear Deck Removal
  72. This is kind of shocking
  73. stock bose spkers..
  74. Anyone know how to remove back seat - 97 SLS
  75. no crank, just click, no start
  76. 03 Seville running a little hot ...
  77. Spark Plug Wires and Coil Pack Question
  78. help, just got a 99 sts
  79. Beating Dead Horse?
  80. 2000 ETC Cabin Air Filter, does it exist?
  81. LOL what now
  82. Pause before Accelerating
  83. Made the tough decision to Sell my Eldorado
  84. 99 SLS Cleared Taillights
  85. Where can i buy a replacement taillight for a 98 sls?
  86. My Key Fobs Or Keyless Entry Remotes
  87. Driving Along and My Car Dies
  88. Remote Programming
  89. just bought struts
  90. coolant sitting on top of radiator?
  91. How can I tell if struts are bad...
  92. No electrical power!
  93. any one know where i can buy????
  94. Aftermarket Sunroof / Moonroof ... ?
  95. 1995 Eldorado
  96. Best front Mask for 92-97 Sevilles?
  97. HID on 96 STS
  98. Wot...?????
  99. Serpentine Belt misaligned
  100. HELP: STS Rearview mirror installation
  101. sts 2000 catalic problem
  102. Steering Column
  103. Oil & Tail Light Issue Please Help!
  104. 1978 Seville EFI system flooding problem
  105. Transmission Issue
  106. How to check AC relay - Eldo 97
  107. How to access A/C clutch connector - eldo 97
  108. 2000 SLS Rough Idle
  109. Battery Leaking while parked
  110. Temp Gage tick marks ?
  111. Question...
  112. Climate control questions. Why dont I have heat?!?!
  113. Hot Key ? Hmmmm ??
  114. 2003 Seville SLS Extended Warranty vs. Certified ?????
  115. Replacing steering position sensor
  116. Trunks Pull Down Got Me Stumped
  117. speaker issue
  118. speaker issue
  119. It has finally happened...
  120. Anyone need a transmission ? (4T80E)
  121. Pull Down and Power Release
  122. '94 Seville STS with high miles for $1300???
  123. Compressor does not come on
  124. Looking at a 2003 Seville, are these codes reason for concern?
  125. 96 Seville SLS Turn signal problems
  126. Seville Donation???
  127. Chance to buy a 1998 Eldorado, do I take the risk?
  128. Compressor does not click in - need help please
  129. Need help in clearing DPC codes
  130. step by step installation manual for navigation unit
  131. 96 STS Transmission Hot
  132. Z-Rated Tire Question
  133. Considering a 96 STS Black/black
  134. 99 sts driver door rear view mirror loose
  135. Coolant stabilizer
  136. Heavy Steering
  137. New Here, Have 01 STS
  138. Aftermarket Antenna adaptation help...
  139. Fog Light Project - In progress - Need info
  140. Over heating. Water pump mabe
  141. 99 STS Z-Rated Tire Questions
  142. I lent my caddy to my older sis...
  143. Shimmy @ 60-70mph
  144. Performance parts
  145. 99 Seville wiring diagram- Will pay
  146. codes..
  147. Replacement Headlamps For 2002?
  148. headlight bulb replacement
  149. 2 Questions...
  150. Trany Went
  151. Accelleration Hesitation
  152. Good Deal???
  153. 2003 Cadillac STS
  154. Need Help Please!
  155. 94 sts tranny wont shift
  156. 99 STS on Jack Stands, no Start.
  157. engine idled at over 1500rpm, weird..
  158. Northstar
  159. a/c question
  160. 96 Eldorado Theft Problem Won't Start
  161. Injector removal??? How??
  162. Service Suspension System codes
  163. Feature programming not coming up...
  164. Who wants there FWD Northstar Tuned ?
  165. Need Info Stat
  166. Looking to purchase 03 Seville SLS ....
  167. 99 STS Shudder on turns and when selecting reverse
  168. A/C not working
  169. My water pump tensioner pulley exploded...
  170. New Eldorado owner
  171. Tail light wire/resistor burnt up
  172. rss code
  173. Cadillac Joke of the day. Harmonic Balancer broke.
  174. Looking For A Mechanic In Queens Or Brooklyn Who Knows Cadillacs
  175. 325HP or 300HP
  176. Odd Noise
  177. Steering wheel conversion...
  178. My 78 Eldorado Barritz. Dial up Beware.
  179. do these work?
  180. 2000 sts, engines done at 50,000 miles
  181. Thinkin of gettin another Caddy...suggestions?
  182. A011 & S073
  183. Cadillac Only Junkyards
  184. Changing Swaybar Bushings
  185. door won´t open fully
  186. Stability Reduced?
  187. Pillars and Rocker panels
  188. Headlamps suggested in DIC?
  189. 58 eldorado
  190. Correct voltage for A/C Control Module
  191. Rough Idle at Start Up S.O.S. GUYS!
  192. Check Engine Light
  193. Audio-Related Question :: Trunk Changer Disconnect?
  194. Is there a "Mr. Loser" around these parts???
  195. Fixed my fuel mileage problem!
  196. 1976 Cadillac Seville power seat problem
  197. Northstar Eldorado Fuel
  198. radio...
  199. 2002-2003 Seville Sts 400 hp Engine uprgrade
  200. Wheel Wrench for 1998 STS
  201. 95 seville question
  202. 79 seville smog pump
  203. parting out 1969 cadillaceldorado
  204. 1985 Eldorado that thinks it's a diesel?
  205. automatic level control
  206. 94 sts broken solenoid harness
  207. Am I screwed? Power Steering Costs
  208. New member
  209. Traction Control Off - Still starts out in 1st gear - 2003 STS
  210. Last Gen seville cabin air filter tips
  211. sorry (happy) to report
  212. Rear level is not level on my 2003 STS
  213. Anybody got a stock Subwoofer
  214. 1998 SLS/ Front Struts...?
  215. Seat travel - can I extend it?
  216. Seville sts 1998-RIM PROM ID 8410
  217. Anybody tint their tails - 98-04 sevilles?
  218. 2000 Seville new owner engine miss questions
  219. 94 Seville STS trans 4t80e Shifting problem
  220. Priceless!
  221. To do, or not to do?
  222. Occasional miss at idle
  223. Engine oil cooler - Do I have one? 00' STS
  224. What size front sway bar bushings do I need?
  225. The left side of dash clicking noise - I may have found the cause...
  226. 75 Eldorado convertible resources?
  227. Sirius in 02 Seville
  228. A few things...
  229. '97 Seville STS rear shocks: F45, FE3 & FE1
  230. B&B COLD AIR INTAKE FOR 99-04 Cadillac SLS/STS
  231. 94 STS, and Radar Detector usage.
  232. seville sts 1994 bumper shock absorber
  233. How far should I be able to go on a tank?
  234. Squeeking noise from A/C on 1999 STS
  235. I Need help with a " P 1646" code
  236. How hot is too hot?
  237. Compass Calibration
  238. Vacuum To Climate Control
  239. Anyone have a Rock Auto discount code
  240. Electrical?
  241. 99 ETC Gold Trim
  242. Bridgestone Potenza RE960AS Pole Position
  243. 2000 STS noise question
  244. 98 Seville SLS I need upgrade ideas
  245. Bad PCM?
  246. How do I install the horns and how many are there?
  247. New Problem
  248. Source for '81 Eldorado Sunroof Gasket
  249. The 89-91 Eldorado Models: your opinion
  250. Probelm with my 98 STS
