View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. 89 Seville trunk refusing to close
  2. Dash Kit Help - 96 STS
  3. Cruise control issues-I've used the search feature.
  4. Clear Coat
  5. Problem with my 2000 STS
  6. Air compressor for 2001 ETC struts?
  7. 1995 Sls Passive Suspension System
  8. 1995 Seville Factory Service Manual
  9. Found coolant droplets under car today
  10. hard hot starts.... help!
  11. 1994 seville sts front struts
  12. Do radiator side tanks have just transmission oil?
  13. Install Fog Lights on '93 Seville?
  14. '78 Eldorado Custom Biarritz Classic--What Say You?
  15. Radiator water leak - Please advise
  16. 99 STS No lights on steering wheel controls
  17. Cadillac wrecking yards?
  18. 98 seville - Dash lights go out
  19. 1994 STS Stalling
  20. New member with electrical problems
  21. clearing the codes
  22. What's the difference between the 4.9 and the Northstar engine?
  23. STS to ETC
  24. Low Beam Electrical Problem- 94 STS
  25. Custom Painted STS
  26. 94 SLS--Pull codes w/o engine?
  27. Newbie!!!
  28. Maybe I just Blind !!!
  29. Looking at a 2003 STS
  30. Fuel filler pipe
  31. PC0240 - 1996 Seville STS - What's This One?
  32. 1997 Seville FS
  33. Brand New Here
  34. Need Help: VERY Quick Coolant Leakage
  35. 1993 4.9 liters Seville
  36. 96 Deville Transmission slips in 3rd and 4th
  37. I am new and need help
  38. Pulled codes,got a RIM B1009, what does this affect?
  39. Exhaust question (ECS)
  40. 93 Sts
  41. 2001 STS water pump replacement - which parts do I need?
  42. Buying a 99 SLS with a blown engine (CHEAP!)
  43. Front Hub Change
  44. 1994 STS | Your Thoughts?
  45. 1994 STS - Your Thoughts?
  46. Garage door opener 2000 STS
  47. Trunk pull-down latch out
  48. Static in my Sirius
  49. Wet spare
  50. 2003 STS loud ac fan
  51. Motor Mounts
  52. 1976-1978 Eldo Rear Rotors?
  53. Hard shifting / Reverse to drive
  54. ground effects kit, 98+
  55. Fan Motor
  56. Direct Wiring a Radar Detector
  57. P1106 code - MAP sensor intermittent voltage high
  58. 99 STS Problem...Please Help
  59. Emissions / EGR System
  60. Transmission Cooler Line
  61. 94 STS Still Stumbles when Starting
  62. Speakers in a 1992 Seville aftermarket
  63. Brake Caliper Question
  64. Introduction and Inquiry
  65. My A/C quit cooling this morning!
  66. GM Microcat all or Powerquest
  67. 1998-2004 Direct Fit Seville Suspension Upgrades Using GM Parts
  68. Isc motor correcting its self after car is turned off ???
  69. Replaced power steering line, now what?!!
  70. 4T80E Experts!!!!!
  71. Replace Interior/Dome Lights (2000 Eldo ETC)
  72. Anybody here run 2007 STS 18x8" rims on a 98-04 Seville?
  73. '00 Seville Engine Turns Off Often
  74. vinyl decal for window
  75. '94 seville with a rough idle (a/c related?)
  76. Hub Assembly Question
  77. Very odd thing happened last night. SES and the engine bucking.
  78. Seats Replace Old
  79. 96 Sts ?
  80. Weird...my car keeps turning off
  81. Service Ride Control
  82. Trunk Pulldown issue
  83. 1996 Seville SLS 160,000k TC0027
  84. Turn idicator cam
  85. Stupid water pump. Need help please.
  86. Upgrades I am condsidering- Want input
  87. Location of Fuel Pump Relay for 94 STS
  88. power lock relay, '94 STS
  89. Bose Dash Speakers
  90. DENSO Firmware upgrade
  91. 1995 STS no fourth gear
  92. Sts Rear Air Struts No More !!
  93. AC recharge 97 eldo
  94. 1991 Eldorado Touring Coupe
  95. Woodgrain Steering Wheels
  96. Can someone try this and report back - sticking right wheel when off ground
  97. 2000 Sts Wheel Bearing Replacement
  98. 99' Eldorado right rear speed sensor code triggering suspension light?
  99. 1993 STS Garage door opener power pack
  100. 93 sts problem diagnosis help.
  101. Anyone Here Have A Slab?
  102. 76 Edlo Door Insert Question - HELP
  103. 93 eldorado
  104. Mark99STS site no longer exists?
  105. Hard Starting '94 STS
  106. 4t80e questions
  107. Please help!
  108. detonation
  109. Blower fan will not shut off
  110. 99 STS Turbo
  111. Truth about coolant
  112. LO (Fuel Level Very LOW)
  113. STS all windows stuck..
  114. Replacing the Bose Speakers in My '99 STS
  115. PLEASE HELP!!! Car battery draining!!!
  116. Oil Leak Locations?
  117. sunroof not fully open? can't see drain tubes
  118. IAT sensor distortion - is it worth it?
  119. Side mirror on 2000 SLS toast
  120. 2001 STS Steering Rack
  121. A/C recharge problems
  122. Tranny shifting hard from 2nd to 3rd gear
  123. programing ignition key
  124. 98 eldo water under rear seat
  125. Threads
  126. ahh, broke something help me?!
  127. Shaking at 1-5 MPH with brakes applied
  128. winter storage
  129. Should I Be Concerned?
  130. Wheel covers aka "I know nothing"
  131. My spring has sprung
  132. suspension codes/problems NEED HELP
  133. 1991 Cadillac Seville Fuel Pump
  134. Coolant leaking near front driver side under radiator
  135. 1992 Eldorado Bose loud ringing siren sound
  136. looking at a 95 Eldo
  137. How important are those pesky ball joints?
  138. No Power
  139. I smell Fuel
  140. Suspension Questions
  141. 2003 STS tail running lights problem
  142. key Remote for 1993 sts
  143. 92 STS 309K dies when running/ can't access ECM
  144. Need help with Service Code B0022.
  145. Tranny fluid leak question
  146. Recycle Air option doesn't seem to work
  147. Can I get your opinion on my new tire style?
  148. Odd part needed, please help
  149. Oil check - WARM or COLD?
  150. how can I clear the codes in my 94 eldorado help please
  151. Weird noise from under hood that doesn't seem to go away
  152. How Do I Retreive The Codes From My 94 Eldorado,northstar Engine?
  153. Where Can I Get the 1996 STS Brochure?
  154. Cadillac Eldorado Parts
  155. Exp Id
  156. 1994 STS Help
  157. my car is lost
  158. 94 Eldorado cup holder rebuild question
  159. Door panel woes- 94 Eldorado
  160. Oil Pressure Stop Engine
  161. STSi Project
  162. Looking for info on a 2001 SLS-pre purchase
  163. 97 STS a/c compressor repair
  164. Just Wondering
  165. Can power window manually be raised?
  166. Someone hit my Seville!
  167. P/S Pressure Line Pics for Crown Vic Owner
  168. advice on wheels
  169. Some "deglisten" for your wood.
  170. Modifications... Magneride?
  171. Sts Cosmetics
  172. Too much oil in my Northstar's crankcase!
  173. 92 STS - Floor rattling and strong front end shaking.
  174. Suspension differences 02-03
  175. Bcm?
  176. something is tearing apart my accessory belts.
  177. Refrigerant Leak
  178. Might be in the market for a used Eldorado. What year's best?
  179. Thread for helping people with EGR and FPR problems
  180. Engine missfire affecting trany? 99 eldo
  181. So, is this the stock sunroof?
  182. SLS with L37
  183. trans starting out in 2nd gear?
  184. hard/stuck gas pedal
  185. 94 seville mufflers
  186. I pulled some codes and don't like what I see.
  187. Play in front tire / Wheel bearing?
  188. Sourcing a good reman 4.5
  189. Couple of Noises
  190. Cadillac emblems
  191. Coolant Crossover
  192. sts sounds like a diesel
  193. Northstar mechanic in the Massachusetts??
  194. 02 Eldorado Still Cutting Out
  195. Ride a Little Bumpy - What can it be?
  196. wood grain dash for 01 SLS
  197. 85 Eldo ext mirrors loose
  198. SLS / STS -- For sale spottings...
  199. New CTS
  200. Gas tether strap
  201. Woodgrain Steering Wheel???
  202. n00b to the forum here! Check out my baby!
  203. Im gonna get one
  204. Engine case half oil leak easy repair?
  205. Has anybody found a viable brake upgrade for the 93-97 Sevilles yet?
  206. Ipod2car that actually WORKS! (02+ Seville)
  207. 1996 Cadillac Eldorado Engine Overheating
  208. what is the differences in a 02 seville sts and a sls ?
  209. 98 SLS Cabin Air filter replacement results.
  210. ABS C1246 code
  211. Just bought a 1995 STS 77,000 miles for almost nothing
  212. high idle
  213. 2000 STS Navigation
  214. Will a 4.6 out of a 01 seville fit into a 99 sts?
  215. Car quit
  216. 92 ETC Service Ride Control questions
  217. 92-97 Seville Erebuni Body kit. Anybody have it?
  218. Leaking coolant
  219. 99 Seville - Replaced Battery now trouble
  220. Window Circuit Breaker
  221. how can you tell
  222. service engine soon and service ride control
  223. Another STS Chase Scene
  224. Fog/driving lights keep burning out
  225. Need to change fog light...
  226. New (to me) 03 STS - how to change volume button bulbs on steering wheel
  227. Just wondering about a sound and a key?
  228. 96 SLS driver window switch
  229. So, I got a fresh chance, a new northstar, tons of ?s
  230. Installed Components and they are quiet!
  231. Fog Lights
  232. Engine tap
  233. 2002 Sts Q & A
  234. Just ordered some new tires
  235. 1984 Eldorado Biarritz Convertible Power Windows
  236. 99 STS / Mirror Vandalized - ARRRGH!
  237. 1984 Biarritz Conv. rear Power window
  238. 235-55-16 on 89 Seville?
  239. High Oxides of Nitrogen, 89 Seville
  240. Oil on Spark Plugs
  241. Remote tap
  242. STS oil press light on
  243. New tires for '00 STS?
  244. 90 seville stalling problem
  245. 01 Seville STS Nav CD Question
  246. 2000 Eldorado brakes bad again
  247. What general maintenance should I perform?
  248. Door Check replacement problem.....
  249. '99 STS Bose Speaker Problems
  250. 94 eldorado P039 code
