View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. What do u say? 99 STS or 99 ETC
  2. STS Subwoofer/Rear Deck Rattle Starting to Get to Me
  3. Headrests
  4. brake line busted??
  5. massive vibration @ highway speeds(not the usual shimmy/shake)
  6. Fuel filter ?
  7. 2001 Eldorado drivers window rolls up too far.
  8. Help, my '00 STS has a (fuel) drinking problem!
  9. STSi update
  10. 97 sts shut off while driving, won't start
  11. Eldorado shutting off
  12. Need parts & resources for 1975 Eldorado
  13. Bose stereo is shutting off at start
  14. 1999 Cadillac Seville Gets Hot Help
  15. 2000 Seville Windows Locks Mirrors Won't Work ???
  16. 94 sls overheating
  17. Miss Fire
  18. Dirty Fuel Guage sensor
  19. Defroster Not Working 01 Eldo
  20. service stability system but no codes
  21. '93 Eldorado, 4.9L - Bad Fuel Pump?
  22. 98-04 Seville - What % are SLS and what % are STS?
  23. thump
  24. Anyone has subwoofers installed into stock 98 STS
  25. 1996 STS fan relays
  26. Companies out there??
  27. Temporary Power Steering Loss?
  28. 99 STS Coolant Change - Still More Questions?
  29. Tell me it's just the region I live in.
  30. Bad luck continues (retractable antenna)
  31. 2008 CTS Rims Question or maybe FOR SALE!
  32. New user, cruise control problems
  33. 2002 sls vibrates at 65 mph
  34. Help 98 Eldo light show
  35. 94 sts starting problem *plz help*
  36. 460E trans fluid, loss
  37. New Altornator...which one?
  38. Rear Courtesy Lights
  39. I miss my Cadillac
  40. Port & polishing
  41. WTB: Heater/coolant pipe for 98/99 Seville
  42. acceleration problems
  43. Broken Thermometer
  44. Frost on inside of windows
  45. C1738 - Exhaust Solenoid Valve Short to GND
  46. Cadillac Stealer "recommendation" !!??
  47. 96 STS noise question
  48. I Love My Seville
  49. HID headlight problem 2001
  50. 1991 Seville heater problem, *help its cold in MN*
  51. 2003 STS Shopping
  52. 1991 Seville CCR
  53. '91 Seville CCR
  54. Door Handle Woo's
  55. "Speed Limited to 145" message
  56. P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance
  57. 98 SLS Pics after Clay bar and wax job.
  58. no ALDL pin H
  59. Car acting up need help!
  60. low voltage
  61. NEW . . . Electrical or Computer ? ? ?
  62. STSI video
  63. Navigation
  64. 75 eldo out of retirement
  65. Trouble code help [1996 Seville SLS]
  66. wiper blade arm...
  67. code question
  68. Climate control
  69. Need help with locked ignition??
  70. STSi project
  71. 2002 STS Noise
  72. Tirerack TPM Sensor issues
  73. Need GMVIS record for my STS. Help Please
  74. Where do I plug-In the OBD II Scanner ?
  75. NEW rims
  76. What can you tell me by my Vin?
  77. 1996 Cadillac Seville SLS Repair
  78. 2ooo sts noise
  79. Bass Response
  80. From Valvoline Max Life to Mobil 1 Synthetic
  81. Alternator randomly charging and quiting
  82. 2002 STS Noise
  83. Digital Dash display
  84. 04 Seville Idling Problem?
  85. Please help Car idles When at light, SES light on
  86. 81 Seville parts help...>>>
  87. Question about Brake Sensors
  88. bigtony
  89. headlights frosted
  90. sunroor leak
  91. changes from the 98 to 99 STS
  92. for what's it worth
  93. Changing N* Transmission Fluid
  94. Wireless remote problem or not?
  95. good cadillac/gm tech
  96. pass. temp control
  97. 98 Seville Overheating problem
  98. Check out my STS!
  99. Seville with no heat
  100. Change Break pad message
  101. 2000 sls oil pan removal
  102. Cadillac Logo License Plate & Frame Sale 20% Off
  103. New Here, looking into buying a STS
  104. Trunk Thud
  105. Fuel Rail Recall Job / Done
  106. 93 Eldorado Driver Seat
  107. potential '93-'96 Eldorado buyer: reliability?
  108. Seville Trunk help
  109. Changing Rear Bulb
  110. On the 8th Day of Xmas...
  111. o2 sensor
  112. changing odometer reading
  113. Whats my 2001 STS worth
  114. Changing a windshield washer pump..
  115. Cadillac Computer ?
  116. 99 Eldo info reseting problem.
  117. Does anybody else have endless massage?
  118. RR Wheel Bearing? $350
  119. 79 -88 GM power seat transmission 20225150 20113446
  120. Heated Seats Not Working
  121. IS this a botched connector or what, near the trans, looks like a PCM connector
  122. Low Referigerant A/C Comp off
  123. Digital Displays on a 92 seville
  124. Side mirrors- can I delete the reverse feature?
  125. Electrical Problems NO ONE can help with
  126. Keys locked inside.
  127. Light flashing on WOT
  128. Crashed my poor 02 sts
  129. Service Electrical Sys with New Battery
  130. 92 eldo stall code eo48 wont start
  131. Does Anyone Have a Diagram of the '96 STS Suspension?
  132. Question about buying a "new" STS
  133. RSS codes???
  134. just replaced my rear shocks....
  135. lost keys
  136. Coolant deposits
  137. navigation for cadillac seville sts 2002
  138. New please help with overheating!
  139. Duralast Gold in Seville
  140. Need lowering Springs for eldorado 96
  141. 2004 seat heaters
  142. Help me please!!!
  143. 1999 eldorado blower motor
  144. bigtony
  145. 95 Eldo automatic locks
  146. Radio reception bad when rear window defroster is on...
  147. 2002 Cadillac Seville Mesh Grille
  148. 2002 Cadillac Seville Mesh Grille
  149. 99 STS dash blacked out...body control module?
  150. What is a Kachina Edition?
  151. Help! '97 Eldo drivers seat back fell
  152. How to activate courtesy lights during the daytime
  153. What color should my caddy be
  154. 2003 STS Buy it Now only 8500!!!
  155. Suspension "Upgrade" - Need Opinions
  156. Hello sexy...
  157. Watch that heat guage
  158. back suspension sky high
  159. 2003 Seville Service Manual
  160. Broken/worn center motor mount vs. CV halfshafts....?
  161. ETC shifter locks in park
  162. '76 Eldo convertible pics..
  163. Bose system repairs
  164. Error Codes I039 and R026
  165. XM Radio in Canada?
  166. 2002 vs 2004 Seville SLS
  167. Eldo possibility?!?!
  168. Fsm
  169. pics of my old sevilles
  170. New water pump, abnormal temperature!
  171. NEED HELP..2003 sts steering wheel?
  172. heal a seal treatment
  173. Dash malfunction after boost start
  174. Frustrated finding Dexron VI
  175. broken passenger side mirror..how to install new one?
  176. grill emblem
  177. Now it's the damn struts
  178. TRULY dissabling tcs
  179. Who needs 2 keys?
  180. 96 ETC Positive Battery Cable
  181. Part Numbers Needed for 2002 RHD Seville
  182. Engine bogging down
  183. My manual says that i cant have rainsense
  184. I need some help with codes, they are gettin pretty annoying!
  185. Door Seal Leak
  186. Blower Motor Install
  187. $500+ Catalytic Converter!?
  188. Tire Question
  189. Tire Rotation with TPM
  190. Service manual 97 seville
  191. Got my 03 STS home! NAV is being weird
  192. Traction Control
  193. '99 Seville Center Cap Needed
  194. Heater hose Routing
  195. engine stops running
  196. I think I danaged suspension modules while geting out of the snow pile
  197. "SERVICE STABILITY SYSTEM" on my 2001 Seville STS
  198. Frost on INSIDE of windshield...
  199. Bearing Problems???
  200. Change Barke Pads Message
  201. dash mat
  202. Cars doing some sitting
  203. Strange Tale Light Issue - 96 ETC
  204. One Last Question
  205. Replace Front Seat Belt & Retractor
  206. Bad Downshift, Floor Vibrates, Whine and Airplane Noise...
  207. Vibration In Steering Wheel When In Park
  208. Confused about oil for 2003 STS
  209. Cadillac Logo Gifts For The Holidays
  210. seville 2002 stalls on highway
  211. How to Charge the battery?
  212. Plug and play nav system source
  213. wood dash kit for sls 96
  214. Twilight sensor
  215. stupid question but???
  216. oil pressure
  217. parting out 97 eldorado
  218. '92 ETC appearance update?
  219. another wiper question
  220. 1992 sts heater
  221. Cadillac Apparel And Cadillac Merchandise Gifts
  222. wiper problems
  223. 2003 Sts 0-70
  224. Homework question - anyone interested?
  225. 1992 Seville Transmission Problems???
  226. Check Coolant Message
  227. Emabarrssed
  228. fog lights dont work
  229. wacky electronics..need help!
  230. erratic idle
  231. New pistons, rings, timeserts
  232. 2002 SLS - Silver / need to modify
  233. So, i had a ton of problems, quess the part 165 bucks for one, and it gets programmed
  234. Eldorado owners should be outraged
  235. Seville Appearance: Stage #1
  236. Need advice-1984 Cadillac Eldorado Barrtz
  237. Part name? Need help identifying.
  238. 95 SLS Trouble starting Key Problem?
  239. Delay wipers not woeking
  240. 98' STS Installing Issue/ Advice
  241. Parking brake Eldorado 1991
  242. Searching: interior parts supplier
  243. TCS C1234 abs + traction light on after brake job!!!!
  244. 2000 Sls --what The Heck???
  245. Small AMP Drain/Weakening Battery 97 seville sls
  246. HORN ISSUES! plz help quick!
  247. Need a 98-99 Northstar engine
  248. Heated seats Not working-Help?
  249. Rear Window Defrost KaPut!
  250. who turned out the lights?
