View Full Version : Cadillac Seville / Cadillac Eldorado Forum
  1. my level ride start working again
  2. 79 Seville Power Seat Problem
  3. Fuel Tank Volume
  4. 76 Eldorado Foot Switch???
  5. Injector leak, or fuel line?
  6. EGR valve cleaning
  7. 1998 SLS power steering problems + Service Stability System Msg
  8. Traction Control Disabled
  9. hard wire sirius radio into fuse block
  10. 93 seville coil springs?
  11. step by step intructions for starter
  12. 2000 SLS "Cell phone" Antenna in rear window - why?
  13. 98 STS need new strut, opinion pls
  14. 2000 STS Implodes. (Whine Alert)
  15. power seat on a 69 eldorado
  16. Did Eldos have wood steering wheels?
  17. Electical Problem
  18. Selling my 98 Eldorado
  19. Need help
  20. 90 eldo coupe code pulling and reading
  21. Pulsing headlights
  22. Tranny Question
  23. Lights
  24. Starter Install
  25. 99 STS ride level is now stuck "butt up"
  26. Transmission Pump
  27. Front suspension rattles?
  28. So long but not Goodbye
  29. Headlight restoration kit results. 98 Seville.
  30. what is the difference tween the sts 300 hp engine and the 275 sls?
  31. hard wire 1999 seville radio
  32. Where can i find ignition switched + 12v power?
  33. Are 20 inch bad?
  34. Looking for advice on experience with 99 Eldorado
  35. To Strut or Not to Strut
  36. A few questions about the Performance Algorithm Shifting....
  37. White Smoke...
  38. I have a new favorite modern-day Cadillac.
  39. No heat from front Air Vents
  40. Struts or Springs?
  41. 95 STS with idle problem
  42. Runnin Hot,,,sometimes!
  43. Fuse Panel
  44. Battery Change
  45. Need Help
  46. 95 Cadillac ETC Relay
  47. 92 Seville Rear Nameplate
  48. What A GREAT Deal!!!
  49. Dawsongrant98
  50. Smashed HVAC Ducting?!?!
  51. overhead handles above rear doors
  52. STS / SLS's running newer 18 inch cadillac wheels
  53. The right price...
  54. oil puddle under intake manifold
  55. 95 sts died while running and won't start.
  56. Anyone Selling Rims for 2004 SLS?
  57. Question about brake pads
  58. Cadillac Gifts For Valentines Day
  59. 93 Eldorado 4.9 or N*???
  60. A Big Thank You To Ranger
  61. Anybody need an sls center cap ?
  62. Hub problem ?
  63. Some pics and a movie of my 79 Seville
  64. Fuel Line
  65. Looking for brake line diagram.
  66. starter problem
  67. 85 Eldorado
  68. Codes, and STS broken into
  69. Water pump tensioner
  70. Serpentine Belt
  71. I am in need of two window regulators, any idea what years work?
  72. 97 Eldorado Pass. Window Motor
  73. Looking for '01 STS Headlight, Used, New, Broken, whatever ASAP!
  74. wear and tear
  75. exhaust question
  76. Codes...
  77. Park Brake Problem (Ranger, Sub, Ewill, AJ etc)
  78. Will the strut tower brace off from a 92-97 fit 98-02?
  79. Just got 02 SLS, GREAT car, but some weird stuff too!
  80. pcm1106
  81. Beep click sound when driving normal
  82. Parting out 99 STS
  83. What a weekend! <sigh>
  84. Cadillac Owners Event Coming Soon (Save the DATE!!)
  85. Cruise Control
  86. What type of coolant?
  87. 97 STS -- very low refriderant AC compressor off
  88. Check out my happin' Hooptie!
  89. 99 STS - battery (new) draining quickly
  90. Whistling noise when cold, diagnosed as cracked intake plenum?
  91. 79 Seville question
  92. This may be a stupid question......but
  93. Exhaust opinion.
  94. Distributor question
  95. FPR and fuel line question
  96. So which side is bank 1?
  97. 1997 STS New Mods (pics)
  98. Ignition Control Module
  99. coolant flow direction
  100. Look what I found....
  101. Car Is Making a Whining Noise
  102. Need to pass smog
  103. Wanted (Grill for cadi 2001 sts)
  104. Air ride system leak
  105. Resale Value
  106. fsm...
  107. is this the right fuel pump
  108. FSM is in the mail have general question.
  109. Coolant flush
  110. Klanky Noise ( rear brake area )
  111. Correct tire size on 84 Eldo 225/215/205?
  112. 88 Eldorado driver’s side door lock
  113. 2000 Eldo
  114. H.I.D. Help Please
  115. DRL not working
  116. Heat, PLEASE!!!!!!!!!!!!!
  117. Bose radio problem 2001 Eldorado
  118. 2001 Eldorado Headlight Bulb Removal
  119. where is the blower motor 03 sts
  120. Troubleshooting chart needed
  121. Normal temperature ?
  122. After-market parts
  123. brake problems
  124. Rain Guard for Cars?
  125. How can I tell if my battery is original?
  126. Navigation to non-nav Seville 98´
  127. Stop Engine Hightemp Lights On When Car Off! After H2o Pump Changed!
  128. trans problem please help
  129. 03 sts heater problem blower??
  130. Need a new battery? lemme know thoughts.
  131. Changing Spark Plugs
  132. Radio & Speaker Replacement
  133. shimmy after an alignment?
  134. Center Caps
  135. Codes,suspension,and Hard Start Problems
  136. I can coast for MILES!
  137. I started my Cadillac today and...
  138. Daytime Running Lights Working then not
  139. more V8 sound which muffler?
  140. Wheel Needed 2000 STS
  141. Don't know whats wrong
  142. 2001 SLS CD Changer Wiring Question
  143. How big is the stock exhaust pipe?
  144. '95 Eldorado "service engine soon" light...
  145. Help me with rotors real quick
  146. Looking at buying a Seville SLS....what kind of mileage to expect?
  147. "Original" ETC ... interesting ...
  148. Intermitent Starting Problem-01 STS
  149. Seville owners, look on your registration
  150. New owner
  151. just want to thank ranger and the fellas
  152. Generator - HELP
  153. Compas
  154. Is this worth it?
  155. Right Head and Taill like not working
  156. Injector leak? Or false accusation?
  157. Fitted Rubber Floor Mats
  158. Trailer Hitch On Seville ?
  159. I am shocked at how different the Seville and Eldorado dive.
  160. I am new here and looking to buy an STS.
  161. How to adjust the clock?
  162. cadillac el do transmission
  163. Is Bank 1 front or back?
  164. Northstar in basement...what to do?
  165. Multiple problems...may be related
  166. Heated Seats Clicking
  167. XLR Rims on Seville STS
  168. In the market for a Caddy Eldorado
  169. Extended Warranty?
  170. Oil cooler leak
  171. Water pump gaskets
  172. 1976-78 hubcap Decals
  173. Just change H2o pump having more problems
  174. Tune-up Time
  175. SES codes 97 seville sls
  176. Codes...Help !
  177. 96 STS buy it now 17500
  178. Suspension
  179. 1996-1999 Eldorado Neutral Safety Switch
  180. New owner questions
  181. WOT Huge Power Loss :: Can The Catalytic Converter Cause This?
  182. 1988 Eldorado
  183. Cadillac Logo Apparel & Merchandise
  184. Cold Starts - '91 Eldorado
  185. Heater vents
  186. Northstar 4.6
  187. newbe
  188. Just rolled 100,000 miles
  189. '93 Seville STS what to look for?
  190. 98' STS Stalling/rough Idle Cold Weather
  191. 98' STS Stalling/rough Idle Cold Weather
  192. Need the Passenger Trashbox
  193. Car turns over..
  194. How many...
  195. Calling STS2003 Exhaust question
  196. Where to buy a used 2002 Hood
  197. Another Cadillac Centurion Joins the Ranks
  198. Need GM part number for 97 ETC evap solonoid
  199. cornering lights
  200. headlight out
  201. Possible partial HG problem???
  202. 2nd annual midwest meet!
  203. Got my H.I.D. conversion kit yesterday
  204. 99 STS struts
  205. 92 STS Illuminated Entry/RAP Module
  206. Proud New Owner with a problem
  207. Fuel Filler Pipe
  208. Eldorado/Seville compatibility
  209. 03 STS front engine mount replacement time at the dealer
  210. Engine surges, wants to run @ 3000 rpm
  211. my rke isnt working right i think?
  212. Power Loss 79 Seville
  213. 1979 Caddy Puffs Out Smoke
  214. Coolant reservoir overflowing
  215. Auto Leveling/air ride struts and shocks 1999 STS
  216. OEM Replacement Parts
  217. humming noise
  218. 93 Eldo heat
  219. Should compressor be cycling when cold out?
  220. 1998 ETC RPM Spike
  221. Remote - from how far away are u supposed to be able to unlock the car?
  222. Fuel Smell out of Oil Compt.
  223. 1979 Seville *Nice Caddy*
  224. It"s Back!!!!
  225. gettin my car fixed tomorrow
  226. 98 SLS... to keep (fix) it, or not?
  227. Service Engine Light/97 seville sls
  228. carpet hanging from interior roof
  229. What controls the lighting in our cars
  230. air conditioner fans
  231. 93 - 96 Sts Northstars Sc?
  232. What to do with my 94 eldorado?
  233. no power steering when turning right
  234. Part Needed Front Bumper License Panel?
  235. Testing EBTCM without completely installing
  236. wiring the fans to run all the time
  237. Got oil analysis done..who can read it
  238. B1312 Current How Do I Clear It??
  239. whats a 12v fuse???
  240. EGR Valve Error
  241. Phantom Problem with Sun Roof
  242. heater motor vibration in the gas petal
  243. Remote starter that can activate seat heaters?
  244. disadvantages of eibach springs
  245. bulb replacement license plate
  246. 93 STS won't shift into overdrive
  247. Beeping
  248. GMPARTSDIRECT.com
  249. 91 seville no fuel pressure
  250. "Chirp" sound from engine bay?
